JDPower Posted December 21, 2013 Share Posted December 21, 2013 I don't think it's random at all if we look at Automatic Updates/Windows Updates as a culprit of where it unpacks files which is always the hard disk with the most free space available - it's a very Microsoft thing to do even if drive C:\ has more than enough room for temporary setup files which annoys the living piss out of me, we have a Temp folder on the system drive for a reason. I personally don't know how to code a cleaner for winapp2.ini (file) to look on other hard disks without specifically specifying things like E:\, P:\, T:\, etc., which wouldn't be suited for everyone's system, unless of course we included all possible hard disk locations running the alphabetic drive gauntlet going from C:\ to Z:\ Edit: I'll use this on my system since those are the hard disks I have, it should work as a template for others to modify for their own. [VCRedist Temp Setup Files*] Section=VCRedist Temp Setup Files Default=False DetectFile=%systemdrive%\VC_RED.cab DetectFile2=%systemdrive%\VC_RED.MSI DetectFile3=D:\VC_RED.cab DetectFile4=D:\VC_RED.MSI DetectFile5=E:\VC_RED.cab DetectFile6=E:\VC_RED.MSI FileKey1=%systemdrive%\|eula.1028.txt;eula.1031.txt;eula.1033.txt;eula.1036.txt;eula.1040.txt;eula.1041.txt;eula.1042.txt;eula.2052.txt;eula.3082.txt;globdata.ini;install.exe;install.ini;install.res.1028.dll;install.res.1031.dll;install.res.1033.dll;install.res.1036.dll;install.res.1040.dll;install.res.1041.dll;install.res.1042.dll;install.res.2052.dll;install.res.3082.dll;VC_RED.cab;VC_RED.MSI;vcredist.bmp FileKey2=D:\|eula.1028.txt;eula.1031.txt;eula.1033.txt;eula.1036.txt;eula.1040.txt;eula.1041.txt;eula.1042.txt;eula.2052.txt;eula.3082.txt;globdata.ini;install.exe;install.ini;install.res.1028.dll;install.res.1031.dll;install.res.1033.dll;install.res.1036.dll;install.res.1040.dll;install.res.1041.dll;install.res.1042.dll;install.res.2052.dll;install.res.3082.dll;VC_RED.cab;VC_RED.MSI;vcredist.bmp FileKey3=E:\|eula.1028.txt;eula.1031.txt;eula.1033.txt;eula.1036.txt;eula.1040.txt;eula.1041.txt;eula.1042.txt;eula.2052.txt;eula.3082.txt;globdata.ini;install.exe;install.ini;install.res.1028.dll;install.res.1031.dll;install.res.1033.dll;install.res.1036.dll;install.res.1040.dll;install.res.1041.dll;install.res.1042.dll;install.res.2052.dll;install.res.3082.dll;VC_RED.cab;VC_RED.MSI;vcredist.bmp That's what I've done, just added detect and delete keys for the E drive as well. I'm guessing wildcards wouldn't work for drive letters? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 21, 2013 Moderators Share Posted December 21, 2013 (edited) That's what I've done, just added detect and delete keys for the E drive as well. I'm guessing wildcards wouldn't work for drive letters? Never tried it, but even without trying it I doubt it would work for drives. What we need is a new variable from the developers such as %roothdd% or something similar that would let CCleaner detect and delete from the root of hard disks, if instructed to via a winapp2.ini cleaner. Edit: Such a variable could help with stuff that isn't stored on drive C:\ Edited December 21, 2013 by Andavari Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 22, 2013 Author Share Posted December 22, 2013 wildcards work in detectfiles now, so *:\VC_RED.cab might actually work. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
dafmat71 Posted December 22, 2013 Share Posted December 22, 2013 Since last update, "Windows media player ( database)" delete .wmdb in WMP, so make WMP empty of artists and we must wait the build of the files!!! It's not crap files!! Why always change what works? Link to comment Share on other sites More sharing options...
