ROCKNROLL Posted March 27, 2017 Share Posted March 27, 2017 The [Device Manager Cache XP*] code is now showing up on Windows 10 systems. [Device Manager Cache XP*] DetectOS=5.1| LangSecRef=3025 Default=False Warning=This clears cached drivers of connected devices. As soon as you connect a new device, this file regenerates. FileKey1=%WinDir%\inf|INFCACHE.1 I changed the DetectOS to DetectOS=|5.1 and it no longer shows up on Windows 10. HOWEVER, I have no way to determine if it shows up properly on XP systems after this change. So DetectOS only works if it is like this DetectOS=|X? I thought this was wrong because other entries have it like this DetectOS=X| I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 27, 2017 Share Posted March 27, 2017 The "Detect" is missing on this entry because the entry should always be present. The Config.msi folder pops in and out based on program installers. If you do a TRIM of Winapp2.ini at a time when Config.msi is not present on the drive because the last run installer properly cleaned up after itself, then you will not pick up the cleaning code so that it can cleanup a left over Config.msi until the next time your trim. Interesting. I didn't know CCleaner worked without a Detect either, but I guess i never really tested. I wonder if we can do this with other system entries, like logs and temp files, but only if it applies to all Windows systems, like temp files for example are the same from XP-10, as far as I am concerned. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
APMichael Posted March 27, 2017 Share Posted March 27, 2017 So DetectOS only works if it is like this DetectOS=|X? I thought this was wrong because other entries have it like this DetectOS=X| DetectOS should work as follows: #5365. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 27, 2017 Share Posted March 27, 2017 Interesting. I didn't know CCleaner worked without a Detect either, but I guess i never really tested. I wonder if we can do this with other system entries, like logs and temp files, but only if it applies to all Windows systems, like temp files for example are the same from XP-10, as far as I am concerned. In CCleaner, if you look under the Applications tab>Windows, you should find [Config.msi Folder*] which is just sitting waiting for a %systemdrive%\Config.msi to be created by an installer\uninstaller. As far as temp files or logs, you need to be careful to not force CCleaner to scan the entire drive looking for logs or temp files. But if there is a folder that gets created and is full of logs or temp files, then yes you can create code to clean out that folder and delete it and the code needs no Detect. It will show up on every system. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
dvdbane Posted March 28, 2017 Share Posted March 28, 2017 for [Device Manager Cache XP*], somehow the | changed location during this "Major update" so the correct entry should be [Device Manager Cache XP*] DetectOS=|5.1LangSecRef=3025Default=FalseWarning=This clears cached drivers of connected devices. As soon as you connect a new device, this file regenerates.FileKey1=%WinDir%\inf|INFCACHE.1 Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 28, 2017 Share Posted March 28, 2017 Updates: https://github.com/MoscaDotTo/Winapp2/commit/7ce37cb2add545593322362768aeb661d57b5813 https://github.com/MoscaDotTo/Winapp2/commit/37b73775519caafb8a5e363a9a7c022323dbce13 I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
siliconman01 Posted March 29, 2017 Share Posted March 29, 2017 There are duplicates showing up in the Chrome section. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted March 29, 2017 Share Posted March 29, 2017 There are duplicates showing up in the Chrome section. Also, [Application Cache*] Link to comment Share on other sites More sharing options...
APMichael Posted March 29, 2017 Share Posted March 29, 2017 Updates: https://github.com/MoscaDotTo/Winapp2/commit/7ce37cb2add545593322362768aeb661d57b5813 https://github.com/MoscaDotTo/Winapp2/commit/37b73775519caafb8a5e363a9a7c022323dbce13 Duplicate entry names are not working, even if they are in different sections. These entries are duplicates (one for Chrome and one for Firefox): [Crash Reports*] [html5 Storage*] [Logs*] [Temps*] [updates*] Link to comment Share on other sites More sharing options...
