Moderators Andavari 1 Posted June 27, 2014 Moderators Share Posted June 27, 2014 Program's versions 1 & 2 are obsolete. Only thing is some people won't like changes and updates in programs and will refuse to upgrade, so it shouldn't be a problem to allow cleaning of old versions. Link to post Share on other sites
nodles 0 Posted June 27, 2014 Share Posted June 27, 2014 Old programs/versions are definitely not obsolote. As Nergal said it and some new version of a program might not support older OS (for example XP etc). Link to post Share on other sites
ROCKNROLL 0 Posted June 27, 2014 Share Posted June 27, 2014 Something is wrong with this entry: [Multi-Edit 2008 Logs*]LangSecRef=3024DetectFile2=%AppData%\Multi Edit SoftwareFileKey1=%AppData%\Multi Edit Software|*.log|RECURSE It's being detected on my system, but I never used this program in my life. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to post Share on other sites
Moderators Nergal 0 Posted June 27, 2014 Moderators Share Posted June 27, 2014 Something is wrong with this entry: [Multi-Edit 2008 Logs*] LangSecRef=3024 DetectFile2=%AppData%\Multi Edit Software FileKey1=%AppData%\Multi Edit Software|*.log|RECURSE It's being detected on my system, but I never used this program in my life. Why is there only a detectfile2? If you change it to detectfile does it disappear? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted June 27, 2014 Author Share Posted June 27, 2014 Also no default winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Winapp2.ini 0 Posted June 28, 2014 Author Share Posted June 28, 2014 4 emails i got today (No, this email's not real, it's http://deadfake.com'>http://deadfake.com'>http://deadfake.com'>http://deadfake.com)[seagate SeaTools for Windows Logs*]LangSecRef=3024Detect1=HKLM\SOFTWARE\Wow6432Node\SeaToolsforWindowsDetect2=HKLM\SOFTWARE\SeaToolsforWindowsDefault=FalseFileKey1=%ProgramFiles%\Seagate\SeaTools for Windows|*.logFileKey2=%LocalAppData%\VirtualStore\Program Files*\Seagate\SeaTools for Windows|*.logFound these:HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SeaToolsforWindowsC:\Program Files (x86)\Seagate\SeaTools for Windows\98TIT4GMT.log[Copernic DesktopSearch4 Logs*]LangSecRef=3024Detect1=HKLM\SOFTWARE\Copernic\DesktopSearch4Detect2=HKLM\SOFTWARE\Wow6432Node\Copernic\DesktopSearch4Default=FalseFileKey1=%LocalAppData%\Copernic\DesktopSearch4\Logs|*.*|REMOVESELFFound these:C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\Cds4Install.log 23 KBC:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\Cds4Install.log 23 KBC:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\CdsApp.log4 44 KBC:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\CdsQueue.log4 243 KBC:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SP.0.log4 2 KBC:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SPP.0.log4 31 KBC:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\CdsQueue.log4C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\Cds4Install.logC:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SP.0.log4C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SPP.0.log4I made a mistake in Filekey in both entries. They should be solved now.And I added Virtual store for Seagate. (No, this email's not real, it's http://deadfake.com)And the Realtek logs was my fault to. I have added RECURSE. You must remove RECURSE, it just on C:. (No, this email's not real, it's http://deadfake.com)[Paint.NET More*]LangSecRef=3021Detect=HKCU\Software\Paint.NETDefault=FalseFileKey1=%LocalAppData%\Paint.NET|*.