Winapp2.ini additions
Winapp2.ini
Revised Entry
Removed ExcludeKey's. Because of the ExcludeKey's, lots of LOG and .old files were not being removed. I have tested it on the latest version of Chrome with several extensions installed, no issue whatsoever.
[Logs*]
LangSecRef=3029
SpecialDetect=DET_CHROME
Detect1=HKCU\Software\Torch
Detect2=HKCU\Software\SuperBird
Default=False
FileKey1=%LocalAppData%\Google\Chrome*\Application|debug.log
FileKey2=%LocalAppData%\Google\Chrome*\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey3=%LocalAppData%\Chrome Plus\Application|debug.log
FileKey4=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey5=%LocalAppData%\Chromium\Application|debug.log
FileKey6=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey7=%LocalAppData%\Flock\Application|debug.log
FileKey8=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey9=%LocalAppData%\Rockmelt\Application|debug.log
FileKey10=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey11=%LocalAppData%\SRWare Iron\Application|debug.log
FileKey12=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey13=%LocalAppData%\Torch\Application|debug.log
FileKey14=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey15=%LocalAppData%\SuperBird\Application|debug.log
FileKey16=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey17=%LocalAppData%\Amigo\Application|debug.log
FileKey18=%LocalAppData%\Amigo\User Data\*\*|*LOG.*;Log;*.log;*.old|RECURSE
FileKey19=%LocalAppData%\Google\Chrome Cleanup Tool|*.*|REMOVESELF
Making this change broke my Sticky Password extension in Chrome V50.0.2661.102 m on Windows 10 x64 insider build 14342.  The extension became inactive.  I had to uninstall it from Chrome and then re-install the extension via the Sticky Password program.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
No surprise, exclude keys are usually added for good reason. Generally a bad idea to remove them from the universal winapp2 file just cos it causes no problems on one persons system.
Link to comment
  • Moderators
This!
Link to comment
Fully agree and understand.  I just wanted to re-enforce that they should not be removed by presenting a real-time example from my systems.   ;)
Link to comment
Maybe you can find a way to have those log/old files to be removed while leaving the ExcludeKeys intact.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
  • 2 weeks later...
Modified Entry:  [CyberLink Crash Dumps*]
LangSecRef=3023
Detect=HKCU\Software\CyberLink
Default=False
FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp
FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp
FileKey3=%CommonAppData%\CyberLink\PowerDVD*\Boomerang\*\|*.xml;*.dmp
FileKey4=%LocalAppData%\VirtualStore\ProgramData\CyberLink\PowerDVD*\Boomerang\*\|*.xml;*.dmp
Modified FileKey3 and FileKey4 to accommodate the newly released Cyberlink PowerDVD 16
Link to comment
Hello,
I had some problems with one of the entries - [internet Explorer More*], damaged 3 windows 8.1 apps :
Bitmap live tile clock - no longer opens and live tile gone.
The weather channel app - opens ok, but live tile gone.
Windows calendar app - opens ok, but live tile gone.
I reinstalled the Bitmap clock and it was working with live tile, then ran ccleaner again to confirm.  It stopped working.
Then I reinstalled the weather channel app and got it working with live tile and analyzed again, and mostly log files entries came up and [internet Explorer More*]. Unchecked [internet Explorer More*] and ran ccleaner and weather channel app is still working with live tile - even after reboot.
I analyzed just the entry in ccleaner :
Internet - Internet Explorer More*    1,544 KB    5 files
C:\Users\Neil\AppData\Local\Microsoft\Windows\WebCache\V01.chk    8 KB
C:\Users\Neil\AppData\Local\Microsoft\Windows\WebCache\V01001FF.log    512 KB
C:\Users\Neil\AppData\Local\Microsoft\Windows\WebCache\V01res00001.jrs    512 KB
C:\Users\Neil\AppData\Local\Microsoft\Windows\WebCache\V01res00002.jrs    512 KB
C:\Users\Neil\AppData\Roaming\Microsoft\Internet Explorer\UserData\container.dat    0 KB
This maybe should be removed from the entry ? :
FileKey12=%LocalAppData%\Microsoft\Windows\WebCache|*.*|RECURSE
FileKey13=%LocalAppData%\Microsoft\Windows\WebCache.old|*.*|REMOVESELF
I could not find the container.dat file, but maybe add an excludekey for that.
