Winapp2.ini Posted May 31, 2018 Author Share Posted May 31, 2018 On 5/25/2018 at 01:34, siliconman01 said: For some reason, the TRIM function of winapp2ool.exe (V0.8.0.0) does not recognize the DetectFile shown below for Chrome and it trims these all out. DetectFile2=%LocalAppData%\Google\Chrome* If I change this to DetectFile2=%LocalAppData%\Google\Chrome, then they are not TRIMMED out. I wonder if CCleaner is recognizing %LocalAppData%\Google\Chrome* where it is used in FileKey and ExcludeKey. ??? A build of winapp2ool.exe with this fixed is available: https://github.com/MoscaDotTo/Winapp2/pull/245 It's not yet on the master as I've made significant changes to the code and want to make sure everything is still functional before pushing. Everything in my tests seemed OK though winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 31, 2018 Share Posted May 31, 2018 5 hours ago, Winapp2.ini said: A build of winapp2ool.exe with this fixed is available: https://github.com/MoscaDotTo/Winapp2/pull/245 It's not yet on the master as I've made significant changes to the code and want to make sure everything is still functional before pushing. Everything in my tests seemed OK though Fix is confirmed. From what I have tested thus far, this new version appears to be working okay. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 31, 2018 Author Share Posted May 31, 2018 I created a "redux" version of Trim called TrimXP which targets .NET Framework 4: https://github.com/MoscaDotTo/Winapp2/tree/master/Tools/TrimXP This should be useful to anyone on WindowsXP who cannot otherwise run winapp2ool due to the .NET 4.6 Requirement The only concern I have is that I have never tested environment variable expanding on WindowsXP and don't know how/if some will work. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 5, 2018 Author Share Posted June 5, 2018 Winapp2ool has been (officially) updated to v0.85beta, existing previous versions should inform users of this. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 7, 2018 Share Posted June 7, 2018 Revised Entry Added: RegKey1 [Adobe CC *] LangSecRef=3023 Detect=HKCU\Software\Adobe\CreativeCloud Default=False FileKey1=%AppData%\Adobe\Adobe Media Encoder\*\logs|*.*|RECURSE FileKey2=%AppData%\Adobe\Adobe Photoshop CC *\Adobe Photoshop CC * Settings\CrashLogs|*.*|RECURSE FileKey3=%AppData%\Adobe\Adobe Photoshop CC *\Adobe Photoshop CC * Settings\web-cache-temp|*.*|RECURSE FileKey4=%AppData%\Adobe\Adobe Photoshop CC *\Logs|*.*|RECURSE FileKey5=%AppData%\Adobe\CRLogs|*.*|RECURSE FileKey6=%AppData%\Adobe\dynamiclinkmanager\*\logs|*.*|RECURSE FileKey7=%AppData%\Adobe\Extension Manager CC\Log|*.*|RECURSE FileKey8=%AppData%\Adobe\Extension Manager CC\Temp|*.*|RECURSE FileKey9=%AppData%\Adobe\LogTransport2CC\Logs|*.*|RECURSE FileKey10=%AppData%\Adobe\Lumetri\*\logs|*.*|RECURSE FileKey11=%AppData%\Adobe\Premiere Pro\*|Plugin Loading.log FileKey12=%AppData%\Adobe\Premiere Pro\*\logs|*.*|RECURSE FileKey13=%CommonProgramFiles%\Adobe\Installers|CoreSyncInstall.log;Install.log FileKey14=%Documents%\Adobe|*.log FileKey15=%Documents%\Adobe\Adobe Media Encoder\*\logs|*.*|RECURSE FileKey16=%Documents%\Adobe\Premiere Pro\*|Plugin Loading.log RegKey1=HKCU\Software\Adobe\MediaBrowser\MRU Link to comment Share on other sites More sharing options...
