APMichael Posted September 27, 2018 Share Posted September 27, 2018 Edit: Before answering, please see my latest post. Thanks. On 26.9.2018 at 23:04, SMalik said: Now, it is deleting favorites. Most programs exclude %LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore\LogFiles from cleaning. Also, spartan.edb and spartan.jfm files from %LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore The changed entry doesn't remove more files as before! It still doesn't remove the files "spartan.edb", "spartan.jfm" and "LogFiles\edb.log"! I just changed the pattern of the FileKey, therefore the ExcludeKeys aren't necessary anymore. The bug was caused by removing the file "edb.chk", that's why I changed the pattern of the FileKey. Summary: The entry removes exactly the same files as before, but additionally protects one more file. If you compare both versions you will see that also! This is more precise and removes the same (respectively less) files... FileKey7=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore|V01*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore\LogFiles|edb0*.log;edb*.jrs;edbtmp.log ...than: FileKey7=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore|*.*|RECURSE ExcludeKey1=FILE|%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore\|spartan.edb ExcludeKey2=FILE|%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore\|spartan.jfm ExcludeKey3=FILE|%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore\LogFiles\|edb.log Edit: It could be a side effect of the previous entry. Now the "edb.chk" file doesn't get removed anymore and it may be not correctly synced with the other files. But this should occur only once. Link to comment Share on other sites More sharing options...
APMichael Posted September 27, 2018 Share Posted September 27, 2018 On 26.9.2018 at 23:02, SMalik said: You twisted my question. As per my understanding, this policy applies to any backup. Therefore, the backup entries from Google Chrome should be removed. No, the "policy" is that backups should not mixed with other files and that they should have their own entry always. Please check the Winapp2.ini and you will find many backup entries. The community decided not to include backups of security programs (and things like registry cleaners), because that could possibly damage important system functions. Please see siliconman01s reply also. On 26.9.2018 at 23:20, SMalik said: We don't use those (winsys.ini) LangSecRefs because the entries don't appear under the correct section in CCleaner (e.g. tab "Windows", section "Microsoft Edge"). Unfortunately, they appear at the very bottom of the tab "Applications", what people don't expect. And you also would have doubled sections. Link to comment Share on other sites More sharing options...
APMichael Posted September 27, 2018 Share Posted September 27, 2018 14 hours ago, siliconman01 said: Looks like you have fixed MS Edge favorites and Chrome extensions. Thanks immensely! Thanks for testing and your reply. Link to comment Share on other sites More sharing options...
APMichael Posted September 27, 2018 Share Posted September 27, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/1d044ed823bdd5c86752db10eb4632c45844598d Link to comment Share on other sites More sharing options...
APMichael Posted September 27, 2018 Share Posted September 27, 2018 @SMalik: Before we get caught in an endless discussion , I revised the entry [Microsoft Edge *] again. Now it matches exactly with the files shown on your screenshot. If the entry is ok for you now, please test it. And could you please test the new Chrome entry [Logs Old *] also? Any idea for a better entry name? I will wait for your reply before updating the Winapp2.ini. Thanks! [Microsoft Edge *] LangSecRef=3022 Detect=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!00*\INetCookies|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!00*\Microsoft\Cryptnet*Cache|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!00*\MicrosoftEdge\Cookies|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\Microsoft\Cryptnet*Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\Cookies|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\UrlBlock|*.tmpFileKey7=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore|V01*.log;V01*.jrs FileKey8=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\Datastore\Data\nouser1\*\Favorites|*.ico FileKey9=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Indexed\Data\nouser1\*|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\ImageStore|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\Recovery\Active|*.dat FileKey12=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\Temp|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AppData\User\Default\Indexed DB|*.