Moderators Andavari Posted June 19, 2013 Moderators Share Posted June 19, 2013 I strongly recommend that the entry Windows SCM Logs* be removed from WinApp2.ini because it causes the Event ID 114 failure in the system Task Scheduler as described above. Good find, and all because of logs. Hopefully Piriform also looks at your post and makes certain no future version of CCleaner ever touches them "out-of-the-box". Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 19, 2013 Moderators Share Posted June 19, 2013 thanks for the catch @siliconman01 ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 19, 2013 Author Share Posted June 19, 2013 Thanks! These are the things that always get me - entries i run and test but have effects on other things I don't make use of (so I don't run into the problem!) I'll remove it in the next iteration. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
KapnJackSparrow Posted June 20, 2013 Share Posted June 20, 2013 expanded LangSecRef (I used a batchfile to BFIthe syntax since the "complete" syntax doesn't seem to be listed anywhere and some of those are useful like the Registry Cleaner) ; LangSecRef ; ; 3001 = Internet Explorer ; 3002 = Windows Explorer ; 3003 = System ; 3004-3100 = Advanced (not including 3021-3029) ; 3021 = Applications ; 3022 = Internet ; 3023 = Multimedia ; 3024 = Utilities ; 3025 = Windows ; 3026 = Firefox ; 3027 = Opera ; 3028 = Safari ; 3029 = Google Crome ; 3101 = Temporary Internet Files ; 3102 = Cookies ; 3103 = History ; 3104 = Recently Typed URLs ; 3105 = Index.dat files ; 3106 = & 3107 Autocomplete Form History ; 3108 = Last Download Location ; 3109 = Saved Passwords ; 3110 = Cached Feeds ; 3111-3120 = Add-ons Statistics ; 3121 = Recent Documents ; 3122 = Run (In Start Menu) ; 3123 = Search Autocomplete ; 3124 = Other Explorer MRUs ; 3125 = Menu Order Cache ; 3126 = Tray Notifications Cache ; 3127 = Windows Size/Location Cache ; 3128 = User Assist History ; 3129 = custom Files and Folders ; 3130 = Hotfix uninstallers ; 3131 = Thumbnail Cache ; 3132 = Wipe Free Space ; 3133 = Taskbar Jump Lists ; 3134-3140 = Wipe MFT Free Space ; 3141 = Empty Recycle Bin ; 3142 = Temporary Files ; 3143 = Memory Dumps ; 3144 = Chdsk File Fragments ; 3501 = Registry Cleaner [* More Windows Crap] LangSecRef=3025 Detect=HKLM\SYSTEM Default=True RegKey1=HKCU\Software\Microsoft\PerfVis\Recent File List RegKey2=HKCU\Software\Microsoft\Office\12.0\Common\Open Find RegKey3=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU RegKey4=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU a Regestry to batchfile conversion tool, the regestry key's literally seem to do nothing. [* Reg to Bat] LangSecRef=3021 Detect=HKLM\SOFTWARE\BlueLife Default=True RegKey1=HKLM\SOFTWARE\BlueLife these don't normally seem to be cleaned ? [* User Assist] LangSecRef=3501 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\UserAssist Default=True RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\UserAssist RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32 part of where the system stores information for usb devices that have been mounted (viewed by Os Forensics.) [* USB Store] LangSecRef=3501 Detect=HKLM\SYSTEM\CurrentControlSet\Enum\USBSTOR Default=True RegKey1=HKLM\SYSTEM\CurrentControlSet\Enum\USBSTOR Snagit is running in portable mode so not sure if this is somewhere. [* Snagit] LangSecRef=3025 Detect=HKLM\SYSTEM Default=True RegKey1=HKCU\Software\TechSmith\SnagIt\8\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\8\Catalog\Recent Editor Files RegKey3=HKCU\Software\TechSmith\SnagIt\8\CatalogOpenFolder [* Windows Media Player (Databases)] LangSecRef=3023 Detect=HKCU\Software\Microsoft\MediaPlayer Default=True Warning=This will remove ratings, play counts, last played, etc. FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Microsoft\Media Player|*.*|REMOVESELF FileKey2=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Media Player|*.*|REMOVESELF FileKey3=%SystemDrive%\Documents and Settings\Default User\Local Settings\Application Data\Microsoft\Media Player|*.*|REMOVESELF FileKey4=%windir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Media Player|*.*|REMOVESELF FileKey5=%UserProfile%\Local Settings\Application Data\Microsoft\Media Player|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
CSGalloway Posted June 21, 2013 Share Posted June 21, 2013 [Pando Cache*] Warning=Make sure Pando is totally shut down before using this Detect=HKCU\Software\Pando Networks\Pando LangSecRef=3024 Default-False Filekey1=%localappdata%\Pando\Pando Files|*.*|RECURSE ExcludeKey1=FILE|%localappdata%\Pando\Pando Files|*Pando.prev.log;pando.save;pando.txt;pando.prev.log;pando.sav;pando.log ExcludeKey2=PATH|%localappdata%\Pando\Pando Files\Cert|*.* Link to comment Share on other sites More sharing options...
