CCleaner Community Forums
Winapp2.ini additions
Revised Entry
Added:  *.ipcc
[Apple Device Updates*]
LangSecRef=3023
Detect=HKLM\Software\Apple Computer, Inc.
Default=False
FileKey1=%AppData%\Apple Computer\iTunes|*.ipcc;*.ipsw;*.log|RECURSE
Link to post
Revised Entry
Removed: FileKey2=%Public%\Videos\Pause Buffer|*.*|RECURSE
It removes saved recordings.
[Hauppauge WinTV*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Hauppauge
Default=False
FileKey1=%SystemDrive%|hcwDriverInstall.txt
FileKey2=%Public%\WinTV|Settings-old.xml
FileKey3=%Public%\WinTV\Channel Database|hcwChanDB_5-lastgood.mdb
FileKey4=%Public%\WinTV\Logs\minidump|*.*|RECURSE
Link to post
Modified Entry:  [bitdefender Logs*]
Combines [bitDefender*] and [bitDefender Total Security 2014/15 Logs*] + now includes Bitdefender Internet Security
[Bitdefender Logs*]
LangSecRef=3024
Detect1=HKLM\Software\Softwin\Bitdefender Antivirus
Detect2=HKLM\Software\Bitdefender\Bitdefender Total Security
Detect3=HKLM\Software\Bitdefender\Bitdefender Total Security 2015
Detect4=HKLM\Software\Bitdefender\Bitdefender Internet Security
Default=False
FileKey1=%LocalAppData%\VirtualStore\Program Files*\Softwin\Bitdefender*\Logs|*.*
FileKey2=%ProgramFiles%\Softwin\Bitdefender*\Logs|*.*
FileKey3=%AppData%\Bitdefender\Desktop\profiles\Logs\*|*.xml
FileKey4=%SystemDrive%\|bdlog.txt
Link to post
Welcome! :)
Please Read
A large ini such as this one can cause a slower startup for ccleaner (far more noticeable on older/slower machines) and users may wish to manually remove entries they do not need from the file if they feel this lag time is too great.
Please bear in mind that these entries are NOT endorsed or supported in any way by the developers of CCleaner, and should be considered "beta."
That being said, they can (though we do our best to prevent this) cause issues with various programs or your system as a whole.
Piriform is not responsible for any damages done to your computer, and I also ask that if you encounter an error/problem with an entry here, you post it in this thread to keep winapp2.ini related issues centralized.
Thank you
Link to download Winapp2.ini
GitHub
Direct Download
ADVANCED USAGE AND TRIMMING
To create a custom winapp2.ini file that only holds entries relevant to your computer, Alan_B has kindly created a batch file that will do this for you.
It requires that you save your ccleaner settings to an ini file (this option is found in settings - advanced)
Simply download this file and place it in your CCleaner directory, then double click it and let it do its job. It will backup the old winapp2.ini and create a new one. This file will load much more quickly than the full file, and yield the same results!
Click here for Alan's original help file for Trim.bat
Click here for LaunchCC.bat
How to make your own Winapp2.ini entry! (And if you do, feel free to post it here smile.gif )
Preferred Format:
[Name*]
LangSecRef/Section=
Detect/DetectFile=
Default=False
FileKey/RegKey
*Warning=
*See bottom for information on Warning (it is optional)
[Name*]
This is the name of your entry, usually followed by a * for formatting purposes. This is what will appear in the Applications list within CCleaner.
LangSecRef=
This indicates where on the list of applications within CCleaner your entry will appear. Appropriate LangSecRef numbers are below.
Section is the same idea, however it is user-defined. We currently use Section=Games for example in the main download, however it can be set to anything and a new category with that name will appear in the applications tab.
Detect/DetectFile
These values are what CCleaner looks for to check if it should return true on an entry. Eg. DetectFile=%WinDir%\ will return true because this points to your windows directory.
Environment Variables (below) are vastly preferred over direct paths (such as C:\*)
Detect= points to a registry key
DetectFile= points to a file or folder.
Detect Paths:
DetectFile paths
Default=False
It is preferred that Default be set to false because Default is the default setting of the tickbox (False=Unticked)
This is to ensure no one has any boxes ticked that they didn't want ticked.
FileKey1/RegKey1=
The FileKeys and RegKeys are paths of items you'd like to delete. When pointing to these, you must list the path (using the environment variables above) then use the pipe symbol | and have the filenames/registry keys after
Warning=
If there is something the end user should know about an entry, such as it resetting play counts in a media player, high scores on a game, add a warning= followed by the message.
