Moderators Andavari 1 Posted April 1, 2012 Moderators Share Posted April 1, 2012 So I wait a couple of days and get the FileHippo one with nothing bundled... just easier I guess. Getting the installers from FileHippo is significantly easier! I just wish FileHippo also hosted the Flash Uninstaller, then I wouldn't bother with Adobe's site. Link to post Share on other sites
Willy2 0 Posted April 1, 2012 Author Share Posted April 1, 2012 All the newest versions are either Betas or Release Candidates (RC). Seems Adobe knows Flash needs to be (dramatically) improved. Don't know if I am going to install the latest version any time soon. But the Adobe website also said that v11.1 wasn't succesfully installed on my laptop. Ouch. I guess I'll try to re-install v11.1 properly first. @Andavari: Very good idea. The Flash uninstaller should be available at Filehippo as well. But then the 32 bit and 64 bit uninstaller version should merged into one program and that's not the case, according to Adobe. Still some work to be done for Adobe. The wesbite has become (a bit) more user friendly. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators Nergal 0 Posted April 2, 2012 Moderators Share Posted April 2, 2012 No, the version they mention is not beta nor alpha, http://get.adobe.com/flashplayer/ Adobe Flash Player 11.2.202.228 (3.93 MB) Your system: Windows 32-bit , English, MSIE ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
login123 0 Posted April 2, 2012 Share Posted April 2, 2012 Is there a good alternative to adobe flash player for wxp? That will open both website and local files? I would like to be totally free of adobe software. Thanks in advance. The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to post Share on other sites
Alan_B 0 Posted April 2, 2012 Share Posted April 2, 2012 A bit faster. Why use FileHippo and not the official site (http://get.adobe.com/flashplayer/)? Because Adobe = Malware. A few years ago their site substituted for the Flash Download a Downloader, which then chose what part of my system it would pollute with itself and with the "Flash Download" that it insisted upon managing itself. At that time there was no way to update Flash without the extra malware. I chose to restore my partition backup and live with the known vulnerabilities of an obsolete Flash Trash rather than trust my system to unknown but guaranteed to be present vulnerabilities of the latest Flash Trash, and that also eliminated their unwanted downloader. Link to post Share on other sites
Alan_B 0 Posted April 2, 2012 Share Posted April 2, 2012 The Flash uninstaller should be available at Filehippo as well. If only. They supply the trash, but not the means to remove it. When I search FileHippo they only offer various Adobe products, plus 5 off Google Ads to websites I have never heard off. Quite independant of FileHippo I found this http://www.softpedia...installer.shtml Link to post Share on other sites
Moderators Nergal 0 Posted April 2, 2012 Moderators Share Posted April 2, 2012 Because Adobe = Malware. Please be sure to place your opinions in Opinion tags Adobe is not Malware, it's just at times badly written, full of holes and a multiplatform standard so a huge and BROAD malware vector. ( <----- See Not opinion solely facts ) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Alan_B 0 Posted April 2, 2012 Share Posted April 2, 2012 Please be sure to place your opinions in Opinion tags Adobe is not Malware, it's just at times badly written, full of holes and a multiplatform standard so a huge and BROAD malware vector. ( <----- See Not opinion solely facts ) I accept your correction. I would however point out that the only mechanism I could depend upon to remove every trace of their download manager, was the mechanism I will use if my system is ever infected with a virus, i.e. restoring a partition image backup. http://en.wikipedia.org/wiki/Duck_test when I see a bird that walks like a duck and swims like a duck and quacks like a duck, I call that bird a duck Link to post Share on other sites
Moderators Nergal 0 Posted April 2, 2012 Moderators Share Posted April 2, 2012 That's just what duck hunters want you to think ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
login123 0 Posted April 3, 2012 Share Posted April 3, 2012 Is there a good alternative to adobe flash player for wxp? That will open both website and local files? I would like to be totally free of adobe software. Thanks in advance. Guess not. I have looked around quite a bit, cannot seem to find an effective replacement. Pity. Would really love to be wrong about that, and to be apprised of a good alternative. . The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to post Share on other sites
Moderators Andavari 1 Posted April 3, 2012 Moderators Share Posted April 3, 2012 Guess not. I have looked around quite a bit, cannot seem to find an effective replacement. Pity. Would really love to be wrong about that, and to be apprised of a good alternative. . Same here. There's Microsoft's Silverlight, but I refuse to ever install it since the only site I've seen that "needs" it is Microsoft.com. Link to post Share on other sites
nodles 0 Posted April 3, 2012 Share Posted April 3, 2012 Same here. There's Microsoft's Silverlight, but I refuse to ever install it since the only site I've seen that "needs" it is Microsoft.com. Same! Link to post Share on other sites
login123 0 Posted April 4, 2012 Share Posted April 4, 2012 There is an oldies radio station that "needs" it, so I just install it whenever I want to listen, and Powershadow dumps it on restart. The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to post Share on other sites
pcunite 0 Posted April 7, 2012 Share Posted April 7, 2012 Haven't noticed this. Btw. latest Flash version is 11.2.202.228. That version caused me no end of trouble with IE8 for some reason. I had to revert to the previous version of Flash. Link to post Share on other sites
Moderators hazelnut 5 Posted April 7, 2012 Moderators Share Posted April 7, 2012 That version caused me no end of trouble with IE8 for some reason. I had to revert to the previous version of Flash. Did you uninstall the previous version first or did you install over the top of it? CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
pwillener 0 Posted April 9, 2012 Share Posted April 9, 2012 The Adobe site also provides full (offline) installers without bundled software: http://www.adobe.com/products/flashplayer/distribution3.html The uninstallers can be found at http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html (Windows) or http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-mac-os.html (Mac). Link to post Share on other sites
pcunite 0 Posted April 9, 2012 Share Posted April 9, 2012 Did you uninstall the previous version first or did you install over the top of it? At first, I did as I normally do; I went to Adobe's website and installed the latest version (over the top). When all my home computers starting having browser lockups, I remembered I had updated flash. Then I manually uninstalled Flash, downloaded the previous version, and then ran the install .exe directly for it. Link to post Share on other sites
pwillener 0 Posted April 13, 2012 Share Posted April 13, 2012 New Flash Player versions can often cause various problems when used in conjunction with outdated graphics drivers. Link to post Share on other sites
Willy2 0 Posted January 12, 2013 Author Share Posted January 12, 2013 Adobe's Flash is used by (almost) everyone. But how many users have Shockwave installed ? Is it still relevant ? About the differences between Flash and Shockwave: http://www.askdavetaylor.com/the_difference_between_flash_and_shockwave.html http://www.howstuffworks.com/web-animation6.htm System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators Andavari 1 Posted January 13, 2013 Moderators Share Posted January 13, 2013 Adobe's Flash is used by (almost) everyone. But how many users have Shockwave installed ? Is it still relevant ? Haven't used Shockwave since I think near the end of me using Win98. Link to post Share on other sites