*|RECURSERegKey1=HKCU\Software\Paint.NET|LastFileDialogDirectoryRegKey2=HKCU\Software\Paint.NET|File/MostRecent/Path0RegKey3=HKCU\Software\Paint.NET|File/MostRecent/Path1RegKey4=HKCU\Software\Paint.NET|File/MostRecent/Path2RegKey5=HKCU\Software\Paint.NET|File/MostRecent/Path3RegKey6=HKCU\Software\Paint.NET|File/MostRecent/Path4RegKey7=HKCU\Software\Paint.NET|File/MostRecent/Path5RegKey8=HKCU\Software\Paint.NET|File/MostRecent/Path6RegKey9=HKCU\Software\Paint.NET|File/MostRecent/Path7RegKey10=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail0RegKey11=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail1RegKey12=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail2RegKey13=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail3RegKey14=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail4RegKey15=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail5RegKey16=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail6RegKey17=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail7Is that ok with "/"[spiral Knights**]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\99900Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\Spiral Knights|*.loghas got two stars.Forte should be named Forte Agent like CSGalloway has supplied. It's better I think. (No, this email's not real, it's http://deadfake.com)[Paint.NET More*]LangSecRef=3021Detect=HKCU\Software\Paint.NETDefault=FalseFileKey1=%LocalAppData%\Paint.NET|*.*|RECURSERegKey1=HKCU\Software\Paint.NET|LastFileDialogDirectoryRegKey2=HKCU\Software\Paint.NET|File/MostRecent/Path0RegKey3=HKCU\Software\Paint.NET|File/MostRecent/Path1RegKey4=HKCU\Software\Paint.NET|File/MostRecent/Path2RegKey5=HKCU\Software\Paint.NET|File/MostRecent/Path3RegKey6=HKCU\Software\Paint.NET|File/MostRecent/Path4RegKey7=HKCU\Software\Paint.NET|File/MostRecent/Path5RegKey8=HKCU\Software\Paint.NET|File/MostRecent/Path6RegKey9=HKCU\Software\Paint.NET|File/MostRecent/Path7RegKey10=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail0RegKey11=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail1RegKey12=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail2RegKey13=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail3RegKey14=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail4RegKey15=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail5RegKey16=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail6RegKey17=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail7Is that ok with "/"[spiral Knights**]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\99900Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\Spiral Knights|*.loghas got two stars.Forte should be named Forte Agent like CSGalloway has supplied. It's better I think. Andrew Z (BleachBit dev) pointed out these keys are duplicated [Google Calendar Sync*][Logitech Setpoint 6 (Logs)*][RegEditX More*] winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
back_track 0 Posted June 28, 2014 Share Posted June 28, 2014 4 emails i got today (No, this email's not real, it's http://deadfake.com'>http://deadfake.com'>http://deadfake.com'>http://deadfake.com) [seagate SeaTools for Windows Logs*] LangSecRef=3024 Detect1=HKLM\SOFTWARE\Wow6432Node\SeaToolsforWindows Detect2=HKLM\SOFTWARE\SeaToolsforWindows Default=False FileKey1=%ProgramFiles%\Seagate\SeaTools for Windows|*.log FileKey2=%LocalAppData%\VirtualStore\Program Files*\Seagate\SeaTools for Windows|*.log Found these:HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SeaToolsforWindows C:\Program Files (x86)\Seagate\SeaTools for Windows\98TIT4GMT.log [Copernic DesktopSearch4 Logs*] LangSecRef=3024 Detect1=HKLM\SOFTWARE\Copernic\DesktopSearch4 Detect2=HKLM\SOFTWARE\Wow6432Node\Copernic\DesktopSearch4 Default=False FileKey1=%LocalAppData%\Copernic\DesktopSearch4\Logs|*.*|REMOVESELF Found these: C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\Cds4Install.log 23 KB C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\Cds4Install.log 23 KB C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\CdsApp.log4 44 KB C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\CdsQueue.log4 243 KB C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SP.0.log4 2 KB C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SPP.0.log4 31 KB C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\CdsQueue.log4 C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\Cds4Install.log C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SP.0.log4 C:\Users\Boss\AppData\Local\Copernic\DesktopSearch4\Logs\SPP.0.log4 I made a mistake in Filekey in both entries. They should be solved now. And I added Virtual store for Seagate. (No, this email's not real, it's http://deadfake.com) And the Realtek logs was my fault to. I have added RECURSE. You must remove RECURSE, it just on C:. (No, this email's not real, it's http://deadfake.com) [Paint.NET More*]LangSecRef=3021Detect=HKCU\Software\Paint.NETDefault=FalseFileKey1=%LocalAppData%\Paint.NET|*.