Willy2 0 Posted June 29, 2010 Share Posted June 29, 2010 I have installed several RC versions of Adobe Flash 10, starting in, say february of this year. But these are Release Candidates and I wanted to un-install those versions but the un-install programs seem to do a lousy job. I used the -force option and that supposedly would get rid of all that Flash software. When I try to install a previous version of Flash the installation program simply refuses to install that older software. The install program tells me that I should go to the website and download and use the latest version. And that's precisely what I don't want. The problem is that those versions 10 seem to take CPU usage to (very) high levels. It seems somewhere in the registry there's an entry that records which Flash version was previously installed. But I haven't found those entries (yet). Does anyone have a solution ? Does anyone know what to wipe in the registry ? System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators hazelnut 6 Posted June 29, 2010 Moderators Share Posted June 29, 2010 Do you still have anything listed here? C:\WINDOWS\system32\Macromed\Flash\ CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Willy2 0 Posted June 29, 2010 Author Share Posted June 29, 2010 Yes, that folder still contains a number of files after un-installing Flash. Should I delete those files ? Some seem to be in use by Explorer (?) and refuse to be deleted. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators hazelnut 6 Posted June 29, 2010 Moderators Share Posted June 29, 2010 What flash entry is listed there? CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Willy2 0 Posted June 29, 2010 Author Share Posted June 29, 2010 When I install Flash 10.1.53.64 the following files appear: Flash10h.ocx FlashUtil10h_ActiveX.dll FlashUtil10h_ActiveX.exe FlashInstall.log And only the *.ocx file doesn't want to be removed/deleted. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators hazelnut 6 Posted June 29, 2010 Moderators Share Posted June 29, 2010 Have a look here http://forums.techarena.in/windows-xp-support/936506.htm CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Willy2 0 Posted June 29, 2010 Author Share Posted June 29, 2010 Thanks. Info from that page solved the problem. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Willy2 0 Posted July 1, 2010 Author Share Posted July 1, 2010 Unregistering those Adobe Flash files allowed me to delete those files and to perform a new ""clean"" installation of Flash 10.1. Even a re-installation of the latest Flash RC 10.1.53,64 version went well. This ""clean"" installation also solved the problem of CPU usage going up to 100% and staying there, in Windows Explorer. CPU usage now also sometimes can go up significantly but not to the extreme levels as seen before. I think there were some remnants of older versions of Flash and that caused - IMO - the problem to occur. So, it's VERY important to get rid of the old Flash version(s) before installing a new version. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators hazelnut 6 Posted July 1, 2010 Moderators Share Posted July 1, 2010 Good to hear it's all well for you now Willy. Flash can cause many problems as users have found. Unregistering and deleting old stubborn installs can clear up lots of other issues too. CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Willy2 0 Posted August 15, 2010 Author Share Posted August 15, 2010 The lastest version Adobe Flash (10.1.82.76) can be considered to be an dramatic improvement over all the previous 10.1 versions. Up to now, on my PC, it didn't push CPU usage up to 100% like the previous versions did. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators Andavari 1 Posted August 15, 2010 Moderators Share Posted August 15, 2010 I always uninstall Flash with Revo Uninstaller Free, then run Adobe's Flash Player Uninstaller which is a separate download, and then reboot. After all that it's safe to install a new Flash Player version. Link to post Share on other sites
Willy2 0 Posted August 15, 2010 Author Share Posted August 15, 2010 I think I need to elaborate. Up to version 10.1 (not including v10.1) I never had any problem installing a new version of Adobe Flash without un-installing the previous version. I just installed the new version and that always worked. But with v10.1 the problems started (I never could go back to a previous version and CPU usage would (sooner or later) go up to 100%). But that seems to be fixed in the latest version. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Willy2 0 Posted August 16, 2010 Author Share Posted August 16, 2010 I recently found out that the combination of Apple's Quicktime and Flash 10.1 was the cause for pushing up CPU usage up to 100% when I opened certain folders with Windows Explorer. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators hazelnut 6 Posted August 17, 2010 Moderators Share Posted August 17, 2010 I recently found out that the combination of Apple's Quicktime and Flash 10.1 was the cause for pushing up CPU usage up to 100% when I opened certain folders with Windows Explorer. That's quite an interesting thing to have come across Willy. What have you done now you've found that out? Uninstalled Quicktime, or just accept the problem as you know what it causing it? CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
