CCleaner Community Forums
Winapp2.ini additions
The [Windows Shellbags*] re-addition is another one of those irritating "Why is my File Explorer not maintaining the view settings I set up for it?" items that filter into Winapp2.ini.  It causes the view size of File Explorer to go back to the default and also removes any user added columns from a user's File Explorer.  I know there is a warning message in the code; however, I do not think registry key cleaning benefits warrant the potential user irritation factor from having to spend time figuring out why view settings are not be retained....particularly if a user is not really computer savvy.
My vote is to take [Windows Shellbags*] back out.
And I would like to see [MS Notepad*] for the same reason.
JMO.  <_<
Link to post
  • Moderators
Remove Entry:
[Kodak AiO Software Disable Startup*]
LangSecRef=3021
Detect1=HKLM\Software\Eastman Kodak Company\KODAK AiO Home Center
Detect2=HKLM\Software\Kodak\Kodak AiO Software
Warning=Disables the Kodak AiO Software from automatically starting with Windows. Every time you print, it will re-enable itself to start with Windows.
Default=False
RegKey1=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|EKAIO2StatusMonitor
RegKey2=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|EKStatusMonitor
It does nothing other then just keep resetting the auto startup.
I made that cleaner, and find it very useful because I don't want the Kodak software running when I start Windows.
Link to post
  • Moderators
If people would leave certain warnings in, then people would know what it does instead of having a very long name for the cleaner. In particular the MS Notepad cleaner originally had this warning in that explained what it does when I made it, although I realize it would rarely need to be used:
[MS Notepad*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Notepad
Default=False
Warning=If Notepad stops remembering your window size settings using this cleaner will reset it back to the original Windows default size.
RegKey1=HKCU\Software\Microsoft\Notepad|iWindowPosDX
RegKey2=HKCU\Software\Microsoft\Notepad|iWindowPosDY
RegKey3=HKCU\Software\Microsoft\Notepad|iWindowPosX
RegKey4=HKCU\Software\Microsoft\Notepad|iWindowPosY
Link to post
[MS Notepad*]
LangSecRef=3025
Default=False
But is that the real purpose/function of CCleaner?  I've always felt that CCleaner's purpose for the general public is to remove junk files (and registry keys) that are no longer used/needed by the user's system.
Link to post
JMO.  <_<
All known and popular privacy eraser programs today have this included. They have this included since those programs were introduced in Windows XP. I can write all of those programs' names here. Have you ever looked at that path in the Windows Registry? It grows very large, it is always recommended to remove those traces. If you don't like this entry, you can always uncheck it.
Link to post
I added HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders to the CCleaner Exclude option and that prevents this cleaning code from deleting File Explorer's view settings and user added columns.  And it allows cleaning all the other keys that you rightfully are concerned about.   :)
How about modifying [Windows Shellbags*] to
Added ExcludeKey1/2 and eliminated the warning
[Windows ShellBags*]
LangSecRef=3025
Detect1=HKCU\Software\Microsoft\Windows
Detect2=HKCU\Software\Microsoft\Windows\ShellNoRoam
Default=False
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU
RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags
RegKey3=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU
RegKey4=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags
ExcludeKey1=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell
ExcludeKey2=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders\Shell
Link to post
JMO.  <_<
Why not keep a separate file of dangerous or not widely needed or wanted entries.
Link to post
It seems that winapp2.ini development is not getting updated.  Is the correct web address to copy from:
https://raw.githubusercontent.com/MoscaDotTo/Winapp2/ee06a5132c3b979c40dd028f236af2849b76b20a/Development/Winapp2
I copied the file this AM and the header is:
=== begin paste ===
; Version: 170329
; # of entries: 2,571
; You can get the latest Winapp2 here: https://github.com/MoscaDotTo/Winapp2
; Any contributions are appreciated. Please send them to the link above.
; Is CCleaner taking too long to load with Winapp2? Please head to this link and follow the instructions: http://www.winapp2.com/howto.html
; Valid commands can be found on the first post here: https://forum.piriform.com/index.php?showtopic=32310
; Please do not host this file anywhere without permission. This is to facilitate proper distribution of the latest version. Thanks.
=== end paste ===
but I recall an update being announced a few days after 17-03-29......
Link to post
  • Moderators
If CCleaner had a general Fix section like some tools have maybe so because most people aren't going to know how to fix certain things, and it makes it very easy for them, and it avoids them having to go into RegEdit.
Link to post
Isn't there an option to just disable it?
[MS Notepad*]
LangSecRef=3025
Default=False
The warning is in there..
I have a plan to make a Winapp3, that will be exactly like that, and taking some cleaners from the unofficial winsys.ini file, but that probably won't happen for a while yet. First I want to finish overhauling Winapp2.
Link to post
LangSecRef=3025
Default=False
Gets my vote ;)
Link to post
Do we need 2 detects on the Windows Shellbags? The first detect covers the whole Windows registry section, including the ShellNoRoam entry that is in the 2nd detect. Maybe just one or the other is fine.
Link to post
  • Moderators
I agree, whichever is most specific without detecting the exact thing that's removed. (This sounded better in my head than it probably reads)
Link to post
One detect works for me.  ;)
Link to post
  • Moderators
In regards to the Kodak AIO Software, no there isn't any option to disable it.
