CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
There needs to be a format that states "show on all versions but the specified version". For example:
DetectOS=|6.2| = could say "Show on all versions earlier than Windows 8, all versions later than Windows 8, but do not show on Windows 8.
I think you misunderstand the power of this thread, perhaps mention in ccleaner suggestions board.
Share this post
Link to post
Folder icons are missing text labels after hibernation or a certain period of time, so I have to restart explorer.exe. I can tell you this didn't happen when I took the advice saad2011 or the previous version of winapp2,ini.
I'll just remove it in the next version.
FWIW i haven't experienced this though
Share this post
Link to post
I believe you, though I'm wondering why other people haven't come forward. Thanks for removing.
Cheers for maintaining it for the last 3 years. I've been using this since 2008 when it was first introduced.
Share this post
Link to post
New (Not included in 4.05.130826):
[MS Visual Studio dump files*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Microsoft\VisualStudio
Default=False
FileKey1=%LocalAppData%\PerfWatson|*.*
Share this post
Link to post
The new nvidia tool ... very usefull
[NVIDIA GFExperience Logs*]
LangSecRef=3023
Detect=HKLM\Software\NVIDIA Corporation
Default=False
FileKey1=%SystemDrive%\NvidiaLogging\GFExperience|GridClientLog.log*|RECURSE
this string kills a lot of 0 byte files :D
i have some huge files on C:\ProgramData\NVIDIA\Updatus\DownloadManager !!!
can we delt?
It seems to be the updates where you downloaded with gfexperience!
Share this post
Link to post
Revised Entries.
[Cached File Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
RegKey2=HKCU\Software\Microsoft\Windows\Roaming\OpenWith\FileExts
RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
[Registry First Aid (Backups)*]
LangSecRef=3024
Detect=HKCU\Software\KsL Software\RFA
Default=False
FileKey1=%CommonAppData%\RFA_Backups|*.*|RECURSE
FileKey2=%WinDir%\ServiceProfiles\LocalService|*.tmp
FileKey3=%WinDir%\ServiceProfiles\LocalService|*.tmp.LOG1
FileKey4=%WinDir%\ServiceProfiles\LocalService|*.tmp.LOG2
FileKey5=%WinDir%\ServiceProfiles\NetworkService|*.tmp
FileKey6=%WinDir%\ServiceProfiles\NetworkService|*.tmp.LOG1
FileKey7=%WinDir%\ServiceProfiles\NetworkService|*.tmp.LOG2
FileKey8=%WinDir%\System32\config\systemprofile|*.tmp
FileKey9=%WinDir%\System32\config\systemprofile|*.tmp.LOG1
FileKey10=%WinDir%\System32\config\systemprofile|*.tmp.LOG2
FileKey11=%WinDir%\System32\config|*.tmp
FileKey12=%WinDir%\System32\config|*.tmp.LOG1
FileKey13=%WinDir%\System32\config|*.tmp.LOG2
Share this post
Link to post
LangSecRef=3023
Default=False
can we delt?
Try it and see what happens ;) That's usually how I test things.
Share this post
Link to post
ok nothing after restart :-)
it worked but we need more tests.... we must wait for the next update .....
[NVIDIA GFExperience Updates*]
LangSecRef=3023
Warning=!!!Needs more tests don't do this on NV updates! Only after! It could be that you need to reinstall the NV driver!!!
Default=False
FileKey1=%SystemDrive%\ProgramData\NVIDIA\Updatus\DownloadManager\*.*
Share this post
Link to post
New Entry
You can change the name if you like.
[Windows Temp Files*]
LangSecRef=3025
DetectFile=%WinDir%\WinSxS
Default=False
FileKey1=%WinDir%\WinSxS|Reserve.tmp
big file. Approx. 3GB
Windows 8 64-bit system
http://answers.microsoft.com/en-us/windows/forum/windows_8-performance/can-you-delete-file-reservetmp-in-win-sxs/7d7d750f-c5b3-43a4-8870-41a4422b0be8?msgId=9a968aa8-821f-452c-8434-110ec885654d
Share this post
Link to post
what is the danger of playing with WinSxS files?
even .tmp ones?
should be a big caveat - USER BEWARE.
Share this post
Link to post
New Entry
LangSecRef=3025
DetectFile=%WinDir%WinSxS
Default=False
FileKey1=%WinDir%WinSxS|Reserve.tmp
Seeing as that linked page states "it's not really as big as it says" and other such admonitions I'd say leave it alone
Share this post
Link to post
2014 Norton Products Released. Changed name on [Norton Internet Security 2012/13/14 Dumps*]
LangSecRef=3024
DetectFile=%CommonAppData%\Norton\LocalDumps
Default=False
FileKey1=%CommonAppData%\Norton\LocalDumps|*.dmp
Share this post
Link to post
There are a few other web pages referencing this file and stating to NOT remove it. I agree with Nergal's recommendation.
