siliconman01 Posted July 4, 2013 Share Posted July 4, 2013 New Entries LSys (Local System) [LSys Cached File Extensions*] LangSecRef=3025 Detect=HKU\.DEFAULT\Software\Microsoft\Windows Default=False RegKey1=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts [LSys Cached Shell Extensions*] LangSecRef=3025 Detect=HKU\.DEFAULT\Software\Microsoft\Windows Default=False RegKey1=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached If these are added to Winapp2.ini, I suggest the name be "Local System" instead of the abbreviated "LSys" so that users are better able to identify what these are related to. Does Windows have to rebuild these after they are cleared? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted July 4, 2013 Share Posted July 4, 2013 If these are added to Winapp2.ini, I suggest the name be "Local System" instead of the abbreviated "LSys" so that users are better able to identify what these are related to. Does Windows have to rebuild these after they are cleared? It's safe to remove and Windows will rebuild the ones you need. Link to comment Share on other sites More sharing options...
SMalik Posted July 4, 2013 Share Posted July 4, 2013 Is this related to the existing File/Shell exts? Yes, you may add these in the existing entries. [Cached File Extensions*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts RegKey2=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts [Cached Shell Extensions*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached RegKey2=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached Link to comment Share on other sites More sharing options...
natsumerio Posted July 6, 2013 Share Posted July 6, 2013 I'm not sure if this is already in the latest version of Winapp2.ini or not, but recently, I used the latest stable version of Utorrent to download a few torrents, & by accident, when I was checking on something else's appdata, I noticed this. After I finished downloading a few torrents with Utorrent (read, they were all at 100%), I left them in Utorrent's list for about 6 hours to help seed them. After that, I removed them from Utorrent's list & shut down Utorrent completely. Utorrent wasn't even in the task bar, & I have my task bar set to show me everything that is running. Later, I was checking on something else in my appdata, & I noticed that Utorrent's appdata still had a .torrent file of everything that I had downloaded with Utorrent. I ran CCleaner with CCenhancer & Winapp2.ini, but they were still there after that. Below is where they were located. C:\Users\Yumi6\AppData\Roaming\uTorrent Link to comment Share on other sites More sharing options...
FreeRyde Posted July 6, 2013 Share Posted July 6, 2013 CCleaner (Winapp.ini) and Winapp2.ini do not have rules to remove torrent files and their relative downloaded data. If you want to clear the above data, right-click any or all of those listed in the µTorrent GUI, then select 'Delete .torrent + Data' from the menu instead of 'Delete .torrent'. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 6, 2013 Author Share Posted July 6, 2013 .torrent files aren't generated if you use magnet links to load the torrent information. That's the only solution for their generation that I can afford you, since there's no way to distinguish between active and finished torrents. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted July 7, 2013 Share Posted July 7, 2013 New App Network Speed Test by Microsoft [Network Speed Test*] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.NetworkSpeedTest_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_*\AC\Microsoft\CLR_v4.0*\UsageLogs|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_*\AC\PRICache|*.* FileKey6=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_*\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\Microsoft.NetworkSpeedTest_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Fuebar Posted July 10, 2013 Share Posted July 10, 2013 [iDLE Recent Files*] LangSecRef=3021 DetectFile=%UserProfile%\.idlerc Default=False FileKey1=%UserProfile%\.idlerc|recent-files.lst For Python's IDLE editor/IDE. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 12, 2013 Moderators Share Posted July 12, 2013 Updated again: [Wise Video Downloader*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Wise Video Downloader_is1 DetectFile=%ProgramFiles%\Wise\Wise Video Downloader\WiseDownloader.exe Default=False FileKey1=%SystemDrive%\ThumbnailCache|*.* FileKey2=%AppData%\Wise Video Downloader|DownloadList.ini FileKey3=%AppData%\Wise Video Downloader|FileListConfig.ini Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 20, 2013 Moderators Share Posted July 20, 2013 (edited) Updated: [Wise Video Downloader*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Wise Video Downloader_is1 DetectFile=%ProgramFiles%\Wise\Wise Video Downloader\WiseDownloader.exe Default=False FileKey1=%SystemDrive%\|urlinfo.txt FileKey2=%SystemDrive%\ThumbnailCache|*.* FileKey3=%AppData%\Wise Video Downloader|DownloadList.ini FileKey4=%AppData%\Wise Video Downloader|FileListConfig.ini If anyone uses Wise Video Downloader it will create a urlinfo.txt file in the root of the disk drive that you download to. So if you've changed the default settings to for instance download to H:\Downloads\YouTube instead of the default path it will create a urlinfo.txt file in H:\ Edited July 20, 2013 by Andavari Link to comment Share on other sites More sharing options...