Eg: Warning=This will delete all of your high scores.
This is considered a courtesy to the end user in helping making them aware of what they're deleting.
Remember, when posting, please test your entries before you post them, so you can be sure they don't harm the workings of the programs. Also try to post which operation system(s) you tested it with! smile.gif
Hi, I want suggest for add to the registry clean the next keys
HKEY_CURRENT_USER\Software\ACD Systems\ACD Photo Editor\31\Recent File List - where ACD Systems store the recently open files.
HKEY_CURRENT_USER\Software\Code Industry\Master PDF Editor\resent_files_history\ - where Master PDF Editor store the recently open files
HKEY_CURRENT_USER\Software\Diamond Cut Productions\DC Forensics10\Recent File List - where DCForensics10 store the recently open files
Delete Internet Download Manager incomplete or corrupted data
C:\Users\%USERNAME%\AppData\Roaming\IDM\DwnlData
Delete Internet Download Manager complete downloads
HKEY_CURRENT_USER\Software\DownloadManager\
Value: LocalFileName
Value: LogFileName
Value: LocalPath
RPGVX Last Project
HKEY_CURRENT_USER\Software\Enterbrain\RPGVX
Value: LastProjectName
RPGVXAce Last Project
HKEY_CURRENT_USER\Software\Enterbrain\RPGVXAce
GifMovieGear
HKEY_CURRENT_USER\Software\gamani\GIFMovieGear\2.0
Value: File1-File99
JPEGSnoop
HKEY_CURRENT_USER\Software\ImpulseAdventure\JPEGsnoop\Recent File List
All the files who used audio device (I found 332 useless keys)
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore\
Windows 10 News App Cache
C:\Users\%USERNAME%\AppData\Local\Microsoft\Windows\Notifications\wpnidm
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm\
Link to post
Revised Entry
Removed Warning as it is useless because removing these files does not effect future updates.
Replaced *.7z with *.* because the rest of the files there are also from the same installer build/version.
[installer*]
LangSecRef=3029
SpecialDetect=DET_CHROME
Detect1=HKCU\Software\Vivaldi
Default=False
FileKey1=%LocalAppData%\Google\Chrome*\Application\*\Installer|*.*|RECURSE
FileKey2=%LocalAppData%\Google\Update\*\*\Installer|*.*|RECURSE
FileKey3=%ProgramFiles%\|GUT*tmp
FileKey4=%ProgramFiles%\Google\Chrome*\Application\*\Installer|*.*|RECURSE
FileKey5=%ProgramFiles%\Google\Update\*\*\Installer|*.*|RECURSE
FileKey6=%LocalAppData%\Vivaldi\Application\*\Installer|*.*|RECURSE
Link to post
Modified entry:  [HitmanPro*]
Changed name from [HitManPro*] to [HitmanPro*]
Added Detect5
[HitmanPro*]
LangSecRef=3024
Detect1=HKCU\Software\HitMan Pro
Detect2=HKCU\Software\HitMan Pro 2
Detect3=HKCU\Software\HitMan Pro 3
Detect4=HKLM\SOFTWARE\Wow6432Node\HitmanPro
Detect5=HKLM\SOFTWARE\HitmanPro
Default=False
FileKey1=%CommonAppData%\HitmanPro\Logs|*.*
FileKey2=%ProgramFiles%\Hitman Pro*\downloads|*.*
FileKey3=%ProgramFiles%\Hitman Pro*\logs|*.htm
FileKey4=%ProgramFiles%\Hitman Pro*\updates|*.*
FileKey5=%LocalAppData%\VirtualStore\Program Files*\Hitman Pro*\downloads|*.*
FileKey6=%LocalAppData%\VirtualStore\Program Files*\Hitman Pro*\logs|*.htm
FileKey7=%LocalAppData%\VirtualStore\Program Files*\Hitman Pro*\updates|*.*
FileKey8=%LocalAppData%\VirtualStore\ProgramData\HitmanPro\Logs|*.*
Link to post
Modified entries:  [Corel Paintshop Photo Pro*] and [Corel Paintshop Pro AutoPreserve*]
-  Changed name [Corel Paintshop Photo Pro*]  to [Corel Paintshop Pro*]
