Winapp2.ini Posted February 7, 2012 Author Share Posted February 7, 2012 You have missed some of my modified entries: [code] [star Wars: The Old Republic*] LangSecRef=3021 DetectFile1=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic Default=False FileKey1=%Documents%|Install STAR WARS The Old Republic.log FileKey2=%LocalAppData%\SWTOR\CrashDump\swtor|*.* FileKey3=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\betatest\retailclient\Temp|*.log FileKey4=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\logs|*.log FileKey5=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\swtor\retailclient\swtor\logs|*.log FileKey6=%UserProfile%\Documents|Uninstall STAR WARS The Old Republic.log Modified & added FileKeys. Ah ok, but %Documents% is shorter! Yep. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted February 7, 2012 Share Posted February 7, 2012 I only mention it because (as above) many entries people submit use %UserProfile%\Documents instead of just %Documents% Is %Documents% documented ? I was not aware of it, and it is not part of the environment for Windows 7 Ultimate + SP1 Are there other special variables I should be aware of Link to comment Share on other sites More sharing options...
nodles Posted February 7, 2012 Share Posted February 7, 2012 Yep. Ooops, not blind! But you can modify that entry, too. Link to comment Share on other sites More sharing options...
SMalik Posted February 7, 2012 Share Posted February 7, 2012 A fresh install of Windows 7 doesn't creates the registry key listed below. Some of the programs (e.g: Norton programs) create this key in Windows 7 registry. Deleting this key is completely safe. HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam There is an issue with RealPlayer 15. It creates a registry key that belongs to the RealPlayer 12. I am listing the registry key here. HKEY_CURRENT_USER\Software\RealNetworks\RealPlayer\12.0 Because of this CCleaner detects Real Player SP 12 and Real Player 15. Deleting the above key is completely safe. Link to comment Share on other sites More sharing options...
Alan_B Posted February 7, 2012 Share Posted February 7, 2012 Latest Winapp2.ini Version: v1.0.120206 Also in List of changes - reDscanner :- DetectFile=%ProgramFiles%\NirSoft\RegScanner Warning=This will remove all backups and reports made by RedScanner. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 7, 2012 Author Share Posted February 7, 2012 It's looking for communists! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 7, 2012 Author Share Posted February 7, 2012 Is %Documents% documented ? I was not aware of it, and it is not part of the environment for Windows 7 Ultimate + SP1 Are there other special variables I should be aware of %Documents% %Videos% %Music% Not standard variables, but CCleaner ones. %CommonAppData% points to ProgramData or \Documents and Settings\All Users\Application Data\ winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted February 7, 2012 Share Posted February 7, 2012 Latest Winapp2.ini Version: v1.0.120206 Also in List of changes - reDscanner :- DetectFile=%ProgramFiles%\NirSoft\RegScanner Warning=This will remove all backups and reports made by RedScanner. Sorry about that. My typo. Oops :/ Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 7, 2012 Author Share Posted February 7, 2012 Too bad it isn't RedScanner, Jopseph Mccarthy would have loved it. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted February 7, 2012 Share Posted February 7, 2012 MODIFIED ENTRY [FastStone Capture*] LangSecRef=3024 DetectFile=%ProgramFiles%\FastStone Capture\FSCapture.exe Default=False FileKey1=%LocalAppData%\FastStone\FSC\EditWith|*.* FileKey2=%LocalAppData%\FastStone\FSC|*.db FileKey3=%AppData%\FastStone\FSC|*.bak FileKey4=%AppData%\FastStone\FSC|*.db RegKey1=HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId RegKey2=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastClipPlayed RegKey3=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastRecordingFileName Link to comment Share on other sites More sharing options...
siliconman01 Posted February 7, 2012 Share Posted February 7, 2012 The following needs to be changed for DisplayFusion: [DisplayFusion*] LangSecRef=3024 Detect=HKCU\Software\Binary Fortress Software\DisplayFusion Default=False FileKey1=%AppData%\DisplayFusion|DisplayFusion.log FileKey2=%AppData%\DisplayFusion|DisplayFusionSetup.exe change the above code to: [DisplayFusion TroubleShooting Log*] LangSecRef=3024 Detect=HKCU\Software\Binary Fortress Software\DisplayFusion Default=False FileKey1=%AppData%\DisplayFusion|DisplayFusion.log And this code needs to added: [DisplayFusion (Setup File & Log)*] Warning=This removes the DisplayFusionSetup.exe file and DisplayFusionSetup.log generated during the installation of DisplayFusion. Both are unneeded after the installation is completed. LangSecRef=3024 Detect=HKCU\Software\Binary Fortress Software\DisplayFusion Default=False FileKey1=%AppData%\DisplayFusion|DisplayFusionSetup.log FileKey2=%AppData%\DisplayFusion|DisplayFusionSetup.exe Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
CSGalloway Posted February 7, 2012 Share Posted February 7, 2012 Please add the following items: [AOL 9.7*] LangSecRef=3022 DetectFile=%CommonAppData%\AOL\C_AOL Desktop 9.7 Default=False FileKey1=%CommonAppData%\AOL\C_AOL Desktop 9.7\spool|*.tmp FileKey2=%CommonAppData%\AOL\C_AOL Desktop 9.7\bart|*.*|RECURSE [Windows HOSTs Backups] LanSecRef=3025 DetectFile=%windir%\system32\drivers\etc|hosts.*-*.backup Default=False FileKey1=%windir%\system32\drivers\etc|hosts.*-*.backup TIA.... Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 7, 2012 Author Share Posted February 7, 2012 Will do... I've removed a few extreaneous 1's and 2' from DetectFiles and Detect's that just didn't need them. (ie. singular detectfiles marked with Detectfile1) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted February 7, 2012 Moderators Share Posted February 7, 2012 Windows HOSTs Backups] LanSecRef=3025 DetectFile=%windir%\system32\drivers\etc|hosts.*-*.backup Default=False FileKey1=%windir%\system32\drivers\etc|hosts.*-*.backup Cleans it's own detect, detects cannot contain wildcards, detects do not contain | ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 7, 2012 Author Share Posted February 7, 2012 could change the DetectFile to %WinDir%\System32\Drivers\etc\HOSTS winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted February 8, 2012 Share Posted February 8, 2012 I've actually got a new entry to add for first time in ages thanks to currently trying Easeus Backup: [*EaseUS ToDo Backup logs] LangSecRef=3024 Detect=HKCU\Software\EaseUS\EaseUS Todo Backup Default=True Filekey1=%ProgramFiles%\EaseUS\Todo Backup\bin|easeus.log Filekey2=%ProgramFiles%\EaseUS\Todo Backup\bin|TbLogsysClient.tblog A small disclaimer - easeus.log can only be deleted if the Easeus Agent service is not running. I have included it anyway as I have that service set to manual, some other users may too and it seems to get quite sizeable. And it's actually the other log file that clears the logs you see within the program itself and that deletes regardless of the service running. Link to comment Share on other sites More sharing options...