pwillener 0 Posted August 17, 2010 Share Posted August 17, 2010 I recently found out that the combination of Apple's Quicktime and Flash 10.1 was the cause for pushing up CPU usage up to 100% when I opened certain folders with Windows Explorer. Does this still happen with the latest QuickTime version 7.6.7? Link to post Share on other sites
Willy2 0 Posted August 17, 2010 Author Share Posted August 17, 2010 I didn't like Apple's Quicktime (including v7.67) performance anyway in the last, say 12 months. When I played a video, the video part of a *.MP4 file could freeze up (especially with large video sizes), in combination with high CPU usage. And then QT barely responded anymore. So, recently I ditched QT and started using an other mediaplayer to play *.MP4 files. That's when I found out that CPU usage wouldn't go up to 100% anymore when I opened certain folders with Windows Explorer. To confirm it, I re-installed QT and yes, the CPU usage problem reared it's ugly head again. So, no more Quicktime for me. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Willy2 0 Posted January 5, 2011 Author Share Posted January 5, 2011 It seems that the folks at Adobe have improved the Flash software. I recently needed Quicktime because I downloaded a *.MOV video and therefore I needed to re-install Quicktime. Now the ugly combination of *.flv files and Quicktime doesn't push CPU usage up to 100% anymore (/less often (???)). Thanks to Defraggler I am able to open the temporary internet folders and move *.flv files from there to another folder. Windows simply doesn't allow the user to open those special folders. But after using Quicktime I nearly always remove QT again. The program simply sucks (as explained above). System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
login123 0 Posted January 6, 2011 Share Posted January 6, 2011 ... But after using Quicktime I nearly always remove QT again. The program simply sucks (as explained above). Both VLC player HERE and MPlayer HERE will play .mov and .flv files. If you like them, it might save you a bunch of uninstalling. The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to post Share on other sites
Willy2 0 Posted January 6, 2011 Author Share Posted January 6, 2011 @Login123, Thanks for the suggestion !!! System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
login123 0 Posted January 7, 2011 Share Posted January 7, 2011 You're welcome, Willy2. Turns out there may be a vulnerability in VLC Player. Never happened here, and soon to be fixed by ver 1.1.6. Read about it HERE The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to post Share on other sites
Willy2 0 Posted April 1, 2012 Author Share Posted April 1, 2012 Adobe Flash has advanced to version 11.1.102.62. But it still sucks. When I open a folder with one or more *.FLV files in it then Windows (XP) becomes (more) sluggish / less responsive and it takes Windows Explorer (significant) more time to display the content of those (and other) folders. It also takes XP (significantly) more time to switch between running programs. Taskmanager shows that from time to time CPU usage spikes up higher and usage even can reach 100% for a number of minutes. I extract those *.FLV files from the temporary internet files folders. I didn't install Quicktime with this or the previous version of Flash. So, that's not the cause for this sluggish behaviour. Do other user have similar problems ? System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
nodles 0 Posted April 1, 2012 Share Posted April 1, 2012 Haven't noticed this. Btw. latest Flash version is 11.2.202.228. Link to post Share on other sites
Moderators hazelnut 6 Posted April 1, 2012 Moderators Share Posted April 1, 2012 Latest flash version is11.2.202 .228 http://www.filehippo.com/download_flashplayer_ie/ Perhaps have try with the new version. CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
nodles 0 Posted April 1, 2012 Share Posted April 1, 2012 A bit faster. Why use FileHippo and not the official site (http://get.adobe.com/flashplayer/)? Link to post Share on other sites
Moderators hazelnut 6 Posted April 1, 2012 Moderators Share Posted April 1, 2012 Sometimes navigating the Adobe site can be a minefield there are so many Adobe sites with conflicting info on when a new build comes out, sometimes the download page even downloads the old version So I wait a couple of days and get the FileHippo one with nothing bundled... just easier I guess. Plus any reports about problems with the new version will have been put on different forums by then CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
