Moderators Nergal Posted November 26, 2015 Moderators Share Posted November 26, 2015 A quick question I have, whats the difference if any, between downloading winapp2 file and running the .bat file to trim it manually vs using [Voldemort]? I gave [Voldemort] a try for the first time yesterday and it produced a winapp2.ini 54KB's in size vs the one I trim manually with the .bat file that was 71KB's in size. From what I could tell at a glance while running CCleaner, everything was there. As I stated in the post above yours, it is not possible to discuss the existence of ccleaner enhancing software on this forum. I've removed your reference with the accepted name however I will have to forbid this question from being answered or discussed. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
SMalik Posted November 26, 2015 Share Posted November 26, 2015 Well, I wonder what this program is that I installed yesterday from the Ashampoo website. BurningStudio2016.png Link to comment Share on other sites More sharing options...
siliconman01 Posted November 26, 2015 Share Posted November 26, 2015 abs16.PNG Yes, and I will most likely install the paid version when it is released. However, I still do not see how this negates my recommended change at post #5238. There are a lot of programs that have a free and paid version and have the same cleaner in Winapp2.ini. ?? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted November 26, 2015 Share Posted November 26, 2015 Yes, and I will most likely install the paid version when it is released. However, I still do not see how this negates my recommended change at post #5238. There are a lot of programs that have a free and paid version and have the same cleaner in Winapp2.ini. ?? I don't support that. Like in this case, both programs are different so that's why there should be separate entries. Link to comment Share on other sites More sharing options...
SMalik Posted November 26, 2015 Share Posted November 26, 2015 Revised Entry Please use this one instead of the one I posted above. Included history.xml into%CommonAppData%\Avg\log\AV16|history.xml;*.log;*.log.*;*.log.lock%LocalAppData%\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lock%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lockAdded:%WinDir%\System32\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF%WinDir%\SysWOW64\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF [AVG Protection*]LangSecRef=3024Detect=HKLM\SOFTWARE\AVG\AVDefault=FalseFileKey1=%ProgramFiles%\AVG\Av|updatecomps.bak;*.oldFileKey2=%CommonAppData%\Avg\AV\Antispam|*.tmp;*.tmp1;*.tmp2;*.gzFileKey3=%CommonAppData%\Avg\AV\SetupBackup|*.*|REMOVESELFFileKey4=%CommonAppData%\Avg\log\AV16|history.xml;*.log;*.log.*;*.log.lockFileKey5=%CommonAppData%\Avg\log\fmw1|*.log;*.log.*;*.log.lockFileKey6=%CommonAppData%\MFAData\logs|*.*FileKey7=%CommonAppData%\MFAData\pack|*.*FileKey8=%CommonAppData%\MFAData|msistorg.dat.bkp;public_installation_log.xmlFileKey9=%LocalAppData%\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lockFileKey10=%LocalAppData%\Avg\log\fmw1|*.log;*.log.*;*.log.lockFileKey11=%LocalAppData%\AvgSetupLog|*.*|REMOVESELFFileKey12=%LocalAppData%\MFAData\logs|*.*FileKey13=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\av16\temp|*.*FileKey14=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lockFileKey15=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log\fmw1|*.log;*.log.*;*.log.lockFileKey16=%WinDir%\System32\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELFFileKey17=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\av16\temp|*.*FileKey18=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log\av16|history.xml;*.log;*.log.*;*.log.lockFileKey19=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log\fmw1|*.log;*.log.*;*.log.lockFileKey20=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 New Entry [Auslogics Disk Defrag Professional*]LangSecRef=3024Detect1=HKLM\SOFTWARE\Auslogics\Disk Defrag ProfessionalDetect2=HKLM\SOFTWARE\WOW6432Node\Auslogics\Disk Defrag ProfessionalDefault=FalseFileKey1=%CommonAppData%\Auslogics\Disk Defrag Professional\*\Logs|*.*|RECURSEFileKey2=%CommonAppData%\Auslogics\Disk Defrag Professional\*\Reports|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 New Entry [Auslogics Registry Cleaner 5*]LangSecRef=3024Detect1=HKLM\Software\Auslogics\Registry Cleaner\5.XDetect2=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.XDefault=FalseWarning=This will remove your backups, and you will be unable to undo any changes you made with Auslogics Registry Cleaner.FileKey1=%CommonAppData%\Auslogics\Registry Cleaner\5.X\Rescue\Auslogics Registry Cleaner|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Auslogics\Registry Cleaner\5.X\Rescue\Auslogics Registry Cleaner|*.*|RECURSERegKey1=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey2=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey3=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey4=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey5=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.LastScanRegKey6=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey7=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey8=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey9=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey10=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.LastScan I remember the discussion we had before on this entry. Since we have not removed any other registry cleaner entries from Winapp2.ini, we should add this entry. http://forum.piriform.com/index.php?showtopic=32310&page=253&do=findComment&comment=264474 Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 New Entry [PerfectDisk 14.0*]LangSecRef=3024Detect=HKCU\Software\Raxco\PerfectDisk\14.0Default=FalseFileKey1=%CommonAppData%\Raxco\PerfectDisk\14.0|PDBootLog Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 Revised Entry Added *.txt into FileKey1 and FileKey2 [PerfectDisk More*]LangSecRef=3024Detect=HKCU\Software\Raxco\PerfectDiskDefault=FalseFileKey1=%CommonAppData%\Raxco\PerfectDisk\*|*.log;*.txtFileKey2=%LocalAppData%\VirtualStore\ProgramData\Raxco\PerfectDisk\*|*.log;*.txt Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 Revised Entry Changed the Detect [Auslogics Disk Defrag*]LangSecRef=3024Detect1=HKLM\SOFTWARE\Auslogics\DiskDefragDetect2=HKLM\SOFTWARE\WOW6432Node\Auslogics\DiskDefragDefault=FalseFileKey1=%CommonAppData%\Auslogics\DiskDefrag\*\Logs|*.