*|RECURSERegKey1=HKCU\Software\Paint.NET|LastFileDialogDirectoryRegKey2=HKCU\Software\Paint.NET|File/MostRecent/Path0RegKey3=HKCU\Software\Paint.NET|File/MostRecent/Path1RegKey4=HKCU\Software\Paint.NET|File/MostRecent/Path2RegKey5=HKCU\Software\Paint.NET|File/MostRecent/Path3RegKey6=HKCU\Software\Paint.NET|File/MostRecent/Path4RegKey7=HKCU\Software\Paint.NET|File/MostRecent/Path5RegKey8=HKCU\Software\Paint.NET|File/MostRecent/Path6RegKey9=HKCU\Software\Paint.NET|File/MostRecent/Path7RegKey10=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail0RegKey11=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail1RegKey12=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail2RegKey13=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail3RegKey14=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail4RegKey15=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail5RegKey16=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail6RegKey17=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail7 Is that ok with "/" [spiral Knights**]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\99900Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\Spiral Knights|*.log has got two stars. Forte should be named Forte Agent like CSGalloway has supplied. It's better I think. (No, this email's not real, it's http://deadfake.com) [Paint.NET More*]LangSecRef=3021Detect=HKCU\Software\Paint.NETDefault=FalseFileKey1=%LocalAppData%\Paint.NET|*.*|RECURSERegKey1=HKCU\Software\Paint.NET|LastFileDialogDirectoryRegKey2=HKCU\Software\Paint.NET|File/MostRecent/Path0RegKey3=HKCU\Software\Paint.NET|File/MostRecent/Path1RegKey4=HKCU\Software\Paint.NET|File/MostRecent/Path2RegKey5=HKCU\Software\Paint.NET|File/MostRecent/Path3RegKey6=HKCU\Software\Paint.NET|File/MostRecent/Path4RegKey7=HKCU\Software\Paint.NET|File/MostRecent/Path5RegKey8=HKCU\Software\Paint.NET|File/MostRecent/Path6RegKey9=HKCU\Software\Paint.NET|File/MostRecent/Path7RegKey10=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail0RegKey11=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail1RegKey12=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail2RegKey13=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail3RegKey14=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail4RegKey15=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail5RegKey16=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail6RegKey17=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail7 Is that ok with "/" [spiral Knights**]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\99900Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\Spiral Knights|*.log has got two stars. Forte should be named Forte Agent like CSGalloway has supplied. It's better I think. Andrew Z (BleachBit dev) pointed out these keys are duplicated [Google Calendar Sync*][Logitech Setpoint 6 (Logs)*] [RegEditX More*] that are corrections .... but the [RegEditX More*] is double but one has the wrong name .... and the paint.net reg key are korret with / ! [RCrawler More*] LangSecRef=3024 Detect=HKLM\Software\4Developers\RCrawler Default=False RegKey1=HKLM\Software\4Developers\RCrawler\History RegKey2=HKLM\Software\4Developers\RCrawler\Settings|LastSearch we need better correction tools ! _______________________________________________________ new: [Banished Crash dump*] Section=Games Default=False DetectFile=%Documents%\Banished\Save\Crash.dmp FileKey1=%Documents%\Banished\Save|Crash*.dmp Link to post Share on other sites
