CCleaner Community Forums
Winapp2.ini additions
New Entries
[ACDSee Photo Studio Professional 2018 *]
LangSecRef=3023
Detect=HKCU\Software\ACD Systems\ACDSee Professional\110
Default=False
FileKey1=%LocalAppData%\ACD Systems\ICMCache|*.*|RECURSE
FileKey2=%LocalAppData%\ACD Systems\Logs|*.*|RECURSE
RegKey1=HKCU\Software\ACD Systems\ACDSee Professional\110|HistMCFDestFolder
RegKey2=HKCU\Software\ACD Systems\ACDSee Professional\110|HistPaths
RegKey3=HKCU\Software\ACD Systems\ACDSee Professional\110|LastOptionPageName
RegKey4=HKCU\Software\ACD Systems\ACDSee Professional\110|OnlineHistPaths
RegKey5=HKCU\Software\ACD Systems\ACDSee Professional\110|OpenFolder
RegKey6=HKCU\Software\ACD Systems\EditLib\Presets\Photo Repair 2|Last Used
[ACDSee Photo Studio Standard 2018 *]
LangSecRef=3023
Detect=HKCU\Software\ACD Systems\ACDSee Standard\210
Default=False
RegKey1=HKCU\Software\ACD Systems\ACDSee Standard\210|HistMCFDestFolder
RegKey2=HKCU\Software\ACD Systems\ACDSee Standard\210|HistPaths
RegKey3=HKCU\Software\ACD Systems\ACDSee Standard\210|LastOptionPageName
RegKey4=HKCU\Software\ACD Systems\ACDSee Standard\210|OnlineHistPaths
RegKey5=HKCU\Software\ACD Systems\ACDSee Standard\210|OpenFolder
[ACDSee Photo Studio Ultimate 2018 *]
LangSecRef=3023
Detect=HKCU\Software\ACD Systems\ACDSee Ultimate\110
Default=False
RegKey1=HKCU\Software\ACD Systems\ACDSee Ultimate\110|HistMCFDestFolder
RegKey2=HKCU\Software\ACD Systems\ACDSee Ultimate\110|HistPaths
RegKey3=HKCU\Software\ACD Systems\ACDSee Ultimate\110|LastOptionPageName
RegKey4=HKCU\Software\ACD Systems\ACDSee Ultimate\110|OnlineHistPaths
RegKey5=HKCU\Software\ACD Systems\ACDSee Ultimate\110|OpenFolder
Link to post
Just a comment/suggestion:
The last big overhaul merged many entries with duplicate FileKeys. Therefore, the entries count and file size was dramatically reduced. IMHO it would be wise to continue that.
The 3 new "ACDSee" entries could be merged with the 2 existing ones into one big entry, like the many other "versions independent" entries:
[ACDSee Photo Studio *]
LangSecRef=3023
Detect1=HKCU\Software\ACD Systems\ACDSee Pro\90
Detect2=HKCU\Software\ACD Systems\ACDSee Professional\110
Detect3=HKCU\Software\ACD Systems\ACDSee Standard\210
Detect4=HKCU\Software\ACD Systems\ACDSee Ultimate\110
Detect5=HKCU\Software\ACD Systems\ACDSee\60
Default=False
FileKey3=%LocalAppData%\ACD Systems\SavedSearches|*.*|RECURSE
RegKey1=HKCU\Software\ACD Systems\ACDSee Pro\90|HistMCFDestFolder
RegKey2=HKCU\Software\ACD Systems\ACDSee Pro\90|HistPaths
RegKey3=HKCU\Software\ACD Systems\ACDSee Pro\90|LastOptionPageName
RegKey4=HKCU\Software\ACD Systems\ACDSee Pro\90|OpenFolder
RegKey5=HKCU\Software\ACD Systems\ACDSee Pro\90\PrintOptions\OutputContactSheet|ContactSheetFN
RegKey6=HKCU\Software\ACD Systems\ACDSee Pro\90\PrintOptions\OutputContactSheet|ImageMapFN
RegKey7=HKCU\Software\ACD Systems\ACDSee Professional\110|HistMCFDestFolder
RegKey8=HKCU\Software\ACD Systems\ACDSee Professional\110|HistPaths