SMalik Posted June 21, 2013 Share Posted June 21, 2013 New Entry [Tag&Rename 3.7*] LangSecRef=3024 Detect=HKCU\Software\Softpointer\Tag&Rename3.7\Config Default=False FileKey1=%Music%|*.jpg RegKey1=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FCurrentFolder RegKey2=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FHistoryList RegKey3=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FileListHeader RegKey4=HKCU\Software\Softpointer\Tag&Rename3.7\Config|HistoryList Can we combine all the Tag&Rename entries somehow? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 21, 2013 Author Share Posted June 21, 2013 I suppose we could make one big entry that cleared all of the paths, but it would require the hard coding of the paths (2,3,3.7, and any future paths) as regkeys don't support wildcards. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Fuebar Posted June 22, 2013 Share Posted June 22, 2013 [sublime Text 3 Session*] LangSecRef=3024 DetectFile=%APPDATA%\Sublime Text 3\ Default=False FileKey1=%APPDATA%\Sublime Text 3\Local|Session.sublime_session Link to comment Share on other sites More sharing options...
Hav0c Posted June 24, 2013 Share Posted June 24, 2013 Bit more language files to be removed. [COMODO Internet Security (Lng)*] Section=Language Files Detect=HKCU\Software\ComodoGroup Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\COMODO\COMODO Internet Security\translations|*.lang ExcludeKey1=FILE|%ProgramFiles%\COMODO\COMODO Internet Security\translations|*.english.* [NVIDIA GeForce Experience (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\NVIDIA Corporation\Global\GFEClient Default=False Warning=This will delete all language files excluding English. FileKey1=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\cs-CZ|*.*|REMOVESELF FileKey2=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\da-DK|*.*|REMOVESELF FileKey3=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\de-DE|*.*|REMOVESELF FileKey4=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\el-GR|*.*|REMOVESELF FileKey5=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\es-ES|*.*|REMOVESELF FileKey6=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\es-MX|*.*|REMOVESELF FileKey7=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\fi-FI|*.*|REMOVESELF FileKey8=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\fr-FR|*.*|REMOVESELF FileKey9=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\hu-HU|*.*|REMOVESELF FileKey10=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\it-IT|*.*|REMOVESELF FileKey11=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\ja-JP|*.*|REMOVESELF FileKey12=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\ko-KR|*.*|REMOVESELF FileKey13=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\nb-NO|*.*|REMOVESELF FileKey14=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\nl-NL|*.*|REMOVESELF FileKey15=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\pl-PL|*.*|REMOVESELF FileKey16=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\pt-BR|*.*|REMOVESELF FileKey17=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\pt-PT|*.*|REMOVESELF FileKey18=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\ru-RU|*.*|REMOVESELF FileKey19=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\sk-SK|*.*|REMOVESELF FileKey20=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\sl-SI|*.*|REMOVESELF FileKey21=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\sv-SE|*.*|REMOVESELF FileKey22=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\th-TH|*.*|REMOVESELF FileKey23=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\tr-TR|*.*|REMOVESELF FileKey24=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\zh-CHS|*.