CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
12 hours ago, SMalik said:
In Windows 8/10, TokenBroker/Cache is being used to store login infos, so this should be removed from all the Windows 8/10 related entries. There was a similar issue with the [Security Service Token Cache *] entry, where Windows Insider Program account login infos were being removed.
That's done already.
https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=282&tab=comments#comment-292586
Share this post
Link to post
3 hours ago, APMichael said:
Did you read your old post?!
You clearly talked about "%LocalAppData%\Packages\*\AC\INetCache"!
IMHO it's not a good idea to recommend something if you don't know why... But let's forget the topic.
BTW, I checked the container.dat files on my system. They all are empty and have 0 KB. And they get recreated after deletion. It seems there's no reason for deleting them.
Things change over time. I am currently trying Windows 10 Pro Preview build 17112 on one of my systems and lots of things have changed. In computer science/science, there is no final!
Share this post
Link to post
Revised Entry
Added: HKCU\Software\Microsoft\Windows\CurrentVersion\Search\JumplistData
[MS Search *]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edb
FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE
FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE
FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE
FileKey5=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edb
FileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE
FileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE
FileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE
FileKey9=%UserProfile%\Searches|*.search-ms
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery
RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Search\JumplistData
RegKey3=HKLM\Software\Microsoft\Windows Search\VolumeInfoCache
Share this post
Link to post
Removed entries:
[TCP Optimizer Backups *]
LangSecRef=3024
Detect=HKCU\Software\TCP Optimizer
Default=False
FileKey1=%Documents%|*.spg
TCP Optimizer is a portable application that can be installed anywhere. This entry is useless.
[Sticky Notes *]
LangSecRef=3021
Detect=HKLM\Software\Classes\StickyNotes
Default=False
Warning=Selecting this will also delete all sticky notes currently in use.
FileKey1=%AppData%\Microsoft\Sticky Notes|*.snt
FileKey2=%UserProfile%\Searches|Sticky Notes (Windows Sticky Notes).searchconnector-ms
Users have been requesting to have this entry removed, due to it removing sticky notes.
New Entry:
[DOOM *]
Section=Games
Detect=HKCU\Software\Valve\Steam\Apps\379720
Default=False
FileKey1=%LocalAppData%\id Software\DOOM\base\generated\temp|*.*
FileKey2=%UserProfile%\Saved Games\id Software\DOOM\base\generated\temp|*.*
I also revised [The Witcher *] entry here: https://github.com/MoscaDotTo/Winapp2/commit/6f4883ba79bd474ba12bdb56e21f7fdbd232c4d9
Edited by ROCKNROLL
Share this post
Link to post
How do entries like Sticky Notes end up in Winapp2.ini? We should be very careful.
Share this post
Link to post
winapp2ool has been updated, comes with some neat lil tidbits
user facing changes:
new: merge module for removed entries.ini and custom.ini
new: autocorrect feature in WinappDebug
new: download & trim the latest winapp2.ini
new: diff local winapp2.ini against online versions
new: download removed entries.ini
changed: menu layouts
It also now requires .NET Framework 4.6 which I think means Windows XP will no longer be supported. This is because of a TLS change on GitHub's end that .NET Framework 4.5 alone didn't support.
Share this post
Link to post
This applies to Windows 10x64 Pro Insider Build 17115.1, V1803 and the latest winapp2ool (Run as Administrator).  When I attempt to MERGE my custom.ini with winapp2.ini, I get an exception error.  I have attached the Event Viewer errors.  4.7.1 .NET Framework is installed.
EventViewerErrors.zip
Edited by siliconman01
Added .NET Framework version comment
Share this post
Link to post
And !!!  Thanks for the new update and enhancements in winapp2ool.exe.  It's turned into a very powerful and useful tool for users of winapp2.ini.:wub:
Share this post
Link to post
I think I have an idea of the problem here and have a fix ready. Does your custom.ini have a "; version " string? or any ini comments (lines that start with ; ) at all? If not, try adding one and see if it works. I found a spot in the winapp2file constructor where an exception would occur if handed an inifile object with no comments. If that's the problem, the next build will fix it.
Share this post
Link to post
I added a ; Version by Tom comment line and the MERGE worked perfectly.  I MERGEd, TRIMmed, WINAPPDEBUGged, and CCINIDEBUGged all in one round.....everything ran exactly as designed.  So your "idea" as to what can cause the exception is correct.