*|*.*|RECURSEFileKey2=%CommonAppData%\Auslogics\DiskDefrag\*\Reports|*.*|*.*|RECURSE Link to comment Share on other sites More sharing options...
JDPower Posted November 27, 2015 Share Posted November 27, 2015 I remember the discussion we had before on this entry. Since we have not removed any other registry cleaner entries from Winapp2.ini, we should add this entry. http://forum.piriform.com/index.php?showtopic=32310&page=253&do=findComment&comment=264474 And it still won't, and shouldn't, be added, no matter how many times you post it. Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 And it still won't, and shouldn't, be added, no matter how many times you post it. I just wanted your lives to be easier. That program leaves lots of traces that are harder to delete manually. Read what you said before http://forum.piriform.com/index.php?showtopic=32310&p=264484 My response http://forum.piriform.com/index.php?showtopic=32310&p=264572 Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 How about this @siliconman01? New Entry [Ashampoo Burning Studio 2016*]LangSecRef=3024Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016Default=FalseFileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 2016\log|*.xml;*.txtRegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectoryRegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\tempFiles Link to comment Share on other sites More sharing options...
ROCKNROLL Posted November 27, 2015 Share Posted November 27, 2015 [starCraft II Logs*]Section=GamesDetect=HKCU\Software\Blizzard Entertainment\StarCraft IIFileKey1=%ProgramFiles%\Starcraft II\Logs|*.*FileKey2=%Public%\games\Starcraft II\Logs|*.*FileKey3=%SystemDrive%\Starcraft II\Logs|*.*FileKey4=%Documents%\StarCraft II\GameLogs|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\Program Files*\Starcraft II\Logs|*.*FileKey6=%Documents%\StarCraft II\UserLogs|*.*|RECURSE The detect on this entry, the registry key it is pointing to, does not exist on my system, however I am still getting log files that the FileKeys are pointing to. Was the registry key changed in a StarCraft 2 update? Can anyone else confirm this? I am on a Windows 10 64-bit and I also play StarCraft in 64-bit (since you can play it in either 32-bit or 64-bit). I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
JDPower Posted November 27, 2015 Share Posted November 27, 2015 I just wanted your lives to be easier. That program leaves lots of traces that are harder to delete manually. Read what you said before http://forum.piriform.com/index.php?showtopic=32310&p=264484 My response http://forum.piriform.com/index.php?showtopic=32310&p=264572 I was involved in that discussion, I know what was said. But the ethos of CCleaner right from day one was to be a SAFE cleaner, and not deleting registry backups has always fallen into that category. The solution to the entries that shouldn't be there is to remove/edit them, not add more. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 27, 2015 Moderators Share Posted November 27, 2015 The solution to the entries that shouldn't be there is to remove/edit them, not add more.And (as I believe I stated before) the only way to change/remove them is for community members to point out the entries which overstep this guideline, so @Winapp2.ini can cull them. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
JDPower Posted November 27, 2015 Share Posted November 27, 2015 And (as I believe I stated before) the only way to change/remove them is for community members to point out the entries which overstep this guideline, so @Winapp2.ini can cull them. I was referring to them being changed/removed by members, not winapp2 himself, he already does more than enough! Link to comment Share on other sites More sharing options...
siliconman01 Posted November 27, 2015 Share Posted November 27, 2015 How about this @siliconman01? New Entry [Ashampoo Burning Studio 2016*] LangSecRef=3024 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016 Default=False FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 2016\log|*.xml;*.txt RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\tempFiles This is okay by me if it is not desirable to combine and use the one I submitted. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted November 27, 2015 Share Posted November 27, 2015 And (as I believe I stated before) the only way to change/remove them is for community members to point out the entries which overstep this guideline, so @Winapp2.ini can cull them. I don't understand this logic. If Auslogic Registry Cleaner is dangerous because it removes backup files made by that program, then all of the programs in the post listed below do the same. http://forum.piriform.com/index.php?showtopic=32310&page=253&do=findComment&comment=264572 Link to comment Share on other sites More sharing options...
