Winapp2.ini additions
Winapp2.ini
I think there is some miscommunication here.
@SMalik is correct, he already listed the ones which need be removed the post he linked specifically called out many entries.Either somebody can refute them (one-by-one) or they should be wholesale removed and let members resubmit entries without reg backup removal
I of course meant for him to push the removals to the template, don't be stubborn for little reason.
The following is just my opinion:
I continue to feel that all these cleaning modules should not be removed from Winapp2.ini.  Most of them have been present in Winapp2.ini for years.  The user base of Winapp2.ini who utilize them (one or many of them) is accustomed to them doing their cleaning work.  I suspect that most of the users will be unaware that these cleaner modules have suddenly disappeared...that is, unless the read the monthly release notes...which many users probably do not.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
i think it would be better if we remove the entries from winapp2.ini and put it in another file for NSFW entries which include entries like Nvidia Installer2 and Language cleanup entries
its up to user if they want to add it or not
for me, i think winapp2.ini(user) already done that in form of changes.txt and changes_old3.txt
if they come here looking for the entries, we can just point to them where to find it
i think this will help to decrease people come here reporting problems with cc, for those who use Voldemort to download winapp2.ini
Link to comment
Revised Entry
Removed: FileKey3=%AppData%\East-Tec\east-tec Eraser|*.rst
.rst is a file extension that holds any error details and sometimes, East-Tec needs it to resolve issues.
[east-tec Eraser*]
LangSecRef=3024
Detect=HKLM\Software\East-Tec\east-tec Eraser
Default=False
FileKey1=%ProgramFiles%\east-tec Eraser|except.log
FileKey2=%CommonAppData%\East-Tec\east-tec Eraser\Updates|*.*|RECURSE
Link to comment
@tss
i think its this tail in winapp...
i dont know exactly how it work but how is it with delete this section?
i use shortcuts in quickstartbar too on w8.1 :-)
@trium
No, actually it was the "Compatibility Assistant" under the "Windows" section (in winapp2.ini)
Link to comment
  • Moderators
@tss
@trium
I just can't see how that's possible as this is that entry, which touches nothing in file explorer and the reg keys it removes are not related to the quicklaunch bar or pinning.
[Compatibility Assistant*] LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant
Warning=The will clear compatibility settings for some applcations.
Default=False
RegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted
RegKey2=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store
RegKey3=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
RegKey4=HKLM\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
RegKey5=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted
RegKey6=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store
Link to comment
  • Moderators
Do you have any plan to release Winapp2.ini this month?
My guess is he, as a young man, is probably working on finals and/or with his family for fall/winter holidays
Link to comment
Hi folks! So sorry I've been gone :lol:
I'm buried under a back-log of school work (that wasn't able to be dealt with over the holidays for technical reasons). It's all due tomorrow so I'll probably get to updating the file/site on Saturday
Sorry for the delay! :)
Link to comment
Don't worry, take your time.
Link to comment
Please remove the entries listed below as they are already in the CCleaner TeamViewer entry.
[TeamViewer Connections*]
LangSecRef=3024
DetectFile=%AppData%\TeamViewer
Default=False
FileKey1=%AppData%\TeamViewer|Connections.txt
[TeamViewer Temporary Files*]
LangSecRef=3024
Detect=HKCU\Software\TeamViewer
Default=False
FileKey1=%ProgramFiles%\TeamViewer|*.tmp|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\TeamViewer|*.tmp|RECURSE
CCleaner's TeamViewer entry
[TeamViewer]
ID=2395
LangSecRef=3024
Default=True
RegKey1=HKCU\Software\TeamViewer\Version9|MRU
FileKey1=%ProgramFiles%\TeamViewer\*|*.tmp|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\TeamViewer\*|*.tmp|RECURSE
FileKey3=%ProgramFiles%\TeamViewer\Version9|Connections_incoming.txt
FileKey4=%AppData%\TeamViewer|Connections.txt
FileKey5=%AppData%\TeamViewer\MRU\RemoteSupport|*.tvc
Link to comment
Found out my issue with StarCraft 2 entries.