Share this post
Link to post
Modified entry:  [PDF-XChange Viewer *]
Added FileKey1
LangSecRef=3021
Detect=HKCU\Software\Tracker Software\PDFViewer
Default=False
FileKey1=%CommonAppData%\Tracker Software\TrackerUpdate|TrackerUpdate.exe.del
FileKey2=%LocalAppData%\Tracker Software\LiveUpdate\Updates|*.*
RegKey1=HKCU\Software\Tracker Software\PDFViewer\Documents\LastOpened
RegKey2=HKCU\Software\Tracker Software\PDFViewer\Documents\LatestView\Bars
RegKey3=HKCU\Software\Tracker Software\PDFViewer\Documents\LatestView\Panes
Share this post
Link to post
New entry:  [PDF-XChange Editor *]
LangSecRef=3021
Detect=HKCU\Software\Tracker Software\PDFXEditor
Default=False
FileKey1=%CommonAppData%\Tracker Software\Update|TrackerUpdate.exe.del
Share this post
Link to post
Merge error in Winapp2ool.exe
Attached is a pic that shows that the Merge process in Winapp2ool.exe is clipping off lines at the end of the Merge txt.  This is 100% repeatable on my Windows 10x64 Pro systems.
Share this post
Link to post
Merge has had its underlying behaviors changed since you posted this (namely how it handles sections with duplicate names between ini files) so I'll have to ask that you test with the newest build when its posted (hopefully tonight!) and see if this issue persists!
Share this post
Link to post
winapp2ool.exe has been updated
Something not listed in the changes on the commit (pasted below) is that the application should no longer crash when you hand it an ini with no ; version string in it. :)
I posted about the command line arguments here: https://github.com/MoscaDotTo/Winapp2/issues/200
New: Merge Modes - Merge now has 2 behaviors for dealing with duplicate section names in the two ini files it's merging. The default is Replace & Add, which will replace any sections in the first ini with the section of the same name from the second ini. The other mode will remove any sections with the same names. Enjoy!
New: Preliminary support for command line arguments. I'll post a list of these somewhere that isn't this commit message soon. Added basic support for loading winapp2ool with arguments to automate certain tasks. This feature is not fool proof yet (ie. if you try to break it, it will probably break) and for lacking of testing, not necessarily use proof yet either. For this functionality to work, most of the initialization for the modules was rewritten, so most of my testing so far has been to make sure the modules still work for testing the automation (though if the module works then in theory handing it valid command line args should work just as well)
CCiniDebug was rewritten to a degree. The prompt to save ccleaner.ini has been removed, and it instead automatically saves its changes back to ccleaner.ini.
The prompt to save diff.txt has been removed. It is now available as a menu level toggle instead.
[/spoiler]
Share this post
Link to post
  Reveal hidden contents
[/spoiler]
The new version appears to have corrected the clipping issue.  Have not encountered any issues or failures in the new version thus far (Download, Merge, Trim, cciniDebug, WinappDebug, Exist used/tested).
Share this post
Link to post
for [CutePDF Writer*] in Winapp2.ini, there was an typo in the Detect preventing it from detecting which I have corrected below.  Also I added FileKey1.  CutePDF makes tmp files in that folder and normally deletes them when the PDF has been saved, but occasionally the files can be left behind.
[CutePDF Writer *]
LangSecRef=3023
Detect=HKCU\Software\Acro Software Inc\CPW
Default=False
RegKey1=HKCU\Software\Acro Software Inc\CPW|Filename
RegKey2=HKCU\Software\Acro Software Inc\CPW|Title
FileKey1=%LocalAppData%\CutePDF Writer|*.tmp
Share this post
Link to post
I'd like to suggest an addition to [VLC Media Player *].  There are sometimes leftover zero byte .tmp???? files (???? being some number) here so i've added the removal of ml.xspf.tmp* to FileKey1.
LangSecRef=3023
Detect=HKLM\Software\VideoLAN\VLC
Default=False
FileKey1=%AppData%\vlc|*.cache-3;ml.xspf.tmp*
Share this post
Link to post
I am pleased to announce the first introduction of Winapp3. This file will be for aggressive/dangerous entries that do not make it in Winapp2. Currently, this is a very early beta build of an old Winsys.ini file I recovered that I have modified slightly to include a header, version number, # of entries, and removed all the old comments that are unneeded.
The file is very unpredictable at it's current state since it is quite old, but I will be improving it over time. It is very possible that this file can nuke peoples systems, so use with extreme caution. DO NOT use this file if you do not know what you are doing and you know how to back up and restore your system.
The first step would be to rename Winapp3 to Winapp2 so it runs on CCleaner (if you don't know how to do this step, then you probably shouldn't be using this file at all). All of this is pretty clear in the header, too.
So with all that said, here it is: https://github.com/MoscaDotTo/Winapp2/blob/master/Winapp3/Beta/Winapp3.ini
Ultimately, this is also where cleaning of useless language files will be put, too.
Share this post
Link to post
Register a new account
Sign in