siliconman01 Posted June 8, 2018 Share Posted June 8, 2018 On 6/4/2018 at 22:21, Winapp2.ini said: Winapp2ool has been (officially) updated to v0.85beta, existing previous versions should inform users of this. Is the format for 0.85beta for the features included at this point pretty much as you expect to keep them? The reason for my question is that I would like to generate a "How to use" procedure for a few "not so computer savvy" friends and relatives that I help with their computers. They are currently using the pre-Winapp2ool tools to trim their Winapp2.ini. They only use Trim and the CCinidebug tools because I do the other "stuff" prior to sending them the latest Winapp2.ini each time a new version of CCleaner is released. TIA for your feedback. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 8, 2018 Author Share Posted June 8, 2018 At this point yes, the features are mostly in their final state under the new menu system. I'll be working on creating documentation for it all soon. 14 hours ago, siliconman01 said: Is the format for 0.85beta for the features included at this point pretty much as you expect to keep them? The reason for my question is that I would like to generate a "How to use" procedure for a few "not so computer savvy" friends and relatives that I help with their computers. They are currently using the pre-Winapp2ool tools to trim their Winapp2.ini. They only use Trim and the CCinidebug tools because I do the other "stuff" prior to sending them the latest Winapp2.ini each time a new version of CCleaner is released. TIA for your feedback. On a related note, I have intention to create likely one more module that executes combinations of the other modules tasks, so simplify the tool further. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted June 9, 2018 Share Posted June 9, 2018 8 hours ago, Winapp2.ini said: At this point yes, the features are mostly in their final state under the new menu system. I'll be working on creating documentation for it all soon. On a related note, I have intention to create likely one more module that executes combinations of the other modules tasks, so simplify the tool further. Hey, thanks for the feedback. I think I will wait a bit before I send it out. One simplification combination suggestion: One that trims the winapp2.ini file and then edits the ccleaner.ini file. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted June 9, 2018 Share Posted June 9, 2018 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/6e94b5b89525af861a809de23bc69ac6a3f0df58https://github.com/MoscaDotTo/Winapp2/commit/503652f3057ccb4e72b92db89b3448132d3c64b4 Link to comment Share on other sites More sharing options...
SMalik Posted June 13, 2018 Share Posted June 13, 2018 New Entry [Apple iTunes *] DetectOS=10.0 LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AppleInc.iTunes_nzyj5cx40ttqa DetectFile=%LocalAppData%\Packages\AppleInc.iTunes_nzyj5cx40ttqa Default=False FileKey1=%LocalAppData%\Packages\AppleInc.iTunes_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\AppleInc.iTunes_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\AppleInc.iTunes_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Local\Apple Computer\iTunes|Cache.db;*.xml FileKey5=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Local\Microsoft\Windows\Caches|*.*|RECURSE FileKey6=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\LocalLow\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey7=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Roaming\Apple Computer\iTunes\Cookies|Cookies.binarycookies FileKey8=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Roaming\Apple Computer\iTunes\Device Support|*.*|RECURSE FileKey9=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Roaming\Apple Computer\Logs|*.*|RECURSE FileKey10=%LocalAppData%\Packages\AppleInc.iTunes_*\SystemAppData\Helium\Cache|*.*|RECURSE FileKey11=%LocalAppData%\Packages\AppleInc.iTunes_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
PICPro Posted June 15, 2018 Share Posted June 15, 2018 For the new README.md file with the Winapp2 instructions, it appears that most of the backslashes have been "escaped" like in a c string. So most of the backslashes in the path names are doubled up, also some of the asterisks are escaped, showing up as *\ instead of just * For the LangSecRef list, here are a few more: LangSecRef=3029 = Google Chrome LangSecRef=3030 = Thunderbird LangSecRef=3031 = Windows Store Link to comment Share on other sites More sharing options...
APMichael Posted June 15, 2018 Share Posted June 15, 2018 On 15.6.2018 at 03:12, PICPro said: For the new README.md file with the Winapp2 instructions, it appears that most of the backslashes have been "escaped" like in a c string. So most of the backslashes in the path names are doubled up, also some of the asterisks are escaped, showing up as *\ instead of just * That's correct, because GitHub uses the Markdown format (.md not .txt). Workaround: You can copy and paste the readme text, instead of downloading the .md file. On 15.6.2018 at 03:12, PICPro said: For the LangSecRef list, here are a few more: LangSecRef=3029 = Google Chrome LangSecRef=3030 = Thunderbird LangSecRef=3031 = Windows Store Thanks! Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/ecc4968946fb8b4a796cf55e2c15a8ab6c340203 Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/0ce47e9475825095ffb481eb001deaa440e35dbc Link to comment Share on other sites More sharing options...