-  Added Detect6 in [Corel Paintshop Pro*]
-  Incorporated wildcard (*) in [Corel Paintshop Pro*]
-  Added RegKey4 in [Corel Paintshop Pro*]
-  Added Detect 3 in [Corel Paintshop Pro AutoPreserve*]
[Corel PaintShop Pro*]
LangSecRef=3023
Detect1=HKCU\Software\Corel\PhotoDownloader\2
Detect2=HKCU\Software\Corel\PaintShop Pro\X4
Detect3=HKCU\Software\Corel\PaintShop Pro\X5
Detect4=HKCU\Software\Corel\PaintShop Pro\X6
Detect5=HKCU\Software\Corel\PaintShop Pro\X7
Detect6=HKCU\Software\Corel\PaintShop Pro\X10
Default=False
FileKey1=%AppData%\Corel\PaintShop Photo Pro\13\Cache|*.*|RECURSE
FileKey2=%LocalAppData%\Corel|*.db;*.PspCache
FileKey3=%LocalAppData%\Corel\Thumbs|*.*|RECURSE
FileKey4=%LocalAppData%\Corel PaintShop Pro\*\Database|*.db
FileKey5=%LocalAppData%\Corel PaintShop Pro\*\Thumbs|*.*|RECURSE
FileKey6=%LocalAppData%\Corel PaintShop Pro\*\Cache|*.*
RegKey1=HKCU\Software\Corel\PaintShop Pro\X7\CoreMemoryManager\0
RegKey2=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DefaultDownloadFolder
RegKey3=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DownloadFolder
RegKey4=HKCU\Software\Corel\PaintShop Pro\X10\CoreMemoryManager\0
[Corel PaintShop Pro AutoPreserve*]
LangSecRef=3023
Detect1=HKCU\Software\Corel\PaintShop Pro\X6
Detect2=HKCU\Software\Corel\PaintShop Pro\X7
Detect3=HKCU\Software\Corel\PaintShop Pro\X10
Default=False
FileKey1=%Pictures%\Corel Auto-Preserve|*.*
Link to post
Amaya web browser and html editor:
[Amaya*]
LangSecRef=3021
DetectFile=%UserProfile%\amaya
Default=False
FileKey1=%UserProfile%\amaya\libwww-cache|*.*
FileKey2=%UserProfile%\amaya|list_url_utf8.dat
FileKey3=%UserProfile%\amaya\0|*.*|REMOVESELF
FileKey4=%UserProfile%\amaya\1|*.*|REMOVESELF
FileKey5=%UserProfile%\amaya\2|*.*|REMOVESELF
FileKey6=%UserProfile%\amaya\3|*.*|REMOVESELF
FileKey7=%UserProfile%\amaya\4|*.*|REMOVESELF
FileKey8=%UserProfile%\amaya\5|*.*|REMOVESELF
FileKey9=%UserProfile%\amaya\6|*.*|REMOVESELF
FileKey10=%UserProfile%\amaya\7|*.*|REMOVESELF
FileKey11=%UserProfile%\amaya\8|*.*|REMOVESELF
FileKey12=%UserProfile%\amaya\9|*.*|REMOVESELF
FileKey13=%UserProfile%\amaya\10|*.*|REMOVESELF
FileKey14=%UserProfile%\amaya\11|*.*|REMOVESELF
FileKey15=%UserProfile%\amaya\12|*.*|REMOVESELF
FileKey16=%UserProfile%\amaya\13|*.*|REMOVESELF
FileKey17=%UserProfile%\amaya\14|*.*|REMOVESELF
FileKey18=%UserProfile%\amaya\15|*.*|REMOVESELF
FileKey19=%UserProfile%\amaya\16|*.*|REMOVESELF
FileKey20=%UserProfile%\amaya\17|*.*|REMOVESELF
FileKey21=%UserProfile%\amaya\18|*.*|REMOVESELF
FileKey22=%UserProfile%\amaya\19|*.*|REMOVESELF
Cleans up the cache and leftovers.
Link to post
Canon Zoom Browser exists but doesn't recurse and deletes its detector.  I'd like to suggest changing it to:
[Canon Zoom Browser*]
LangSecRef=3021
Detect=HKCU\Software\Canon\ZoomBrowser Ex
DetectFile1=%Pictures%\ZbThumbnail.info
DetectFile2=%AppData%\ZoomBrowser EX
Default=False
FileKey1=%Pictures%|ZbThumbnail.info|RECURSE
so that it removes all of the files even if the application is no longer present.
Link to post
CCleaner already natively cleans Seamonkey browser however most of the additional Winapp2 entries for Firefox also apply to Seamonkey so I've gathered the Firefox together as a single entry with the path renamed for Seamonkey.  There may be a better way to handle it but this is a convenient way to finish cleaning Seamonkey.
