CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
I also nuke the non-English lang files.
As for a Detect I use only this (on old XP 32-bit):
Detect=HKCU\Software\Malwarebytes
Interesting will look into that Detect.
Thanks Andavari.
EDIT:
Weird, after a clean, clean install of v3.2.2.2029 it does create that detect now. (Windows7 x64)
Will use that from now on.
Share this post
Link to post
OpalCalc saves your last session even if restore previous session is turned off so (new addition):
[OpalCalc*]
LangSecRef=3021
DetectFile1=%AppData%\OpalCalc_prefs
DetectFile2=%ProgramFiles%\OpalCalc
Default=False
FileKey1=%AppData%\OpalCalc_prefs|lastSession.txt
Share this post
Link to post
Remove entries [Malwarebytes Lng*] and [Revo Uninstaller Pro Lng*]
I do not recommend that these two language cleaners be added to the public Winapp2.ini.  There are totally user dependent based on a user's location.  Users of Winapp2.ini could inadvertently remove their user profile language for these two programs.  We have never included language files in the past.  This type of file should be maintained in custom.ini by individual users of CCleaner.
Share this post
Link to post
Never said it should be included in the Winapp2.ini
That why I added the following in the original post
"NOTE: This is not an every day use and should be used at own risk."
"Warning=This will delete all language files excluding the en_GB and en_US language files."
Share this post
Link to post
Understood,  :rolleyes:   But it got placed in the last update Post 6403 above.   :wacko:
Share this post
Link to post
Well find it strange that it did as some people do know that Section=Language Files  (Custom Section) should never be added to the public Winapp2.ini.....
Share this post
Link to post
Is there a separate collection of language file entries for winapp2?
Share this post
Link to post
Maybe we could make a Winapp3 topic and then write all more aggressive entries there, including language entries like these.
Share this post
Link to post
Problem with that is this is a public forum and someone not paying extra close attention could copy those entries and have undesired results, such as with lang removal entries that could wipe out their needed non-English lang for a software.
Share this post
Link to post
No there is not .
I second this.
Yes, I know I posted entries to nuke non-English language files and I am sure that some people out there did not read the warnings and their native language was nuked and did not know what to do.
Share this post
Link to post
Revised Entry
Changed name from [Notification Cache*] to [Push Notifications*]
Removed HKCU\Software\Microsoft\Windows\CurrentVersion\Notifications\Current
DetectOS=6.2|
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm
Share this post
Link to post
Revised Entry
DetectOS=6.2|
LangSecRef=3025
Default=False
Updated: https://github.com/MoscaDotTo/Winapp2/commit/cc69a83ee5126add82d566e2b45939175915b876
Share this post
Link to post
Lynx text based web browser.
New entry to remove temp files:
[Lynx Web Browser*]
LangSecRef=3022
DetectFile1=%ProgramFiles%\Lynx - web browser
Default=False
FileKey1=%LocalAppData%\VirtualStore\Program Files*\Lynx - web browser\tmp|*.*
FileKey2=%ProgramFiles%\Lynx - web browser\tmp|*.*
Share this post
Link to post
Something to check in Winapp2.ini:
There are two entries ( [bus-Simulator 2009*] and [blueSky Interactive*] ) with
=%LocalAppData%\VirtualStore\Program Files\   ...
that probably should be
=%LocalAppData%\VirtualStore\Program Files*\  ...
to cover 64 bit systems unless these are 64 bit apps only.  Perhaps someone with either of these applications could check it.  I don't have either but it looks like an oversight.
Also there are a number of entries containing:
=%LocalAppData%\VirtualStore\ProgramFiles*\
that probably should be:
Perhaps those entries could be checked also.
Share this post
Link to post
Unless you tell me which ones specifically, I don't know what they are. If you could list them, I would be willing to fix them for you.
Committed your other suggestions though: https://github.com/MoscaDotTo/Winapp2/commit/c87510d69375d5367087fe0c4da7814ac06b8dd6
Share this post
Link to post
The only one I can personally confirm (because I have the software) is:
[Maintenance Service*]
LangSecRef=3026
SpecialDetect=DET_MOZILLA
Default=False
FileKey1=%CommonAppData%\Mozilla*\logs|*.*
FileKey2=%LocalAppData%\VirtualStore\ProgramData\Mozilla*\logs|*.*
FileKey3=%LocalAppData%\VirtualStore\ProgramFiles*\Mozilla Maintenance Service\logs|*.log
FileKey4=%ProgramFiles%\Mozilla Maintenance Service\logs|*.log
which should be:
LangSecRef=3026
Default=False
FileKey3=%LocalAppData%\VirtualStore\Program Files*\Mozilla Maintenance Service\logs|*.log
The other 5 entries are:
[10 Years After*]
[1000 Amps*]
[140*]
[1954 Alcatraz*]
[Tribes: Ascend*]
I don't have any of these programs to personally verify if there is an error there.  They are all "Steam" games.  Maybe they are weird that way.  The other Steam games in Winapp2.ini are correct though.
Share this post
Link to post
New Entry:
[Canon Digital Photo Professional 4*]
LangSecRef=3021
Detect1=HKLM\Software\Canon_Inc_IC\DPP4
DetectFile1=%ProgramFiles%\Canon\Digital Photo Professional 4
Default=False
FileKey1=%AppData%\Canon_Inc_IC\DPP4\DppMWare\Cache|*.*|RECURSE
This clears out the thumbnail cache in DPP4.  Eventually there will be entries for pictures no longer present so it makes sense to clean out the cache from time to time and let it regenerate with use.
Share this post
Link to post
New Entry:  [Corel PaintShop Pro 2018 Downloads*]
Note:  I isolated this to the 2018 version because I do not have any way to test whether it applies to previous versions of Corel PaintShop Pro
LangSecRef=3023
Detect=HKCU\Software\Corel\PaintShop Pro\X10
Default=False
FileKey1=%CommonAppData%\Corel\Downloads\|*.*|RECURSE
Share this post
Link to post
Register a new account
Sign in
