jopa66 Posted February 28, 2016 Share Posted February 28, 2016 Just an observation in regards to Revo Uninstaller. Revo creates registry backups of uninstalled apps. I personally do not need these and manually delete them. There is an entry in Winapp2.ini to remove Revo's backups but, it does not do as I expect it to do. The registry backups are NOT deleted with this entry. What IS deleted in the database file that Revo uses to analyze the programs to be deleted. Perhaps I'm misunderstanding what this entry is supposed to do - perhaps it's an error. Have instructed CCleaner to ignore this file (rupilogs.rupldb ) but, then the whole thing is redundant as nothing else gets deleted that I can see. Analysis Complete - (2.677 secs)------------------------------------------------------------------------------------------4.85 MB to be removed. (Approximate size)Secure file deletion enabled - Simple Overwrite (1 pass)------------------------------------------------------------------------------------------ Details of files to be deleted (Note: No files have been deleted yet)------------------------------------------------------------------------------------------System - Temporary Files 1,099 KB 1 files Utilities - Revo Uninstaller Backups* 3,864 KB 1 files Windows - Cached Certification Files* 5 KB 8 files ------------------------------------------------------------------------------------------C:\Program Files\VS Revo Group\Revo Uninstaller Pro\rupilogs.rupldb 3,864 KB Link to comment Share on other sites More sharing options...
ROCKNROLL Posted February 29, 2016 Share Posted February 29, 2016 All registry backup cleaners were removed from Winapp2 due to some problems in the past. As to the other issue, this should fix it: EDIT: [Revo Uninstaller Backups*]LangSecRef=3024DetectFile=%LocalAppData%\VS Revo groupFileKey1=%LocalAppData%\VS Revo Group\Revo Uninstaller Free\BackupsData|*.*|RECURSEFileKey2=%LocalAppData%\VS Revo Group\Revo Uninstaller Pro\BackupsData|*.*|RECURSE Removed the following entries: FileKey3=%ProgramFiles%\VS Revo Group\Revo Uninstaller Pro|*.bak;rupilogs.rupldbFileKey4=%LocalAppData%\VirtualStore\Program Files*\VS Revo Group\Revo Uninstaller Pro|*.bak;rupilogs.rupldb I haven't used revo in many years, so I do not know what FileKey 1 and 2 are suppose to do. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 3, 2016 Moderators Share Posted March 3, 2016 (edited) For whatever reason this was removed from winapp2.ini. Here's a re-submission with updates: Changed Detect to Detect1. Added Detect2 and FileKey3 [Auslogics Disk Defrag Portable*] LangSecRef=3024 Detect1=HKCU\Software\Auslogics\Disk Defrag Portable Detect2=HKLM\Software\Auslogics\DiskDefrag Portable Default=False FileKey1=%AppData%\Auslogics\Disk Defrag\Reports|*.* FileKey2=%AppData%\Auslogics\Disk Defrag\Logs|*.* FileKey3=%CommonAppData%\Auslogics\DiskDefrag Portable\*\Reports|*.* Edited March 4, 2016 by Andavari Fixed the first Detect, it needed to be Detect1 to also work with BleachBit. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 3, 2016 Moderators Share Posted March 3, 2016 For whatever reason this was removed from winapp2.ini. * * * [Auslogics Disk Defrag Portable*] Weird, it was added in 5.13 but maybe got accidentally excised with Auslogics Registry? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 4, 2016 Moderators Share Posted March 4, 2016 Notice it's the Portable version, not the regular installation version. Although the "Portable" version isn't really a true portable it's just minus an installer. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 4, 2016 Moderators Share Posted March 4, 2016 Notice it's the Portable version, not the regular installation version. Although the "Portable" version isn't really a true portable it's just minus an installer. Ah ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 4, 2016 Author Share Posted March 4, 2016 Hey guys! been absolutely swamped recently (four exams this week) this was sent to me via email: Please post this on the forum, because of a proper documenation.The rest please add to winapp2.iniThanks.[Honeyview MRU*]LangSecRef=3023Detect=HKCU\SOFTWARE\HoneyviewDefault=FalseRegKey1=HKCU\SOFTWARE\Honeyview\RecentFolder0RegKey2=HKCU\SOFTWARE\Honeyview\RecentFolder1RegKey3=HKCU\SOFTWARE\Honeyview\RecentFolder2RegKey4=HKCU\SOFTWARE\Honeyview\RecentFolder3RegKey5=HKCU\SOFTWARE\Honeyview\RecentFolder4RegKey6=HKCU\SOFTWARE\Honeyview\RecentFolder5RegKey7=HKCU\SOFTWARE\Honeyview\RecentFolder6RegKey8=HKCU\SOFTWARE\Honeyview\RecentFolder7RegKey9=HKCU\SOFTWARE\Honeyview\RecentFolder8RegKey10=HKCU\SOFTWARE\Honeyview\RecentFolder9RegKey11=HKCU\SOFTWARE\Honeyview\sRecentFolderRegKey12=HKCU\SOFTWARE\Honeyview\sStoreFilePathRegKey13=HKCU\SOFTWARE\Honeyview\sStoreFilePath2RegKey14=HKCU\SOFTWARE\Honeyview\transf.sTargetFolder[Honeyview Bookmarks*]LangSecRef=3023Warning=This will delete your Bookmarks.Detect=HKCU\SOFTWARE\HoneyviewDefault=FalseRegKey1=HKCU\SOFTWARE\Honeyview\BMPath0RegKey2=HKCU\SOFTWARE\Honeyview\BMPath1RegKey3=HKCU\SOFTWARE\Honeyview\BMPath2RegKey4=HKCU\SOFTWARE\Honeyview\BMPath3RegKey5=HKCU\SOFTWARE\Honeyview\BMPath4RegKey6=HKCU\SOFTWARE\Honeyview\BMPath5RegKey7=HKCU\SOFTWARE\Honeyview\BMPath6RegKey8=HKCU\SOFTWARE\Honeyview\BMPath7RegKey9=HKCU\SOFTWARE\Honeyview\BMPath8RegKey10=HKCU\SOFTWARE\Honeyview\BMPath9RegKey11=HKCU\SOFTWARE\Honeyview\BMPath10RegKey12=HKCU\SOFTWARE\Honeyview\BMPath11RegKey13=HKCU\SOFTWARE\Honeyview\BMPath12RegKey14=HKCU\SOFTWARE\Honeyview\BMPath13RegKey15=HKCU\SOFTWARE\Honeyview\BMPath14RegKey16=HKCU\SOFTWARE\Honeyview\BMPath15RegKey17=HKCU\SOFTWARE\Honeyview\BMPath16RegKey18=HKCU\SOFTWARE\Honeyview\BMPath17RegKey19=HKCU\SOFTWARE\Honeyview\BMPath18RegKey20=HKCU\SOFTWARE\Honeyview\BMPath19RegKey21=HKCU\SOFTWARE\Honeyview\BMPath20RegKey22=HKCU\SOFTWARE\Honeyview\BMPath21RegKey23=HKCU\SOFTWARE\Honeyview\BMPath22RegKey24=HKCU\SOFTWARE\Honeyview\BMPath23RegKey25=HKCU\SOFTWARE\Honeyview\BMPath24RegKey26=HKCU\SOFTWARE\Honeyview\BMPath25RegKey27=HKCU\SOFTWARE\Honeyview\BMPath26RegKey28=HKCU\SOFTWARE\Honeyview\BMPath27RegKey29=HKCU\SOFTWARE\Honeyview\BMPath28RegKey30=HKCU\SOFTWARE\Honeyview\BMPath29[AceBIT Password Depot 9 Password Backups*]LangSecRef=3023Warning=This will delete your Backups of your passwords.Detect=HKCU\SOFTWARE\AceBIT\Password Depot 9Default=FalseFileKey1=%Documents%\Password Depot\Backup|*.*[AceBIT Password Depot 9 Password MRU*]LangSecRef=3023Detect=HKCU\SOFTWARE\AceBIT\Password Depot 9Default=FalseFileKey1=%AppData%\AceBIT\Password Depot 9\pwdepot.cfg:[<LastFile>][</LastFile>][E]FileKey2=%AppData%\AceBIT\Password Depot 9\pwdepot.cfg:[<MRU>][</MRU>][E]%2 winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 4, 2016 Author Share Posted March 4, 2016 (edited) Edit: My mistake, when I copied the email I didn't copy the whole thing. Here is the rest This MRU file in cleaning is currently not supported by CCleaner, but if this gets supported,it should look a little bit like this.It should clean between point A "[A]" and point B "". All between this both things should get cleaned.But it should always scan through the file with the switch [E] standing for endless.It should kill all Lastfiles he finds within the file. Found:Within the file "C:\Users\{Username}\AppData\Roaming\AceBIT\Password Depot 9\pwdepot.cfg":<LastFile>..