Share this post
Link to post
As per the file size, it is 2.95 GB. I wiped the file from the directory and no issues at all. After wiping the file I reclaimed approx 3 GB on the hard disk!
Share this post
Link to post
is there any entries in winapp2.ini that change how we view the screen?
i mean, the font look smaller after i run ccleaner+winapp2.ini with another cleaning software esp at Start Menu
the font size currently at 100% which is default setting
i just want to make sure that there is no entry in winapp2.ini that can do that
Share this post
Link to post
It is very tempting to remove reserve.tmp; however, I am going to wait until after Windows 8.1 is installed. If the file is still there, I most likely will save it on a flash drive and delete it from Winsys.
Share this post
Link to post
Re: [Windows SCM Logs*]
As I was saying, that wiping these log files are completely safe. The problem is when you wipe SCM.EVM files. If you'd like to add this entry back to Winapp2.ini then it should be changed to:
[Windows SCM Logs*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\System32\LogFiles\Scm|*.*
ExcludeKey1=FILE|%WinDir%\System32\LogFiles\Scm|*.EVM;*.EVM.1;*.EVM.2;*.EVM.3;*.EVM.4
A snapshot is attached with this message showing which files shouldn't be deleted.
Share this post
Link to post
[Windows SCM Logs*]
LangSecRef=3025
Default=False
Thanks for the update. I never had any issues from using the original entry, but having looked in the scm folder I don't have any evm files so maybe just been lucky.
Share this post
Link to post
Original - already in winapp2.ini:
[Windows XP Error Reporting*]
DetectOS=|5.2
LangSecRef=3025
Default=False
FileKey1=%WinDir%\pchealth\ERRORREP|*.*|RECURSE
Updated, added FileKey2 and Warning. Not sure about the DetectOS, I thought XP was 5.1. Also on my system FileKey2 will only get cleaned as it's listed below using %userprofile%.
DetectOS=|5.2
LangSecRef=3025
Default=False
Warning=This deletes the error reports generated by Windows (such as failed Windows Updates) that Microsoft Error Reporting requests to upload directly to Microsoft. Make sure you upload the error reports before using this cleaner, that way Microsoft may be able to fix the problem in a future Windows Update.
FileKey2=%userprofile%\Local Settings\Application Data\PCHealth\ErrorRep\QSignoff|*.*
Edited by Andavari
Added info and fixed the wording in the Warning=
Share this post
Link to post
I've been using this without problems:
[Windows SCM Logs*]
LangSecRef=3025
Default=False
[Windows SCM Logs*]
LangSecRef=3025
Default=False
Wouldn't
[Windows SCM Logs*]
LangSecRef=3025
Default=False
ExcludeKey1=FILE|%WinDir%\System32\LogFiles\Scm|*.EVM*
work also (don't have to list all the numbers)?
Share this post
Link to post
The ExcludeKey1 addition to Windows SCM Logs* still not resolve the basic issue of this code causing Windows Scheduled Tasks to re-run any scheduled task that has the option "Run task as soon as possible after a scheduled start is missed" activated. The logs in the SCM folder are used to control this option.
I strongly recommend that Windows SCM Logs* not be re-added to Winapp2.ini.
Share this post
Link to post
Modified Entry for [TuneUp Utilities Reg Defrag Cleanup*] to include TuneUp Utilities 2014. Added Detect4
LangSecRef=3024
Detect1=HKCU\Software\TuneUp\Utilities\10.0
Detect2=HKCU\Software\TuneUp\Utilities\12.0
Detect3=HKCU\Software\TuneUp\Utilities\13.0
Detect4=HKCU\Software\TuneUp\Utilities\14.0
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_new.LOG*;USRCLASS.DAT_tureg_old
FileKey2=%SystemDrive%\Boot|BCD_tureg_new.LOG*;BCD_tureg_old
FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey4=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey5=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey6=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey7=%UserProfile%|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey10=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG*;COMPONENTS_tureg_old;DEFAULT_tureg_new.LOG*;DEFAULT_tureg_old;SAM_tureg_new.LOG*;SAM_tureg_old;SECURITY_tureg_new.LOG*;SECURITY_tureg_old;SOFTWARE_tureg_new.LOG*;SOFTWARE_tureg_old;SYSTEM_tureg_new.LOG*;SYSTEM_tureg_old;DRIVERS_tureg_new.LOG*;DRIVERS_tureg_old
Share this post
Link to post
New Entry: [TuneUp Utilities (CrashDumps)*]
LangSecRef=3024
Detect=HKCU\Software\TuneUp
Default=False
Warning=This removes ALL crash/dump files saved by program TuneUp Utilities.
FileKey1=%AppData%\TuneUp Software\TuneUp Utilities\CrashDumps|*.*
Share this post
Link to post
Register a new account
Sign in