SMalik 0 Posted June 29, 2014 Share Posted June 29, 2014 what is to merge that entries: [Tag&Rename] LangSecRef=3024 Detect=HKCU\Software\Softpointer\Tag&Rename Detect2=HKCU\Software\Softpointer\Tag&Rename2 Detect3=HKCU\Software\Softpointer\Tag&Rename3 Detect4=HKCU\Software\Softpointer\Tag&Rename3.7 Default=False RegKey1=HKCU\Software\Softpointer\Tag&Rename\Config|FCurrentFolder RegKey2=HKCU\Software\Softpointer\Tag&Rename\Config|FHistoryList RegKey3=HKCU\Software\Softpointer\Tag&Rename2\Config|FCurrentFolder RegKey4=HKCU\Software\Softpointer\Tag&Rename2\Config|FHistoryList RegKey5=HKCU\Software\Softpointer\Tag&Rename3\Config|FCurrentFolder RegKey6=HKCU\Software\Softpointer\Tag&Rename3\Config|FHistoryList RegKey7=HKCU\Software\Softpointer\Tag&Rename3\Config|FileListHeader RegKey8=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FCurrentFolder RegKey9=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FHistoryList RegKey10=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FileListHeader RegKey11=HKCU\Software\Softpointer\Tag&Rename3.7\Config|HistoryList I think this is better. Link to post Share on other sites
SMalik 0 Posted June 29, 2014 Share Posted June 29, 2014 Revised Entry [Office 2013 More*]LangSecRef=3021Detect=HKCU\Software\Microsoft\Office\15.0\CommonDefault=FalseRegKey1=HKCU\Software\Microsoft\Office\15.0\Word\Reading LocationsFileKey1=%LocalAppData%\Microsoft\Office\15.0\OfficeFileCache|*.*|RECURSEFileKey2=%LocalAppData%\Microsoft\Office\15.0|OneNoteOfflineCache.onecacheFileKey3=%LocalAppData%\Microsoft\OneNote\15.0\OneNoteOfflineCache_Files|*.*|RECURSE Added: HKCU\Software\Microsoft\Office\15.0\Word\Reading Locations Link to post Share on other sites
siliconman01 0 Posted June 30, 2014 Share Posted June 30, 2014 Revised Entry [Office 2013 More*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Office\15.0\Common Default=False RegKey1=HKCU\Software\Microsoft\Office\15.0\Word\Reading Locations FileKey1=%LocalAppData%\Microsoft\Office\15.0\OfficeFileCache|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Office\15.0|OneNoteOfflineCache.onecache FileKey3=%LocalAppData%\Microsoft\OneNote\15.0\OneNoteOfflineCache_Files|*.*|RECURSE Added: HKCU\Software\Microsoft\Office\15.0\Word\Reading Locations This RegKey1 addition might be better positioned in the code below inasmuch as it applies to MS Word. [MS Office Word More*] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\12.0 Detect2=HKCU\Software\Microsoft\Office\14.0 Detect3=HKCU\Software\Microsoft\Office\15.0 Default=False RegKey1=HKCU\Software\Microsoft\Office\15.0\Word\Reading Locations FileKey1=%AppData%\Microsoft\Word|*.*|RECURSE FileKey2=%Documents%|~*.doc|RECURSE ExcludeKey1=FILE|%AppData%\Microsoft\Word\listgal.dat ExcludeKey2=PATH|%AppData%\Microsoft\Word\STARTUP Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
dvdbane 0 Posted July 1, 2014 Share Posted July 1, 2014 duplicate entries maybe the dev can tweak winapp.ini entry to include [Common Language Runtime Logs*] and [Microsoft CLR Logs*] into [Windows Log Files] or combine both entries for winapp2.ini [Common Language Runtime Logs*]LangSecRef=3025Detect=HKCU\Software\Microsoft\WindowsDefault=FalseFileKey1=%LocalAppData%\Microsoft\CLR_v*.*|*.*|RECURSEFileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v*.*|*.*|RECURSEFileKey3=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v*.*|*.*|RECURSEFileKey4=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v*.*|*.*|RECURSEFileKey5=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v*.*|*.*|RECURSE[Microsoft CLR Logs*]LangSecRef=3025DetectFile1=%LocalAppData%\Microsoft\CLR_v2.0DetectFile2=%LocalAppData%\Microsoft\CLR_v2.0_32DetectFile3=%LocalAppData%\Microsoft\CLR_v4.0_32DetectFile4=%LocalAppData%\Microsoft\CLR_v4.0_32Default=FalseFileKey1=%LocalAppData%\Microsoft\CLR_*|*.log|RECURSE[Windows Log Files]ID=1017LangSecRef=3003LangRef=3145Default=TrueFileKey31=%LocalAppData%\Microsoft\CLR_v4.0\*|*.logFileKey32=%LocalAppData%\Microsoft\CLR_v4.0_32\*|*.logFileKey33=%SystemDirectory%\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0\*|*.logFileKey34=%SystemDirectory%\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0_32\*|*.log Link to post Share on other sites