*|RECURSE FileKey14=%UserProfile%\MicrosoftEdgeBackups\backups\*|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted September 29, 2018 Share Posted September 29, 2018 Revised Entry Added: %LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\LocalState\Favicons\PushNotificationGrouping|*.*|RECURSE RegKey1 is associated with FileKey11 RegKey2 thru RegKey4: Favorites html file last open and save locations [Microsoft Edge *] LangSecRef=3022 Detect=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!00*\INetCookies|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!00*\Microsoft\Cryptnet*Cache|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!00*\MicrosoftEdge\Cookies|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\Microsoft\Cryptnet*Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\Cookies|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\UrlBlock|*.tmp FileKey7=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data\nouser1\*\DBStore|V01*.log;V01*.jrs FileKey8=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\Datastore\Data\nouser1\*\Favorites|*.ico FileKey9=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Indexed\Data\nouser1\*|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\ImageStore|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\Recovery\Active|*.dat FileKey12=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\Temp|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AppData\User\Default\Indexed DB|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\LocalState\Favicons\PushNotificationGrouping|*.*|RECURSE FileKey15=%UserProfile%\MicrosoftEdgeBackups\backups\*|*.*|REMOVESELF RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\MicrosoftEdge\Recovery\PendingDelete RegKey2=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\PersistedPickerData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe!MicrosoftEdge\DefaultOpenFileMultiple RegKey3=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\PersistedPickerData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe!MicrosoftEdge\DefaultOpenFileSingle RegKey4=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\PersistedPickerData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe!MicrosoftEdge\DefaultSaveFileSingle Link to comment Share on other sites More sharing options...
siliconman01 Posted September 30, 2018 Share Posted September 30, 2018 JFI and to let others know that our CCleaner with Winapp2.ini works fine in the impending October update: I updated my ASUS homebuilt gaming computer and my Dell XPS 15 2in1 laptop/tablet to Windows 10x64 Pro OS Build 17763.1 Version 1809. The Dell update went almost seemlessly. The gaming computer had to have the nvidia driver, Sound Blaster Z driver, Norton Security, removed and re-installed to work properly. Overall I am very pleased with the update and the speed at which it installed. Just thought you might be interested Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted September 30, 2018 Share Posted September 30, 2018 On 29.9.2018 at 06:58, SMalik said: Revised Entry ... [Microsoft Edge *] ... Thank you for your renewed revision. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/e285b8012e7e849512ad96cc5210331b0c823dee 3 hours ago, siliconman01 said: JFI and to let others know that our CCleaner with Winapp2.ini works fine in the impending October update ... Thank you for your information. Link to comment Share on other sites More sharing options...