[SeaMonkey More*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\SeaMonkey\
Default=False
FileKey1=%AppData%\Mozilla\SeaMonkey\Profiles\*\adblock*|patterns-backup*.ini;*.tmp
FileKey2=%AppData%\Mozilla\SeaMonkey\Profiles\*\datareporting\archived|*.jsonlz4|REMOVESELF
FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*\bookmarkbackups|*.json*
FileKey4=%AppData%\Mozilla\SeaMonkey\Profiles\*\chatzilla|inputHistory.txt
FileKey5=%AppData%\Mozilla\SeaMonkey\Profiles|*.corrupt|RECURSE
FileKey6=%AppData%\Mozilla\SeaMonkey\Crash Reports|*.*|REMOVESELF
FileKey7=%AppData%\Mozilla\SeaMonkey\Profiles\*\storage|*.*|REMOVESELF
ExcludeKey1=%AppData%\Mozilla\SeaMonkey\Profiles\*\storage\default\moz-extension*
FileKey8=%AppData%\Mozilla\SeaMonkey\Profiles\*|FlashGot.log;FlashGot.log.bak*
FileKey9=%AppData%\Mozilla\SeaMonkey\Profiles\*|lazarus.sqlite;lazarus-backup.sqlite
FileKey10=%AppData%\Mozilla\SeaMonkey\Profiles\*|*.lock
FileKey11=%AppData%\Mozilla\SeaMonkey\Profiles\*\minidumps|*.*
FileKey12=%AppData%\Mozilla\SeaMonkey\Profiles\*|seer.sqlite;netpredictions.sqlite
FileKey13=%AppData%\Mozilla\SeaMonkey\Profiles\*|sessionstore.bak*
FileKey14=%AppData%\Mozilla\SeaMonkey\Profiles\*\sessions\Deleted Sessions|*.session
FileKey15=%AppData%\Mozilla\SeaMonkey\Profiles\*\weave\logs|*.*
FileKey16=%LocalAppData%\Mozilla\SeaMonkey\Profiles\*\shortcutCache|*.*
FileKey17=%LocalAppData%\Mozilla\SeaMonkey\Profiles\*\startupCache|*.*
FileKey18=%AppData%\Mozilla\SeaMonkey\Profiles\*|Telemetry*.*
FileKey19=%AppData%\Mozilla\SeaMonkey\Profiles\*\saved-telemetry-pings|*.*
FileKey20=%AppData%\Mozilla\SeaMonkey\Profiles|TestPilotErrorLog.*|RECURSE
FileKey21=%LocalAppData%\Mozilla\SeaMonkey\*\updates|*.*|RECURSE
FileKey22=%LocalAppData%\Mozilla\SeaMonkey\Profiles\*|urlclassifier3.sqlite
FileKey23=%AppData%\Mozilla\SeaMonkey\Profiles\*|webappsstore.sqlite
Link to post
[Amaya*]
LangSecRef=3021
Default=False
3 - 22 You can just use a wildcard for those and make only 1 FileKey.
Link to post
Thank you. This would be better and doesn't remove other folders that should be kept:
[Amaya Browser*]
LangSecRef=3021
Default=False
FileKey3=%UserProfile%\amaya\??|*.*|REMOVESELF
Link to post
New entry:  [Corel AfterShot Pro*]
LangSecRef=3023
Detect1=HKCU\Software\Corel\AfterShot Pro V3
Default=False
FileKey1=%LocalAppData%\Corel\AfterShot Pro *\Cache|*.*|RECURSE
FileKey2=%LocalAppData%\Corel\AfterShot Pro *|*.log
Link to post
Modified entry:  [Nikon ViewNX 2 Pic Viewer Cache*]
Added FileKey2-3-4-5
LangSecRef=3023
Detect=HKLM\Software\Nikon\MCA2\ViewNX 2
Default=False
FileKey1=%LocalAppData%\Nikon\ViewNX 2\Cache|*.*
FileKey2=%LocalAppData%\Nikon\mPT\*\CacheData\Original\|*.*
FileKey3=%LocalAppData%\Nikon\mPT\*\CacheData\Others\|*.*
FileKey4=%LocalAppData%\Nikon\mPT\*\CacheData\Screen\|*.*
FileKey5=%LocalAppData%\Nikon\mPT\*\CacheData\Thumbnail\|*.*
Link to post
New entry (somehow this one was left out):
[Pale Moon - Startup Cache*]