As soon as you print anything it automatically puts itself back into the registry to always run on startup and I don't like that behavior - hence the reason that cleaner is very useful to disable it with a simple click of the Run Cleaner button as it involves no registry editing or hunting down the Run section in the registry.
Edit:
And MSConfig is of no help either to disable it, because you'll only end up with orphaned disabled entries in the registry for disabled startups of it.
Link to post
> master
   "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini"
> development
   "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/ee06a5132c3b979c40dd028f236af2849b76b20a/Development/Winapp2"
          The winapp2.ini I copied from the master link above has: Version: v5.26.170306
The winapp2.ini I copied from the development link above has: Version: 170329
Why is the one from today not available?
Link to post
Modified entry:  [Cyberlink PowerDVD 16/17*]
Added FileKey7
[CyberLink PowerDVD 16/17*]
LangSecRef=3023
Detect1=HKCU\Software\CyberLink\PowerDVD16
Detect2=HKCU\Software\CyberLink\PowerDVD17
Default=False
FileKey1=%LocalAppData%\Cyberlink\PowerDVD*\cache\|*.*
FileKey2=%CommonAppData%\Cyberlink\Evoparser\|*.xml
FileKey3=%LocalAppData%\Cyberlink\PowerDVD*\caches\|*.*|RECURSE
FileKey4=%LocalAppData%\Cyberlink\PowerDVD*\CL_DMP_Browser\|*.*|RECURSE
FileKey5=%LocalAppData%\Cyberlink\DigitalHome\|*.log|RECURSE
FileKey6=%LocalAppData%\Cyberlink\PowerDVD*\|*.log|RECURSE
FileKey7=%CommonAppData%\install_backup\*\|*.log
Link to post
Modified Entry:  [DriverMax*]
Added FileKey8
[DriverMax*]
LangSecRef=3024
Detect=HKCU\Software\Innovative Solutions\DriverMax
Default=False
FileKey1=%LocalAppData%\Innovative Solutions\DriverMax\Agent\Downloded Drivers|*.*
FileKey2=%LocalAppData%\Innovative Solutions\DriverMax\Agent\Uploads|*.*|RECURSE
FileKey3=%LocalAppData%\Innovative Solutions\DriverMax\Backup|*.*
FileKey4=%LocalAppData%\Innovative Solutions\DriverMax\LastScan|*.*
FileKey5=%LocalAppData%\Innovative Solutions\DriverMax\Temp|*.*
FileKey6=%LocalAppData%\Innovative Solutions\DriverMax\TempBackup|*.*
FileKey7=%LocalAppData%\Innovative Solutions\DriverMax\Agent|dmxlog.txt
FileKey8=%LocalAppData%\Innovative Solutions\DriverMax\Agent\|*.tmp
Link to post
Modified entry:  [Malwarebytes Anti-Malware*]
Added FileKey8
LangSecRef=3024
Detect=HKCU\Software\Malwarebytes
DetectFile=%ProgramFiles%\Malwarebytes Anti-Malware\mbam.exe
Default=False
Warning=You must manually and temporarily turn off Malwarebytes "self-protection" to remove the logs.
FileKey1=%AppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.*
FileKey2=%LocalAppData%\VirtualStore\ProgramData\Malwarebytes\Malwarebytes*Anti-Malware\Logs|*.*
FileKey3=%LocalAppData%\VirtualStore\ProgramData\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe
FileKey4=%CommonAppData%\Malwarebytes\Malwarebytes*Anti-Malware\Logs|*.*
FileKey5=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe
FileKey6=%CommonAppData%\Malwarebytes\MBAMService|*.log;*.bak
FileKey7=%CommonAppData%\Malwarebytes\MBAMService\logs|*.*
FileKey8=%CommonAppData%\Malwarebytes\MBAMService\ScanResults|*.*
Link to post
> master
> development
??? Please check my reply to your last post. Thanks.
https://forum.piriform.com/index.php?showtopic=32310&p=282584
Link to post
New Entry:  ​[MS Office 2013/16 ClickToRun Update Files*]
NOTE:  This code might also work for MS Office 2010; however, I do not have a MS Office 2010 installation to test...so I cannot confirm.  If someone has MS Office 2010 locally installed on their system to test it, that would be great.  You would need to change the Detects to:
Detect1=HKCU\Software\Microsoft\Office\14.0
Detect2=HKCU\Software\Microsoft\Office\15.0
Detect3=HKCU\Software\Microsoft\Office\16.0
This code ONLY applies to locally installed MS Office.  There are many megabytes of files in the ProductRelease folder following each Office update.  So this will clean a large volume of files on the user's first run of CCleaner with this code active.
LangSecRef=3021
Detect1=HKCU\Software\Microsoft\Office\15.0
Detect2=HKCU\Software\Microsoft\Office\16.0
Default=False
FileKey1=%CommonAppData%\Microsoft\ClickToRun\ProductReleases\|*.*|RECURSE|
Link to post
  • Moderators
ClickToRun only came out for Office 365, which would mean only Office 2013 and later are effected.
Link to post
Register a new account
Sign in