*|REMOVESELF FileKey25=%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience\zh-CHT|*.*|REMOVESELF FileKey26=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\cs-CZ|*.*|REMOVESELF FileKey27=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\da-DK|*.*|REMOVESELF FileKey28=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\de-DE|*.*|REMOVESELF FileKey29=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\el-GR|*.*|REMOVESELF FileKey30=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\es-ES|*.*|REMOVESELF FileKey31=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\es-MX|*.*|REMOVESELF FileKey32=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\fi-FI|*.*|REMOVESELF FileKey33=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\fr-FR|*.*|REMOVESELF FileKey34=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\hu-HU|*.*|REMOVESELF FileKey35=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\it-IT|*.*|REMOVESELF FileKey36=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\ja-JP|*.*|REMOVESELF FileKey37=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\ko-KR|*.*|REMOVESELF FileKey38=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\nb-NO|*.*|REMOVESELF FileKey39=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\nl-NL|*.*|REMOVESELF FileKey40=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\pl-PL|*.*|REMOVESELF FileKey41=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\pt-BR|*.*|REMOVESELF FileKey42=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\pt-PT|*.*|REMOVESELF FileKey43=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\ru-RU|*.*|REMOVESELF FileKey44=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\sk-SK|*.*|REMOVESELF FileKey45=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\sl-SI|*.*|REMOVESELF FileKey46=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\sv-SE|*.*|REMOVESELF FileKey47=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\th-TH|*.*|REMOVESELF FileKey48=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\tr-TR|*.*|REMOVESELF FileKey49=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\zh-CHS|*.*|REMOVESELF FileKey50=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\zh-CHT|*.*|REMOVESELF FileKey51=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\ar-AE|*.*|REMOVESELF FileKey52=%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*\he-IL|*.*|REMOVESELF ExcludeKey1=PATH|%ProgramFiles%\NVIDIA Corporation\NVIDIA GeForce Experience|en-GB;en-US ExcludeKey2=PATH|%ProgramFiles%\NVIDIA Corporation\Installer2\Display.GFExperience*|en-GB;en-US Any suggestions on how to “clean up” the NVIDIA GeForce Experience (Lng) ? Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 25, 2013 Author Share Posted June 25, 2013 Sorry guys, I'm in a rush today. I've updated but I forgot to check the forums thread to include entries, so most of them are probably missing. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 25, 2013 Share Posted June 25, 2013 Thanks for the update. Revised entry. Changed the entry name from [Registry First Aid 8 (Backups)*] to [Registry First Aid 9 (Backups)*] [Registry First Aid 9 (Backups)*] LangSecRef=3024 Detect=HKCU\Software\KsL Software\RFA Default=False FileKey1=%CommonAppData%\RFA_Backups|*.*|RECURSE You forgot to add this one: [Tag&Rename 3.7*] LangSecRef=3024 Detect=HKCU\Software\Softpointer\Tag&Rename3.7\Config Default=False FileKey1=%Music%|*.jpg RegKey1=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FCurrentFolder RegKey2=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FHistoryList RegKey3=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FileListHeader RegKey4=HKCU\Software\Softpointer\Tag&Rename3.7\Config|HistoryList Link to comment Share on other sites More sharing options...