Coffee4Joe Posted December 22, 2013 Share Posted December 22, 2013 New the warning might need tweaking/rewording. [Windows 8 Sharing MFU*] DetectOS=6.2| LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will remove the frequently shared list. e.g. email addresses that have been used to share. This does not remove the Apps listed under sharing. RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\SharingMFU Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 22, 2013 Author Share Posted December 22, 2013 Since last update, "Windows media player ( database)" delete .wmdb in WMP, so make WMP empty of artists and we must wait the build of the files!!! It's not crap files!! Why always change what works? Sorry about that. The change was posted on the forum and no one objected so I assumed it to be okay. I'll remove that in the next update. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 23, 2013 Share Posted December 23, 2013 Revised Entry Added FileKey1, FileKey2 and changed FileKey3 from REMOVESELF to RECURSE [iMobie PhoneClean*] LangSecRef=3024 Detect=HKCU\Software\Imobie\PhoneClean Default=False FileKey1=%AppData%\iMobie\PhoneClean\DeviceBackup\Backup|*.*|RECURSE FileKey2=%AppData%\iMobie\PhoneClean\DeviceBackup\Restore|*.*|RECURSE FileKey3=%AppData%\iMobie\PhoneClean\ErrorLog|*.*|RECURSE Link to comment Share on other sites More sharing options...
dafmat71 Posted December 23, 2013 Share Posted December 23, 2013 Sorry about that. The change was posted on the forum and no one objected so I assumed it to be okay. I'll remove that in the next update. Ok, thx a lot...It seems that nobody uses WMP!!!! Link to comment Share on other sites More sharing options...
dvdbane Posted December 23, 2013 Share Posted December 23, 2013 Since last update, "Windows media player ( database)" delete .wmdb in WMP, so make WMP empty of artists and we must wait the build of the files!!! It's not crap files!! Why always change what works? does this entry only affect windows xp? based on filekey directory %SystemDrive%\Documents and Settings\ because i can't access it in win 7 in my windows 7+wmp 12, without filekey4,there nothing to delete only filekey4 relevant to my system and detect 6 files : CurrentDatabase_372.wmdb,LocalMLS_0.wmdb,LocalMLS_1.wmdb,LocalMLS_2.wmdb,LocalMLS_3.wmdb,wmpfolders.wmdb clean and it only clear library, playlist still intact and playable the main db would be CurrentDatabase_372.wmdb clean this and whole library gone i ignore this update because of the warning for this entry Warning=This will remove ratings, play counts, last played, etc. i've seen other tool able to delete this db and welcome this changes to the new winapp2.ini but this is only my opinion i don't know how the entry supposed to work but i'm gonna keep this if it is remove in the next update Link to comment Share on other sites More sharing options...
dafmat71 Posted December 23, 2013 Share Posted December 23, 2013 does this entry only affect windows xp? based on filekey directory %SystemDrive%\Documents and Settings\ because i can't access it in win 7 in my windows 7+wmp 12, without filekey4,there nothing to delete only filekey4 relevant to my system and detect 6 files : CurrentDatabase_372.wmdb,LocalMLS_0.wmdb,LocalMLS_1.wmdb,LocalMLS_2.wmdb,LocalMLS_3.wmdb,wmpfolders.wmdb clean and it only clear library, playlist still intact and playable the main db would be CurrentDatabase_372.wmdb clean this and whole library gone i ignore this update because of the warning for this entry Warning=This will remove ratings, play counts, last played, etc. i've seen other tool able to delete this db and welcome this changes to the new winapp2.ini but this is only my opinion i don't know how the entry supposed to work but i'm gonna keep this if it is remove in the next update I'm on win8.1!! And it deletes the whole library! In fact when we "analyse" ( wmp must be closed): The 194 Mo is the whole library!! Winapp2 is supposed to delete craps, for me: it's not craps and it takes a lot of time for rebuild it! Link to comment Share on other sites More sharing options...