PICPro Posted June 20, 2018 Share Posted June 20, 2018 After installing the current 64 bit Vivaldi in Windows 7, I noticed that an entry was missing in [SetupMetrics *]. I'm suggesting to add FileKey21 as this is where the files have been going: [SetupMetrics *] LangSecRef=3029 Detect1=HKCU\Software\7Star\7Star Detect2=HKCU\Software\360Browser\Browser Detect3=HKCU\Software\Amigo Detect4=HKCU\Software\CentBrowser Detect5=HKCU\Software\ChromePlus Detect6=HKCU\Software\Chromium\PreferenceMACs Detect7=HKCU\Software\CocCoc\Browser Detect8=HKCU\Software\Comodo\Dragon Detect9=HKCU\Software\Coowon\Coowon Detect10=HKCU\Software\Epic Privacy Browser Detect11=HKCU\Software\Flock Detect12=HKCU\Software\RockMelt Detect13=HKCU\Software\Slimjet Detect14=HKCU\Software\Torch Detect15=HKCU\Software\Vivaldi Detect16=HKCU\Software\Yandex\YandexBrowser DetectFile1=%AppData%\brave DetectFile2=%LocalAppData%\Google\Chrome* Default=False FileKey1=%LocalAppData%\7Star\7Star\Application\SetupMetrics|*.*|REMOVESELF FileKey2=%LocalAppData%\360Browser\Browser\Application\SetupMetrics|*.*|REMOVESELF FileKey3=%LocalAppData%\Amigo\Application\SetupMetrics|*.*|REMOVESELF FileKey4=%LocalAppData%\Brave\SetupMetrics|*.*|REMOVESELF FileKey5=%LocalAppData%\CentBrowser\Application\SetupMetrics|*.*|REMOVESELF FileKey6=%LocalAppData%\CocCoc\Browser\Application\SetupMetrics|*.*|REMOVESELF FileKey7=%LocalAppData%\Coowon\Coowon\Application\SetupMetrics|*.*|REMOVESELF FileKey8=%LocalAppData%\Epic Privacy Browser\Application\SetupMetrics|*.*|REMOVESELF FileKey9=%LocalAppData%\Flock\Application\SetupMetrics|*.*|REMOVESELF FileKey10=%LocalAppData%\Google\Chrome*\Application\SetupMetrics|*.*|REMOVESELF FileKey11=%LocalAppData%\MapleStudio\ChromePlus\Application\SetupMetrics|*.*|REMOVESELF FileKey12=%LocalAppData%\RockMelt\Application\SetupMetrics|*.*|REMOVESELF FileKey13=%LocalAppData%\Torch\Application\SetupMetrics|*.*|REMOVESELF FileKey14=%LocalAppData%\Vivaldi\Application\SetupMetrics|*.*|REMOVESELF FileKey15=%LocalAppData%\Yandex\YandexBrowser\Application\SetupMetrics|*.*|REMOVESELF FileKey16=%ProgramFiles%\Comodo\Dragon\SetupMetrics|*.*|REMOVESELF FileKey17=%ProgramFiles%\Google\Chrome*\Application\SetupMetrics|*.*|REMOVESELF FileKey18=%ProgramFiles%\Slimjet\SetupMetrics|*.*|REMOVESELF FileKey19=%ProgramFiles%\SRWare Iron\SetupMetrics|*.*|REMOVESELF FileKey20=%ProgramFiles%\SuperBird\SetupMetrics|*.*|REMOVESELF FileKey21=%ProgramFiles%\Vivaldi\Application\SetupMetrics|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
PICPro Posted June 20, 2018 Share Posted June 20, 2018 I'm suggesting to add FileKey21 to [Installer *] for the same reason as above: [Installer *] LangSecRef=3029 Detect1=HKCU\Software\7Star\7Star Detect2=HKCU\Software\360Browser\Browser Detect3=HKCU\Software\Amigo Detect4=HKCU\Software\CentBrowser Detect5=HKCU\Software\ChromePlus Detect6=HKCU\Software\Chromium\PreferenceMACs Detect7=HKCU\Software\CocCoc\Browser Detect8=HKCU\Software\Comodo\Dragon Detect9=HKCU\Software\Coowon\Coowon Detect10=HKCU\Software\Epic Privacy Browser Detect11=HKCU\Software\Flock Detect12=HKCU\Software\RockMelt Detect13=HKCU\Software\Slimjet Detect14=HKCU\Software\Torch