siliconman01 0 Posted February 24, 2018 Share Posted February 24, 2018 6 hours ago, SMalik said: Please change [AVG PC TuneUp & Utilities *] to [AVG PC TuneUp *]. I think [AVG PC TuneUp & Utilities Reg Defrag Cleanup *] should be merged into this entry. https://www.avg.com/en-us/avg-pctuneup [AVG PC TuneUp *] LangSecRef=3024 Detect1=HKCU\Software\AVG\AWL\RegistryCleaner Detect2=HKCU\Software\TuneUp Default=False FileKey1=%AppData%\AVG\AWL*\CrashDumps|*.* FileKey2=%AppData%\TuneUp Software\TuneUp Utilities\CrashDumps|*.* FileKey3=%CommonAppData%|NTUSER.DAT_tureg_new.LOG1;NTUSER.DAT_tureg_new.LOG2;NTUSER.DAT_tureg_old FileKey4=%CommonAppData%\TuneUp Software\TuneUp Utilities *|*.log|RECURSE FileKey5=%LocalAppData%\Avg\AWL*\Log|*.log FileKey6=%LocalAppData%\Avg\dumps\fmw1|*.* FileKey7=%LocalAppData%\Avg\Log|*.log;zappapi.log.1|RECURSE FileKey8=%LocalAppData%\Avg\Log\fmw1|*.* FileKey9=%LocalAppData%\AvgSetupLog|*.*|REMOVESELF FileKey10=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_new.LOG*;USRCLASS.DAT_tureg_old;NTUSER.DAT_tureg_old FileKey11=%LocalAppData%\TuneUp Software|*.log|RECURSE FileKey12=%Public%|NTUSER.DAT_tureg_new.LOG1;NTUSER.DAT_tureg_new.LOG2;NTUSER.DAT_tureg_old FileKey13=%SystemDrive%\Boot|BCD_tureg_new.LOG*;BCD_tureg_old FileKey14=%SystemDrive%\Documents and Settings\LocalService*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey15=%SystemDrive%\Documents and Settings\NetworkService*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey16=%SystemDrive%\Users\Default\AppData\Local\Avg\Log\tu16|*.log FileKey17=%UserProfile%|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey18=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey19=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG* FileKey20=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey21=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG* FileKey22=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG*;COMPONENTS_tureg_old;DEFAULT_tureg_new.LOG*;DEFAULT_tureg_old;SAM_tureg_new.LOG*;SAM_tureg_old;SECURITY_tureg_new.LOG*;SECURITY_tureg_old;Software_tureg_new.LOG*;Software_tureg_old;SYSTEM_tureg_new.LOG*;SYSTEM_tureg_old;DRIVERS_tureg_new.LOG*;DRIVERS_tureg_old;Software_tureg_new;SYSTEM_tureg_new FileKey23=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\Log\fmw1|*.log;*.log.lock FileKey24=%WinDir%\System32\config\systemprofile\AppData\Local\Avg\Log\tu16|*.log;*.log.lock FileKey25=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\Log\fmw1|*.log FileKey26=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\Log\setup1|*.log FileKey27=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg\Log\tu16|*.log Link to post Share on other sites
SMalik 0 Posted February 25, 2018 Share Posted February 25, 2018 On 2/23/2018 at 22:49, siliconman01 said: [AVG PC TuneUp *] Isn’t Detect2 enough? Link to post Share on other sites
SMalik 0 Posted February 25, 2018 Share Posted February 25, 2018 On 2/23/2018 at 15:56, siliconman01 said: Then why make a separate entry? Just leave them in [Windows Logs *] and state that every time a person runs CCleaner, the system should be rebooted. I would like to know what entries in CCleaner (unless you are referring the Advanced category) and Winapp2.ini require a system reboot because I am totally unaware of that requirement on certain entries. There is no need to wipe WDI logs each time CCleaner is used. By having a separate entry, we can leave it unchecked and use it when needed. Link to post Share on other sites
siliconman01 0 Posted February 25, 2018 Share Posted February 25, 2018 4 hours ago, SMalik said: Isn’t Detect2 enough? I don't know about earlier versions of PC TuneUp which may need it. Link to post Share on other sites
Winapp2.ini 0 Posted February 25, 2018 Author Share Posted February 25, 2018 5 hours ago, SMalik said: There is no need to wipe WDI logs each time CCleaner is used. By having a separate entry, we can leave it unchecked and use it when needed. I think it's fruitless to separate this entry without also including a warning that informs the user of the restart requirement Link to post Share on other sites
SMalik 0 Posted February 26, 2018 Share Posted February 26, 2018 21 hours ago, Winapp2.ini said: I think it's fruitless to separate this entry without also including a warning that informs the user of the restart requirement It is fine to have a warning, but I suggest to have a separate entry for WDI diagnostic and startup logs.. Link to post Share on other sites
SMalik 0 Posted February 26, 2018 Share Posted February 26, 2018 I think we should remove the [Security Service Token Cache *] entry. It is removing the Windows Insider Program account login info. Link to post Share on other sites