siliconman01 Posted March 29, 2017 Share Posted March 29, 2017 Duplicate entry names are not working, even if they are in different sections. These entries are duplicates (one for Chrome and one for Firefox): [Crash Reports*] [html5 Storage*] [Logs*] [Temps*] [updates*] Yep, duplicate names are not permitted. The bad part is that if Trim.bat encounters duplicate names, it may include both or it may omit both. So duplicate names can cause cleaning code to not be included in the final "trimmed" winapp2.ini Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 29, 2017 Share Posted March 29, 2017 Should be fixed: https://github.com/MoscaDotTo/Winapp2/commit/ee06a5132c3b979c40dd028f236af2849b76b20a https://github.com/MoscaDotTo/Winapp2/commit/67c0bdbcd6082ffff23db6eab5e9730b9a72d5d0 I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
APMichael Posted March 30, 2017 Share Posted March 30, 2017 Thanks for fixing! Forgot to move to Chrome section: [Extensions State*] Forgot to move to Firefox section: [Adblock Plus/Edge For Firefox*] [Archived Data Reporting*] Please use "Find and Replace" with "Match case":Find what: FilekeyReplace with: FileKey (There are 5 wrong written FileKeys.) Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 30, 2017 Share Posted March 30, 2017 Updates: https://github.com/MoscaDotTo/Winapp2/commit/3d29a25d48a2ff6884d71ed6eff574d8466218aa I am sorry to have to do this, but I am going to be taking a short break from Winapp2 for a few days or so. I am currently having a family crisis situation here. My grandma has passed away yesterday and I have been very upset to continue Winapp2 right now. The current development build of Winapp2 should be stable enough to use for awhile. I will try to come back to Winapp2 next week. I hope everyone can understand my situation right now. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 30, 2017 Moderators Share Posted March 30, 2017 Sorry to hear about your sad loss. Your real life is more important right now so deal with things for as long as you want and need. hazel Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
JDPower Posted March 30, 2017 Share Posted March 30, 2017 Sorry to hear about your sad loss. Your real life is more important right now so deal with things for as long as you want and need. hazel Seconded. In the grand scheme of things, winapp2 is an irrelevance. Do what you have to and ignore this place for a couple of weeks, and when you're ready, it'll all still be here when you come back, and the sky won't have fallen in for anyone not having an up to date winapp2 file xx Link to comment Share on other sites More sharing options...
CSGalloway Posted March 30, 2017 Share Posted March 30, 2017 What is the link to download the most updated winapp2.ini (I guess that would be the development buld ?) please? I currently download from [ https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini ] Link to comment Share on other sites More sharing options...
SMalik Posted March 30, 2017 Share Posted March 30, 2017 Updates: https://github.com/MoscaDotTo/Winapp2/commit/3d29a25d48a2ff6884d71ed6eff574d8466218aa I am sorry to have to do this, but I am going to be taking a short break from Winapp2 for a few days or so. I am currently having a family crisis situation here. My grandma has passed away yesterday and I have been very upset to continue Winapp2 right now. The current development build of Winapp2 should be stable enough to use for awhile. I will try to come back to Winapp2 next week. I hope everyone can understand my situation right now. Sorry for your loss. May God give you and the rest of your family patience. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 31, 2017 Share Posted March 31, 2017 What is the link to download the most updated winapp2.ini (I guess that would be the development buld ?) please? I currently download from [ https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini ] https://raw.githubusercontent.com/MoscaDotTo/Winapp2/ee06a5132c3b979c40dd028f236af2849b76b20a/Development/Winapp2 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted April 2, 2017 Share Posted April 2, 2017 Modified entry: [Movavi Video Converter (Logs)*] Added FileKey2 [Movavi Video Converter (Logs)*] LangSecRef=3023 Detect=HKCU\Software\MOVAVI Default=False FileKey1=%LocalAppData%\Movavi\Logs\VideoConverter*|*.