SMalik Posted September 30, 2018 Share Posted September 30, 2018 Revised Entry Now compatible with version 12 [CyberLink Power2Go *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\Power2Go9\9.0 Detect2=HKCU\Software\CyberLink\Power2Go10\10.0 Detect3=HKCU\Software\CyberLink\Power2Go11\11.0 Detect4=HKCU\Software\CyberLink\Power2Go12\12.0 Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE FileKey2=%Documents%\PDRMUSIC.TMP|*.*|REMOVESELF FileKey3=%LocalAppData%\Cyberlink\Power2Go*|DLDB.db FileKey4=%Music%|*.tmp FileKey5=%Pictures%|*.tmp FileKey6=%ProgramFiles%\Cyberlink\Power2Go*|*.tmp FileKey7=%ProgramFiles%\Cyberlink\Power2Go*|Thumbs.db|RECURSE FileKey8=%Public%\Documents\Cyberlink\Power2Go11|MP3Cache.log FileKey9=%Public%\Documents\Cyberlink\Power2Go12|MP3Cache.log RegKey1=HKCU\Software\CyberLink\LabelPrint\Recent File List RegKey2=HKCU\Software\CyberLink\MediaCache\Data4 RegKey3=HKCU\Software\CyberLink\MediaCache5\Data5 RegKey4=HKCU\Software\CyberLink\MediaCache5\Thumbnail5 RegKey5=HKCU\Software\CyberLink\Power2Go9\9.0|CDRippingPath RegKey6=HKCU\Software\CyberLink\Power2Go9\9.0|CUEName RegKey7=HKCU\Software\CyberLink\Power2Go9\9.0|CUEPath RegKey8=HKCU\Software\CyberLink\Power2Go9\9.0|DestFolder RegKey9=HKCU\Software\CyberLink\Power2Go9\9.0|DVDFolderPath RegKey10=HKCU\Software\CyberLink\Power2Go9\9.0|ImagePath RegKey11=HKCU\Software\CyberLink\Power2Go9\9.0|LastBrowsePath RegKey12=HKCU\Software\CyberLink\Power2Go9\9.0|LastSaveProjPath RegKey13=HKCU\Software\CyberLink\Power2Go9\9.0|MonitorPaths RegKey14=HKCU\Software\CyberLink\Power2Go9\9.0|OpenPrjFilePath RegKey15=HKCU\Software\CyberLink\Power2Go9\9.0|SelectedFolderPath RegKey16=HKCU\Software\CyberLink\Power2Go9\9.0\MediaObj\MediaCache5\Data5 RegKey17=HKCU\Software\CyberLink\Power2Go9\9.0\MediaObj\MediaCache5\Thumbnail5 RegKey18=HKCU\Software\CyberLink\Power2Go10\10.0|CDRippingPath RegKey19=HKCU\Software\CyberLink\Power2Go10\10.0|CUEName RegKey20=HKCU\Software\CyberLink\Power2Go10\10.0|CUEPath RegKey21=HKCU\Software\CyberLink\Power2Go10\10.0|DestFolder RegKey22=HKCU\Software\CyberLink\Power2Go10\10.0|DVDFolderPath RegKey23=HKCU\Software\CyberLink\Power2Go10\10.0|ImagePath RegKey24=HKCU\Software\CyberLink\Power2Go10\10.0|LastBrowsePath RegKey25=HKCU\Software\CyberLink\Power2Go10\10.0|LastSaveProjPath RegKey26=HKCU\Software\CyberLink\Power2Go10\10.0|MonitorPaths RegKey27=HKCU\Software\CyberLink\Power2Go10\10.0|OpenPrjFilePath RegKey28=HKCU\Software\CyberLink\Power2Go10\10.0|SelectedFolderPath RegKey29=HKCU\Software\CyberLink\Power2Go10\10.0\MediaObj\MediaCache5\Data5 RegKey30=HKCU\Software\CyberLink\Power2Go10\10.0\MediaObj\MediaCache5\Thumbnail5 RegKey31=HKCU\Software\CyberLink\Power2Go11\11.0|CDRippingPath RegKey32=HKCU\Software\CyberLink\Power2Go11\11.0|CUEName RegKey33=HKCU\Software\CyberLink\Power2Go11\11.0|CUEPath RegKey34=HKCU\Software\CyberLink\Power2Go11\11.0|DestFolder RegKey35=HKCU\Software\CyberLink\Power2Go11\11.0|DVDFolderPath RegKey36=HKCU\Software\CyberLink\Power2Go11\11.0|ImagePath RegKey37=HKCU\Software\CyberLink\Power2Go11\11.0|LastBrowsePath RegKey38=HKCU\Software\CyberLink\Power2Go11\11.0|LastSaveProjPath RegKey39=HKCU\Software\CyberLink\Power2Go11\11.0|MonitorPaths RegKey40=HKCU\Software\CyberLink\Power2Go11\11.0|OpenPrjFilePath RegKey41=HKCU\Software\CyberLink\Power2Go11\11.0|SelectedFolderPath RegKey42=HKCU\Software\CyberLink\Power2Go11\11.0\MediaObj\MediaCache5\Data5 RegKey43=HKCU\Software\CyberLink\Power2Go11\11.0\MediaObj\MediaCache5\Thumbnail5 RegKey44=HKCU\Software\CyberLink\Power2Go12\12.0|CDRippingPath RegKey45=HKCU\Software\CyberLink\Power2Go12\12.0|CUEName RegKey46=HKCU\Software\CyberLink\Power2Go12\12.0|CUEPath RegKey47=HKCU\Software\CyberLink\Power2Go12\12.0|DestFolder RegKey48=HKCU\Software\CyberLink\Power2Go12\12.0|DVDFolderPath RegKey49=HKCU\Software\CyberLink\Power2Go12\12.0|ImagePath RegKey50=HKCU\Software\CyberLink\Power2Go12\12.0|LastBrowsePath RegKey51=HKCU\Software\CyberLink\Power2Go12\12.0|LastSaveProjPath RegKey52=HKCU\Software\CyberLink\Power2Go12\12.0|MonitorPaths RegKey53=HKCU\Software\CyberLink\Power2Go12\12.0|OpenPrjFilePath RegKey54=HKCU\Software\CyberLink\Power2Go12\12.0|SelectedFolderPath RegKey55=HKCU\Software\CyberLink\Power2Go12\12.0\MediaObj\MediaCache5\Data5 RegKey56=HKCU\Software\CyberLink\Power2Go12\12.0\MediaObj\MediaCache5\Thumbnail5 RegKey57=HKCU\Software\CyberLink\WaveEditor\2.0|ImportDir RegKey58=HKCU\Software\CyberLink\WaveEditor\2.0|TempFileDir RegKey59=HKCU\Software\CyberLink\WaveEditor\2.0|WorkDir Link to comment Share on other sites More sharing options...