internetaddict47 0 Posted February 26, 2018 Share Posted February 26, 2018 Hello, new user so sorry if been asked before: I switched from Chrome to Chrome Beta, simply copying the old user profile over in appdata. It seems that CCleaner doesn't recognize Chrome Beta. Can I use winapp2.ini to make Chrome Beta "look like" the normal Chrome to CCleaner? (e.g. replacing each entry or something?) Can you add a category especially for Chrome Beta in winapp2.ini? Thanks Link to post Share on other sites
ROCKNROLL 0 Posted February 27, 2018 Share Posted February 27, 2018 Updates: https://github.com/MoscaDotTo/Winapp2/commit/2caea33099d40e46b2b014b28d6f66283029d352 Link to post Share on other sites
siliconman01 0 Posted February 27, 2018 Share Posted February 27, 2018 Modified Entry: [Corel Downloads *] Changed REMOVESELF to RECURSE because of the volatility of the DetectFile which can cause downloaded files between TRIMS to be left on the system. [Corel Downloads *] LangSecRef=3021 DetectFile=%CommonAppData%\Corel\Downloads Default=False FileKey1=%CommonAppData%\Corel\Downloads|*.*|RECURSE Also, did you decide not to change the name of [AVG PC TuneUp & Utilities *] to [AVG PC Tuneup *] or is it just an oversight in the last Update? Link to post Share on other sites
APMichael 0 Posted February 27, 2018 Share Posted February 27, 2018 13 hours ago, internetaddict47 said: Hello, new user so sorry if been asked before: I switched from Chrome to Chrome Beta, simply copying the old user profile over in appdata. It seems that CCleaner doesn't recognize Chrome Beta. Can I use winapp2.ini to make Chrome Beta "look like" the normal Chrome to CCleaner? (e.g. replacing each entry or something?) You can use following methods to add other browsers:https://www.ccleaner.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-clean-user-data-from-non-standard-mozilla-browsers CustomLocation1=CHROME|path_to_user_profilehttps://forum.piriform.com/search/?q=CustomLocation1=CHROME Link to post Share on other sites
SMalik 0 Posted February 28, 2018 Share Posted February 28, 2018 Revised Entry Added: .tmp in FileKey1 [Notifications *] DetectOS=10.0| LangSecRef=3025 Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Notifications|*.db;*.db-shm;*.db-wal;*.tmp FileKey2=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\Backup RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm Link to post Share on other sites
internetaddict47 0 Posted February 28, 2018 Share Posted February 28, 2018 On 2/27/2018 at 12:52, APMichael said: You can use following methods to add other browsers:https://www.ccleaner.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-clean-user-data-from-non-standard-mozilla-browsers CustomLocation1=CHROME|path_to_user_profilehttps://forum.piriform.com/search/?q=CustomLocation1=CHROME Yes, that worked perfectly! Added the line in ccleaner.ini and it made it look like normal Chrome. Thanks! Link to post Share on other sites
ROCKNROLL 0 Posted February 28, 2018 Share Posted February 28, 2018 Updates: https://github.com/MoscaDotTo/Winapp2/commit/8653eebb5b4f779a91445d3d325a82a2d57558e4 On 2/26/2018 at 23:08, siliconman01 said: Also, did you decide not to change the name of [AVG PC TuneUp & Utilities *] to [AVG PC Tuneup *] or is it just an oversight in the last Update? Yes it was an oversight. Should be called that now. Link to post Share on other sites
SMalik 0 Posted March 1, 2018 Share Posted March 1, 2018 I suggest removing the [Adobe Media Cache *] entry. If someone starts a project in Premiere Elements or Premiere Pro, save an unfinished project and if this cache is removed, the project will break. I use this when I complete the project, but a person might not know about it and remove this cache while the project is not yet completed. So I think it is dangerous. CyberLink entries have same media cache removal. I’ll install CyberLink trial programs and will test them by removing the cache files the same way I did with Adobe Media Cache files. Link to post Share on other sites
Winapp2.ini 0 Posted March 1, 2018 Author Share Posted March 1, 2018 5 hours ago, SMalik said: I suggest removing the [Adobe Media Cache *] entry. If someone starts a project in Premiere Elements or Premiere Pro, save an unfinished project and if this cache is removed, the project will break. I use this when I complete the project, but a person might not know about it and remove this cache while the project is not yet completed. So I think it is dangerous. CyberLink entries have same media cache removal. I’ll install CyberLink trial programs and will test them by removing the cache files the same way I did with Adobe Media Cache files. Is the Media Cache worth cleaning at all? Link to post Share on other sites
Winapp2.ini 0 Posted March 1, 2018 Author Share Posted March 1, 2018 Capture software didn't seem to see the "this file has been modified by an external program" prompt in notepad++.... anyway here's a video of winapp2ool fixing up winapp2.ini.. https://streamable.com/1z3wg Link to post Share on other sites
