CCleaner Community Forums
Winapp2.ini additions
The Metro Apps entries I provided above do not work with DetectOS=10.0|, but they do work when DetectOS=10.0| is not there.
I tested DetectOS=10.0 without the pipe | and it worked for me. Then tested DetectOS=11 and it didn't show on 10. Also tried 10.1-10.9, only the 10.0 one appeared.
I can't seem to find a explanation on what the pipe does. What I thought it did didn't work. I see 4 different uses between winapp2.ini and winapp.ini
(6.3 for example)
DetectOS=6.3
DetectOS=6.3|6.3
DetectOS=|6.3
DetectOS=6.3|
Link to post
  • Moderators
The pipe means that versions on the pipe side will not work
I believe, but may be wrong, you want |10.0
Link to post
Added FileKey9
[Skype Temporary Files*]
LangSecRef=3022
Detect=HKCU\Software\Skype
Default=False
FileKey1=%AppData%\Skype\DbTemp|*.*|RECURSE
FileKey2=%AppData%\Skype|*.tmp|RECURSE
FileKey3=%AppData%\Skype\|*.db-journal|RECURSE
FileKey4=%AppData%\Skype\*\simcache|*.*
FileKey5=%AppData%\Skype\*\httpfe|*.*
FileKey6=%AppData%\Skype\*\ecache|*.*
FileKey7=%AppData%\Skype\DataRv|*.*
FileKey8=%AppData%\Skype\*\media_messaging\media_cache|*.*
FileKey9=%AppData%\Skype\*\media_messaging\media_cache*|*.*
FileKey10=%AppData%\Skype\*\media_messaging\storage_db\asyncdb\tmp|*.*
FileKey11=%AppData%\Skype\*\media_messaging\media_cache\asyncdb\tmp|*.*
FileKey12=%AppData%\Skype\*\qikdb\tmp|*.*
FileKey13=%AppData%\Skype\*\logs|*.*
FileKey14=%UserProfile%\Tracing\WPPMedia\*.*|RECURSE
Link to post
New Rule:
[Privacy Badger*]
LangSecRef=3026
SpecialDetect=DET_MOZILLA
Default=False
Warning=This will remove all filter settings.
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\jetpack\jid1-MnnxcxisBPnSXQ-eff@jetpack\simple-storage|store.json
Privacy Badger saves all visited domains in that file and is thereby ironically a privacy threat itself.
Link to post
New Rule:
[Privacy Badger*]
LangSecRef=3026
Default=False
maybe need to change the warning to This will remove all settings or Reset to default
removing store.json not only delete custom filter setting but all setting including "Whitelisted Domains" and "Other Settings"
imo, removing store.json will make PB useless
you need to start over again to create new db and custom filter setting for website that doesn't load properly with PB enable
Link to post
It didn't remove "Other Settings" for me. "Whitelisted Domains" I don't know about.
It's true though that PB has to relearn which sites are tracking the user. That's why I put the warning.
Link to post
  • Moderators
Remeber that 99% of warnings are ignored or misunderstood by users. A warning is only shown once (when the user makes a checkmark in the entry). A warning does not and should not excuse bad behavior (such as removal of settings) in the case of public winapp2.ini entries (what the developers do is out of my hands but this thread isn't).
Link to post
(6.3 for example)
DetectOS=6.3
DetectOS=6.3|6.3
DetectOS=|6.3
DetectOS=6.3|
You're right, these entries work with DetectOS=10.0 except for the [store*] entry, as there is one already there with the same name. How should we handle this now?
Link to post
Revised Entry
Removed because this path never existed in any Windows: FileKey3=%AppData%\Microsoft\CryptnetUrlCache|*.*|RECURSE
[Cached Certification Files*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
Link to post
You're correct! There was one value that was being removed and that was causing the issue. Please look at the attached snapshot.
Revised Entry
Changed FileKey1 & RegKey1
[Notification Cache*]
DetectOS=6.2|
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm
If anyone got affected because of this entry and some of their Windows 10 built-in apps are not working, they can run the command listed below using PowerShell as Administrator.
Get-AppxPackage -AllUsers| Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”}
http://www.howtogeek.com/224798/how-to-uninstall-windows-10s-built-in-apps-and-how-to-reinstall-them/
Link to post
I tried with both [store*]'s, the one you posted and the one already in winapp2.ini. Only the new one showed. So at least they are separate.. But it might need a rename so a duplicate finder doesn't remove one.
This works! I was fiddling with the the FileKey so that explains why I couldn't get it.
Link to post
Revised Entry
LangSecRef=3025
Default=False
Win XP
Link to post
Win XP
There is a difference between %AppData%\Microsoft\CryptnetUrlCache and Documents and Settings\zak\Application Data\Microsoft\CryptnetUrlCache. I think we should add Win XP location in that entry.
Link to post
I added both [store*] entries and none of them showed up. When I removed the Windows 8 [store*] entry, then the [store*] entry with DetectOS=10.0 started showing up.
Link to post
%AppData%
 - Windows XP: C:\Documents and Settings\{username}\Application Data
 - Windows Vista/7: C:\Users\{username}\AppData\Roaming
the entry is ok
no need to remove FileKey3
Link to post
New Entries
[sourceHash Files*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\Installer|SourceHash*
[wix Files*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\Installer|wix*
Link to post
  • Moderators
New Entries
[sourceHash Files*]
LangSecRef=3025
Default=False
[wix Files*]
LangSecRef=3025
Default=False
any links for us to learn what either SourceHash or Wix are for (it would help so we can decide on the junkiness of the removed)
Link to post
I have opened each and every file with Notepad to see the content. I'm attaching a SourceHash file's content with this message. Also, I asked a question in the WindowsTen Forums and here is the response: http://www.tenforums.com/general-discussion/34528-what-these-sourcehash-files.html
Link to post
  • Moderators
My guess is the hash are not safe to remove as they may break Windows Update and/or future updates.
Link to post
After reading the contents of the files, I don't think they have to do anything with Windows update.
Link to post
I have opened each and every file with Notepad to see the content. I am pasting a few files' content here. Also, I have asked a question in the WindowsTen Forums and here is the response: http://www.tenforums.com/general-discussion/34528-what-these-sourcehash-files.html
So you're suggesting an entry to delete items that you don't even know the function of?
Link to post
As per my understanding, these files hold the msi installers' content information.
Link to post
Register a new account
Sign in