SMalik Posted September 30, 2018 Share Posted September 30, 2018 Revised Entry Now compatible with version 10 [CyberLink PhotoDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PhotoDirector3 Detect2=HKLM\Software\CyberLink\PhotoDirector4 Detect3=HKLM\Software\CyberLink\PhotoDirector5 Detect4=HKLM\Software\CyberLink\PhotoDirector6 Detect5=HKLM\Software\CyberLink\PhotoDirector7 Detect6=HKLM\Software\CyberLink\PhotoDirector8 Detect7=HKLM\Software\CyberLink\PhotoDirector9 Detect8=HKLM\Software\CyberLink\PhotoDirector10 Default=False FileKey1=%Pictures%\PhotoDirector\*\*|*.*|RECURSE ExcludeKey1=PATH|%Pictures%\PhotoDirector\*\*\|*.phd Link to comment Share on other sites More sharing options...
SMalik Posted September 30, 2018 Share Posted September 30, 2018 Revised Entry Now compatible with version 17 [CyberLink PowerDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PowerDirector10 Detect2=HKCU\Software\CyberLink\PowerDirector11 Detect3=HKCU\Software\CyberLink\PowerDirector12 Detect4=HKCU\Software\CyberLink\PowerDirector13 Detect5=HKCU\Software\CyberLink\PowerDirector14 Detect6=HKCU\Software\CyberLink\PowerDirector15 Detect7=HKCU\Software\CyberLink\PowerDirector16 Detect8=HKCU\Software\CyberLink\PowerDirector17 Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE FileKey2=%AppData%\Cyberlink\PowerDirector\*|Recentfiles.ini FileKey3=%AppData%\CyberLink\PowerDirector\*\AutoSave|*.*|RECURSE FileKey4=%AppData%\CyberLink\PowerDirector\*\photoTmp|*.*|RECURSE FileKey5=%AppData%\Cyberlink\PowerDirector\*\WaveForms|*.*|RECURSE FileKey6=%Documents%\CyberLink\PowerDirector\*|Snapshot(*).jpg FileKey7=%Documents%\CyberLink\PowerDirector\*\MyTitles|*.*|RECURSE FileKey8=%Documents%\Cyberlink\PowerDirector\*\PDRMUSIC.TMP|*.*|REMOVESELF FileKey9=%Documents%\Cyberlink\PowerDirector\*\PP.TWOPASS|*.*|REMOVESELF FileKey10=%Documents%\CyberLink\PowerDirector\*\Preview Cache Files|*.* FileKey11=%Documents%\CyberLink\PowerDirector\*\ShadowEditFiles|*.MPG FileKey12=%Documents%\CyberLink\PowerDirector\*\SplitterIndex|*.maidx RegKey1=HKCU\Software\CyberLink\Hanuman RegKey2=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Data5 RegKey3=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Thumbnail5 RegKey4=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Thumbnail5 RegKey6=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Data5 RegKey7=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Thumbnail5 RegKey8=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Data5 RegKey9=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Thumbnail5 RegKey10=HKCU\Software\CyberLink\PowerDirector14\MediaObj\MediaCache5\Data5 RegKey11=HKCU\Software\CyberLink\PowerDirector14\MediaObj\MediaCache5\Thumbnail5 RegKey12=HKCU\Software\CyberLink\PowerDirector15\MediaObj\MediaCache5\Data5 RegKey13=HKCU\Software\CyberLink\PowerDirector15\MediaObj\MediaCache5\Thumbnail5 RegKey14=HKCU\Software\CyberLink\PowerDirector16\MediaObj\MediaCache5\Data5 RegKey15=HKCU\Software\CyberLink\PowerDirector16\MediaObj\MediaCache5\Thumbnail5 RegKey16=HKCU\Software\CyberLink\PowerDirector17\MediaObj\MediaCache5\Data5 RegKey17=HKCU\Software\CyberLink\PowerDirector17\MediaObj\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