Detect15=HKCU\Software\Vivaldi Detect16=HKCU\Software\Yandex\YandexBrowser DetectFile1=%AppData%\brave DetectFile2=%LocalAppData%\Google\Chrome* Default=False FileKey1=%LocalAppData%\7Star\7Star\Application\*\Installer|*.7z FileKey2=%LocalAppData%\360Browser\Browser\Application\*\Installer|*.7z FileKey3=%LocalAppData%\Amigo\Application\*\Installer|*.7z FileKey4=%LocalAppData%\Brave\*\Installer|*.7z FileKey5=%LocalAppData%\CentBrowser\Application\*\Installer|*.7z FileKey6=%LocalAppData%\CocCoc\Browser\Application\*\Installer|*.7z FileKey7=%LocalAppData%\Coowon\Coowon\Application\*\Installer|*.7z FileKey8=%LocalAppData%\Epic Privacy Browser\Application\*\Installer|*.7z FileKey9=%LocalAppData%\Flock\Application\*\Installer|*.7z FileKey10=%LocalAppData%\Google\Chrome*\Application\*\Installer|*.7z FileKey11=%LocalAppData%\MapleStudio\ChromePlus\Application\*\Installer|*.7z FileKey12=%LocalAppData%\RockMelt\Application\*\Installer|*.7z FileKey13=%LocalAppData%\Torch\Application\*\Installer|*.7z FileKey14=%LocalAppData%\Vivaldi\Application\*\Installer|*.7z FileKey15=%LocalAppData%\Yandex\YandexBrowser\Application\*\Installer|*.7z FileKey16=%ProgramFiles%\Comodo\Dragon\*\Installer|*.7z FileKey17=%ProgramFiles%\Google\Chrome*\Application\*\Installer|*.7z FileKey18=%ProgramFiles%\Slimjet\*\Installer|*.7z FileKey19=%ProgramFiles%\SRWare Iron\*\Installer|*.7z FileKey20=%ProgramFiles%\SuperBird\*\Installer|*.7z FileKey21=%ProgramFiles%\Vivaldi\Application\*\Installer|*.7z Link to comment Share on other sites More sharing options...
APMichael Posted June 21, 2018 Share Posted June 21, 2018 23 hours ago, PICPro said: After installing the current 64 bit Vivaldi in Windows 7, I noticed that an entry was missing in [SetupMetrics *]. I'm suggesting to add FileKey21 as this is where the files have been going:... Thank you for the info. I found out that it depends on the installation type. On the first setup screen you can click on "Advanced" and choose the "Installation type": "Install per user" (default setting) uses "%LocalAppData%\Vivaldi\Application" and "Install for all users" uses "%ProgramFiles%\Vivaldi\Application". Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/f26f273c079d3273935f80d8a0deed18a39cb3e1 Link to comment Share on other sites More sharing options...
PICPro Posted June 25, 2018 Share Posted June 25, 2018 I've noticed that VLC Media Player makes backups of the vlc-qc-interface.ini file from time to time, adding an additional file extension. I'm not sure what triggers the backup, but it seems like every couple weeks it happens. Depending on your settings, there can be an MRU file name list near the end of each file which may have privacy implications, therefore I'm suggesting to add FileKey2 to remove the backups, but not the actual .ini file. FileKey3 can be added to make sure that the crashdump and crashdump.mv folders are emptied. [VLC Media Player *] LangSecRef=3023 Detect=HKLM\Software\VideoLAN\VLC Default=False FileKey1=%AppData%\vlc|*.cache-3;ml.xspf.tmp* FileKey2=%AppData%\vlc|vlc-qt-interface.ini.* FileKey3=%AppData%\vlc\crashdump*|*.* Link to comment Share on other sites More sharing options...
