CCleaner Community Forums
Winapp2.ini additions
New entry:   [Acrok Video Converter Ultimate*]
LangSecRef=3023
Detect=HKCU\Software\Acrok Software\Acrok Video Converter Ultimate
Default=False
FileKey1=%UserProfile%\.BDAccess\|*.*|RECURSE|
FileKey2=%AppData%\Acrok\Acrok Video Converter Ultimate\log|*.*
Link to post
Please don't forget to include this modified entry:  [Windows Installer Temps*]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Installer
Default=False
FileKey1=%WinDir%\Installer|*.tmp|RECURSE
FileKey2=%WinDir%\Installer|*.rmi|RECURSE
FileKey3=%WinDir%\Installer|SourceHash{*.*|RECURSE
FileKey4=%WinDir%\Installer\*.tmp-|*.*|REMOVESELF
FileKey5=%WinDir%\Installer\MSI*.tmp-|*.*|REMOVESELF
FileKey6=%WinDir%\Installer\MSI*|*.*|REMOVESELF
Link to post
LangSecRef=3025
Default=False
FileKey2 is equivalent to [wix Files*]
FileKey3 is equivalent to [sourceHash Files*]
FileKey5 should be enough, and it's safe. FileKey4+6 are not really needed. (And FileKey6 could be possibly dangerous.)
Link to post
so it should be:
LangSecRef=3025
Default=False
FileKey2=%WinDir%\Installer\MSI*.tmp-|*.*|REMOVESELF
Link to post
I think [sourceHash Files*] and [wix Files*] entries should be merged into [Windows Installer Temps*]. Also, please add support for .rmi traces.
LangSecRef=3025
Default=False
FileKey1=%WinDir%\Installer\MSI*.tmp-|*.*|REMOVESELF
FileKey4=%WinDir%\Installer|*.tmp|RECURSE
Link to post
LangSecRef=3025
Default=False
(Note: .rmi = [wix Files*])
My suggestion for merging [Windows Installer Temps*], [sourceHash Files*] and [wix Files*]:
LangSecRef=3025
Default=False
FileKey2=%WinDir%\Installer|*.tmp|RECURSE
FileKey3=%WinDir%\Installer|SourceHash{*};wix{*}.SchedServiceConfig.rmi
Link to post
Remove Duplicate
[WebSite-Watcher*]
LangSecRef=3021
Detect=HKCU\Software\aignes\wswatch
Default=True
FileKey1=%AppData%\aignes\WebSite-Watcher\bookmarks\bookmark_wsw|*.*|REMOVESELF
FileKey2=%AppData%\aignes\WebSite-Watcher\config\autobackup|*.zip
FileKey3=%AppData%\aignes\WebSite-Watcher\config\favicons|*.*
FileKey4=%AppData%\aignes\WebSite-Watcher\config\log|*.log
FileKey5=%AppData%\aignes\WebSite-Watcher\config\settings|*.cfg_bak*
FileKey6=%AppData%\aignes\WebSite-Watcher\config\temp|*.*
BUMP* sorry been a year, but this duplicate is still in the ini
Link to post
Perhaps you want to show both the entries that are being duplicated first, so we can compare them and make sure one doesn't have something the other doesn't.
Updated the others: https://github.com/MoscaDotTo/Winapp2/commit/caa3d292bc8b21bbef69c1663ab40136790f32ac
Link to post
Easy, search for the word "Website-Watcher" and you will find
[Aignes Website-Watcher AutoBackup*]
[Aignes Website-Watcher Bookmarks*]
[Aignes Website-Watcher*]
Link to post
Yes, but as you can see, none of them are exactly the same:
LangSecRef=3023
Warning=This will delete your AutoBackup of your site.
Detect=HKCU\SOFTWARE\aignes\wswatch
Default=False
FileKey1=%AppData%\aignes\website-watcher\config\autobackup|*.*
LangSecRef=3023
Warning=This will delete all of your Bookmarks.