Edit:
[starCraft II Logs*]
Section=Games
Detect1=HKCU\Software\Blizzard Entertainment\StarCraft II
Detect2=HKLM\Software\Wow6432Node\Blizzard Entertainment\StarCraft II
FileKey1=%ProgramFiles%\Starcraft II\Logs|*.*
FileKey2=%Public%\games\Starcraft II\Logs|*.*
FileKey3=%SystemDrive%\Starcraft II\Logs|*.*
FileKey4=%Documents%\StarCraft II\GameLogs|*.*|RECURSE
FileKey5=%LocalAppData%\VirtualStore\Program Files*\Starcraft II\Logs|*.*
FileKey6=%Documents%\StarCraft II\UserLogs|*.*|RECURSE
Added Detect2, for people who play StarCraft 2 in 64-bit, which happened after the 3.0 patch for the game.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
  • Moderators
 Added Detect2 to the above entries. This is for people who play StarCraft 2 in 64-bit, which happened after the 3.0 patch for the game.
Awesome thanks...not that I use starcraft, but I appreciate the members of this thread reseaching and finding cause of issues. This benefits all.
Link to comment
New Entry for Full Licensed Ashampoo Burning Studio 16:  [Ashampoo Burning Studio 16*]
LangSecRef=3024
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16
Default=False
FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 16\log|*.xml;*.txt
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\tempFiles
Link to comment
@Winapp2.ini Please release the file whenever you get a chance. Do not make us wait until next month becasue there are lot of useful entries which we have provided and modified this time. We don't want to lose some of the entries.
Link to comment
New Entries
Windows 10 Store Apps. DetectOS=10.0| not working. Should we remove DetectOS=10.0|?
[Cortana*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Cortana_cw5n1h2txyewy
FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\Temp|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalCache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\Cache|*.*|RECURSE
FileKey11=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\TempState|*.*|RECURSE
[Cloud Experience Host*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.CloudExperienceHost_cw5n1h2txyewy
FileKey1=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalState\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\TempState|*.*|RECURSE
[Content Delivery Manager*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy
FileKey1=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalState\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\TempState|*.*|RECURSE
[Messaging*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Messaging_8wekyb3d8bbwe
FileKey1=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Messaging_*\LocalCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.Messaging_*\LocalState\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.Messaging_*\TempState|*.*|RECURSE
[store*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsStore_8wekyb3d8bbwe
FileKey1=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.WindowsStore_*\LocalCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.WindowsStore_*\LocalState\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.WindowsStore_*\TempState|*.*|RECURSE
[XboxApp*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxApp_8wekyb3d8bbwe
FileKey1=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.XboxApp_*\TempState|*.*|RECURSE
[Xbox Identity Provider*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxIdentityProvider_cw5n1h2txyewy
FileKey1=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_\AC\Microsoft\CLR_v4.0|*.log|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_\AC\Microsoft\CLR_v4.0\NativeImages\Temp|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_\AC\Microsoft\CLR_v4.0_32|*.log|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_\AC\Microsoft\CLR_v4.0_32\NativeImages\Temp|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Temp|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalCache|*.*|RECURSE
FileKey11=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalState\Cache|*.*|RECURSE
FileKey12=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\TempState|*.*|RECURSE
Link to comment
On 12/11/2015 at 12:43, Coffee4Joe said:
those DetectOS's should work fine. They show on 10 but not 8/8.1.
The Store Apps entries I provided above do not work with DetectOS=10.0|, but they do work when DetectOS=10.0| is not there.