JDPower Posted June 26, 2013 Share Posted June 26, 2013 Sorry guys, I'm in a rush today. I've updated but I forgot to check the forums thread to include entries, so most of them are probably missing. Is it just me that's getting screwy formatting in the winapp2 update, it's all just one continuous line when opening with notepad Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 26, 2013 Author Share Posted June 26, 2013 haha yeah wow it's a total mess in notepad winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted June 26, 2013 Share Posted June 26, 2013 Is it just me that's getting screwy formatting in the winapp2 update, it's all just one continuous line when opening with notepad That is the reward for using Windows to look at a Unix style file which concludes each line with "0x0A" instead of "0x0d,0x0A" You can either use MetaPad instead of Notepad, or rename the file as WinApp2.txt and then launch CMD.EXE and select the relevant folder and run the command MORE WinApp2.txt > WinApp2.ini Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 26, 2013 Moderators Share Posted June 26, 2013 So Notepad is still quite feeble even in newer OSes, ah. I agree with Alan on using MetaPad, I've used it for years and have never bothered with Notepad since. Link to comment Share on other sites More sharing options...
APMichael Posted June 26, 2013 Share Posted June 26, 2013 Sorry guys, I'm in a rush today. I've updated but I forgot to check the forums thread to include entries, so most of them are probably missing. Thanks for the update! Here they come: #3196, #3197, #3205, #3206, #3208 Link to comment Share on other sites More sharing options...
SMalik Posted June 27, 2013 Share Posted June 27, 2013 (edited) New Entry [Foxit PhantomPDF 6 More*] LangSecRef=3021 Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0 Default=False RegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\Recent File List RegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\RecentFiles Revised Entry Changed the entry name from [Foxit Reader 6.0 More*] to [Foxit Reader 6 More*] [Foxit Reader 6 More*] LangSecRef=3021 Detect=HKCU\Software\Foxit Software\Foxit Reader 6.0 Default=False FileKey1=%AppData%\Foxit Software\Foxit Reader\StartPage\Start|history.txt RegKey1=HKCU\Software\Foxit Software\Foxit Reader 6.0\Preferences\History\Options Edited June 27, 2013 by saad2011 Link to comment Share on other sites More sharing options...
ProPaan Posted June 27, 2013 Share Posted June 27, 2013 text not updated in first post : Link to download Winapp2.ini Version: v4.02.130527 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 27, 2013 Author Share Posted June 27, 2013 fixed the first post winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Guest Keatah Posted June 28, 2013 Share Posted June 28, 2013 Since there is an entry for Ultimate Defrag by Disktrix, might as well make it complete by adding the line in bold. This is a crashdump logfile and is created if Ultimate Defrag crashes. [ultimate Defrag*] LangSecRef=3024 DetectFile=%ProgramFiles%\Disktrix\UltimateDefrag\Udefrag.exe Default=False FileKey1=%ProgramFiles%\Disktrix\UltimateDefrag|*.db FileKey2=%ProgramFiles%\Disktrix\UltimateDefrag|*Crash.dmp Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 30, 2013 Moderators Share Posted June 30, 2013 Updated, it will now get rid of all logs recursively: [Cook'n Recipe Organizer (Logs)*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Cook'n DetectFile=%LocalAppData%\DVO\Cook'n10App\Cook'n.exe Default=False FileKey1=%Documents%\Cook'n10|*.log|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 30, 2013 Author Share Posted June 30, 2013 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Neil79 Posted July 3, 2013 Share Posted July 3, 2013 Please add this to winapp2.ini to clean xbmc thumbnails of previously viewed movies/clips [XBMC Thumbnails*] LangSecRef=3023 DetectFile=%AppData%\xbmc Default=False FileKey1=%AppData%\xbmc\userdata\thumbnails|*.*|RECURSE FileKey2=%AppData%\xbmc.old\userdata\thumbnails|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted July 4, 2013 Share Posted July 4, 2013 New Entries LSys (Local System) [LSys Cached File Extensions*] LangSecRef=3025 Detect=HKU\.DEFAULT\Software\Microsoft\Windows Default=False RegKey1=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts [LSys Cached Shell Extensions*] LangSecRef=3025 Detect=HKU\.DEFAULT\Software\Microsoft\Windows Default=False RegKey1=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 4, 2013 Author Share Posted July 4, 2013 Is this related to the existing File/Shell exts? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