SMalik Posted July 21, 2013 Share Posted July 21, 2013 Revised Entry [Foxit PhantomPDF 6 More*] LangSecRef=3021 Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0 Default=False RegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\Preferences\History RegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\Recent File List RegKey3=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\RecentFiles Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 21, 2013 Author Share Posted July 21, 2013 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Hav0c Posted July 23, 2013 Share Posted July 23, 2013 New language files entry for those who would like it. [VMware Keymap (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\VMware, Inc. Default=False Warning=This will delete all language keymap files excluding the US English. FileKey1=%CommonAppData%\VMware\vnckeymap|* ExcludeKey1=FILE|%CommonAppData%\VMware\vnckeymap\us Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
siliconman01 Posted July 24, 2013 Share Posted July 24, 2013 New addition of App LifeCam [LifeCam*] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.LifeCamDashboard_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_*\AC\PRICache|*.* FileKey5=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_*\AC\Temp|*.* FileKey6=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_*\TempState|*.*|RECURSE Also a language addition for US English edit on LifeCam [LifeCam (Lng)*] Section=US English Language Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.LifeCamDashboard_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.LifeCamDashboard_8wekyb3d8bbwe Warning=This deletes all languages EXCEPT the United States English language. Default=False FileKey1=%ProgramFiles%\Microsoft LifeCam\DriverComponents\de-DE\|*.*|REMOVESELF FileKey2=%ProgramFiles%\Microsoft LifeCam\DriverComponents\el-GR\|*.*|REMOVESELF FileKey3=%ProgramFiles%\Microsoft LifeCam\DriverComponents\es-ES\|*.*|REMOVESELF FileKey4=%ProgramFiles%\Microsoft LifeCam\DriverComponents\fr-FR\|*.*|REMOVESELF FileKey5=%ProgramFiles%\Microsoft LifeCam\DriverComponents\it-IT\|*.*|REMOVESELF FileKey6=%ProgramFiles%\Microsoft LifeCam\DriverComponents\ja-JP\|*.*|REMOVESELF FileKey7=%ProgramFiles%\Microsoft LifeCam\DriverComponents\ko-KR\|*.*|REMOVESELF FileKey8=%ProgramFiles%\Microsoft LifeCam\DriverComponents\pt-BR\|*.*|REMOVESELF FileKey9=%ProgramFiles%\Microsoft LifeCam\DriverComponents\pt-PT\|*.*|REMOVESELF FileKey10=%ProgramFiles%\Microsoft LifeCam\DriverComponents\ru-RU\|*.*|REMOVESELF FileKey11=%ProgramFiles%\Microsoft LifeCam\DriverComponents\zh-CN\|*.*|REMOVESELF FileKey12=%ProgramFiles%\Microsoft LifeCam\DriverComponents\zh-TW\|*.*|REMOVESELF Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted July 25, 2013 Share Posted July 25, 2013 New Entries Tested on a Windows 8 64-bit system. [LastGood.tmp Folder*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%WinDir%\LastGood.tmp|*.*|REMOVESELF [Windows Search Cache Files*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Caches|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Windows\Caches|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 25, 2013 Author Share Posted July 25, 2013 Hey folks! Looks like piriform added a SpecialDetect for Chrome presumably encompassing all of this: Detect=HKCU\Software\Chromium DetectFile=%localappdata%\Google\Chrome\Application\chrome.exe DetectFile2=%ProgramFiles%\Google\Chrome\Application\chrome.exe DetectFile3=%localappdata%\Flock\Application\flock.exe DetectFile4=%ProgramFiles%\Flock\Application\flock.exe DetectFile5=%localappdata%\Google\Chrome