Alan_B Posted December 23, 2013 Share Posted December 23, 2013 Why always change what works? Changes are made to enhance cleaning. Sometimes the consequences may prove to be unfortunate. Regrettably the only ways to avoid an unfortunate result are :- To never update CCleaner.exe nor Winapp2.ini; or to closely examine the ANALYZE results and understand potential consequences before they occur; or to create backups to fall back on when it goes wrong. Link to comment Share on other sites More sharing options...
dvdbane Posted December 23, 2013 Share Posted December 23, 2013 I'm on win8.1!! And it deletes the whole library! In fact when we "analyse" ( wmp must be closed): The 194 Mo is the whole library!! Winapp2 is supposed to delete craps, for me: it's not craps and it takes a lot of time for rebuild it! that why there is warning included with the entry another way to prevent this from happening aside from what @Alan_B had wrote : deselect all > select one by one every winapp2.ini update or search inside winapp2.ini for warning or go to http://winapp2.com/changes.html to check for any changes inside winapp2.ini here another changes that might affect you [Cached File Extensions*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=Can cause issues on Windows 8.1! RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts RegKey2=HKCU\Software\Microsoft\Windows\Roaming\OpenWith\FileExts RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts - Added Warning Link to comment Share on other sites More sharing options...
JDPower Posted December 23, 2013 Share Posted December 23, 2013 Winapp2 is supposed to delete craps, for me: it's not craps and it takes a lot of time for rebuild it! For YOU it's not crap (your words), it may be for someone else. You don't have to use every entry (in fact it's encoraged NOT to). There are many entries I don't use because what they clean is valuable to me. I hate WMP adding stuff to libraries, playlists, ratings etc, so have no problem with the entry. If I used those functions, I'd simply not use that entry (or edit out the filekey for the item I wanted to keep). The entry does have a fairly clear warning and as winapp2 entries are user created extra care should ALWAYS be taken when adding them, Winapp2 (the member) simply cannot check every single item is safe and without him there would BE no entries. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 23, 2013 Moderators Share Posted December 23, 2013 I believe the WMDB was removed from the entry (after a ton of griping by me) when the devs adopted the entry and it started killing people's media library wholesale.Edit: found it Agree with this. This was added to Winapp2.ini and I spokme out against it. Some how it seems to have crossed over without the proper removal of database removal or at least the warning that appears in Winapp2This is the offending ItemFileKey4=%LocalAppData%MicrosoftMedia Player|*.wmdb ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 23, 2013 Moderators Share Posted December 23, 2013 Regrettably the only ways to avoid an unfortunate result are :- To never update CCleaner.exe nor Winapp2.ini; or to closely examine the ANALYZE results and understand potential consequences before they occur; or to create backups to fall back on when it goes wrong. One other way which I prescribe to: Only pick and choose what you want from the winapp2.ini file. Like you stated analyze first before ever committing to a clean. Even new versions of CCleaner should be treated in that way, analyze first! Link to comment Share on other sites More sharing options...
dafmat71 Posted December 24, 2013 Share Posted December 24, 2013 Hmm, but it's not a big problem, as you said: i can uncheck it! But if i posted this problem, it was cause i thought it was a mistake! ( like it was, in the past, for "utorrent more" ) But you're right, for each new update, it's better to analyse first!! BTW: thx for the advertize for [Cached File Extensions*], i just uncheck it!! What's wrong with it? I wish that it's not too late! Link to comment Share on other sites More sharing options...