If at the very least add a warning that this will damage windows apps and live tiles.
I tried to look through the reg key entries, but could not find anything there.
Has anybody else had problems with this?  I hope this info will help someone else.
Thanks, Neil
Link to comment
Remove Duplicate
[WebSite-Watcher*]
LangSecRef=3021
Detect=HKCU\Software\aignes\wswatch
Default=True
FileKey1=%AppData%\aignes\WebSite-Watcher\bookmarks\bookmark_wsw|*.*|REMOVESELF
FileKey2=%AppData%\aignes\WebSite-Watcher\config\autobackup|*.zip
FileKey3=%AppData%\aignes\WebSite-Watcher\config\favicons|*.*
FileKey4=%AppData%\aignes\WebSite-Watcher\config\log|*.log
FileKey5=%AppData%\aignes\WebSite-Watcher\config\settings|*.cfg_bak*
FileKey6=%AppData%\aignes\WebSite-Watcher\config\temp|*.*
Link to comment
New Entry:  [Movavi Video Converter (Logs)*]
LangSecRef=3023
Detect=HKCU\Software\MOVAVI
Default=False
FileKey1=%LocalAppData%\Movavi\Logs\VideoConverter16\|*.*
Link to comment
New and modified entries to incorporate the new Techsmith Snagit 13 version.
[Snagit 13*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\13
Default=False
RegKey1=HKCU\Software\TechSmith\SnagIt\13\Recent Captures
RegKey2=HKCU\Software\TechSmith\SnagIt\13\SnagItEditor\Recent File List
FileKey1=%LocalAppData%\TechSmith\SnagIt|Tray.bin
FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.ico
FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.ico
FileKey4=%LocalAppData%\TechSmith\SnagIt\Thumbnails|*.*
[Snagit 12/13 Local Dumps*]
LangSecRef=3024
Detect1=HKCU\Software\TechSmith\SnagIt\12
Detect2=HKCU\Software\TechSmith\SnagIt\13
Default=False
FileKey1=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*
[Snagit 12/13 More*]
LangSecRef=3024
Default=False
Warning=This will delete the backups of the captures that you have performed with SnagIt 12/13.
FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG;*.SNAGundo;*.MP4
FileKey2=%Documents%\|SnagItDebug.log
FileKey3=%LocalAppData%\TechSmith\Logs\|*.log
RegKey1=HKCU\Software\TechSmith\Snagit\12|CaptureCount
RegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder
[snagit 13*] is only needed until the primary CCleaner Winapp.ini is updated by the developers to include Snagit 13.
Link to comment
Hi... trim.bat has stopped working for me. I realize the version of winapp2.ini is a little behind the times but, I've installed some softwares and uninstalled others since the latest iteration and was just trying to re-customized the winapp2 file to more accurately reflect my current setup. Upon re-downloading the latest winapp2 file from the website, I am encountering an impasse when trying to accomplish my mission. http://i64.tinypic.com/4raqzr.jpg
Link to comment
Make sure you are running trim as administrator. Also, make sure you are clicking "Analyze" and not "Run Cleaner" during this operation.
Link to comment
Yup. Did that. As I am only one on this machine UAC has been turned off for some time. Right click, runas administrator still gives no joy. I do remember not too long ago removing the Ccleaner task from the Task Manager. I created a new task but, maybe the parameters are incorrect? Can someone advise proper setup for this?
Link to comment
I hope that Winapp2.ini is okay and that SMalik comes back someday; I've been looking over all posts in this thread since the last release of winapp2.ini and I especially appreciate the research done by SMalik on the Windows 10 Universal Apps.
By the way, it looks like, to support both new Opera and the Vivaldi web browser in these winapp2.ini entries, for every FileKey where you see
add a line where the "Google\Chrome*" bit is replaced by "Opera Software\Opera *" (I added a space to minimize false positives), and another line where that bit is replaced by "Vivaldi" (the only exceptions being for "Application" directories, which are in Program Files and where I have never seen debug.log files); additionally, it looks like more of the Chrome-related sections could use a registry detection for HKCU\Software\Chromium where they already have lines for Torch and SuperBird, and then after that, lines for Opera Software and Vivaldi.
(For some of these entries, it looks like new Opera uses %AppData% instead of %LocalAppData% and does not have a "User Data" subdirectory, nor separate user profiles.)