\..\..\Users\{Username}\Documents\Password Depot\test.pswd</LastFile><MRU>..\..\..\Users\{Username}\Documents\Password Depot\test.pswd=0</MRU> [blackBeltPrivacy DarkNet Logs*]LangSecRef=3023DetectFile=%LocalAppData%\BlackBeltPrivacyDefault=FalseFileKey1=%LocalAppData%\BlackBeltPrivacy\darkNet\logs|*.*|RECURSEFileKey2=%LocalAppData%\BlackBeltPrivacy\MicroSip|MicroSIP.logFileKey3=%LocalAppData%\BlackBeltPrivacy\Logs|*.*|RECURSEFound:C:\Users\PC\AppData\Local\BlackBeltPrivacy\darkNet\logsC:\Users\PC\AppData\Local\BlackBeltPrivacy\Logs\tor-log.txt [blackBeltPrivacy DarkNet Runtime*]LangSecRef=3023DetectFile=%LocalAppData%\BlackBeltPrivacyDefault=FalseFileKey1=%LocalAppData%\BlackBeltPrivacy\3rdParty|*.*|RECURSEFound:C:\Users\PC\AppData\Local\BlackBeltPrivacy\3rdParty [Plex Media Server*]LangSecRef=3023DetectFile=%ProgramFiles%\Plex\Plex Media ServerDefault=FalseFileKey1=%ProgramFiles%\Plex\Plex Media Server|log*.txt;*.log|RECURSEFileKey2=%LocalAppData%\VirtualStore\Program Files*\Plex\Plex Media Server|log*.txt;*.log|RECURSEFileKey3=%LocalAppData%\Plex Media Server\Logs|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\Program Files*\Plex Media Server\Logs|*.*|RECURSEFileKey5=%LocalAppData%\Plex Media Server\Crash Reports|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\Program Files*\Plex Media Server\Crash Reports|*.*|RECURSE -FileKey1 and 2 optimized.-Added FileKey3-6. [Zoner Photo Studio 18 (AutoSave)*]LangSecRef=3023Detect=HKCU\Software\ZONER\Zoner Photo Studio 18Default=FalseFileKey1=%LocalAppData%\Zoner\OriginalsRepository|*.JPG.info;*.JPG.original|RECURSE [Zoner Photo Studio 18*]LangSecRef=3023Detect=HKCU\Software\ZONER\Zoner Photo Studio 18Default=FalseFileKey1=%LocalAppData%\Zoner\ZPS 18\ZPSCache.dat|*.*FileKey2=%Pictures%|*.uid-zpsFileKey3=%LocalAppData%\Zoner\ZPS 18\CEF|*.logFileKey3=%LocalAppData%\Zoner\ZPS 18\Cache|RECURSE|REMOVESELF -Added two new entries [Zoner Photo Studio 14*]LangSecRef=3022DetectFile=%LocalAppData%\Zoner\ZPS 14Default=FalseFileKey1=%LocalAppData%\Zoner\ZPS 14\ZPSCache.dat|*.*FileKey2=%LocalAppData%\Zoner\ZPS 14\CEF|*.log [Zoner Photo Studio 15*]LangSecRef=3023Detect=HKCU\Software\ZONER\Zoner Photo Studio 15Default=FalseFileKey1=%LocalAppData%\Zoner\ZPS 15\ZPSCache.dat|*.*FileKey2=%Pictures%|*.uid-zpsFileKey3=%LocalAppData%\Zoner\ZPS 15\CEF|*.log [Zoner Photo Studio 16*]LangSecRef=3023Detect=HKCU\Software\ZONER\Zoner Photo Studio 16Default=FalseFileKey1=%LocalAppData%\Zoner\ZPS 16\ZPSCache.dat|*.*FileKey2=%LocalAppData%\Zoner\ZPS 16\CEF|*.logFileKey3=%Pictures%|*.uid-zps added additional filekeys, which have been forgotten to add. [Aignes Website-Watcher (AutoBackup)*]LangSecRef=3023Warning=This will delete your AutoBackup of your site.Detect=HKCU\SOFTWARE\aignes\wswatchDefault=FalseFileKey1=%AppData%\aignes\website-watcher\config\autobackup|*.* If you delete this, you can reload it easy back with your internet connection. [Aignes Website-Watcher*]LangSecRef=3023Detect=HKCU\SOFTWARE\aignes\wswatchDefault=FalseFileKey1=%AppData%\aignes\website-watcher\config\log|*.*FileKey2=%AppData%\aignes\website-watcher\config\temp|*.* [Aignes Website-Watcher (Bookmarks)*]LangSecRef=3023Warning=This will delete your Bookmarks. Export, before you tick this.Detect=HKCU\Software\aignes\wswatchDefault=FalseFileKey1=%AppData%\aignes\website-watcher\bookmarks|*.