SMalik 0 Posted July 1, 2014 Share Posted July 1, 2014 Revised Entry [Foxit PhantomPDF 6 More*]LangSecRef=3021Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0Default=FalseFileKey1=%LocalAppData%\Foxit PhantomPDF\msilog|*.logFileKey2=%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.dsFileKey3=%AppData%\Foxit Software\RMS|FXRMS_Log.txtRegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\Preferences\HistoryRegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\RecentFiles Added: %LocalAppData%\Foxit PhantomPDF\msilog|*.log Link to post Share on other sites
ZeroByDivide 0 Posted July 3, 2014 Share Posted July 3, 2014 would love if there was support for Coowon Browser (chromium-based), tried to do it myself but failed hard :c Link to post Share on other sites
SMalik 0 Posted July 4, 2014 Share Posted July 4, 2014 This RegKey1 addition might be better positioned in the code below inasmuch as it applies to MS Word. [MS Office Word More*] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\12.0 Detect2=HKCU\Software\Microsoft\Office\14.0 Detect3=HKCU\Software\Microsoft\Office\15.0 Default=False RegKey1=HKCU\Software\Microsoft\Office\15.0\Word\Reading Locations FileKey1=%AppData%\Microsoft\Word|*.*|RECURSE FileKey2=%Documents%|~*.doc|RECURSE ExcludeKey1=FILE|%AppData%\Microsoft\Word\listgal.dat ExcludeKey2=PATH|%AppData%\Microsoft\Word\STARTUP Word and PoperPoint applications are part of Microsoft Office. There should be no seperate entries for these applications, instead they should be under Office 2010 More and Office 2013 More. Link to post Share on other sites
SMalik 0 Posted July 4, 2014 Share Posted July 4, 2014 duplicate entries maybe the dev can tweak winapp.ini entry to include [Common Language Runtime Logs*] and [Microsoft CLR Logs*] into [Windows Log Files] or combine both entries for winapp2.ini [Common Language Runtime Logs*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Microsoft\CLR_v*.*|*.*|RECURSE FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v*.*|*.*|RECURSE FileKey3=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v*.*|*.*|RECURSE FileKey4=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v*.*|*.*|RECURSE FileKey5=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v*.*|*.*|RECURSE [Microsoft CLR Logs*] LangSecRef=3025 DetectFile1=%LocalAppData%\Microsoft\CLR_v2.0 DetectFile2=%LocalAppData%\Microsoft\CLR_v2.0_32 DetectFile3=%LocalAppData%\Microsoft\CLR_v4.0_32 DetectFile4=%LocalAppData%\Microsoft\CLR_v4.0_32 Default=False FileKey1=%LocalAppData%\Microsoft\CLR_*|*.log|RECURSE [Windows Log Files] ID=1017 LangSecRef=3003 LangRef=3145 Default=True FileKey31=%LocalAppData%\Microsoft\CLR_v4.0\*|*.log FileKey32=%LocalAppData%\Microsoft\CLR_v4.0_32\*|*.log FileKey33=%SystemDirectory%\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0\*|*.log FileKey34=%SystemDirectory%\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0_32\*|*.log Have CCleaner remove FileKey31 through FileKey34 from the [Windows Log Files] entry and just keep [Common Language Runtime Logs*]. Also remove the [Microsoft CLR Logs*] entry from Winapp2. Otherwise they can add the lines listed below in the [Windows Log Files] entry: %LocalAppData%\Microsoft\CLR_v2.0|*.log %LocalAppData%\Microsoft\CLR_v2.0_32|*.log %WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0|*.log %WinDir%\System32\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v2.0_32|*.log %WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0|*.log %WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v2.0_32|*.log %WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0|*.log %WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v4.0_32|*.log Link to post Share on other sites
