Miroku4444 Posted November 5, 2010 Share Posted November 5, 2010 Thanks for the update. I see you took the version# and dating suggestion. Thank you so much. Link to comment Share on other sites More sharing options...
siliconman01 Posted November 5, 2010 Share Posted November 5, 2010 (edited) Here are some additions. Note that I put the * in front of the name so that I can delineate those that are not currently in Winapp2.ini For the x64 version of SuperAntiSpyware [*SUPERAntiSpyware (More for x64)] LangSecRef=3024 DetectFile=%ProgramFiles%\Superantispyware\SASCore64.exe Default=False FileKey1=%CommonAppData%\!SASCORE\Applogs|*.SDB FileKey2=%CommonAppData%\!SASCORE|*.SDB FileKey3=%Appdata%\SuperantiSpyware.com\SUPERAntiSpyware\AppLogs|*.* NOTE: FileKey3 actually applies to all versions of SAS. You could add it into the SuperAntiSpyware component that is already part of Winapp2.ini. For Ashampoo Burning Studio 10 [*Ashampoo Burning Studio 10 (Logs)] LangSecRef=3024 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 10 Default=False FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 10|backupmetainfo.xml FileKey2=%AppData%\Ashampoo\Ashampoo Burning Studio 10\Log|*.xml FileKey3=%AppData%\Ashampoo\Log|*.txt For Belarc [*Belarc (log)] LangSecRef=3024 Detect=HKCU\Software\Belarc\Advisor Default=False Filekey1=%ProgramFiles(x86)%\Belarc\Advisor\|INSTALL.Log Filekey2=%ProgramFiles%\Belarc\Advisor\INSTALL.log For Thumbsplus 8 [*ThumbsPlus 8] LangSecRef=3023 Detect=HKCU\Software\Cerious Software Inc. Default=False Filekey1=%AppData%\Thumbsplus|*.log Filekey2=%AppData%\Thumbsplus|*.bak For Windows 7 QuickLaunch (which is not used in Win 7) [*Windows 7 QuickLaunch (QL Not Used)] LangSecRef=3025 DetectFile=%ProgramFiles(x86)%\Internet Explorer\iexplore.exe DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\Quick Launch|*.lnk For TrojanHunter [*TrojanHunter (Scan Logs)] LangSecRef=3024 Detect=HKCU\Software\TrojanHunter Default=False FileKey1=%ProgramFiles(x86)%\TrojanHunter 5.3\Scan Reports|*.* FileKey2=%ProgramFiles%\TrojanHunter 5.3\Scan Reports|*.* For Hijackthis [*HijackThis (Backups)] LangSecRef=3024 DetectFile=%ProgramFiles(x86)%\Trend Micro\HijackThis\HijackThis.exe DetectFile=%ProgramFiles%\Trend Micro\HijackThis\HijackThis.exe Default=False FileKey1=%ProgramFiles(x86)%\Trend Micro\HijackThis\backups|*.* FileKey2=%ProgramFiles%\Trend Micro\HijackThis\backups|*.* For Microsoft Baseline Analyzer [*MS Baseline Analyzer (Cache)] LangSecRef=3024 DetectFile=%ProgramFiles%\Microsoft Baseline Security Analyzer 2\mbsa.exe Detect=HKLM\Software\Microsoft\Microsoft Baseline Security Analyzer Default=False FileKey1=%USERPROFILE%\AppData\Local\Microsoft\MBSA\Cache|*.* FileKey2=%USERPROFILE%\SecurityScans|*.mbsa For SnagIt 10 (Removal of saved captures) [*SnagIt 10 (Saved Captures)] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt Default=False FileKey1=%USERPROFILE%\AppData\Local\TechSmith\SnagIt\DataStore|*.* FileKey2=%USERPROFILE%\AppData\Local\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%USERPROFILE%\AppData\Local\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* For X-NetStat [*X-NetStat (Logs)] LangSecRef=3024 DetectFile=%Program Files(x86)%\X-NetStat Professional\xns5.exe DetectFile=%Program Files%\X-NetStat Professional\xns5.exe Default=False FileKey1=%USERPROFILE%\AppData\Roaming\X-NetStat\Logs|*.* For WallWatcher [*WallWatcher (Logs)] LangSecRef=3024 DetectFile=%Program Files(x86)%\Wall Watcher\WallWatcher.exe DetectFile=%Program Files%\Wall Watcher\WallWatcher.exe Default=False FileKey1=%Program Files(x86)%\Wall Watcher\Logs|*.* FileKey2=%Program Files%\Wall Watcher\Logs|*.* For JavaRa [*JavaRa (Log)] LangSecRef=3024 Detect=HKLM\Software\Wow6432Node\JavaRa Detect=HKLM\Software\JavaRa Default=False Filekey1=C:\|JavaRa.log Edited November 5, 2010 by Nergal added code tags for easier reading Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 5, 2010 Author Share Posted November 5, 2010 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