* [Lupinho.Net Hardlink Backup Logs*]LangSecRef=3023Detect=HKLM\Software\Lupinho.NetDefault=FalseFileKey1=%LocalAppData%\Lupinho.Net|*.log|RECURSE [iGC Brava!Free DWG Viewer*]LangSecRef=3023Detect1=HKLM\SOFTWARE\IGC\Free DWG ViewerDetect2=HKLM\SOFTWARE\WOW6432Node\IGC\Free DWG ViewerDefault=FalseFileKey1=%AppData%\IGC\Brava! FreeDWG Viewer|ViewerConfig.xml This will delete some useless settings too. But in general there are few other setting files. [usbFix*]LangSecRef=3023Detect=HKCU\SOFTWARE\UsbFixDefault=FalseRegKey1=HKCU\SOFTWARE\UsbFix\LastReportFileKey1=%SystemDrive%\UsbFix|Log|REMOVESELFFileKey2=%SystemDrive%\UsbFix|Quarantine|REMOVESELFFileKey3=%UserProfile%\Desktop|UsbFix_Report.txt [Cloudfogger*]LangSecRef=3023Detect1=HKCU\SOFTWARE\CloudfoggerDetect2=HKCU\SOFTWARE\Cloudfogger.comDefault=FalseFileKey1=%AppData%\Cloudfogger|*.log|RECURSEFileKey2=%LocalAppData%\CrashRpt|*.log|RECURSE [Cloudfogger Keys*]LangSecRef=3023Detect1=HKCU\SOFTWARE\CloudfoggerDetect2=HKCU\SOFTWARE\Cloudfogger.comDefault=FalseFileKey1=%AppData%\Cloudfogger\Keys|*.*|RECURSE [Cloudfogger Password/Logins*]LangSecRef=3023Warning=This will delete your passwords and logins.Detect1=HKCU\SOFTWARE\CloudfoggerDetect2=HKCU\SOFTWARE\Cloudfogger.comDefault=FalseFileKey1=%AppData%\Cloudfogger|Autofogg.prefFileKey1=%AppData%\Cloudfogger|Settings This will delete the settings and logins, which is doable with the Software itself.But it's called "delete the cache." [Polarity Log*]Section=BrowsersDetectFile=%ProgramFiles%\PolarityDefault=FalseFileKey1=%ProgramFiles%\Polarity|*.log [Polarity Cache*]Section=BrowsersDetectFile=%ProgramFiles%\PolarityDefault=FalseFileKey1=%AppData%\Stanley Lim\Polarity\Cache|*.*|RECURSE [Polarity Favicon*]Section=BrowsersDetectFile=%ProgramFiles%\PolarityDefault=False [Polarity History*]Section=BrowsersDetectFile=%ProgramFiles%\PolarityDefault=FalseFileKey1=%UserProfile%\Polarity_Config|history_times.ini;savedTabs.ini;history.ini;history_names.ini;history_times.ini;downloads_urls.ini;downloads_times.ini;downloads_names.ini; [Logs*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\Application|debug.logFileKey2=%LocalAppData%\Google\Chrome*\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey3=%LocalAppData%\Chrome Plus\Application|debug.logFileKey4=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey5=%LocalAppData%\Chromium\Application|debug.logFileKey6=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey7=%LocalAppData%\Flock\Application|debug.logFileKey8=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey9=%LocalAppData%\Rockmelt\Application|debug.logFileKey10=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey11=%LocalAppData%\SRWare Iron\Application|debug.logFileKey12=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey13=%LocalAppData%\Torch\Application|debug.logFileKey14=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey15=%LocalAppData%\SuperBird\Application|debug.logFileKey16=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey17=%LocalAppData%\VirtualStore\Program Files*\Google\Chrome*\Application|debug.logFileKey18=%LocalAppData%\Amigo\Application|debug.logFileKey19=%LocalAppData%\Amigo\User Data\*\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey20=%LocalAppData%\Google\Chrome Cleanup Tool|*.logExcludeKey1=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local Extension Settings\|*.*ExcludeKey2=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local App Settings\|*.*ExcludeKey3=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Extensions\|*.*ExcludeKey4=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local Extension Settings\|*.