siliconman01 0 Posted July 4, 2014 Share Posted July 4, 2014 Have CCleaner remove FileKey31 through FileKey34 from the [Windows Log Files] entry and just keep [Common Language Runtime Logs*]. Also remove the [Microsoft CLR Logs*] entry from Winapp2. Otherwise they can add the lines listed below in the [Windows Log Files] entry: %LocalAppData%\Microsoft\CLR_v2.0|*.log %LocalAppData%\Microsoft\CLR_v2.0_32|*.log %WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0|*.log %WinDir%\System32\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v2.0_32|*.log %WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0|*.log %WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v2.0_32|*.log %WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0|*.log %WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\Microsoft\CLR_v4.0_32|*.log There are millions of CCleaner users who do not use Winapp2.ini. Therefore I do not think CCleaner should remove FileKey31 through FileKey34. Any efficiency changes because of duplication needs to be within Winapp2.ini. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
sergej.al 0 Posted July 6, 2014 Share Posted July 6, 2014 I use the 360Browser (Chrome based), which is very fast and also very nice looking. Since CCleaner doesn't recognize it as a Browser I had to manually write some lines to keep my PC clean. [360 Browser - Cache] Section='360Browser LangRef=Internet Cache Detect=HKCU\Software\360Browser\Browser Default=True FileKey1=%LocalAppData%\360Browser\Browser\User Data\Default\Cache|*.* FileKey2=%LocalAppData%\360Browser\Browser\User Data\Default|*-journal* ExcludeKey1=FILE|%LocalAppData%\360Browser\Browser\User Data\Default\|switcher-journal ExcludeKey2=FILE|%LocalAppData%\360Browser\Browser\User Data\Default\|Web data-journal ExcludeKey3=FILE|%LocalAppData%\360Browser\Browser\User Data\Default\|Login data-journal FileKey3=%LocalAppData%\360Browser\Browser\User Data\Default\Local Storage|*.* [360 Browser - History] Section='360Browser LangRef=Internet History Detect=HKCU\Software\360Browser\Browser Default=True FileKey1=%LocalAppData%\360Browser\Browser\User Data\Default|Archived History FileKey2=%LocalAppData%\360Browser\Browser\User Data\Default|Visited Links FileKey3=%LocalAppData%\360Browser\Browser\User Data\Default|Current Tabs FileKey4=%LocalAppData%\360Browser\Browser\User Data\Default|Top Sites FileKey5=%LocalAppData%\360Browser\Browser\User Data\Default|History Provider Cache FileKey6=%LocalAppData%\360Browser\Browser\User Data\Default|Network Action Predictor [360 Browser - Cookies] Section='360Browser LangRef=Cookies Detect=HKCU\Software\360Browser\Browser Default=False FileKey1=%LocalAppData%\360Browser\Browser\User Data\Default|Cookies [360 Browser - Session] Section='360Browser LangRef=Session Detect=HKCU\Software\360Browser\Browser Default=False FileKey1=%LocalAppData%\360Browser\Browser\User Data\Default|Current* FileKey2=%LocalAppData%\360Browser\Browser\User Data\Default|Last* I had to ' before 360 because it wouldn't recognize it beginning with a number -.- If there is someone else using this browser maybe he/she could help by adding or editing some lines and also help me understand the SpecialDetect command and how I can fix the Section name without the quote before. Link to post Share on other sites
Moderators Andavari 1 Posted July 7, 2014 Moderators Share Posted July 7, 2014 I use the 360Browser (Chrome based) It's usually an expected practice to post cleaning routines using: Default=False That way someone won't automatically get something deleted they may want to keep. Link to post Share on other sites
sergej.al 0 Posted July 7, 2014 Share Posted July 7, 2014 It's usually an expected practice to post cleaning routines using: Default=False That way someone won't automatically get something deleted they may want to keep. In my case, I always want the history and cache deleted! Link to post Share on other sites