* FileKey2=%LocalAppData%\Movavi\Video Converter|Log.txt Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted April 2, 2017 Share Posted April 2, 2017 Modified Entry: [AVG PC TuneUp & Utilities Logs*] Changed FileKey5 from |*.log to |*.* [AVG PC TuneUp & Utilities Logs*] LangSecRef=3024 Detect1=HKCU\Software\TuneUp Detect2=HKCU\Software\AVG\AWL\RegistryCleaner Default=False FileKey1=%CommonAppData%\TuneUp Software\TuneUp Utilities *|*.log|RECURSE FileKey2=%LocalAppData%\AvgSetupLog|*.*|REMOVESELF FileKey3=%LocalAppData%\Avg\AWL*\Log|*.log FileKey4=%LocalAppData%\Avg\Log|*.log;zappapi.log.1|RECURSE FileKey5=%LocalAppData%\Avg\log\fmw1|*.* FileKey6=%LocalAppData%\Avg\log\tu16|*.log FileKey7=%LocalAppData%\TuneUp Software|*.log|RECURSE FileKey8=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\Log\fmw1|*.log FileKey9=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\Log\tu16|*.log FileKey10=%SystemDrive%\Users\Default\AppData\Local\Avg\Log\tu16|*.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted April 2, 2017 Share Posted April 2, 2017 Modified Entry: [snagit 13*] Added FileKey5 [Snagit 13*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\13 Default=False FileKey1=%LocalAppData%\TechSmith\SnagIt|Tray.bin FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.ico FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.ico FileKey4=%LocalAppData%\TechSmith\SnagIt\Thumbnails|*.* FileKey5=%LocalAppData%\TechSmith\SnagIt\TrackerbirdFiles|*.log RegKey1=HKCU\Software\TechSmith\SnagIt\13\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\13\SnagItEditor\Recent File List Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
CSGalloway Posted April 3, 2017 Share Posted April 3, 2017 OS: Windows 7 Home Premimum x-64 What is the entry that behaves like the Windows XP Shellbags but for Windows 7 machines? IOWs to remove folder customizations please? Link to comment Share on other sites More sharing options...
siliconman01 Posted April 4, 2017 Share Posted April 4, 2017 New Entry: [Kaspersky Now*] [Kaspersky Now*] Section=3031 Default=False Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\KasperskyLab.KasperskyNow_8jx5e25qw3tdc FileKey1=%LocalAppData%\Packages\KasperskyLab.KasperskyNow_*\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\KasperskyLab.KasperskyNow_*\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\KasperskyLab.KasperskyNow_*\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\KasperskyLab.KasperskyNow_*\AC\Microsoft\CLR_v4.0_32\UsageLogs|*.*|RECURSE FileKey5=%LocalAppData%\Packages\KasperskyLab.KasperskyNow_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\KasperskyLab.KasperskyNow_*\LocalCache\|*.*|RECURSE FileKey7=%LocalAppData%\Packages\KasperskyLab.KasperskyNow_*\AC\Microsoft\CLR_v4.0_32|*.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 5, 2017 Moderators Share Posted April 5, 2017 OS: Windows 7 Home Premimum x-64 What is the entry that behaves like the Windows XP Shellbags but for Windows 7 machines? IOWs to remove folder customizations please? I thought those thinking they were "Cached Shell Extensions" were requested for removal from winapp2.ini not too long ago, but I could be wrong. Link to comment Share on other sites More sharing options...
SMalik Posted April 5, 2017 Share Posted April 5, 2017 I thought those thinking they were "Cached Shell Extensions" were requested for removal from winapp2.ini not too long ago, but I could be wrong. It was: [stored Explorer View Settings*] DetectOS=6.1| LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will delete window size, window position and view setting of all folders. RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags Why it was removed: https://forum.piriform.com/index.php?showtopic=32310&p=280902 Link to comment Share on other sites More sharing options...