*ExcludeKey5=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local App Settings\|*.*ExcludeKey6=PATH|%LocalAppData%\Chrome Plus\User Data\*\Extensions\|*.*ExcludeKey7=PATH|%LocalAppData%\Chromium\User Data\*\Local Extension Settings\|*.*ExcludeKey8=PATH|%LocalAppData%\Chromium\User Data\*\Local App Settings\|*.*ExcludeKey9=PATH|%LocalAppData%\Chromium\User Data\*\Extensions\|*.*ExcludeKey10=PATH|%LocalAppData%\Flock\User Data\*\Local Extension Settings\|*.*ExcludeKey11=PATH|%LocalAppData%\Flock\User Data\*\Local App Settings\|*.*ExcludeKey12=PATH|%LocalAppData%\Flock\User Data\*\Extensions\|*.*ExcludeKey13=PATH|%LocalAppData%\Rockmelt\User Data\*\Local Extension Settings\|*.*ExcludeKey14=PATH|%LocalAppData%\Rockmelt\User Data\*\Local App Settings\|*.*ExcludeKey15=PATH|%LocalAppData%\Rockmelt\User Data\*\Extensions\|*.*ExcludeKey16=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local Extension Settings\|*.*ExcludeKey17=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local App Settings\|*.*ExcludeKey18=PATH|%LocalAppData%\SRWare Iron\User Data\*\Extensions\|*.*ExcludeKey19=PATH|%LocalAppData%\Torch\User Data\*\Local Extension Settings\|*.*ExcludeKey20=PATH|%LocalAppData%\Torch\User Data\*\Local App Settings\|*.*ExcludeKey21=PATH|%LocalAppData%\Torch\User Data\*\Extensions\|*.*ExcludeKey22=PATH|%LocalAppData%\Superbird\User Data\*\Local Extension Settings\|*.*ExcludeKey23=PATH|%LocalAppData%\Superbird\User Data\*\Local App Settings\|*.*ExcludeKey24=PATH|%LocalAppData%\Superbird\User Data\*\Extensions\|*.*ExcludeKey25=PATH|%LocalAppData%\Amigo\User Data\*\Local Extension Settings\|*.*ExcludeKey26=PATH|%LocalAppData%\Amigo\User Data\*\Local App Settings\|*.*ExcludeKey27=PATH|%LocalAppData%\Amigo\User Data\*\Extensions\|*.* -Added FileKey20 C:\Users\PC\AppData\Local\Google\Chrome Cleanup Tool\chrome_cleanup_tool.log [OpenOffice.org*]LangSecRef=3021Detect1=HKLM\Software\OpenOffice.orgDetect2=HKLM\Software\Wow6432Node\OpenOffice.orgDetect3=HKLM\Software\OpenOfficeDetect4=HKLM\Software\Wow6432Node\OpenOfficeDefault=FalseFileKey1=%AppData%\OpenOffice*\*\user|*.log;*.log.txt;*.tmp|RECURSEFileKey2=%AppData%\OpenOffice*\*\user|registrymodifications.xcu;registration.xmlFileKey3=%AppData%\OpenOffice*\*\user\config\imagecache|*.*FileKey4=%AppData%\OpenOffice*\*\user\registry\cache|*.*FileKey5=%AppData%\OpenOffice*\*\user\registry\data\org\openoffice\Office|Views.xcu;Writer.xcu;Common.xcu;Histories.xcuFileKey6=%AppData%\OpenOffice*\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu;Store.xcuFileKey7=%ProgramFiles%\OpenOffice*\share\uno_packages\cache\uno_packages|*.tmp;*.log;log.txt Found this:C:\Users\PC\AppData\Roaming\OpenOffice\4\user\uno_packages\cache\log.txt Edited March 7, 2016 by Winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted March 4, 2016 Share Posted March 4, 2016 Revised Entry Changed DetectFile to Detect [Plex Media Server*]LangSecRef=3023Detect=HKCU\Software\Plex, Inc.\Plex Media ServerDefault=FalseFileKey1=%ProgramFiles%\Plex\Plex Media Server|log*.txt;*.log|RECURSEFileKey2=%LocalAppData%\VirtualStore\Program Files*\Plex\Plex Media Server|log*.txt;*.log|RECURSEFileKey3=%LocalAppData%\Plex Media Server\Logs|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\Program Files*\Plex Media Server\Logs|*.*|RECURSEFileKey5=%LocalAppData%\Plex Media Server\Crash Reports|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\Program Files*\Plex Media Server\Crash Reports|*.*|RECURSE Link to comment Share on other sites More sharing options...