PICPro Posted June 26, 2018 Share Posted June 26, 2018 Here is an update for [Canon Digital Photo Professional 4 *] [Canon Digital Photo Professional 4 *] LangSecRef=3021 Detect=HKLM\Software\Canon_Inc_IC\DPP4 DetectFile=%ProgramFiles%\Canon\Digital Photo Professional 4 Default=False FileKey1=%AppData%\Canon_Inc_IC\DPP4\Application\Temp|*.*|RECURSE FileKey2=%AppData%\Canon_Inc_IC\DPP4\DppMWare\Cache|*.*|RECURSE FileKey3=%AppData%\Canon_Inc_IC\ServiceLog\AutoUpdateService|*.txt FileKey4=%ProgramData%\Canon_Inc_IC\UniversalInstaller\ServiceLog|*.TXT FileKey1 added to make sure that the Temp subfolder gets cleared. FileKey3 and 4 are to clean out the log files that accumulate when using the updater or the lens module downloader. Link to comment Share on other sites More sharing options...
APMichael Posted June 27, 2018 Share Posted June 27, 2018 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/e2db8b12e6ea333145381b10a616d18710df9c91https://github.com/MoscaDotTo/Winapp2/commit/8bc1717672f904cddfbeaec0d00f36554f0db372 Link to comment Share on other sites More sharing options...
SMalik Posted July 2, 2018 Share Posted July 2, 2018 Revised Entry Added: Detect1 and FileKey2 [Apple MobileSync Backups *] LangSecRef=3023 Detect=HKLM\Software\Apple Computer, Inc. Detect1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AppleInc.iTunes_nzyj5cx40ttqa Default=False FileKey1=%AppData%\Apple Computer\MobileSync\Backup|*.*|RECURSE FileKey2=%UserProfile%\Apple\MobileSync\Backup|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted July 3, 2018 Share Posted July 3, 2018 Thanks for the revised entry. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/ea1dc7b355bfae90ce19ce463c3c101beaea6ebfhttps://github.com/MoscaDotTo/Winapp2/commit/04caa3b62cfc2ba273e2bd2b61e5d1cd5eae0dd2 Link to comment Share on other sites More sharing options...
siliconman01 Posted July 11, 2018 Share Posted July 11, 2018 Modified entry: [Syncios Cell Phone Backup & Manage *] Added FileKey3 [Syncios Cell Phone Backup & Manage *] LangSecRef=3024 Detect1=HKCU\Software\Syncios Detect2=HKCU\Software\Syncios Data Transfer Default=False FileKey1=%AppData%\Syncios|android.log;log.txt FileKey2=%AppData%\Syncios Data Transfer|*.log FileKey3=%UserProfile%\Documents\Syncios Data Transfer|preference_conf.ini.old.bak Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted July 11, 2018 Share Posted July 11, 2018 3 hours ago, siliconman01 said: Modified entry: [Syncios Cell Phone Backup & Manage *] Added FileKey3 ... Thanks for the modified entry. For the FileKey3 you can use the variable %Documents%: [Syncios Cell Phone Backup & Manage *] LangSecRef=3024 Detect1=HKCU\Software\Syncios Detect2=HKCU\Software\Syncios Data Transfer Default=False FileKey1=%AppData%\Syncios|android.log;log.txt FileKey2=%AppData%\Syncios Data Transfer|*.log FileKey3=%Documents%\Syncios Data Transfer|preference_conf.ini.old.bak Link to comment Share on other sites More sharing options...
APMichael Posted July 12, 2018 Share Posted July 12, 2018 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/e22e97e681edc140c21d265e7ffc2140ab7c3cbbhttps://github.com/MoscaDotTo/Winapp2/commit/40e7b8ff9985d75aa9aaf0f756bb7aa6cffb46b9 Link to comment Share on other sites More sharing options...
siliconman01 Posted July 25, 2018 Share Posted July 25, 2018 New entry: [Stocks and Futures *] [Stocks and Futures *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\24877CutthroatSoftware.StocksandFutures_xgnzh3xnefnqe Default=False FileKey1=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey3=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\Temp|*.* FileKey4=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AppData\Indexed DB|*.log FileKey5=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\LocalState|*.tmp|RECURSE FileKey6=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\TempState|*.*|RECURSE ExcludeKey1=FILE|%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\INetCache\|container.dat Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted July 26, 2018 Share Posted July 26, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/599d3c9c6895b6682a8b37d9dcd97925431b0359 Link to comment Share on other sites More sharing options...