RegKey9=HKCU\Software\ACD Systems\ACDSee Professional\110|LastOptionPageName
RegKey10=HKCU\Software\ACD Systems\ACDSee Professional\110|OnlineHistPaths
RegKey11=HKCU\Software\ACD Systems\ACDSee Professional\110|OpenFolder
RegKey12=HKCU\Software\ACD Systems\ACDSee Standard\210|HistMCFDestFolder
RegKey13=HKCU\Software\ACD Systems\ACDSee Standard\210|HistPaths
RegKey14=HKCU\Software\ACD Systems\ACDSee Standard\210|LastOptionPageName
RegKey15=HKCU\Software\ACD Systems\ACDSee Standard\210|OnlineHistPaths
RegKey16=HKCU\Software\ACD Systems\ACDSee Standard\210|OpenFolder
RegKey17=HKCU\Software\ACD Systems\ACDSee Ultimate\110|HistMCFDestFolder
RegKey18=HKCU\Software\ACD Systems\ACDSee Ultimate\110|HistPaths
RegKey19=HKCU\Software\ACD Systems\ACDSee Ultimate\110|LastOptionPageName
RegKey20=HKCU\Software\ACD Systems\ACDSee Ultimate\110|OnlineHistPaths
RegKey21=HKCU\Software\ACD Systems\ACDSee Ultimate\110|OpenFolder
RegKey22=HKCU\Software\ACD Systems\ACDSee\60|HistMCFDestFolder
RegKey23=HKCU\Software\ACD Systems\ACDSee\60|HistPaths
RegKey24=HKCU\Software\ACD Systems\ACDSee\60|LastOptionPageName
RegKey25=HKCU\Software\ACD Systems\ACDSee\60|OpenFolder
RegKey26=HKCU\Software\ACD Systems\ACDSee\60\PrintOptions\OutputContactSheet|ContactSheetFN
RegKey27=HKCU\Software\ACD Systems\ACDSee\60\PrintOptions\OutputContactSheet|ImageMapFN
RegKey28=HKCU\Software\ACD Systems\EditLib\Presets\Photo Repair 2|Last Used
Link to post
Revised Entry
Changed RECURSE to REMOVESELF
[Downloaded Installations *]
LangSecRef=3025
DetectFile=%LocalAppData%\Downloaded Installations
Default=False
FileKey1=%LocalAppData%\Downloaded Installations|*.*|REMOVESELF
Link to post
1 hour ago, SMalik said:
You forgot to remove [ACDSee Pro *] and [ACDSee Standard *].
Please consider changing LanSecRefs of Adobe & CyberLink photo/video editing software, FasStone Image Viewer and other photo/video editing software to 3023
https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=285&tab=comments#comment-293161
Why remove [ACDSee Standard *] ??
I use it....
Link to post
On 1/31/2018 at 05:08, APMichael said:
I don't use ACDSee, therefore I can't help much. You could probably add the following:
FileKeys
%AppData%\ACD Systems\ACDSee\Cache|*.*|RECURSE
%LocalAppData%\VirtualStore\Program Files*\ACD Systems\ACDSee\6.0|InTouchErrorLog.txt
RegKeys
HKCU\Software\ACD Systems\PlugIns\InfoCache
HKCU\Software\ACD Systems\PlugIns\V2\InfoCache
(Warning: I don't know if those caches are needed. Please backup your registry before deleting!)
I will ask ACDSee support their suggestions or at least feedback on what you suggested....
Link to post
[Adobe CC *]
[Adobe Elements Organizer *]
[Adobe Media Cache *]
[Adobe Photoshop Elements *]
[Adobe Premiere Elements *]
[CyberLink AudioDirector *]
[CyberLink ColorDirector *]
[CyberLink PhotoDirector *]
[CyberLink PowerDirector *]
[FastStone Image Viewer *]
Link to post
Revised Entry
Removed:
It is not recommended to remove these files.
