CCleaner Community Forums
Winapp2.ini additions
  • Moderators
Maybe we could trim/clear up Winapp2.ini a little bit and remove "Firefox" from:
Can't because of duplication of names but want/need for thunderbird and firefox to be seperate. If two items have the same name only one of them is shown
Link to post
  • Moderators
Hello winapp2 community. Can someone tell me where I can download the previous version of winapp2, the october last month one? I am working on improving winapp2 for the BleachBit community, as I had the ok from Andrew, and I forgot to revise some entries and I lost my copy from october.
Who is andrew, and we're not actually supposed to actively support the importation of winapp2 to other software here in the public forum.
IMVH you are on your own with this quest.
Link to post
Ah true, ok then. :(
Who is andrew, and we're not actually supposed to actively support the importation of winapp2 to other software here in the public forum. IMVH you are on your own with this quest.
Maker of BleachBit.
Link to post
Doesn't FileKey1 make your new additions of FileKey2 & 3 redundant?
[blueStacks Logs*]
LangSecRef=3021
Detect=HKCU\Software\Bluestacks
Detect2=HKLM\Software\Bluestacks
Default=False
FileKey1=%CommonAppData%\BlueStacks|*.log|RECURSE
FileKey2=%CommonAppData%\BlueStacks\Logs|*.log
FileKey3=%CommonAppData%\BlueStacks\UserData\Logs|*.log.*
Link to post
updated
Just a thought - would it not be better to release winapp2 updates well apart from CCleaner releases? Doesn't releasing at the same(ish) time increase the chances of potential bugs caused by winapp2 being erroneously reported elsewhere on the forum as CC bugs?
Link to post
  • Moderators
Correction:
[K-Lite Codec Pack*]
LangSecRef=3023
Detect=HKLM\Software\KLCodecPack
Default=False
FileKey1=%ProgramFiles%\K-Lite|*.log;*.txt|RECURSE
FileKey2=%ProgramFiles%\K-Lite Codec Pack|*.log;*.txt|RECURSE
FileKey3=%SystemDrive%|*klcp_itp_*.tmp
RegKey1=HKU\S-1-5-21-1409082233-152049171-725345543-500\Software\Gabest\vsfilter\DefTextPathes|Path0
RegKey2=HKU\S-1-5-21-1409082233-152049171-725345543-500\Software\Gabest\vsfilter\DefTextPathes|Path1
RegKey3=HKU\S-1-5-21-1409082233-152049171-725345543-500\Software\Gabest\vsfilter\DefTextPathes|Path2
- Corrected FileKey numerical order in winapp2.ini 4.08.131125
I find the registry paths here:
HKEY_CURRENT_USER\Software\Gabest\VSFilter\DefTextPathes
Also taken from the default registry settings the hint it has in it is interesting:
[HKEY_CURRENT_USER\Software\Gabest\VSFilter\DefTextPathes]
"Hint"="The first three are fixed, but you can add more up to ten entries."
"Path0"="."
"Path1"="c:\\subtitles"
"Path2"=".\\subtitles"
Link to post
  • Moderators
What you think?
Probably, but at the same time maybe it could make the stuff harder to find.
Edit:
Saw Nergals post a few up from this one about duplicate names. So it wouldn't work.
Edited by Andavari
Link to post
New Entry
[MAGIX Video Pro X5*]
LangSecRef=3023
Detect=HKCU\Software\MAGIX AG\Videodeluxe19_pro
Default=False
FileKey1=%AppData%\MAGIX\Video Pro X5|*.log
FileKey2=%Documents%\MAGIX\Video Pro X5\AudioTemp|*.*|RECURSE
RegKey1=HKCU\Software\MAGIX AG\Videodeluxe19_pro\ExportConfigurator\DialogItems|LastFile
RegKey2=HKCU\Software\MAGIX AG\Videodeluxe19_pro\ExportConfigurator\DialogItems|LastPreset
Link to post
Thanks Andavari.
Edit:
They are in both HKU and HKCU.
On my PC the existing rule cleans both.
Link to post
Revised Entries
Corrected the RegKey2
[Windows Compatibility Assistant*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant
Default=False
RegKey1=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted
RegKey2=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store
RegKey3=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted
RegKey4=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store
Changed from CurrentControlSet to ControlSet001. The values were not being wiped since CurrentControlSet is always in use.