Link to comment
This is the list of all temp and tmp folders on my OS drive.  Format is:
number of sub-folders, number of files in sub-folders, total size of all files in sub-folders, and the root folder
[C:\]global /h /i /n /q if "%@name[%_CWD]" eq "temp" .or. "%@name[%_CWD]" eq "tmp" echo %@format[5,%@files[/s *,d]] %@format[5,%@files[/s *,-d]] %@format[12,%@filesize[/s *,bc]]  %_cwd
    0     1        2,403  C:\My Programs\Express Archiver\Temp
    0     2          300  C:\My Programs\JDownloader v2.0\.install4j\user\tmp
    0     0            0  C:\My Programs\JDownloader v2.0\tmp
    1     0            0  C:\Program Files\UltraDefrag\tmp
    0     0            0  C:\Program Files (x86)\Hp\Temp
    0     0            0  C:\Program Files (x86)\Temp
    0     0            0  C:\ProgramData\HP\Installer\Temp
    0     0            0  C:\ProgramData\Microsoft\IdentityCRL\production\temp
    0     0            0  C:\ProgramData\Microsoft\RAC\Temp
    0     1            0  C:\Users\Administrator\AppData\Local\Temp
    0     0            0  C:\Users\Default\AppData\Local\Temp
    0     0            0  C:\Users\Galloway\AppData\Local\Amazon Music\Data\Artwork Cache\tmp
    5    20      894,147  C:\Users\Galloway\AppData\Local\Temp
    0     0            0  C:\Users\Galloway\AppData\LocalLow\Microsoft\Windows Live\Setup\tmp
  178   195      567,464  C:\Users\Galloway\AppData\LocalLow\Sun\huksfmgzyj\Temp
    1     0            0  C:\Users\Galloway\AppData\LocalLow\Sun\Java\Deployment\tmp
    1     1       24,040  C:\Users\Galloway\AppData\LocalLow\Sun\Yguwhql\Temp
    0     0            0  C:\Users\Galloway\AppData\Roaming\aignes\AM-DeadLink\temp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Microsoft\IdentityCRL\temp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Multi Edit Software\Multi-Edit\11\Config.04\Tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\csgalloway27609\media_messaging\emo_cache\asyncdb\tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\csgalloway27609\media_messaging\media_cache_v2\asyncdb\tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\csgalloway27609\media_messaging\storage_db\asyncdb\tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\csgalloway27609\qikdb\tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\live#3acharlessgalloway\media_messaging\emo_cache\asyncdb\tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\live#3acharlessgalloway\media_messaging\media_cache\asyncdb\tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\live#3acharlessgalloway\media_messaging\storage_db\asyncdb\tmp
    0     0            0  C:\Users\Galloway\AppData\Roaming\Skype\live#3acharlessgalloway\qikdb\tmp
    0     0            0  C:\Windows\assembly\NativeImages_v2.0.50727_32\Temp
    0     0            0  C:\Windows\assembly\NativeImages_v2.0.50727_64\Temp
    0     0            0  C:\Windows\assembly\NativeImages_v4.0.30319_32\Temp
    0     0            0  C:\Windows\assembly\NativeImages_v4.0.30319_64\Temp
    0     0            0  C:\Windows\assembly\temp
    0     0            0  C:\Windows\assembly\tmp
    1     1        8,493  C:\Windows\System32\DriverStore\Temp
    1   152   30,716,215  C:\Windows\Temp
    2     4      774,144  C:\Windows\winsxs\Temp
[C:\]temp\
It's after running Disk Cleanup (also including Windows Update files) running CCleaner with latest Winapp2.ini, restarting the comptuer, then letting Windows updates do a lot of processing before I selected what Windows user account I wanted to use...
Not sure why so many in Windows Temp, or in these:
Link to comment
  • Moderators
@CSGalloway not every temp file has the same weight. On top of that you have been involved in this thread long enough to know how to properly make and submit an entry and what you gave here is not that.
Just glancing at your list i see at least one winsxs entry; please see my reply in @trium's latest thread explaining why sxs isn't supposed to be touched by anything but official windows tools.
The last that you asked about is likely for Java
Link to comment
Register a new account
Sign in
Important Information