Default=False
FileKey1=%AppData%\aignes\website-watcher\bookmarks|*.*
LangSecRef=3023
Default=False
FileKey1=%AppData%\aignes\website-watcher\config\log|*.*
FileKey2=%AppData%\aignes\website-watcher\config\temp|*.*
[WebSite-Watcher*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\aignes\WebSite-Watcher\config\favicons|*.*
FileKey2=%AppData%\aignes\WebSite-Watcher\config\settings|*.cfg_bak*
The bookmarks and backups should remain separate, in my opinion. The other 2 looks like they could be combined, but you should know that CCleaner is case-sensitive, so if the path is in lower case, then the upper case FileKeys will not work for the lower case directories. Do you know if they should be upper case or lower case? I assume they should be lower case, as the others are all lower case. I have not used this program to know what these entries truly do, but this is just my opinion.
I also think FileKey2=%AppData%\aignes\WebSite-Watcher\config\settings|*.cfg_bak* should be thrown into the backup entry instead, since that is a backup copy of a config file.
Link to post
Modified Entry:  [AVG PC TuneUp & Utilities CrashDumps*]
Added FileKey3
LangSecRef=3024
Detect1=HKCU\Software\TuneUp
Detect2=HKCU\Software\AVG\AWL\RegistryCleaner
Default=False
FileKey1=%AppData%\AVG\AWL*\CrashDumps|*.*
FileKey2=%AppData%\TuneUp Software\TuneUp Utilities\CrashDumps|*.*
FileKey3=%LocalAppData%\Avg\dumps\fmw1|*.*
Link to post
New Entry:
https://github.com/MoscaDotTo/Winapp2/pull/99
Some Fixes for Nvidia
https://github.com/MoscaDotTo/Winapp2/pull/98
But we have to discuss:
%CommonAppData%\NVIDIA Corporation*|.log;.bak;*.stat
%CommonAppData%\Nvidia*|*.bak
would be a nice reduce of entries, but i m not sure its OK to do that.
Link to post
Modified entry:  [Acrok Video Converter Ultimate*]
Added FileKey3
LangSecRef=3023
Default=False
FileKey3=%AppData%\Acrok\Acrok Video Converter Ultimate\|*.dmp
Link to post
  • 2 weeks later...
Wondershare changed the names of Wondershare Dr.Fone for Android to Wondershare dr.fone toolkit for Android and  Wondershare Dr.Fone for iOS to Wondershare dr.fone toolkit for iOS
Please replace [Wondershare Dr.Fone for Android*] and [Wondershare Dr.Fone for iOS*] entries with the ones listed below.
[Wondershare dr.fone toolkit for Android*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Wondershare\dr.fone toolkit for Android
Default=False
FileKey1=%CommonAppData%\Wondershare\DrFoneAndroid\log|*.*|RECURSE
FileKey2=%CommonAppData%\Wondershare\WAF\Log|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare\WAF\ProductFeatures\LocalLogs|*.*|RECURSE
FileKey4=%CommonAppData%\Wondershare\WAF\ProductFeatures\RemoteLogs|*.*|RECURSE
FileKey5=%CommonAppData%\Wondershare\WSRoot|*.tmp
FileKey6=%CommonAppData%\Wondershare\WSRoot\Logs|*.*|RECURSE
[Wondershare dr.fone toolkit for iOS*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Wondershare\dr.fone toolkit for iOS
Default=False
FileKey1=%CommonAppData%\Wondershare\DrFoneiOS\DBCache\NormalMode|*.*|RECURSE
FileKey2=%CommonAppData%\Wondershare\DrFoneiOS\log|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare\WAF\Log|*.*|RECURSE
FileKey4=%CommonAppData%\Wondershare\WAF\ProductFeatures\LocalLogs|*.*|RECURSE
FileKey5=%CommonAppData%\Wondershare\WAF\ProductFeatures\RemoteLogs|*.*|RECURSE
Link to post
New Entry
[JumpListIconsRecentClosed*]
LangSecRef=3029
SpecialDetect=DET_CHROME
Default=False
FileKey1=%LocalAppData%\Google\Chrome\User Data\Default\JumpListIconsRecentClosed|*.*|RECURSE
Link to post
Register a new account
Sign in