Winapp2.ini 0 Posted July 7, 2014 Author Share Posted July 7, 2014 Default=False only signifies whether the entry is ticked or unticked by default winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted July 7, 2014 Share Posted July 7, 2014 New entry: [Creative Soundblaster Recon3D PCIe (Cache & Logs)*] [Creative Soundblaster Recon3D PCIe (Cache & Logs)*] LangSecRef=3024 Detect=HKLM\Software\CREATIVE TECH\Sound Blaster X-Fi MB Default=False FileKey1=%CommonAppData%\Creative\Software Update\Cache|*.*|REMOVESELF FileKey2=%CommonAppData%\Creative\Software Update\Log|*.* FileKey3=%LocalAppData%\VirtualStore\ProgramData\Creative\Software Update\Cache|*.*|REMOVESELF FileKey4=%LocalAppData%\VirtualStore\ProgramData\Creative\Software Update\Log|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
dexter86 0 Posted July 7, 2014 Share Posted July 7, 2014 New entry: [Creative Soundblaster Recon3D PCIe (Cache & Logs)*] .... It's better to change [Creative Soundblaster X-Fi XtremeMusic (Cache & Logs)*] to something like this [Creative Soundblaster (Cache & Logs)*] LangSecRef=3024 Detect1=HKLM\Software\CREATIVE TECH\Software Installed\Software Update Detect2=HKLM\Software\CREATIVE TECH\Sound Blaster X-Fi MB Default=False FileKey1=%CommonAppData%\Creative\Software Update\Cache|*.*|REMOVESELF FileKey2=%CommonAppData%\Creative\Software Update\Log|*.* FileKey3=%LocalAppData%\VirtualStore\ProgramData\Creative\Software Update\Cache|*.*|REMOVESELF FileKey4=%LocalAppData%\VirtualStore\ProgramData\Creative\Software Update\Log|*.* also in [AQQ Temps*] please remove Warning, it doesn't delete chat history and something extra, I posted new topic in suggestions that we all would benefit, see Support for reading registry keys' values Link to post Share on other sites
siliconman01 0 Posted July 7, 2014 Share Posted July 7, 2014 It's better to change [Creative Soundblaster X-Fi XtremeMusic (Cache & Logs)*] to something like this [Creative Soundblaster (Cache & Logs)*] LangSecRef=3024 Detect1=HKLM\Software\CREATIVE TECH\Software Installed\Software Update Detect2=HKLM\Software\CREATIVE TECH\Sound Blaster X-Fi MB Default=False FileKey1=%CommonAppData%\Creative\Software Update\Cache|*.*|REMOVESELF FileKey2=%CommonAppData%\Creative\Software Update\Log|*.* FileKey3=%LocalAppData%\VirtualStore\ProgramData\Creative\Software Update\Cache|*.*|REMOVESELF FileKey4=%LocalAppData%\VirtualStore\ProgramData\Creative\Software Update\Log|*.* also in [AQQ Temps*] please remove Warning, it doesn't delete chat history and something extra, I posted new topic in suggestions that we all would benefit, see Support for reading registry keys' values I certainly have no problem with the combo. I don't know how other SoundBlaster card models are detected via the HKLM registry key; however, some other SB users may be able to add info. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
siliconman01 0 Posted July 7, 2014 Share Posted July 7, 2014 Word and PoperPoint applications are part of Microsoft Office. There should be no seperate entries for these applications, instead they should be under Office 2010 More and Office 2013 More. I suggest that it is best to leave them separate because you can purchase and install Word, Outlook, PowerPoint, OneNote, and Access individually without buying the full MS Office 2013. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
ROCKNROLL 0 Posted July 8, 2014 Share Posted July 8, 2014 Edit: [battle.Net Client Logs*]Section=GamesDetect=HKCU\Software\Blizzard Entertainment\Battle.netFileKey1=%CommonAppData%\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSEFileKey2=%CommonAppData%\Battle.net\Client\Logs|*.*|RECURSEFileKey3=%LocalAppData%\Battle.Net\Logs|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Logs|*.*|RECURSE FileKey6=%Documents%\StarCraft II\GameLogs|*.*|RECURSE Added FileKey 6. EDIT: Nevermind. This is already included in StarCraft II Logs entry. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to post Share on other sites
