Winapp2.ini Posted May 27, 2013 Author Share Posted May 27, 2013 I did it by hand. That said, there may (read: probably are) errors in the alphabetization, but I think I did a good job. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 27, 2013 Moderators Share Posted May 27, 2013 Wouldn't worry about "errors in the alphabetizing" especially since the ABC's taught in school were never confronted with dashes, underscores, etc. Link to comment Share on other sites More sharing options...
ricktendo64 Posted May 28, 2013 Share Posted May 28, 2013 Adobe Reader win8 app fixed [Adobe Reader*] Section=Windows 8 Apps DetectFile=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga Default=True FileKey1=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\Microsoft\CLR_v4.0*|*.log|RECURSE FileKey5=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\PRICache|*.* FileKey6=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\LocalState|*.*|RECURSE FileKey8=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedPickerData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga!App\DefaultOpenFileSingle|LastLocation RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedStorageItemTable\MostRecentlyUsed Link to comment Share on other sites More sharing options...
APMichael Posted May 28, 2013 Share Posted May 28, 2013 Thank you very much for this huge update! Missed posts: #3143 and #3165 Doubled (redundant) entry: [Miranda IM Cache*] Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 28, 2013 Author Share Posted May 28, 2013 Thanks for your ever vigilant watch, APMichael. Seems I always miss a post or two! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 28, 2013 Moderators Share Posted May 28, 2013 Wave Pad* double entry as well ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Alan_B Posted May 28, 2013 Share Posted May 28, 2013 i did but I couldn't figure out a graceful way to do it. Thanks for the contributions so far though! How about creating an empty file "New Entries.txt" when you issue a new version of Winapp2.ini and simply adding to "New Entries.txt" every new proposed entry, and incorporate with each entry a double ;; comment showing the source, e.g. the post #number and author. That could be updated and on-line (read-only) for those who want to "chance their arm", and it might be a more convenient compilation than dozens of individual posts for those who have the ability to refine or warn of consequences. It could also contain complaints from those who "chanced the arm" and got it broken N.B. a single line DOS command can remove every instance of a double ;; comment line from a file without removing single ; comments lines. Link to comment Share on other sites More sharing options...
Coffee4Joe Posted May 29, 2013 Share Posted May 29, 2013 New Entry [sketchUp Make 2013*] LangSecRef=3021 Warning=This will clear your most recent list Detect=HKCU\Software\SketchUp Default=False RegKey1=HKCU\Software\SketchUp\SketchUp 2013\Recent File List Link to comment Share on other sites More sharing options...
APMichael Posted May 29, 2013 Share Posted May 29, 2013 Thanks for your ever vigilant watch, APMichael. Don't mention it! Edit: For anyone interested in how many little changes the alphabetization involved: http://i.imgur.com/6fMO4qR.png Wow, how many hours did you spend for all those changes? Link to comment Share on other sites More sharing options...
SMalik Posted June 2, 2013 Share Posted June 2, 2013 Revised Entry [Roxio Creator NXT Pro*] LangSecRef=3021 Detect=HKCU\Software\Roxio\EMC14 Default=False RegKey1=HKCU\Software\Roxio\EMC14\Label Creator\Recent File List RegKey2=HKCU\Software\Roxio\EMC14\MusicDiscCreator\Directories RegKey3=HKCU\Software\Roxio\EMC14\MusicDiscCreator\MediaSelector RegKey4=HKCU\Software\Roxio\EMC14\SoundEdit\Directories RegKey5=HKCU\Software\Roxio\EMC14\SoundEdit\MediaSelector RegKey6=HKCU\Software\Roxio\EMC14\SoundEdit\WaveCache RegKey7=HKCU\Software\Roxio\EMC14\PhotoSuite\RoxioPhotoSuite\MRUFiles RegKey8=HKCU\Software\Roxio\EMC14\VideoConvert\Directories RegKey9=HKCU\Software\Roxio\EMC14\VideoConvert\MediaSelector RegKey10=HKCU\Software\Roxio\EMC14\VideoUI\RecentFiles\Albums RegKey11=HKCU\Software\Roxio\EMC14\VideoUI\RecentFiles\Catalogs RegKey12=HKCU\Software\Roxio\EMC14\VideoUI\RecentFiles\DVD Projects RegKey13=HKCU\Software\Roxio\EMC14\VideoUI\RecentFiles\Productions RegKey14=HKLM\Software\Roxio\EMC14\Common SDK\Users RegKey15=HKLM\Software\Wow6432Node\Roxio\EMC14\Common SDK\Users FileKey1=%Documents%\Roxio\Music Disc Creator|*.* Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 3, 2013 Author Share Posted June 3, 2013 Wow, how many hours did you spend for all those changes? Actually I don't think it was much longer than two hours, three at most. I did it somewhat passively, so it's hard to estimate. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Fuebar Posted June 5, 2013 Share Posted June 5, 2013 Let's see, for now I've got: LangSecRef=Games Should be Section=Games for each of these entries: Bugsplat Chivalry: Medieval Warfare Don't Starve Faster Than Light Hi-Rez Studios Torchlight 2 Tribes: Ascend Cheers. EDIT: Oh, and a new entry, for calibre's search cache. [Calibre Cache*] LangSecRef=3021 DetectFile=%LocalAppData%\calibre-cache\jsbrowser Default=False FileKey1=%LocalAppData%\calibre-cache\jsbrowser\data*|*.*|RECURSE And by the way, perhaps you should remove the MD5 checksum on the first post if you aren't updating it regularly, it could make a few paranoid people suspicious. Unless of course it is correct, and my hasher is not. Or I'm a victim of a MitM by someone intent on skewing my cleaning definitions... truly evil. Link to comment Share on other sites More sharing options...
pook1y7985 Posted June 6, 2013 Share Posted June 6, 2013 Greetings, The below entry removes the most frequent list of locations for appointments in Outlook . There is actually no way to reset them in Outlook without clearing the key which is recreated and causes no issues. Including Entries for Outlook 2010-2000 New Entries [Outlook 2010 Appointment Location MRU *] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Office\14.0 Warning=This Will Remove the Most Frequent Appointment Locations Default=False RegKey1=HKCU\Software\Microsoft\Office\14.0\Outlook\Preferences\LocationMRU [Outlook 2007 Appointment Location MRU *] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Office\12.0 Warning=This Will Remove the Most Frequent Appointment Locations Default=False RegKey1=HKCU\Software\Microsoft\Office\12.0\Outlook\Preferences\LocationMRU [Outlook 2003 Appointment Location MRU *] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Office\11.0 Warning=This Will Remove the Most Frequent Appointment Locations Default=False RegKey1=HKCU\Software\Microsoft\Office\11.0\Outlook\Preferences\LocationMRU [Outlook 2000 Appointment Location MRU *] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Office\9.0 Warning=This Will Remove the Most Frequent Appointment Locations Default=False RegKey1=HKCU\Software\Microsoft\Office\9.0\Outlook\Preferences\LocationMRU Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 6, 2013 Author Share Posted June 6, 2013 And by the way, perhaps you should remove the MD5 checksum on the first post if you aren't updating it regularly, it could make a few paranoid people suspicious. Unless of course it is correct, and my hasher is not. Or I'm a victim of a MitM by someone intent on skewing my cleaning definitions... truly evil. md5sums.exe is outputting "06abc5621b21f22d396de0b2a27280ef" as the hash from the winapp2.ini download in the main post. Also matches www.winapp2.com/hash.txt winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 6, 2013 Moderators Share Posted June 6, 2013 The MD5 also matches using HashTab, and Snap MD5. Link to comment Share on other sites More sharing options...
kleaner Posted June 7, 2013 Share Posted June 7, 2013 There's a problem with the .ini. It messes my Chrome/Comodo Dragon settings. How to reproduce: In Chome/CD go to settings and delete any links from: Open a specific page or set of pages, then switch to Open the New Tab page. Close the browser. Make sure you have all the options for Google Chrome checked in Applications, Ccleaner. Start cleaning. After it's done, run the browser. You'll get an error that the profile could not be loaded, all your settings, extensions are back to default. Any way to fix it? It definitely deletes something that it shouldn't. Link to comment Share on other sites More sharing options...
Alan_B Posted June 7, 2013 Share Posted June 7, 2013 Any way to fix it? It definitely deletes something that it shouldn't. I suggest you start your own topic, stating version of Windows and specific version numbers of Chrome/Comodo and CCleaner.exe and WinApp2.ini. It would be a waste of time and effort if posts dealing with your issue are intermingled in this topic with its main function of submissions for new entries. Link to comment Share on other sites More sharing options...