SMalik Posted September 30, 2018 Share Posted September 30, 2018 Revised Entry Now compatible with version 9 [CyberLink AudioDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\AudioDirector4 Detect2=HKCU\Software\CyberLink\AudioDirector5 Detect3=HKCU\Software\CyberLink\AudioDirector6 Detect4=HKCU\Software\CyberLink\AudioDirector7 Detect5=HKCU\Software\CyberLink\AudioDirector8 Detect6=HKCU\Software\CyberLink\AudioDirector9 Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE FileKey2=%Documents%\Cyberlink\AudioDirector\*\SplitterIndex|*.*|RECURSE FileKey3=%LocalAppData%\Cyberlink\AudioDirector\*|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\AudioDirector4\MediaObj\MediaCache5\Data5 RegKey2=HKCU\Software\CyberLink\AudioDirector4\MediaObj\MediaCache5\Thumbnail5 RegKey3=HKCU\Software\CyberLink\AudioDirector5\MediaObj\MediaCache5\Data5 RegKey4=HKCU\Software\CyberLink\AudioDirector5\MediaObj\MediaCache5\Thumbnail5 RegKey5=HKCU\Software\CyberLink\AudioDirector6\MediaObj\MediaCache5\Data5 RegKey6=HKCU\Software\CyberLink\AudioDirector6\MediaObj\MediaCache5\Thumbnail5 RegKey7=HKCU\Software\CyberLink\AudioDirector7\MediaObj\MediaCache5\Data5 RegKey8=HKCU\Software\CyberLink\AudioDirector7\MediaObj\MediaCache5\Thumbnail5 RegKey9=HKCU\Software\CyberLink\AudioDirector8\MediaObj\MediaCache5\Data5 RegKey10=HKCU\Software\CyberLink\AudioDirector8\MediaObj\MediaCache5\Thumbnail5 RegKey11=HKCU\Software\CyberLink\AudioDirector9\MediaObj\MediaCache5\Data5 RegKey12=HKCU\Software\CyberLink\AudioDirector9\MediaObj\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
SMalik Posted September 30, 2018 Share Posted September 30, 2018 Revised Entry Now compatible with version 7 [CyberLink ColorDirector *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\ColorDirector3 Detect2=HKCU\Software\CyberLink\ColorDirector4 Detect3=HKCU\Software\CyberLink\ColorDirector5 Detect4=HKCU\Software\CyberLink\ColorDirector6 Detect5=HKCU\Software\CyberLink\ColorDirector7 Default=False FileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSE FileKey2=%LocalAppData%\Cyberlink\ColorDirector\*|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\ColorDirector3\MediaObj\MediaCache5\Data5 RegKey2=HKCU\Software\CyberLink\ColorDirector3\MediaObj\MediaCache5\Thumbnail5 RegKey3=HKCU\Software\CyberLink\ColorDirector4\MediaObj\MediaCache5\Data5 RegKey4=HKCU\Software\CyberLink\ColorDirector4\MediaObj\MediaCache5\Thumbnail5 RegKey5=HKCU\Software\CyberLink\ColorDirector5\MediaObj\MediaCache5\Data5 RegKey6=HKCU\Software\CyberLink\ColorDirector5\MediaObj\MediaCache5\Thumbnail5 RegKey7=HKCU\Software\CyberLink\ColorDirector6\MediaObj\MediaCache5\Data5 RegKey8=HKCU\Software\CyberLink\ColorDirector6\MediaObj\MediaCache5\Thumbnail5 RegKey9=HKCU\Software\CyberLink\ColorDirector7\MediaObj\MediaCache5\Data5 RegKey10=HKCU\Software\CyberLink\ColorDirector7\MediaObj\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
APMichael Posted October 1, 2018 Share Posted October 1, 2018 Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/7a50baabb3396a35701e7a192c3fff29427c0166 Link to comment Share on other sites More sharing options...