back_track Posted November 5, 2010 Share Posted November 5, 2010 I think its time for a update. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 5, 2010 Moderators Share Posted November 5, 2010 I think its time for a update. What do you mean? he just updated yesterday, please keep in mind that Winapp2.ini (the person) is a volunteer, has a life outside of making this file and is under no obligation to maintain the file, he does this at his own volition and his own speed. If you feel a update is needed, add the entry you want to your personal winapp2 file. Please think a little less selfishly next time. Sorry if this seems mean, but your curt request came off a bit ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Miroku4444 Posted November 5, 2010 Share Posted November 5, 2010 What do you mean? he just updated yesterday, please keep in mind that Winapp2.ini (the person) is a volunteer, has a life outside of making this file and is under no obligation to maintain the file, he does this at his own volition and his own speed. If you feel a update is needed, add the entry you want to your personal winapp2 file. Please think a little less selfishly next time. Sorry if this seems mean, but your curt request came off a bit Exactly. All you have to do is add the new stuff that applies to you, to the latest update. Thats what i did. You don't need an update everyday. Link to comment Share on other sites More sharing options...
siliconman01 Posted November 6, 2010 Share Posted November 6, 2010 For DisplayFusion (Mult-Monitor control) [*DisplayFusion (Debug Log)] LangSecRef=3024 Detect=HKCU\Software\Binary Fortress Software\DisplayFusion Default=False Filekey1=%AppData%\DisplayFusion\|DisplayFusion.log For Creative Soundblaster X-Fi XtremeMusic hardware (Support Software Updates) [*Creative Soundblaster X-Fi XtremeMusic (Cache & Logs)] LangSecRef=3024 Detect=HKLM\Software\CREATIVE TECH\Software Installed\Software Update Default=False FileKey1=%CommonAppData%\Creative\Software Update\Cache|*.*|REMOVESELF FileKey2=%CommonAppData%\Creative\Software Update\Log\|*.* PerfectDisk 11 Boot and Offline Defrag Logs [*PerfectDisk 11 (logs)] LangSecRef=3024 Detect=HKLM\Software\Raxco\PerfectDisk\11.0 Default=False FileKey1=%CommonAppData%\Raxco\PerfectDisk\11.0\|PDBootLog FileKey2=%CommonAppData%\Raxco\PerfectDisk\11.0\|PDBootLog.log I think there is an error in the code below: (KegKey3) [borland Developer Studio 2006*] LangSecRef=3024 Detect=HKCU\Software\Borland\BDS\4.0 Default=False RegKey1=HKCU\Software\Borland\BDS\4.0\Closed Files RegKey2=HKCU\Software\Borland\BDS\4.0\Closed Projects KegKey3=HKCU\Software\Borland\BDS\4.0\Session Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
back_track Posted November 6, 2010 Share Posted November 6, 2010 What do you mean? he just updated yesterday, please keep in mind that Winapp2.ini (the person) is a volunteer, has a life outside of making this file and is under no obligation to maintain the file, he does this at his own volition and his own speed. If you feel a update is needed, add the entry you want to your personal winapp2 file. Please think a little less selfishly next time. Sorry if this seems mean, but your curt request came off a bit Sorry i havent see the last update post :-) Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 6, 2010 Author Share Posted November 6, 2010 For DisplayFusion (Mult-Monitor control) [sNIP] PerfectDisk 11 Boot and Offline Defrag Logs [*PerfectDisk 11 (logs)] LangSecRef=3024 Detect=HKLM\Software\Raxco\PerfectDisk\11.0 Default=False FileKey1=%CommonAppData%\Raxco\PerfectDisk\11.0\|PDBootLog FileKey2=%CommonAppData%\Raxco\PerfectDisk\11.0\|PDBootLog.log Its odd that you'd mention this one because just last night, I wrote a very similar one (for 9,10, and 11 since the latest version was 8 in Winapp2.ini) [PerfectDisk 11*] LangSecRef=3024 Detect=HKCU\Software\Raxco\PerfectDisk\11.0 Default=False FileKey1=%CommonAppData%\Raxco\PerfectDisk\11.0|*.log FileKey2=%CommonAppData%\Raxco\PerfectDisk\11.0|PDBootLog Thank you for your contributions ! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted November 6, 2010 Share Posted November 6, 2010 You are most welcome. I like a clean machine and Winapp2.ini is a major assist for this objective. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 7, 2010 Moderators Share Posted November 7, 2010 Sorry i havent see the last update post :-) Read the thread it was three posts above yours Updated -3- first post! Everyone, Just a thought, of course, and I'm super glad to see all these new people submitting entries ; however, so as not to overbloat the winapp2, and this thread, be sure that the software you suggest is something you feel at least a medium population might be running. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Miroku4444 Posted November 7, 2010 Share Posted November 7, 2010 Everyone, Just a thought, of course, and I'm super glad to see all these new people submitting entries ; however, so as not to overbloat the winapp2, and this thread, be sure that the software you suggest is something you feel at least a medium population might be running. Good suggestion, but Winapp2.ini could weed out the less desirable ones when he updates the Winapp2.ini., and maybe trim it once in a while. Also who uses the full Winapp2.ini anyway? I just use it as a resource for making my personal Winapp2.ini. Picking and choosing ones that apply to me. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 7, 2010 Author Share Posted November 7, 2010 I actually like the concept of having a giant range of entries, but thats just me I figure theres no reason not to have everything since most people just pick and choose what they want (though I'm sure some people just use the whole file) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted November 7, 2010 Share Posted November 7, 2010 JMO... I wish that the CCleaner developers would create a new section under Applications: [4036 = Security] The following programs would fit this new category. Windows Defender Malwarebytes Anti Malware AntiVir Desktop TrojanHunter Hijackthis Wallwatcher A-squared Free Antivir Personal 8 Avira Rootkit Detection BitDefender 9 CounterSpy Giant AntiSpyware HostsMan Microsoft AntiMalware Scan Results Online Armor SpyDefense Spyware Doctor Spyware Terminator ZoneAlarm (and others embedded in CCleaner that may be showing up on others' systems) Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 7, 2010 Author Share Posted November 7, 2010 Technically that could be done using Section=Security the only difference would be that there'd be no graphic. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted November 7, 2010 Share Posted November 7, 2010 Technically that could be done using Section=Security the only difference would be that there'd be no graphic. It also would not move CCleaner embedded programs such as Windows Defender and Malwarebytes to the "new" section, correct? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 7, 2010 Author Share Posted November 7, 2010 Correct. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
back_track Posted November 7, 2010 Share Posted November 7, 2010 A game section would be also great. Please can you add this: [sRWare Iron\Chromium - Cache] LangSecRef=3022 Detect=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Chromium\User Data\Default\Cache|*.* [sRWare Iron\Chromium - Cookies] LangSecRef=3022 Detect=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Chromium\User Data\Default|Cookies [sRWare Iron\Chromium - History] LangSecRef=3022 Detect=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Chromium\User Data\Default|*History* FileKey2=%LocalAppData%\Chromium\User Data\Default|Thumbnails FileKey3=%LocalAppData%\Chromium\User Data\Default|Visited Links [sRWare Iron\Chromium - Form Data] LangSecRef=3022 Detect=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Chromium\User Data\Default|Web Data [sRWare Iron\Chromium - Session Restore] LangSecRef=3022 Detect=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Chromium\User Data\Default|Current* FileKey2=%LocalAppData%\Chromium\User Data\Default|Last* Link to comment Share on other sites More sharing options...