FreeRyde Posted December 25, 2013 Share Posted December 25, 2013 New entries: [Aimersoft DRM Media Converter*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Aimersoft\351 Default=False FileKey1=%ProgramFiles%\Aimersoft\DRM Media Converter\Log|*.*|REMOVESELF [DiskBoss Logs*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Flexense\DiskBoss Ultimate Default=False FileKey1=%LocalAppData%\DiskBoss Ultimate\data\reports|*.*|REMOVESELF [Green Ranch Log*] Section=Games Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Green RanchFINAL Default=False FileKey1=%AppData%\Palaplay\GreenRanch_Survey|*.txt [NowSmart Cut*] LangSecRef=3023 Detect=HKLM\Software\NowSmart\Cut Default=False FileKey1=%LocalAppData%\Cut|log.txt;*.dmp [Wondershare Video Converter Pro*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Wondershare\Wondershare Video Converter Pro Default=False FileKey1=%AllUsersProfile%\Documents\Wondershare|*.*|REMOVESELF FileKey2=%CommonAppData%\Wondershare Video Converter*|*.dat.bak FileKey3=%CommonAppData%\Wondershare Video Converter*\TempSiteIconDir FileKey4=%CommonAppData%\Wondershare Video Converter*\TempThumbDir FileKey5=%ProgramFiles%\Wondershare\Video Converter*\Log|*.*|REMOVESELF Modified: [Wondershare Helper Compact*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Wondershare\Wondershare Helper Compact Default=False FileKey1=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Log|*.*|RECURSE - Improved Detect Link to comment Share on other sites More sharing options...
FreeRyde Posted December 27, 2013 Share Posted December 27, 2013 New entries: [Clam Sentinel*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{060FE577-1BDF-4330-ACCA-B6760AB07191}_is1 Default=False FileKey1=%AllUsersProfile%\.clamwin\log|*.*|REMOVESELF FileKey2=%ProgramFiles%\ClamSentinel|*.txt [ClamWin*] LangSecRef=3021 Detect=HKLM\SOFTWARE\ClamWin Default=False FileKey1=%AllUsersProfile%\.clamwin\log|*.*|REMOVESELF FileKey2=%ProgramFiles%\ClamWin\bin|*.txt Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 27, 2013 Author Share Posted December 27, 2013 Thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 27, 2013 Moderators Share Posted December 27, 2013 New entries: [Clam Sentinel*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{060FE577-1BDF-4330-ACCA-B6760AB07191}_is1 Default=False FileKey1=%AllUsersProfile%\.clamwin\log|*.*|RECURSE FileKey2=%ProgramFiles%\ClamSentinel|*.txt [ClamWin*] LangSecRef=3021 Detect=HKLM\SOFTWARE\ClamWin Default=False FileKey1=%AllUsersProfile%\.clamwin\log|*.*|RECURSE FileKey2=%ProgramFiles%\ClamWin\bin|*.txt Remember a while ago when ClamWin/Clam Antivirus was deeming just about every .exe on system as infected? If the log files were still intact the users could restore their files, if not their systems were hosed. Link to comment Share on other sites More sharing options...
FreeRyde Posted December 27, 2013 Share Posted December 27, 2013 Remember a while ago when ClamWin/Clam Antivirus was deeming just about every .exe on system as infected? If the log files were still intact the users could restore their files, if not their systems were hosed. I see there are some previous concerns regarding 'ClamScanLog.txt' mentioned in their forum. Damn, when I get home from work I'll reinstall ClamWin and test that scenerio to qualify the rule or not. Thanks I didn't foresee that. Link to comment Share on other sites More sharing options...
SMalik Posted December 28, 2013 Share Posted December 28, 2013 Revised Entries Changed LangSecRef from 3021 to 3023 CCleaner's CyberLink PowerDirector 12 entry is also under the Multimedia section (LangSecRef 3023). [CyberLink PowerDirector 10*] LangSecRef=3023 Detect=HKCU\Software\CyberLink\PowerDirector10 Default=False FileKey1=%Documents%\CyberLink\PowerDirector\10.0|Snapshot(*).jpg FileKey2=%Documents%\CyberLink\PowerDirector\10.0\MyTitles|*.*|RECURSE FileKey3=%Documents%\CyberLink\PowerDirector\10.0\Preview Cache Files|*.* FileKey4=%Documents%\CyberLink\PowerDirector\10.0\ShadowEditFiles|*.MPG FileKey5=%Documents%\CyberLink\PowerDirector\10.0\SplitterIndex|*.maidx [CyberLink PowerDirector 11*] LangSecRef=3023 Detect=HKCU\Software\CyberLink\PowerDirector11 Default=False FileKey1=%Documents%\CyberLink\PowerDirector\11.0|Snapshot(*).jpg FileKey2=%Documents%\CyberLink\PowerDirector\11.0\MyTitles|*.*|RECURSE FileKey3=%Documents%\CyberLink\PowerDirector\11.0\Preview Cache Files|*.* FileKey4=%Documents%\CyberLink\PowerDirector\11.0\ShadowEditFiles|*.MPG FileKey5=%Documents%\CyberLink\PowerDirector\11.0\SplitterIndex|*.maidx Link to comment Share on other sites More sharing options...