siliconman01 Posted October 5, 2018 Share Posted October 5, 2018 I suggest that we change the name of [My Office *] to something like [MS Office Hub App*] or [MS Office 2019 Hub *] Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted October 5, 2018 Share Posted October 5, 2018 Link to comment Share on other sites More sharing options...
APMichael Posted October 5, 2018 Share Posted October 5, 2018 3 hours ago, siliconman01 said: I suggest that we change the name of [My Office *] to something like [MS Office Hub App*] or [MS Office 2019 Hub *] I'm not sure if people will understand something like "Office Hub" if the displayed name of the app is still "My Office"? Link to comment Share on other sites More sharing options...
SMalik Posted October 7, 2018 Share Posted October 7, 2018 Revised Entry Added FileKey9, FileKey10, FileKey11, FileKey16 & FileKey17 [Internet Explorer *] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE FileKey3=%LocalAppData%\Microsoft\Windows\IECompat*Cache|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Windows\INetCache|*.*|RECURSE FileKey5=%LocalAppData%\Microsoft\Windows\INetCookies|*.*|RECURSE FileKey6=%LocalAppData%\Microsoft\Windows\WebCache|*.*|RECURSE FileKey7=%LocalAppData%\Microsoft\Windows\WebCache.old|*.*|REMOVESELF FileKey8=%LocalAppData%\Packages\windows_ie_ac_*\AC\AppCache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\windows_ie_ac_*\AC\IECompatUaCache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\windows_ie_ac_*\AC\IECompatCache|*.*|RECURSE FileKey11=%LocalAppData%\Packages\windows_ie_ac_*\AC\IEDownloadHistory|*.*|RECURSE FileKey12=%LocalAppData%\Packages\windows_ie_ac_*\AC\INet*|*.*|RECURSE FileKey13=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey14=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey15=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey16=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\EmieSiteList|*.*|RECURSE FileKey17=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\EmieUserList|*.*|RECURSE FileKey18=%LocalAppData%\Packages\windows_ie_ac_*\AC\PRICache|*.*|*.*|RECURSE FileKey19=%LocalAppData%\Packages\windows_ie_ac_*\AC\Temp|*.*|*.*|RECURSE FileKey20=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\Cache|*.*|RECURSE FileKey21=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\navigationHistory|*.*|RECURSE FileKey22=%LocalAppData%\Packages\windows_ie_ac_*\TempState|*.*|RECURSE FileKey23=%WinDir%\System32\config\Systemprofile\AppData\Local\Microsoft\Windows\INetCache|*.*|RECURSE RegKey1=HKCR\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Internet Explorer\DOMStorage RegKey2=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey3=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage RegKey4=HKCU\Software\Microsoft\Internet Explorer\Main\FeatureControl RegKey5=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats ExcludeKey1=FILE|%LocalAppData%\Microsoft\Windows\INetCache\IE\|container.dat ExcludeKey2=FILE|%LocalAppData%\Packages\windows_ie_ac_*\AC\INetCache\|container.dat Link to comment Share on other sites More sharing options...
APMichael Posted October 8, 2018 Share Posted October 8, 2018 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/e770f8e96da2e2146eb393e0c64818989e73ed7ahttps://github.com/MoscaDotTo/Winapp2/commit/4688b19a2be53effa49e30064b42c1b9a6fc6808 Link to comment Share on other sites More sharing options...