bdh Posted November 7, 2010 Share Posted November 7, 2010 Hi all, I'm relatively new here but have used CCleaner for years happily. A lot of the content of this thread has gone over my head but I think it is the right thread in which to ask my question, as it looks like you guys are the 'creme de la creme' of the gurus here. I came across a mention of a free product called CCenhancer which I understand 'turbocharges' CCleaner. My questions are: is it safe, do you guys use it, does it work? I know it is not officially endorsed by Piriform but it looks to give CCleaner support for another 170 or so programs in terms of cleanup. BTW, is this 'winapp2.ini' file mentioned in this thread updated each time I update CCleaner? I think so but just want to check. From my reading here I should update it even more frequently than a regular CCleaner update. Is CCenhancer meant to replace this 'winapp2.ini' file or complement it? As you can see I'm a bit confused. Sorry if this isn't relevant here or off topic. Thanks for your patience. Cheers, bdh P.S: I did do a search for CCenhancer on this forum but nothing came up. Hope I did the search properly! Link to comment Share on other sites More sharing options...
back_track Posted November 7, 2010 Share Posted November 7, 2010 CCenhancer has the same entries as the files here in the thread^^ (It has also the same MD5 code^^) Link to comment Share on other sites More sharing options...
TheWebAtom Posted November 7, 2010 Share Posted November 7, 2010 CCenhancer has the same entries as the files here in the thread^^ (It has also the same MD5 code^^) At some point we were collaborating, but due to my final exams at present, I don't have the time to help (let alone post this response really ) I figure for the sake of being up to date there is no harm using winapp2.ini's file so long as I give back in the future I'm Shane. Link to comment Share on other sites More sharing options...
back_track Posted November 7, 2010 Share Posted November 7, 2010 [Trakmania Forever Cache*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Application Data\TrackMania Default=False FileKey1=%AllUsersProfile%\Application Data\TrackMania\Cache|*.* FileKey2=%AllUsersProfile%\Application Data\TrackMania\Cache\ManiaCode|*.* [Trakmania Forever Cache*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Anwendungsdaten\TrackMania Default=False FileKey1=%AllUsersProfile%\Anwendungsdaten\TrackMania\Cache|*.* FileKey2=%AllUsersProfile%\Anwendungsdaten\TrackMania\Cache\ManiaCode|*.* [Trakmania Forever Manialinks*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Application Data\TrackMania Default=False FileKey1=%AllUsersProfile%\Application Data\TrackMania\Manialinks|*.* [Trakmania Forever Manialinks*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Anwendungsdaten\TrackMania Default=False FileKey1=%AllUsersProfile%\Anwendungsdaten\TrackMania\Manialinks|*.* [Trakmania Forever LadderScores*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Anwendungsdaten\TrackMania Default=False FileKey1=%AllUsersProfile%\Anwendungsdaten\TrackMania\LadderScores|*.* [Trakmania Forever LadderScores*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Application Data\TrackMania Default=False FileKey1=%AllUsersProfile%\Application Data\TrackMania\LadderScores|*.* [Trakmania Forever CampaignsScores*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Anwendungsdaten\TrackMania Default=False FileKey1=%AllUsersProfile%\Anwendungsdaten\TrackMania\CampaignsScores|*.* FileKey2=%AllUsersProfile%\Anwendungsdaten\TrackMania\CampaignsScores\General|*.* FileKey3=%AllUsersProfile%\Anwendungsdaten\TrackMania\CampaignsScores\UnitedRace|*.* [Trakmania Forever CampaignsScores*] LangSecRef=3021 DetectFile=%AllUsersProfile%\Application Data\TrackMania Default=False FileKey1=%AllUsersProfile%\Application Data\TrackMania\CampaignsScores|*.* FileKey2=%AllUsersProfile%\Application Data\TrackMania\CampaignsScores\General|*.* FileKey3=%AllUsersProfile%\Application Data\TrackMania\CampaignsScores\UnitedRace|*.* Link to comment Share on other sites More sharing options...