I might later post the respective changed sections, after adding the entries for new Opera and Vivaldi; I haven't yet found relevant entries for Brave, though.
I will send my updated winapp2.ini file to Winapp2.ini when I am done, but I will not post it publicly out of respect for the project maintainer.
Link to comment
For all the self maintainers these should be all the new entries, edits and removals since that last update.
https://forum.piriform.com/index.php?showtopic=32310&page=271&do=findComment&comment=271094
https://forum.piriform.com/index.php?showtopic=32310&page=270&do=findComment&comment=271093
https://forum.piriform.com/index.php?showtopic=32310&page=273&do=findComment&comment=271809
https://forum.piriform.com/index.php?showtopic=32310&page=273&do=findComment&comment=271884
https://forum.piriform.com/index.php?showtopic=32310&page=273&do=findComment&comment=271885
https://forum.piriform.com/index.php?showtopic=32310&page=273&do=findComment&comment=271982
https://forum.piriform.com/index.php?showtopic=32310&page=273&do=findComment&comment=271983
https://forum.piriform.com/index.php?showtopic=32310&page=273&do=findComment&comment=272015
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272016
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272051
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272186
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272190
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272199
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272200
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272201
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272203
https://forum.piriform.com/index.php?showtopic=32310&page=274&do=findComment&comment=272206
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272307
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272336
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272396
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272580
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272581
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272617
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272621
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272622
https://forum.piriform.com/index.php?showtopic=32310&page=275&do=findComment&comment=272623
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272624
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272641
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272682
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272694
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272698
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272702
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272844
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272845
https://forum.piriform.com/index.php?showtopic=32310&page=276&do=findComment&comment=272924
https://forum.piriform.com/index.php?showtopic=32310&page=277&do=findComment&comment=273084
https://forum.piriform.com/index.php?showtopic=32310&page=277&do=findComment&comment=273090
https://forum.piriform.com/index.php?showtopic=32310&page=278&do=findComment&comment=273524
https://forum.piriform.com/index.php?showtopic=32310&page=278&do=findComment&comment=273698
https://forum.piriform.com/index.php?showtopic=32310&page=278&do=findComment&comment=273802
https://forum.piriform.com/index.php?showtopic=32310&page=278&do=findComment&comment=273878
https://forum.piriform.com/index.php?showtopic=32310&page=279&do=findComment&comment=274019
Link to comment
  • Moderators
Awesome, thank you
Link to comment
So the last update would be the last time WinApp2.ini was updated - hence "Current version: 5.15.160311"
Link to comment
Hi folks!
Sorry I've been away without contact. And doubly sorry that I really can't discuss why.
I haven't had time to read what I've missed here just yet but I should like to restructure how this operates, such that it can at least continue to function well should I lose access to my machines again
As such, I'd like to migrate to Github! I'll get around to this in the coming weeks when more things have settled. I hope to have this going in time for the next CCleaner update, but if not certainly it'll follow shortly after. I'm not too experienced with Git, so I may need a little guidance from some of you experts in the crowd :)
Again, sorry for the communications embargo the last few months. Wasn't much of a choice on my part.
Hope to resume in full swing shortly, I appreciate the patience and commitment to the project you've all shown in my absence. Be well, I shall return soon :)
Link to comment
Hello,
a sorry is not necessary for me, you're back and picks up the work again.
I'm happy and I hope it goes well with you.
_____________________
Best regards …. /
_____________/ Alexei
The Netherlands
Link to comment
Hi folks!
I assume you got my email then, right.
GitHub is actually pretty simple. Everything is pretty straightforward and I have a lot of experience with it. I might recommend you add some admins with it, so when you are away, there is someone else to take over for awhile.
I talked about this in the email I sent, but I will say it here. Consider making 2 Winapp2 files, one for CCleaner and 1 for all other cleaners. That way, when you remove entries for CCleaner, people can download the one for CCleaner, while the other cleaners don't lose their cleaning abilities. Sorry, I know we are not aloud to talk about other cleaners, but it is a good idea to do.
Anyways, no need to apologize for anything. You don't owe us anything and it's not like you are getting paid for it, you know other then donations.
Link to comment
I did get your email I believe :) The idea has been brought up before in this thread, and I think it's a good idea to decentralize things to a degree this way you guys don't get left hanging :) We'll chat more soon
Link to comment
Register a new account
Sign in
Important Information
