CCleaner Community Forums
Winapp2.ini additions
I like [someprogram Temporary Files] best.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti:   Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to post
New entries:
[blindwrite*]
LangSecRef=3021
Detect=HKCU\Software\VSO\Blindwrite
Default=False
FileKey1=%AppData%|pcouffin.log;ezplay.log
FileKey2=%AppData%\VSO|*.log|REMOVESELF
FileKey3=%CommonAppData%\VSO\Blindwrite\*|*.log|REMOVESELF
FileKey4=%Documents%\PcSetup|*.log|REMOVESELF
FileKey5=%UserProfile%|timestamp.txt
[VSO CopyTo*]
LangSecRef=3021
Detect=HKCU\Software\VSO\CopyTo
Default=False
FileKey3=%CommonAppData%\VSO|*.cache;*.crashlist;*.log;*.vsothumb|RECURSE
Link to post
place of interest %LocalAppData%\Microsoft\Windows\SkyDrive\logs
I'm on a local account in 8.1 and never use skydrive. Could someone that uses an MS account & skydrive make sure removing those *.etl's doesn't break anything for them.
edit: If the above is added to SkyDrive App*, DetectFile2=%LocalAppData%\Microsoft\Windows\SkyDrive will be needed
Edited by Coffee4Joe
Link to post
  • Moderators
Additionally, how do we want to refer to temp files
Do we want to make it
or
[someprogram Temps]
or
[someprogram Temp Files]
Something like this is good, it keeps the names shorter to ultimately avoid using the scroll bar in CCleaner:
[someprogram Temps]
These can be too long if the program being cleaned already has a long name:
Link to post
I prefer 'Temporary Files' over 'Temps,' purely because of possible ambiguity. 'Temps' is also the abbreviated form of 'temperature' and could be confusing to people who don't speak English as a first language.
I'm Shane.
Link to post
I agree with you !!!
stay:
Temporary Files
and
Temp Files
I would say Temp Files because to reduce the entry length.
Link to post
  • Moderators
Bug Report: CCleaner isn't telling the correct outside temperature. :P
I think regardless of whatever "naming standard" is attempted the cleaning routines will probably still be submitted in a plethora of differently named variants.
Link to post
  • Moderators
I never had Adobe Acrobat on my PC but CCleaner always detects it. I think Adobe Reader entries detect paths that need to be corrected.
No what probably is occurring is that reader was installed (either by factory or user) and the detect is in residence on your PC. As this is the winapp2 thread i assume you should be able to find those entries in your ini and remove the entry from your registry or drive. If you need further assistance please post back.
Link to post
Revised Entry
Changed entry name from [MS Word 2007 Document Building Blocks*] as it is good on Office 2010 also.
[MS Word Document Building Blocks*]
LangSecRef=3021
DetectFile=%AppData%\Microsoft\Document Building Blocks
Default=False
FileKey1=%AppData%\Microsoft\Document Building Blocks|*.*|RECURSE
Link to post
Revised Entry
Added RegKey1
[internet Explorer Metro*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\windows_ie_ac_001
DetectFile=%LocalAppData%\Packages\windows_ie_ac_001
Default=False
FileKey1=%LocalAppData%\Packages\windows_ie_ac_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\windows_ie_ac_*\AC\INetCache|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\windows_ie_ac_*\AC\INetCookies|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\windows_ie_ac_*\AC\INetHistory|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey7=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey8=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\windows_ie_ac_*\AC\PRICache|*.*
FileKey10=%LocalAppData%\Packages\windows_ie_ac_*\AC\Temp|*.*
FileKey11=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\Cache|*.*|RECURSE
FileKey12=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\navigationHistory|*.*|RECURSE
FileKey13=%LocalAppData%\Packages\windows_ie_ac_*\TempState|*.*|RECURSE
RegKey1=HKCR\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Internet Explorer\DOMStorage
Link to post
Can we combine entries [Adobe Acrobat Cache*] & [Adobe Acrobat More*] with the one listed below.
[Adobe Acrobat XI More*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Acrobat
Default=False
FileKey1=%LocalAppData%\Adobe\Acrobat|.idx|RECURSE
FileKey2=%LocalAppData%\Adobe\Acrobat\11.0\Cache|*.*
FileKey3=%LocalAppData%\Adobe\Acrobat\11.0|UserCache.bin
FileKey4=%LocalAppData%\Adobe\Acrobat\11.0\Updater|*.log
New Entry
I have added RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl from [Adobe Acrobat More*] to the Distiller entry.
[Adobe Acrobat Distiller XI*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Adobe\Acrobat\Distiller 11|*.log
FileKey2=%AppData%\Adobe\Acrobat\Distiller 11\Cache|*.*
Link to post
Revised Entry
Added the highlighted lines. I have IE 11 on my system. The newly added paths might not be there in IE 10.