JDPower Posted March 4, 2016 Share Posted March 4, 2016 HKCU\Software\Plex, Inc.\Plex Media Server Is that right? Strange punctuation for a reg entry. Link to comment Share on other sites More sharing options...
SMalik Posted March 5, 2016 Share Posted March 5, 2016 Revised Entry [Foxit PhantomPDF 7 More*]LangSecRef=3021Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0Default=FalseFileKey1=%LocalAppData%\Foxit PhantomPDF\msilog|*.logFileKey2=%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.dsFileKey3=%AppData%\Foxit Software\RMS|FXRMS_Log.txtRegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\MRU\File MRURegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\MRU\Place MRURegKey3=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Preferences\HistoryRegKey4=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Recent File ListAdded:HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\MRU\File MRUHKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\MRU\Place MRU Link to comment Share on other sites More sharing options...
SMalik Posted March 5, 2016 Share Posted March 5, 2016 Is that right? Strange punctuation for a reg entry. That path is correct. Link to comment Share on other sites More sharing options...
JDPower Posted March 5, 2016 Share Posted March 5, 2016 That path is correct. OK, just checking Link to comment Share on other sites More sharing options...
sistoiv Posted March 6, 2016 Share Posted March 6, 2016 Please, add this entry for some special MS Outlook MRU HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\Outlook\0a0d020000000000c000000000000046 Thanks Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 7, 2016 Author Share Posted March 7, 2016 Finally free from my exams! Updating tonight winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 9, 2016 Share Posted March 9, 2016 Updating tonight 2 days later... I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
JDPower Posted March 10, 2016 Share Posted March 10, 2016 2 days later... Seriously? If I were winapp I'd have quit by now and told people to make their own ruddy file! Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 10, 2016 Share Posted March 10, 2016 Calm down JDPower, it was only a joke. He should take as much time as he needs with Winapp2. I am sure he has more important things to do in his real life. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 10, 2016 Moderators Share Posted March 10, 2016 make their own ruddy file! I maintain my own personal winapp2.ini file. Link to comment Share on other sites More sharing options...
CSGalloway Posted March 10, 2016 Share Posted March 10, 2016 I maintain my own personal winapp2.ini file. Are there any entries in your personal winapp2.ini that are others might like - ? It might be nice to post it and make sure it doesn't conflict with the main winapp2.ini for this thread... Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 10, 2016 Moderators Share Posted March 10, 2016 Are there any entries in your personal winapp2.ini that are others might like - ? It might be nice to post it and make sure it doesn't conflict with the main winapp2.ini for this thread...He already does that ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
CSGalloway Posted March 10, 2016 Share Posted March 10, 2016 He already does that Then is his personal winapp2.ini posted somewhere? If so, where? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 10, 2016 Moderators Share Posted March 10, 2016 Then is his personal winapp2.ini posted somewhere? If so, where? Huh? No, he submits entries to the thread. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 10, 2016 Moderators Share Posted March 10, 2016 What Nergal said. I don't keep entries I've made just to myself, I submit them. What I meant by I maintain my own is all of those in my winapp2.ini I made on my own and maintain it, I don't even use the community winapp2.ini file. Link to comment Share on other sites More sharing options...