SMalik 0 Posted March 1, 2018 Share Posted March 1, 2018 2 hours ago, Winapp2.ini said: Is the Media Cache worth cleaning at all? No, it is too dangerous like I said in my previous post. There are options in Adobe programs to remove these files manually. Link to post Share on other sites
SMalik 0 Posted March 2, 2018 Share Posted March 2, 2018 Revised Entry Added *.etl in FileKey5 [Photos *] DetectOS=10.0| LangSecRef=3031 Default=False Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState|*.etl;*.sqlite;*.sqlite-shm;*.sqlite-wal;*.xml FileKey6=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\LocalState\PhotosAppTile|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Photos_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedPickerData\Microsoft.Windows.Photos_8wekyb3d8bbwe!App\DefaultSaveFileSingle RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\ManagedByApp RegKey3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Photos_8wekyb3d8bbwe\PersistedStorageItemTable\MostRecentlyUsed ExcludeKey1=FILE|%LocalAppData%\Packages\Microsoft.Windows.Photos_*\AC\INetCache\|container.dat Link to post Share on other sites
SMalik 0 Posted March 2, 2018 Share Posted March 2, 2018 I have tested some other privacy cleaners and they all remove container.dat file from %LocalAppData%\Packages\*\AC\INetCache\ I think we should remove ExcludeKeys for this from all the Windows Store apps. Link to post Share on other sites
APMichael 0 Posted March 2, 2018 Share Posted March 2, 2018 1 hour ago, SMalik said: I have tested some other privacy cleaners and they all remove container.dat file from %LocalAppData%\Packages\*\AC\INetCache\ I think we should remove ExcludeKeys for this from all the Windows Store apps. It seems that just a few apps need the ExcludeKey. But you wanted that we add the ExcludeKey to all Windows Store entries!https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=281&tab=comments#comment-292447 Now you changed your mind again... Those apps need the ExcludeKey: Bing Weather, HuluPlus, Netflix (and maybe other?)https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=205&tab=comments#comment-266270 Link to post Share on other sites
ROCKNROLL 0 Posted March 2, 2018 Share Posted March 2, 2018 Updates: https://github.com/MoscaDotTo/Winapp2/commit/3620997f49fab025c4754f8139bea321861a1271 Link to post Share on other sites
SMalik 0 Posted March 2, 2018 Share Posted March 2, 2018 8 hours ago, APMichael said: It seems that just a few apps need the ExcludeKey. But you wanted that we add the ExcludeKey to all Windows Store entries!https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=281&tab=comments#comment-292447 Now you changed your mind again... Those apps need the ExcludeKey: Bing Weather, HuluPlus, Netflix (and maybe other?)https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=205&tab=comments#comment-266270 You’re wrong, I have not said that in that post. I have not changed my mind on not deleting container.dat from %LocalAppData%\Packages\appname_*\AC\TokenBroker\Cache There is a difference between %LocalAppData%\Packages\appname_*\AC\TokenBroker\Cache and %LocalAppData%\Packages\*\AC\INetCache As I mentioned in my last post, other programs delete these container.dat files from %LocalAppData%\Packages\*\AC\INetCache. I tested that and there is no harm in deleting these files. I did not know much about these files at that time. When I saw that deleting these files from %LocalAppData%\Packages\appname_*\AC\TokenBroker\Cache was causing issues, I thought all those files should be excluded. Link to post Share on other sites
SMalik 0 Posted March 2, 2018 Share Posted March 2, 2018 In Windows 8/10, TokenBroker/Cache is being used to store login infos, so this should be removed from all the Windows 8/10 related entries. There was a similar issue with the [Security Service Token Cache *] entry, where Windows Insider Program account login info were being removed. Link to post Share on other sites
APMichael 0 Posted March 3, 2018 Share Posted March 3, 2018 13 hours ago, SMalik said: You’re wrong, I have not said that in that post. ... Did you read your old post?! On 24.1.2018 at 22:52, SMalik said: A FEW RECOMMENDATIONS: This exclude key should be added into each Windows Store app entry. ExcludeKey1=FILE|%LocalAppData%\Packages\appname_*\AC\INetCache\|container.dat ... You clearly talked about "%LocalAppData%\Packages\*\AC\INetCache"! 13 hours ago, SMalik said: ...I did not know much about these files at that time. When I saw that deleting these files from %LocalAppData%\Packages\appname_*\AC\TokenBroker\Cache was causing issues, I thought all those files should be excluded. IMHO it's not a good idea to recommend something if you don't know why... But let's forget the topic. BTW, I checked the container.dat files on my system. They all are empty and have 0 KB. And they get recreated after deletion. It seems there's no reason for deleting them. Link to post Share on other sites