[internet Explorer 10/11*]
LangSecRef=3022
DetectFile=%LocalAppData%\Microsoft\Windows\WebCache
Default=False
FileKey1=%LocalAppData%\Microsoft\SmartScreen|*.tmp
FileKey2=%LocalAppData%\Microsoft\Vault\*|*.vcrd
FileKey3=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE
FileKey4=%LocalAppData%\Microsoft\Windows\IECompatCache|*.*|RECURSE
FileKey5=%LocalAppData%\Microsoft\Windows\IECompatUACache|*.*|RECURSE
FileKey6=%LocalAppData%\Microsoft\Windows\INetCache|*.*|RECURSE
FileKey7=%LocalAppData%\Microsoft\Windows\INetCookies|*.*|RECURSE
FileKey8=%LocalAppData%\Microsoft\Windows\WebCache|*.*|RECURSE
FileKey9=%LocalAppData%\Microsoft\Windows\WebCache.old|*.*|REMOVESELF
FileKey10=%LocalLowAppData%\Microsoft\Windows\AppCache|*.*|RECURSE
FileKey11=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache|*.*|RECURSE
FileKey12=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\INetCookies|*.*|RECURSE
Link to post
I've started using Instantbird and as you may or may not know it's base is a lot of Mozilla code and it creates a lot of similar sturctures and files. I would like to propose one modification and some additions.
From
[instantbird Logs*]
LangSecRef=3022
Warning=This will delete your chat logs as well.
DetectFile=%AppData%\Instantbird
Default=False
FileKey1=%AppData%\Instantbird\Profiles\*\logs|*.*|RECURSE
FileKey2=%AppData%\Instantbird\Crash Reports|*.*
To
[instantbird Logs*]
LangSecRef=3022
Default=False
Because the logs should be seperate from the crash logs
Additions
[instantbird Startup Cache*]
LangSecRef=3022
Default=False
FileKey1=%LocalAppData%\Instantbird\Profiles\*\startupCache|*.*
[instantbird Extensions Log*]
LangSecRef=3022
Default=False
FileKey1=%AppData%\Instantbird\Profiles\*|extensions.log
[instantbird Install Log*]
LangSecRef=3022
Default=False
FileKey1=%ProgramFiles%\Instantbird|install.log
[instantbird Corrupt SQLites*]
LangSecRef=3022
Default=False
FileKey1=%AppData%\Instantbird\Profiles|*.corrupt|RECURSE
[instantbird Crash Reports*]
LangSecRef=3022
Default=False
FileKey1=%AppData%\Instantbird\Crash Reports|*.*|RECURSE
[instantbird Update Logs*]
LangSecRef=3022
Default=False
FileKey1=%LocalAppData%\Instantbird\Profiles\*\Updates|*.log|RECURSE
I'm not 100% sure of this last entry because I've not had an update yet. Also I have all of the Instantbird, Firefox, and Thunderbird profiles junctioned to another drive.
Link to post
New entry:
[Conceiva Mezzmo Crash Dump*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Conceiva
Default=False
Warning=If Mezzmo crashed while streaming, this file was created and may help the developers diagnose your problem and improve future releases.
FileKey1=%CommonAppData%\Conceiva\Mezzmo\CER|*.zip
Link to post
unneeded post
Link to post
Added FileKey11
[bing Weather*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingWeather_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.BingWeather_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INetCache|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INetCookies|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INetHistory|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CLR_v4.0|*.log|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey7=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey8=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\PRICache|*.*
FileKey10=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Temp|*.*
FileKey11=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState|*.tmp
FileKey12=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\Cache|*.*|RECURSE
FileKey13=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\navigationHistory|*.*|RECURSE
FileKey14=%LocalAppData%\Packages\Microsoft.BingWeather_*\TempState|*.*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingWeather_8wekyb3d8bbwe\SearchHistory
Added FileKey9
[bing Maps More*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingMaps_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.BingMaps_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.BingMaps*\AC\Microsoft\CLR_v4.0\NativeImages\Temp|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.BingMaps*\AC\Microsoft\CLR_v4.0|*.log|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\PRICache|*.*
FileKey7=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\Temp|*.*
FileKey8=%LocalAppData%\Packages\Microsoft.BingMaps*\LocalState\Bing.Maps|*.*|RECURSE
FileKey9=%LocalAppData%/Packages\Microsoft.BingMaps_8wekyb3d8bbwe\LocalState\MapInstrumentation|*.*
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingMaps_8wekyb3d8bbwe\SearchHistory
Added FileKey1
[Windows 8 Search History*]
DetectOS=6.2|
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\SearchHistory
FileKey1=%LocalAppData%\Microsoft\Windows\ConnectedSearch\History|*.*
filekey1 Cleans the recent searches from the start screen
Link to post
[Path of Exile*]
Section=Games
Detect1=HKCU\Software\Valve\Steam\Apps\238960
Default=False
FileKey1=%Documents%\My Games\Path of Exile\Minimap|*.*
FileKey2=%ProgramFiles%\Steam\steamapps\common\Path of Exile\logs|*.*
Fixed/corrected FileKey2.
Link to post
Register a new account
Sign in