SMalik Posted October 9, 2018 Share Posted October 9, 2018 Revised Entry Removed unnecessary FileKeys [Store *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsStore_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsStore_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsStore_*\LocalState\Cache|*.*|RECURSE ExcludeKey1=FILE|%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\INetCache\|container.dat Link to comment Share on other sites More sharing options...
SMalik Posted October 9, 2018 Share Posted October 9, 2018 ExcludeKey's should be removed from the Microsoft Store apps rules. There is no harm in removing the container.dat file. Other programs remove this file. ExcludeKey1=FILE|%LocalAppData%\Packages\*\AC\INetCache\|container.dat Link to comment Share on other sites More sharing options...
APMichael Posted October 10, 2018 Share Posted October 10, 2018 15 hours ago, SMalik said: ExcludeKey's should be removed from the Microsoft Store apps rules. There is no harm in removing the container.dat file. Other programs remove this file. ExcludeKey1=FILE|%LocalAppData%\Packages\*\AC\INetCache\|container.dat We had discussed this in March already. Some quotes: On 2.3.2018 at 15:01, APMichael said: Those apps need the ExcludeKey: Bing Weather, HuluPlus, Netflix (and maybe other?)https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=205&tab=comments#comment-266270 On 3.3.2018 at 11:06, APMichael said: BTW, I checked the container.dat files on my system. They all are empty and have 0 KB. And they get recreated after deletion. It seems there's no reason for deleting them. It is similar to the ExcludeKeys of the entry Chrome [Logs *]: most of the Chrome extensions are working flawless without them, but not all. Link to comment Share on other sites More sharing options...
APMichael Posted October 10, 2018 Share Posted October 10, 2018 19 hours ago, SMalik said: Revised Entry Removed unnecessary FileKeys [Store *] ... FileKey4=%LocalAppData%\Packages\Microsoft.WindowsStore_*\AC\TokenBroker\Cache|*.*|RECURSE ... As far as I know, this is a combined entry for the Store App of Windows 8/8.1 and 10. Your revised version would work on Windows 10 only! WinStore_cw5n1h2txyewy = Windows 8/8.1 Microsoft.WindowsStore_8wekyb3d8bbwe = Windows 10 And about the FileKey4 of your revised version: On 2.3.2018 at 23:08, SMalik said: In Windows 8/10, TokenBroker/Cache is being used to store login infos, so this should be removed from all the Windows 8/10 related entries. There was a similar issue with the [Security Service Token Cache *] entry, where Windows Insider Program account login infos were being removed. Link to comment Share on other sites More sharing options...
SMalik Posted October 10, 2018 Share Posted October 10, 2018 On 10/10/2018 at 04:07, APMichael said: As far as I know, this is a combined entry for the Store App of Windows 8/8.1 and 10. Your revised version would work on Windows 10 only! WinStore_cw5n1h2txyewy = Windows 8/8.1 Microsoft.WindowsStore_8wekyb3d8bbwe = Windows 10 And about the FileKey4 of your revised version: I was sure that you were going to bring up my previous posts, as you have done this before as well. These are seven-month-old posts. Programs improve over time. If you know computers, you should know that. Microsoft Store apps are now more stable. Removing these traces are not breaking the apps. I have tested enough before posting the changes here. Stop digging up previous posts, test the changes and then challenge. In Windows 10, the App Store’s name is Microsoft Store whereas in Windows 8/8.1, it is named Windows Store. We should have a separate entry for Windows Store. I’ll provide an entry in a few days. Link to comment Share on other sites More sharing options...
siliconman01 Posted October 11, 2018 Share Posted October 11, 2018 23 hours ago, APMichael said: We had discussed this in March already. Some quotes: It is similar to the ExcludeKeys of the entry Chrome [Logs *]: most of the Chrome extensions are working flawless without them, but not all. It also breaks "Sticky Password" extension. And I get a bit tired of having to retest and then fix things because "we" decide to try removing a file that was proven earlier to cause problems on removal. Just because "other programs" remove it does not mean that "other programs" are correct in removing it. They too can/will create problems because they did not test all possible extensions. Even though Store may "improve", it does not mean that the other extensions "improved" accordingly. Leaving container.dat alone is my preference. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