FreeRyde Posted December 28, 2013 Share Posted December 28, 2013 Remember a while ago when ClamWin/Clam Antivirus was deeming just about every .exe on system as infected? If the log files were still intact the users could restore their files, if not their systems were hosed. After repeated testing, the entries below are fine as is... ClamWin did quarantine several files; though false-positve. The quarantine logs are now stored in the Quarantine folder. 'Quarantine Browser' aka 'QRecover' is used to view content, log, and delete, or restore files. Deletion of the other log files had no bearing upon quarantined file recovery, etc. Everything restored fine after running the entry. The restoration issues you mention date back to version 0.96.4 in 2010. This has been resolved. ClamScanLog.txt is no longer used for restoration. Sidenote: This AV used extremely low resources, but used 749 MB drive space (mostly AV definitions) and has very aggressive heuristics. [Clam Sentinel*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{060FE577-1BDF-4330-ACCA-B6760AB07191}_is1 Default=False FileKey1=%AllUsersProfile%\.clamwin\log|*.*|REMOVESELF FileKey2=%ProgramFiles%\ClamSentinel|*.txt [ClamWin*] LangSecRef=3021 Detect=HKLM\SOFTWARE\ClamWin Default=False FileKey1=%AllUsersProfile%\.clamwin\log|*.*|REMOVESELF FileKey2=%ProgramFiles%\ClamWin\bin|*.txt New entries: [Immunet (ClamAV)*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Immunet Protect Default=False Warning='Immunet' service must be stopped to remove log files. FileKey1=%AllUsersProfile%\Immunet|*.log FileKey2=%AppData%\Immunet|*.*|REMOVESELF FileKey3=%ProgramFiles%\Immunet|*.log|RECURSE [Trend Micro AntiRansomware Tool*] LangSecRef=3021 DetectFile=%ProgramFiles%\AntiRansomware2.0 Default=False FileKey1=%CommonAppData%\AntiRansomware|*.log Link to comment Share on other sites More sharing options...
JDPower Posted December 28, 2013 Share Posted December 28, 2013 Don't you just hate some programs. Just spent half an hour going through Steam directories and making an entry to remove all non-English language files, lots of them in various directories (20Mb worth), then find Steam reinstalls when you try to launch it. Go through the 11-12 filekeys to try to find the troublesome one only to find if you tounch ANY of them, Steam reinstalls when you start it! Link to comment Share on other sites More sharing options...
FreeRyde Posted December 28, 2013 Share Posted December 28, 2013 Modified: [Realtek (Logs)*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Realtek Default=False FileKey1=%ProgramFiles%\Realtek*|*.log;*.txt|RECURSE ExcludeKey1=FILE|%ProgramFiles%\Realtek\*\InstCtrl.txt ExcludeKey2=FILE|%ProgramFiles%\Realtek\*\setupctrl.txt - Changed LangSecRef to 3021- Added ExcludeKey1 and 2- Modified FileKey1 to include additional installations log filesRecommend removal of Realtek Card Reader entry below. It becomes redundant: [Realtek Card Reader*] LangSecRef=3021 DetectFile=%ProgramFiles%\Realtek\Realtek USB 2.0 Card Reader Default=False FileKey1=%ProgramFiles%\Realtek\Realtek USB 2.0 Card Reader|rmb.log Link to comment Share on other sites More sharing options...