LangSecRef=3026
Detect=HKLM\Software\Mozilla\Pale Moon
DetectFile=%ProgramFiles%\Pale Moon\palemoon.exe
Default=False
FileKey1=%LocalAppData%\Moonchild Productions\Pale Moon\Profiles\*\startupCache|startupCache.8.little
Link to post
I don't know if this is too obscure, but PSoC Designer makes a new debug log each time and soon becomes a lot of them:
[PSoC Designer 5.4 Debug Logs*]
LangSecRef=3021
DetectFile=%AppData%\Cypress_Semiconductor\PSoC_Designer_54
Default=False
FileKey1=%AppData%\Cypress_Semiconductor\PSoC_Designer_54|debug.log
FileKey2=%AppData%\Cypress_Semiconductor\PSoC_Designer_54|debug.log.*
Link to post
New entry for DxO Optics Pro, FilmPack, and Viewpoint to clean up thumbnail caches and logs:
[DxO Optics Pro Cleanup*]
LangSecRef=3021
DetectFile1=%LocalAppData%\DxO_Labs\DataCache
DetectFile2=%LocalAppData%\DxO_Labs\DxO Optics Pro 8\Cache
DetectFile3=%LocalAppData%\DxO_Labs\DxO Optics Pro 9\Cache
DetectFile4=%LocalAppData%\DxO_Labs\DxO OpticsPro 10\Cache
DetectFile5=%LocalAppData%\DxO_Labs\DxO OpticsPro 11\Cache
Default=False
FileKey1=%LocalAppData%\DxO_Labs\DataCache|*.*|RECURSE
FileKey2=%LocalAppData%\DxO_Labs\Logs|*.*
FileKey3=%LocalAppData%\DxO_Labs\DxO Optics Pro 8\Cache|*.*|RECURSE
FileKey4=%LocalAppData%\DxO_Labs\DxO Optics Pro 9\Cache|*.*|RECURSE
FileKey5=%LocalAppData%\DxO_Labs\DxO OpticsPro 10\Cache|*.*|RECURSE
FileKey6=%LocalAppData%\DxO_Labs\DxO OpticsPro 11\Cache|*.*|RECURSE
FileKey7=%LocalAppData%\DxO_Labs\DxO FilmPack 5\CrashReports|*.*
FileKey8=%LocalAppData%\DxO_Labs\DxO FilmPack 5\DiskCache|*.*
FileKey9=%LocalAppData%\DxO_Labs\DxO FilmPack 5\Logs|*.*
FileKey10=%LocalAppData%\DxO_Labs\DxO ViewPoint 3\Logs|*.*
FileKey11=%Documents%\DxO FilmPack 3\log|*.*
FileKey12=%Documents%\DxO FilmPack 4\log|*.*
FileKey13=%Documents%\DxO ViewPoint\log|*.*
FileKey14=%Documents%\DxO ViewPoint 2\log|*.*
FileKey15=%Documents%\DxO Optics Pro v7 crashs|*.*
FileKey16=%Documents%\DxO Optics Pro v7 logs|*.*
FileKey17=%Documents%\DxO Optics Pro v8 crashs|*.*
FileKey18=%Documents%\DxO Optics Pro v8 logs|*.*
FileKey19=%Documents%\DxO Optics Pro v9 crashs|*.*
FileKey20=%Documents%\DxO Optics Pro v9 logs|*.*
FileKey21=%Documents%\DxO OpticsPro 10 crashs|*.*
FileKey22=%Documents%\DxO OpticsPro 10 logs|*.*
FileKey23=%Documents%\DxO OpticsPro 11 crashs|*.*
FileKey24=%Documents%\DxO OpticsPro 11 logs|*.*
Link to post
CCleaner has Photoshop CS2 natively but doesn't clean up CS2 bridge.  The ".bridgesort" files are files bridge creates that hold the file sort order in folders viewed in Bridge.
[Adobe Photoshop CS2 More*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Photoshop\9.0
DetectFile1=%AppData%\Adobe\CameraRaw\Cache
DetectFile2=%AppData%\Adobe\Bridge\Cache
Default=False
FileKey1=%AppData%\Adobe\CameraRaw\Cache|*.*|RECURSE
FileKey2=%AppData%\Adobe\Bridge\Cache\Thumbnails|*.*|RECURSE
FileKey3=%Pictures%|.BridgeSort|RECURSE
Link to post
Register a new account
Sign in