Also added RegKey3 and RegKey4
[Windows Session Manager*]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\AppCompat\Programs|*.xml
FileKey2=%WinDir%\AppCompat\Programs\Install|*.xml
RegKey1=HKLM\SYSTEM\ControlSet001\Control\Session Manager|PendingFileRenameOperations
RegKey2=HKLM\SYSTEM\ControlSet001\Control\Session Manager\AppCompatCache|AppCompatCache
RegKey3=HKLM\SYSTEM\ControlSet001\Control\Session Manager\AppCompatCache|CacheMainSdb
RegKey4=HKLM\SYSTEM\ControlSet001\Control\Session Manager\AppCompatCache|SdbTime
Link to post
Didn't we agree these shouldn't be in winapp2?
[ERUNT - Windows Vista Registry Backups*]
LangSecRef=3024
DetectOS=|6.0
DetectFile1=%ProgramFiles%\ERUNT\ERUNT.EXE
DetectFile2=%ProgramFiles%\ERUNT\NTREGOPT.EXE
Default=False
Warning=This will remove all Registry backups made by "Emergency Recovery Utility NT".
FileKey1=%WinDir%\ERDNT|*.*|REMOVESELF
FileKey2=%WinDir%\system32\config|*.bak;*.tmp.LOG1;*.tmp.LOG2
FileKey3=%UserProfile%|NTUSER.bak;NTUSER.tmp.LOG1;NTUSER.tmp.LOG2
FileKey4=%SystemDrive%\Boot|BCD.bak;BCD.tmp.LOG1;BCD.tmp.LOG2
FileKey5=%LocalAppData%\Microsoft\Windows|UsrClass.bak;UsrClass.tmp.LOG1;UsrClass.tmp.LOG2
FileKey6=%WinDir%\ServiceProfiles\LocalService|ntuser.bak;ntuser.tmp.LOG1;ntuser.tmp.LOG2
FileKey7=%WinDir%\ServiceProfiles\NetworkService|ntuser.bak;ntuser.tmp.LOG1;ntuser.tmp.LOG2
[ERUNT - Windows XP Registry Backups*]
LangSecRef=3024
DetectOS=|5.1
Default=False
FileKey4=%AppData%\Microsoft\Windows|UsrClass.bak;UsrClass.tmp.LOG
FileKey5=%SystemDrive%\Documents and Settings\Administrator|NTUSER.bak;NTUSER.tmp.LOG
FileKey6=%SystemDrive%\Documents and Settings\Administrator\Local Settings\Application Data
FileKey7=%SystemDrive%\Documents and Settings\LocalService|NTUSER.bak;NTUSER.tmp.LOG
FileKey8=%SystemDrive%\Documents and Settings\LocalService\Local Settings\Application Data
FileKey9=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.bak;NTUSER.tmp.LOG
FileKey10=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Application Data
FileKey11=%SystemDrive%\Documents and Settings\Default User|NTUSER.bak;NTUSER.tmp.LOG
Link to post
Also a duplicated entry:
[Windows Log Files More*]
LangSecRef=3025
DetectFile=%windir%\Panther
Default=False
FileKey1=%windir%\PANTHER|
LangSecRef=3025
Default=False
FileKey1=%WinDir%\inf|setupapi.offline.log
FileKey2=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html
FileKey3=%WinDir%\winsxs|poqexec.log
FileKey4=%WinDir%\debug\WIA|*.log
FileKey5=%WinDir%|SIGVERIF.TXT
FileKey6=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml
FileKey7=%WinDir%\Panther|PostGatherPnPList.log;PreGatherPnPList.log
FileKey8=%WinDir%\Panther\UnattendGC|diagerr.xml;diagwrn.xml
Link to post
Me again lol. These two entries could probably be combined
[stellarium Cache*]
LangSecRef=3021
DetectFile=%AppData%\Stellarium
Default=False
FileKey1=%LocalAppData%\Stellarium\Cache|*.*|RECURSE
[stellarium*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Stellarium|log.txt
...into:
[*Stellarium]
LangSecRef=3021
Default=False
FileKey2=%LocalAppData%\Stellarium\Cache|*.*|RECURSE
Link to post
New Entry
[Ashampoo Burning Studio 14*]
LangSecRef=3024
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14
Default=False
FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 14|backupmetainfo.xml
FileKey2=%AppData%\Ashampoo\Ashampoo Burning Studio 14\Log|*.xml;*.txt
FileKey3=%AppData%\Ashampoo\Log|*.txt
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\tempFiles
Link to post
More suggestions - there are several Photoshop related entries spread across 3 separate sections, I would suggest they all go in 'Applications' and therefore the following corrections:
[Adobe Bridge CS6 Cache*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Bridge CS6\
Default=False
FileKey1=%AppData%\Adobe\Bridge CS6\Cache|*.*|RECURSE
[Adobe Camera Raw Cache*]
LangSecRef=3021
DetectFile=%LocalAppData%\Adobe\CameraRaw\Cache
Default=False
FileKey1=%LocalAppData%\Adobe\CameraRaw\Cache|*.*|RECURSE
[Adobe CS6 Service Manager*]
LangSecRef=3021
DetectFile=%AppData%\Adobe\CS6ServiceManager
Default=False
FileKey1=%AppData%\Adobe\CS6ServiceManager\Cache|*.*
FileKey2=%AppData%\Adobe\CS6ServiceManager\Logs|*.*
[Adobe Incompatible Icons*]
LangSecRef=3021
Default=False
FileKey1=%CommonProgramFiles%\Adobe|*.icns|RECURSE
FileKey2=%ProgramFiles%\Adobe|*.icns|RECURSE
Also the following entry name change to fit in with the above entry names (changed from Photoshop CS Filebrowser):
[Adobe CS File browser*]
LangSecRef=3021
Default=True
Detect=HKLM\SOFTWARE\Adobe\Photoshop
FileKey1=%userprofile%\application data\Adobe\FileBrowser\PhotoshopCS|*.*
Also have a new Adobe entry to add (I believe this cache location also exacts in Adobe Premiere Plus, and possibly other Adobe products, but only have Photoshop to test it with so detect key MAY not pick up those programs):
[*Adobe Media Cache]
LangSecRef=3021
Default=True
FileKey1=%appdata%\Adobe\Common\Media Cache|*.*
FileKey2=%appdata%\Adobe\Common\Media Cache Files|*.*
Link to post
And another error, filekey duplicated in this entry:
[NVIDIA Updates*]
LangSecRef=3023
Detect=HKLM\Software\NVIDIA Corporation
Default=False
FileKey1=%CommonAppData%\Nvidia\Updates|*.bak
FileKey2=%CommonAppData%\Nvidia\Updatus|*.bak
Can you tell I'm looking through the whole file for the first time in ages :P
These are not duplicated FileKeyx.  One is for Nvidia folder Updates and the other is for Nvidia folder Updatus.  Note the spelling difference.  ;)
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti:   Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to post
Oh yeah, so it is, whoops ^_^
Link to post
  • Moderators
I agree with not messing with actual ERUNT backups, it can be configured to automatically remove older backs all by itself without any need to manually remove them or remove them via CCleaner.
Link to post
[blueStacks Logs*]
LangSecRef=3021
Default=False
I want to stay the compatible to old versions !!!
I understand your addition of Detect2
I am saying your addition of FileKey2 is redundant.
Assuming .log.* is meant to be .log FileKey3 would be unnecessary also. If not, what is   .log.*   ?
Link to post
[Pale Moon - Adblock Lite Backups*]
LangSecRef=3026
Detect=HKLM\Software\Mozilla\Pale Moon
DetectFile=%ProgramFiles%\Pale Moon\palemoon.exe
Default=False
FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*\adblocklite|patterns-backup*.ini
[Pale Moon - Adblock Plus Backups*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*\adblockplus|patterns-backup*.ini
Merge to get:
[Pale Moon - Adblock Backups*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*\adblock*|patterns-backup*.ini
Also found these two programs:
fpsbanana .com/tools/3595
fpsbanana .com/tools/2543
I may write rules for the files they clean later if I have enough time. I will also accept anyone volunteering. :)
Link to post
nope blueStacks creats every 10 mb a new file eg. test.log , test.log.1 , test.log.2 so on .....
I have seen this only in the path of filekey 3.
Link to post
LangSecRef=3025
Default=False
LangSecRef=3025
Default=False
This name duplication is preventing either one from showing up in the Applications tab.  Looks to me that the first/top one needs to be totally removed.  :wacko:
Link to post
Register a new account
Sign in