SxS\Application\chrome.exe DetectFile6=%ProgramFiles%\Google\Chrome SxS\Application\chrome.exe DetectFile7=%localappdata%\SRWare Iron\iron.exe DetectFile8=%ProgramFiles%\SRWare Iron\iron.exe DetectFile9=%ProgramFiles%\Chromium\chrome.exe DetectFile10=%localappdata%\Chromium\chrome.exe DetectFile11=%ProgramFiles%\Chromium\Application\chrome.exe DetectFile12=%localappdata%\Chromium\Application\chrome.exe DetectFile13=%AppData%\ChromePlus\chrome.exe DetectFile14=%localappdata%\RockMelt\Application\rockmelt.exe DetectFile15=%ProgramFiles%\RockMelt\Application\rockmelt.exe DetectFile16=%LocalAppData%\Comodo\Dragon\dragon.exe DetectFile17=%ProgramFiles%\Comodo\Dragon\dragon.exe DetectFile18=%LocalAppData%\MapleStudio\ChromePlus\Application\Chrome.exe DetectFile19=%AppData%\MapleStudio\ChromePlus\Application\Chrome.exe anywho- update incoming winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 25, 2013 Author Share Posted July 25, 2013 updated winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 25, 2013 Moderators Share Posted July 25, 2013 you beat me to it, but it's SpecialDetect=DET_CHROME (incase you didn't see it or if anyone is creating any entries) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 25, 2013 Moderators Share Posted July 25, 2013 Interesting on the Chrome detection. Although I'll continue using this for Comodo Dragon: Detect=HKLM\Software\ComodoGroup\Dragon Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 25, 2013 Author Share Posted July 25, 2013 I moved all of the chrome entries (which all used the standard CCleaner chrom(e|ium) detectfiles/detects) all over to SpecialDetect in celebration winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted July 25, 2013 Share Posted July 25, 2013 Looks like you missed LifeCam at http://forum.piriform.com/index.php?showtopic=32310&st=3220&do=findComment&comment=237487 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 25, 2013 Author Share Posted July 25, 2013 Looks like you missed LifeCam at http://forum.pirifor...220#entry237487 oops- thanks. I misread that entry as a correction for a lng entry. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ricktendo64 Posted July 25, 2013 Share Posted July 25, 2013 Changed HKLM to HKCU [beyond Compare 3*] LangSecRef=3021 Detect=HKCU\Software\Scooter Software\Beyond Compare 3 Default=False FileKey1=%AppData%\Scooter Software\Beyond Compare 3|*.bak;BCCommands.xml;BCSessions.xml Removed RegKey3, Fixed FileKey1 and added "*" file flag [Adobe Reader Touch More*] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga DetectFile=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga Default=True FileKey1=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\Microsoft\CLR_v4.0*|*.log|RECURSE FileKey2=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\AC\PRICache|*.* FileKey3=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_*\LocalState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedPickerData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga!App\DefaultOpenFileSingle|LastLocation RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedStorageItemTable\MostRecentlyUsed Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 28, 2013 Author Share Posted July 28, 2013 I added a bit about section= into the 'how-to' in the OP winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted July 28, 2013 Share Posted July 28, 2013 New Entry Tested on a Windows 8 64-bit system [Troubleshooting Logs*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Diagnostics|*.*|RECURSE Link to comment Share on other sites More sharing options...