%CommonAppData%\Microsoft\Windows Defender\Definition Updates|*.*|RECURSE
%CommonAppData%\Microsoft\Windows Defender\Definition Updates\Backup|*.*|RECURSE
%CommonAppData%\Microsoft\Windows Defender\LocalCopy|*.*|RECURSE
[Windows Defender *]
LangSecRef=3024
Detect=HKLM\Software\Microsoft\Windows Defender
Default=False
FileKey1=%CommonAppData%\Microsoft\Windows Defender\Network Inspection System\Support|*.txt
FileKey2=%CommonAppData%\Microsoft\Windows Defender\Scans|*.bin;*.bin*
FileKey3=%CommonAppData%\Microsoft\Windows Defender\Scans\History\CacheManager|*.*|RECURSE
FileKey4=%CommonAppData%\Microsoft\Windows Defender\Scans\History\ReportLatency\Latency|*.*|RECURSE
FileKey5=%CommonAppData%\Microsoft\Windows Defender\Scans\History\Service|*.log
FileKey6=%CommonAppData%\Microsoft\Windows Defender\Scans\MetaStore|*.*|RECURSE
FileKey7=%CommonAppData%\Microsoft\Windows Defender\Support|*.*|RECURSE
Link to post
I use it....
[ACDSee Photo Studio *] shows on my system, which I do not have installed....
All "ACDSee" entries had the same FileKeys. Therefore, we merged them into one big "versions independent" entry. (Please check the first two posts.)
[ACDSee Pro *], [ACDSee Standard *], [ACDSee Photo Studio Professional 2018 *], [ACDSee Photo Studio Standard 2018 *], [ACDSee Photo Studio Ultimate 2018 *] = [ACDSee Photo Studio *]
10 hours ago, CSGalloway said:
[dvdcss *] shows on my system; What is it?
It's used for decryption of DVDs. The folder "%AppData%\dvdcss" gets created by several Media Player or DVD Copy software.
Link to post
I was just curious why in Winapp2.ini that LangSecRef=3001 or 3005 isn't used by Winapp2.ini for [Internet Explorer *] or [Microsoft Edge *] respectively.  I'm not suggesting a change as 3022 is also a good choice.
Link to post
The LangSecRefs of winsys.ini unfortunately don't work with winapp2.ini.
Link to post
Quote
Actually they do work in 5.40 but the entries appear as an additional section with the correct name and icon at the bottom of the applications tab.  I don't know if they work in all previous versions.  There are many people stuck at 5.26 since later versions of ccleaner don't work without an SSE2 processor.
Link to post
8 hours ago, Tr3bg0D said:
@ Winapp2.ini - Been playing around with the Winapp2ool, coming along very nicely.  Suggestion, why not have the DIFF module output to a TXT file vs CONSOLE?
Look forward to this in the next release when it comes
Had never really considered it I guess :lol: I'm fairly sure this was always an option though.
Link to post
Thanks for the tip. I probably never checked the bottom of the applications tab! :lol:
Link to post
Updates: https://github.com/MoscaDotTo/Winapp2/commit/72d630a8090fbcc6eab0db830bc4d215be94a521
So instead of just linking all the changes I have done to Winapp2, I will just link the changes that only effect what users have posted here. Of course, users should always update their copy of Winapp2 to get all the changes.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to post
I believe the dvdcss folder is generated by applications that use libdvdcss
https://www.wikiwand.com/en/Libdvdcss
Link to post
Revised Entry
[AVG *]
LangSecRef=3024
Detect=HKLM\Software\AVG
Default=False
FileKey1=%CommonAppData%\AVG\Antivirus|*.old
FileKey2=%CommonAppData%\AVG\Antivirus\GrimeFighter2|*.txt
FileKey3=%CommonAppData%\AVG\Antivirus\log|*.log
FileKey4=%CommonAppData%\AVG\Antivirus\opm|*.*|RECURSE
FileKey5=%CommonAppData%\AVG\Antivirus\report|*.*|RECURSE
FileKey6=%CommonAppData%\Avg\Antivirus\SWCUData\Cache|*.*|RECURSE
FileKey7=%CommonAppData%\Avg\Antivirus\SWCUData\icons|*.*|RECURSE
FileKey8=%CommonAppData%\AVG\Persistent Data\Antivirus\Logs|*.*|RECURSE
FileKey9=%LocalAppData%\AVG\log|*.*|RECURSE
FileKey10=%LocalAppData%\AvgSetupLog|*.*|REMOVESELF
FileKey11=%AppData%\AVG\Antivirus\log|*.*|RECURSE
FileKey12=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\log|*.*|RECURSE
FileKey13=%WinDir%\System32\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF
FileKey14=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\log|*.*|RECURSE
FileKey15=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\AvgSetupLog|*.*|REMOVESELF
RegKey1=HKLM\SOFTWARE\AVG\Antivirus\PUB-Detected
RegKey2=HKLM\SOFTWARE\AVG\Antivirus\PUB-Removed
RegKey3=HKLM\SOFTWARE\WOW6432Node\AVG\Antivirus\PUB-Detected
RegKey4=HKLM\SOFTWARE\WOW6432Node\AVG\Antivirus\PUB-Removed
Link to post
Revised Entry
There should be a separate entry for WDI Diagnostic and Startup logs. After removing these logs system should be re-started otherwise some of the programs will not work properly.