Miroku4444 Posted November 7, 2010 Share Posted November 7, 2010 Hi all, I'm relatively new here but have used CCleaner for years happily. A lot of the content of this thread has gone over my head but I think it is the right thread in which to ask my question, as it looks like you guys are the 'creme de la creme' of the gurus here. I came across a mention of a free product called CCenhancer which I understand 'turbocharges' CCleaner. My questions are: is it safe, do you guys use it, does it work? I know it is not officially endorsed by Piriform but it looks to give CCleaner support for another 170 or so programs in terms of cleanup. BTW, is this 'winapp2.ini' file mentioned in this thread updated each time I update CCleaner? I think so but just want to check. From my reading here I should update it even more frequently than a regular CCleaner update. Is CCenhancer meant to replace this 'winapp2.ini' file or complement it? As you can see I'm a bit confused. Sorry if this isn't relevant here or off topic. Thanks for your patience. Cheers, bdh P.S: I did do a search for CCEnhancer on this forum but nothing came up. Hope I did the search properly! CCEnhancer is a small program that downloads and installs the latest Winapp2.ini file to your CCleaner program folder. The winapp2.ini file is a file that adds support for more programs in terms of cleanup. In other words you'll be able to clean more crap off you pc. I dont think CCEnhancer installs itself to your pc, you have to run the exe file every-time you want to update the Winapp2.ini file. Thats why i just update the Winapp2.ini file manually, and put the Winapp2.ini file in my ccleaner program file folder myself. As for winapp2.ini' file being updated each time CCleaner is updated, the answer is no. CCEnhancer is not officially part of CCleaner, its not endorsed by piriform. So no it wont. When i un-install an old ccleaner and install a new one, i move the Winapp2.ini file to my desktop beforehand. Then after i un-install the old cccleaner and in-stall the new version, i move the Winapp2.ini file back from the desktop to the ccleaner program folder. Is it safe, do i use it? Yes i use it, and its fairly safe, but there's no 100% guarantees its totally safe. Link to comment Share on other sites More sharing options...
bdh Posted November 7, 2010 Share Posted November 7, 2010 Thanks for the prompt reply Atom & Back_Track, I'm still a bit unsure of what I need to actually do to apply this Winapp2 file to my setup. From what I've read I must place the .ini file in the CCleaner folder. However I can't seem to find anything clearly identified as the latest version to download. The latest I found was June - surely this can't be the current version? I've found different links/things emanating from this Piriform site but some of them have different amounts of text in them (simple updates?). I even found a zip file here but that didn't have any program info in it. For a non-techy this is just too hard. Is it meant to be so geekish people like me are precluded from having the best? Can anyone please actually point me to a simple download with the latest full ini file, a place I can go to to check often for the latest version? Or is this only the exclusive realm of the mysterious CCenhancer? Somebody please put me out of my misery! Cheers, bdh. Link to comment Share on other sites More sharing options...