JDPower Posted November 27, 2015 Share Posted November 27, 2015 I don't understand this logic. If Auslogic Registry Cleaner is dangerous because it removes backup files made by that program, then all of the programs in the post listed below do the same. http://forum.piriform.com/index.php?showtopic=32310&page=253&do=findComment&comment=264572 Correct, they should not be there, but until a member edits and submits (or suggests complete removal) of those entries they will remain. It's not that hard to understand. This is a COMMUNITY built file, all @Winapp2.ini does is compile all the entries into the downloadable file for US (no small job in itself). He is not a developer, he does this in his own free time and can't be expected to go through them all himself. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 28, 2015 Moderators Share Posted November 28, 2015 (edited) I think there is some miscommunication here. @SMalik is correct, he already listed the ones which need be removed the post he linked specifically called out many entries. Here are some entries that remove registry cleaner/uninstall backups. In fact, all of the entries that remove backups should be removed. The entries that have a warning should also be removed. Acebytes Ace Utilities AMUST Registry Cleaner Undo Data Auslogics (All programs) AVG PC TuneUp & TuneUp Utilities (Backups) CleanMyPC Registry Cleaner Eusing Free Registry Cleaner Backups Glary Utilities (Backups) IObit Advanced SystemCare (All) jv16 PowerTools (All) jv16 PowerTools Reg Compact Backups NirSoft RegScanner Backups Perfect Registry RegClean Pro RegCleaner 4.3 Registry Clean Expert Registry First Aid (Backups) Registry Mechanic Reg Organizer (Backups) Revo Uninstaller Backups System Mechanic SystemTuneUp Total Uninstall Backups Total Uninstall Free Backups TweakNow PowerPack 2005 Uniblue Registry Booster 2(Backups) Uniblue Registry Booster(Backups) WinASO Registry Optimizer (Backups) Either somebody can refute them (one-by-one) or they should be wholesale removed and let members resubmit entries without reg backup removal I was referring to them being changed/removed by members, not winapp2 himself, he already does more than enough!I of course meant for him to push the removals to the template, don't be stubborn for little reason. Edited November 28, 2015 by Nergal tapatalk removes hard returns ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
ROCKNROLL Posted November 28, 2015 Share Posted November 28, 2015 [starCraft II Logs*] Section=Games Detect=HKCU\Software\Blizzard Entertainment\StarCraft II FileKey1=%ProgramFiles%\Starcraft II\Logs|*.* FileKey2=%Public%\games\Starcraft II\Logs|*.* FileKey3=%SystemDrive%\Starcraft II\Logs|*.* FileKey4=%Documents%\StarCraft II\GameLogs|*.*|RECURSE FileKey5=%LocalAppData%\VirtualStore\Program Files*\Starcraft II\Logs|*.* FileKey6=%Documents%\StarCraft II\UserLogs|*.*|RECURSE The detect on this entry, the registry key it is pointing to, does not exist on my system, however I am still getting log files that the FileKeys are pointing to. Was the registry key changed in a StarCraft 2 update? Can anyone else confirm this? I am on a Windows 10 64-bit and I also play StarCraft in 64-bit (since you can play it in either 32-bit or 64-bit). *Ahem* I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
JDPower Posted November 28, 2015 Share Posted November 28, 2015 I of course meant for him to push the removals to the template, don't be stubborn for little reason. I wasn't being stubborn, was just clarifying that I was AGREEING with you to make sure there was no misunderstanding. Now my clarification of misunderstanding has been misunderstood. Not quite sure how you correct a misunderstood misunderstanding, that's like dividing by zero or something ain't it Link to comment Share on other sites More sharing options...
SMalik Posted November 28, 2015 Share Posted November 28, 2015 URGENT Weather, Store and Xbox Metro Apps entries are causing these apps to constantly crash in Windows 10. Link to comment Share on other sites More sharing options...
Tr3bg0D Posted November 28, 2015 Share Posted November 28, 2015 Will be there be an update to WINAPP2.INI? V5.11.151026 is still posted Link to comment Share on other sites More sharing options...