Removed:
%WinDir%\System32\WDI\*|snapshot.etl|REMOVESELF
%WinDir%\System32\WDI\LogFiles\StartupInfo|*.*|RECURSE
[Windows Logs *]
LangSecRef=3025
Default=False
FileKey1=%CommonAppData%\Microsoft\Network\Downloader|*.*|RECURSE
FileKey2=%CommonAppData%\Microsoft\Windows Security Health\Logs|*.*|RECURSE
FileKey3=%CommonAppData%\USOShared\Logs|*.*|RECURSE
FileKey4=%LocalAppData%\ConnectedDevicesPlatform|*.log
FileKey5=%LocalAppData%\Diagnostics|*.*|RECURSE
FileKey6=%ProgramFiles%\UNP\Logs|*.*
FileKey7=%SystemDrive%\PerfLogs\System\Diagnostics|*.*|RECURSE
FileKey8=%SystemDrive%\PerfLogs\System\Performance|*.*|RECURSE
FileKey9=%WinDir%\debug\WIA|*.log
FileKey10=%WinDir%\inf|*.log*
FileKey11=%WinDir%\Logs\CBS|*.cab
FileKey12=%WinDir%\Logs\dosvc|*.*|RECURSE
FileKey13=%WinDir%\Logs\NetSetup|*.*|RECURSE
FileKey14=%WinDir%\Logs\SIH|*.*|RECURSE
FileKey15=%WinDir%\Logs\WindowsBackup|*.etl
FileKey16=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html;PostGatherPnPList.log;PreGatherPnPList.log
FileKey17=%WinDir%\Panther\FastCleanup|*.log
FileKey18=%WinDir%\Panther\Rollback|*.txt
FileKey19=%WinDir%\Panther\UnattendGC|diagerr.xml;diagwrn.xml
FileKey20=%WinDir%\repair|setup.log
FileKey21=%WinDir%\security\logs|*.*|RECURSE
FileKey22=%WinDir%\System32\catroot2|*.chk;*.log;*.jrs;*.txt
FileKey23=%WinDir%\System32\LogFiles\HTTPERR|*.log
FileKey24=%WinDir%\System32\LogFiles\Scm|*.*|RECURSE
FileKey25=%WinDir%\System32\LogFiles\Srt|*.*|RECURSE
FileKey26=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml;*.log
RegKey1=HKLM\Software\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey2=HKLM\Software\Microsoft\Tracing
RegKey3=HKLM\Software\Wow6432Node\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey4=HKLM\Software\Wow6432Node\Microsoft\Tracing
New Entry
[WDI Logs *]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\System32\WDI\*|snapshot.etl|REMOVESELF
FileKey2=%WinDir%\System32\WDI\LogFiles\StartupInfo|*.*|RECURSE
Link to post
5 hours ago, SMalik said:
Revised Entry
Removed:
[Windows Logs *]
New Entry
[WDI Logs *]
LangSecRef=3025
Default=False
I do not understand how the users of Winapp2.ini are expected to know that when [ WDI Logs *] cleans these files, they need to restart their computer(s).  If the computer needs to be rebooted, then perhaps Winapp2.ini should not have [WDI logs*] included at all.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti:   Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to post
WDI logs is not the only entry in CCleaner or Winapp2.ini that requires system reboot.
WDI logs holds information about the started processes. Uninstalled programs traces stay there unless these logs are removed. Every known privacy cleaner wipes these traces.
Link to post
Then why make a separate entry?  Just leave them in [Windows Logs *] and state that every time a person runs CCleaner, the system should be rebooted.  I would like to know what entries in CCleaner (unless you are referring the Advanced category) and Winapp2.ini require a system reboot because I am totally unaware of that requirement on certain entries.
Edited by siliconman01
Link to post
Register a new account
Sign in