Hav0c Posted June 9, 2013 Share Posted June 9, 2013 For those of you who want to delete Language files from your system this may help a bit. Just some I have been using for a while. [7-Zip (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\7-Zip Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%ProgramFiles%\7-Zip\Lang|*.*|REMOVESELF [Defraggler (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\Piriform\Defraggler Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%ProgramFiles%\Defraggler\Lang|*.*|REMOVESELF [Daemon Tools (Lng)*] Section=Language Files Detect=HKCU\Software\DT Soft Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\DAEMON Tools\Lang|*.* ExcludeKey1=FILE|%ProgramFiles%\DAEMON Tools\Lang\ENU.dll [Daemon Tools Pro (Lng)*] Section=Language Files Detect=HKCU\Software\DT Soft Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\DAEMON Tools Pro\Lang|*.* ExcludeKey1=FILE|%ProgramFiles%\DAEMON Tools Pro\Lang\ENU.dll [FileZilla 3 (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\FileZilla 3 Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%ProgramFiles%\FileZilla FTP Client\locales|*.*|REMOVESELF [seaTools for Windows (Lng)*] Section=Language Files DetectFile=%ProgramFiles%\Seagate\SeaTools for Windows\SeaToolsforWindows.exe Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\Seagate\SeaTools for Windows|*.pdf FileKey2=%ProgramFiles%\Seagate\SeaTools for Windows\de-DE|*.*|REMOVESELF FileKey3=%ProgramFiles%\Seagate\SeaTools for Windows\es-ES|*.*|REMOVESELF FileKey4=%ProgramFiles%\Seagate\SeaTools for Windows\fr-FR|*.*|REMOVESELF FileKey5=%ProgramFiles%\Seagate\SeaTools for Windows\it-IT|*.*|REMOVESELF FileKey6=%ProgramFiles%\Seagate\SeaTools for Windows\ja-JP|*.*|REMOVESELF FileKey7=%ProgramFiles%\Seagate\SeaTools for Windows\ko-KR|*.*|REMOVESELF FileKey8=%ProgramFiles%\Seagate\SeaTools for Windows\pt-BR|*.*|REMOVESELF FileKey9=%ProgramFiles%\Seagate\SeaTools for Windows\ru-RU|*.*|REMOVESELF FileKey10=%ProgramFiles%\Seagate\SeaTools for Windows\th-TH|*.*|REMOVESELF FileKey11=%ProgramFiles%\Seagate\SeaTools for Windows\vi-VN|*.*|REMOVESELF FileKey12=%ProgramFiles%\Seagate\SeaTools for Windows\zh-CN|*.*|REMOVESELF FileKey13=%ProgramFiles%\Seagate\SeaTools for Windows\zh-TW|*.*|REMOVESELF FileKey14=%ProgramFiles%\Seagate\SeaTools for Windows|*.rtf ExcludeKey1=FILE|%ProgramFiles%\Seagate\SeaTools for Windows\SeaTools for Windows.en-US.pdf ExcludeKey2=FILE|%ProgramFiles%\Seagate\SeaTools for Windows\SeaTools_EULA_ENGLISH_FINAL.rtf [spybot - Search & Destroy 1.62 (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\Safer Networking Limited\SpybotSnD Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\Spybot - Search & Destroy\Languages|*.*|REMOVESELF ExcludeKey1=FILE|%ProgramFiles%\Spybot - Search & Destroy\Languages\English.sbl [spybot - Search & Destroy 2(Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\Safer Networking Limited\Spybot - Search & Destroy 2 Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%ProgramFiles%\Spybot - Search & Destroy 2\locale|*.*|REMOVESELF [syncBackFree (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\2BrightSparks\SyncBackFree Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%ProgramFiles%\2BrightSparks\SyncBackFree\locale|*.*|REMOVESELF [TeamViewer (Lng)*] Section=Language Files Detect=HKCU\Software\TeamViewer Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\Teamviewer\*|TeamViewer_Resource_*.dll ExcludeKey1=FILE|%ProgramFiles%\Teamviewer\*|TeamViewer_Resource_en.dll [TeraCopy (Lng)*] Section=Language Files Detect=HKCU\Software\Code Sector\TeraCopy Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\TeraCopy\locale|*.*|REMOVESELF ExcludeKey1=PATH|%ProgramFiles%\TeraCopy\locale\en\LC_MESSAGES [K-Lite Media Player Classic (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\Classes\Applications\mpc-hc.exe Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%ProgramFiles%\K-Lite Codec Pack\Media Player Classic\Lang\|*.*|REMOVESELF Note: I split the Spybot and Daemon Tools entries, naturally you will have to select the one applicable to you. Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 9, 2013 Moderators Share Posted June 9, 2013 I suggest you start your own topic, stating version of Windows and specific version numbers of Chrome/Comodo and CCleaner.exe and WinApp2.ini. It would be a waste of time and effort if posts dealing with your issue are intermingled in this topic with its main function of submissions for new entries. Alan is incorrect, if you are sure that this is definitely due to a Chrome Entry that resides on the winapp2.ini file and not the built in Chrome rules, you asked in the proper thread ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 9, 2013 Author Share Posted June 9, 2013 There's a problem with the .ini. It messes my Chrome/Comodo Dragon settings. How to reproduce: In Chome/CD go to settings and delete any links from: Open a specific page or set of pages, then switch to Open the New Tab page. Close the browser. Make sure you have all the options for Google Chrome checked in Applications, Ccleaner. Start cleaning. After it's done, run the browser. You'll get an error that the profile could not be loaded, all your settings, extensions are back to default. Any way to fix it? It definitely deletes something that it shouldn't. I'd recommend going through this process with each chrome entry ticked one at a time (or unticking one at a time) until you find which one(s) are causing it. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 12, 2013 Moderators Share Posted June 12, 2013 New: [Wise Video Downloader*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Wise Video Downloader_is1 DetectFile=%ProgramFiles%\Wise\Wise Video Downloader\WiseDownloader.exe Default=False FileKey1=%SystemDrive%\ThumbnailCache|*.* FileKey2=%AppData%\Wise Video Downloader|FileListConfig.ini Link to comment Share on other sites More sharing options...
rctgamer3 Posted June 18, 2013 Share Posted June 18, 2013 Revised entry: [Google Drive*] LangSecRef=3024 Detect=HKCU\Software\Google\Drive Default=False FileKey1=%LocalAppData%\Google\Drive\CrashReports|*.*|RECURSE FileKey2=%LocalAppData%\Google\Drive|*.log Warning=Cleanup will fail if Google Drive is currently running Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 18, 2013 Author Share Posted June 18, 2013 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted June 19, 2013 Share Posted June 19, 2013 I am attempting to track down what WinApp2.ini entry is causing the system Task Scheduler to experience Event ID 114 on scheduled tasks that run via the Task Scheduler. If anyone has any clues or feedback on what entry might be causing this, please "point me in the right direction". Below is a more detailed description of the issue. I use my "Casper" system backup program as the example; however, the problem affects all programs in the Task Scheduler. My systems are Windows 7 and Windows 8. - I have Casper set up in the Task Scheduler to run every Tuesday and Saturday at 3:00 a.m. to copy my primary operating system to a separate bootable backup drive. - In the Task Scheduler on the Settings tab, I have "Run task as soon as possible after a scheduled start is missed" selected. - The Task Scheduler works correctly and runs Casper on Tuesday and Saturday at the prescribed times. - The time/date of the Casper run is properly displayed via the Task Scheduler under "Last Run Time". - The time/date of the next scheduled Casper execution is properly displayed via the Task Scheduler under "Next Run Time" - When I run CCleaner after the above Casper execution, the "Last Run Time" is cleared out and "Never" now shows as the "Last Run Time". - On system reboot, this causes the Task Scheduler to think that Casper did not run when scheduled (Event ID 114). And it then runs Casper as directed via the option "Run task as soon as possible after a scheduled start is missed". I am going through the process of elimination under the Applications tab of CCleaner; however, in the interest of time I am posting this "request for assistance". Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted June 19, 2013 Share Posted June 19, 2013 I strongly recommend that the entry Windows SCM Logs* be removed from WinApp2.ini because it causes the Event ID 114 failure in the system Task Scheduler as described above. [Windows SCM Logs*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%WinDir%\System32\LogFiles\Scm|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