CSGalloway Posted February 8, 2012 Share Posted February 8, 2012 The files in %WinDir%\System32\Drivers\etc\ are marked RO - will CCleaner handle those ? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 8, 2012 Author Share Posted February 8, 2012 RO? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted February 8, 2012 Share Posted February 8, 2012 RO? Read only? Link to comment Share on other sites More sharing options...
Coffee4Joe Posted February 8, 2012 Share Posted February 8, 2012 the folder \etc is marked as Read-only but it will clean the backup files as long as they aren't read only [Windows HOSTs Backup*] LangSecRef=3025 DetectFile=%WinDir%\System32\drivers\etc\HOSTS Default=False FileKey1=C:\Windows\System32\drivers\etc|hosts.*.backup Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 8, 2012 Author Share Posted February 8, 2012 Bah sorry, mind wasn't working! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
CSGalloway Posted February 8, 2012 Share Posted February 8, 2012 RO = Read Only. ================== [C:\WINDOWS\system32\drivers]attrib /d etc\ ___AD________ C:\WINDOWS\system32\drivers\etc [C:\WINDOWS\system32\drivers]attrib etc\*.* R__A_________ C:\WINDOWS\system32\drivers\etc\HOSTS R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080110-102345.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080129-192042.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080311-025254.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080530-194152.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080807-153608.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080811-214001.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080811-214437.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080820-182017.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080820-182211.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080828-191610.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080830-012452.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080916-014827.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080916-032735.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20080917-023723.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20081022-183520.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20081105-140001.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090128-190147.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090128-191646.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090128-191828.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090214-202536.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090214-203410.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090214-203641.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090215-214621.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090221-203155.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090311-185755.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090423-163549.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090606-205236.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20090606-205919.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20091206-153359.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100203-171845.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100203-190625.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100203-234008.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100412-212328.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100613-155653.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100720-084128.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100721-005814.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100721-193350.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20100831-190340.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20110108-214936.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20110110-225126.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20110111-010400.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20110112-205746.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20110112-210704.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20110112-212438.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.20110516-212719.backup R__A_________ C:\WINDOWS\system32\drivers\etc\hosts.msn ___A_________ C:\WINDOWS\system32\drivers\etc\lmhosts.sam ___A_________ C:\WINDOWS\system32\drivers\etc\networks ___A_________ C:\WINDOWS\system32\drivers\etc\protocol ___A_________ C:\WINDOWS\system32\drivers\etc\services Windows XP Pro sp3 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 8, 2012 Author Share Posted February 8, 2012 Interesting, have you tried running CCleaner to see if it deletes them or not? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted February 8, 2012 Share Posted February 8, 2012 MODIFIED ENTRIES Added highlighted lines. [Corel VideoStudio Pro X4*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel VideoStudio Pro X4\vstudio.exe Default=False FileKey1=%AppData%\Corel\Messages|*.*|RECURSE FileKey2=%AppData%\Ulead Systems\Corel VideoStudio Pro\14.0\en-US|VS_Pro.log FileKey3=%Documents%\Corel VideoStudio Pro\14.0\AudioTmp|*.* FileKey4=%Documents%\Corel VideoStudio Pro\14.0\SmartProxy|*.* ExcludeKey1=FILE|%AppData%\Corel\Messages|*.policy RegKey1=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\HerRFL RegKey2=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\Library Manager|Latest Export Folder RegKey3=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\Preference|Working Folder RegKey4=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\VIO\Recent Dir [snagit 9 More*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\9 Default=False FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.* FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.* FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf FileKey4=%LocalAppData%\TechSmith\SnagIt\Thumbnails|*.* RegKey1=HKCU\Software\TechSmith\SnagIt\9|StampCustomFolder [snagit 10 More*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\10 Default=False FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.* FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.* FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf FileKey4=%LocalAppData%\TechSmith\SnagIt\Thumbnails|*.* RegKey1=HKCU\Software\TechSmith\SnagIt\10|StampCustomFolder Link to comment Share on other sites More sharing options...
SMalik Posted February 8, 2012 Share Posted February 8, 2012 NEW ENTRY [ThumbCacheToDelete*] LangSecRef=3025 DetectFile=%LocalAppData%\Microsoft\Windows\Explorer Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Explorer\ThumbCacheToDelete|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
