akm Posted June 26, 2019 Share Posted June 26, 2019 Just tried download via normal CCleaner link and times out at https://filehippo.com/download_ccleaner/?utm_source=ccleaner&utm_medium=revenue&utm_campaign=ccleaner_filehippo. And, thanks again for your help ! akm (W10,Firefox,Privatefirewall,Avast,Malwarebytes) Link to comment Share on other sites More sharing options...
akm Posted June 26, 2019 Share Posted June 26, 2019 Just tried download update to 559 via normal CCleaner link and it times out at https://filehippo.com/download_ccleaner/?utm_source=ccleaner&utm_medium=revenue&utm_campaign=ccleaner_filehippo. Looks like a big ad. Went to https://www.ccleaner.com/ccleaner/builds and it worked. And, thanks again for your help ! akm (W10,Firefox,Privatefirewall,Avast,Malwarebytes) Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 26, 2019 Moderators Share Posted June 26, 2019 1 hour ago, akm said: Looks like a big ad. While it is a big ad, there's a big button labeled download free version ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
LawrenM Posted October 5, 2019 Share Posted October 5, 2019 Hello, I have tried to do the update to the 5.48, I tried the direct download link for 5.62 and I continue to get the following screenshot, there was two different ones, have tried ignore, retry..It acts like it is updating but I am the same 5.44 version I was before. I have Malwarebytes on my system, is that effecting it? Can you provide any other help? Thank you Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 5, 2019 Moderators Share Posted October 5, 2019 1 hour ago, LawrenM said: Hello, I have tried to do the update to the 5.48, I tried the direct download link for 5.62 and I continue to get the following screenshot, there was two different ones, have tried ignore, retry..It acts like it is updating but I am the same 5.44 version I was before. I have Malwarebytes on my system, is that effecting it? Can you provide any other help? Thank you See here https://forum.piriform.com/topic/5739-solution-when-ccleaner-wont-install-or-download-windows/ ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
LawrenM Posted October 7, 2019 Share Posted October 7, 2019 Nergal, Thank you very much for the reply. Will read over this. Link to comment Share on other sites More sharing options...
MargaretLBA Posted October 31, 2019 Share Posted October 31, 2019 I have been unable to update my free CCleaner for some weeks. I get the message "error opening file for writing". I have tried the obvious such as uninstalling and reinstalling, but nothing fixes it. I run Windows 10 on a laptop with the latest upgrade Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 31, 2019 Moderators Share Posted October 31, 2019 1 hour ago, MargaretLBA said: I have been unable to update my free CCleaner for some weeks. I get the message "error opening file for writing". I have tried the obvious such as uninstalling and reinstalling, but nothing fixes it. I run Windows 10 on a laptop with the latest upgrade See the link I put in two replies up ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
MargaretLBA Posted November 1, 2019 Share Posted November 1, 2019 10 hours ago, Nergal said: See the link I put in two replies up Yes, I read that before I posted and tried those. So far nothing has worked. But I am also having issues with my scanner. It seems to have been from the latest Windows upgrade. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 1, 2019 Moderators Share Posted November 1, 2019 1 hour ago, MargaretLBA said: Yes, I read that before I posted and tried those. So far nothing has worked. Try the CCleaner Slim installer if you haven't tried it yet, some antivirus' don't like the bundled extras that are in the Standard installer: https://www.ccleaner.com/ccleaner/builds Link to comment Share on other sites More sharing options...
Moderators nukecad Posted November 1, 2019 Moderators Share Posted November 1, 2019 8 hours ago, MargaretLBA said: Yes, I read that before I posted and tried those. So far nothing has worked. But I am also having issues with my scanner. It seems to have been from the latest Windows upgrade. Check that in Settings>Apps & features you have 'Choose where to get apps' set to 'Anywhere'. There was a glitch in one of the recent Windows 10 updates that, for some people not all, had set this to 'The Microsoft Store only' - which meant they couldn't download/install anything that didn't come from the MS store. Setting it back to 'Anywhere cures that problem (If it is what is affecting you). *** Out of Beer Error ->->-> Recovering Memory *** Keep getting logged out of websites? See this link: https://community.ccleaner.com/topic/67601-saved-passwords/#comment-349999 Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link: https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
KVS Posted April 4, 2020 Share Posted April 4, 2020 Sure glad I didn't pay for pro. Tried the 14 day trial but half way through it calls for IE or enable Java and will not install. Does the world live and die by IE? It is not even on my Win 7 pro. Have not used IE since about when Fire Fox came out, 20 years maybe. I only use Fire Fox and Java Script is enabled. Ken Link to comment Share on other sites More sharing options...
Moderators nukecad Posted April 7, 2020 Moderators Share Posted April 7, 2020 Ken, You've posted on a year old thread but not to worry. I believe that your problem is that you are still using Windows 7 and the Standard CCleaner installer needs later technology. CCleaner still works fully on Win7 but you will need to install the latest CCleaner on Windows 7 by using the 'Slim' installer which doesn't contain the advertising screen(s) that Win7 doesn't like. You can find the Slim installer here, third one down:https://www.piriform.com/ccleaner/builds *** Out of Beer Error ->->-> Recovering Memory *** Keep getting logged out of websites? See this link: https://community.ccleaner.com/topic/67601-saved-passwords/#comment-349999 Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link: https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
jopa66 Posted December 19, 2020 Share Posted December 19, 2020 On 07/04/2020 at 06:31, nukecad said: You've posted on a year old thread but not to worry. I believe that your problem is that you are still using Windows 7 and the Standard CCleaner installer needs later technology. CCleaner still works fully on Win7 but you will need to install the latest CCleaner on Windows 7 by using the 'Slim' installer which doesn't contain the advertising screen(s) that Win7 doesn't like. Sheesh! I didn't have this problem till last Tuesday. Just lucky I guess. Link to comment Share on other sites More sharing options...
Admin Dave CCleaner Posted December 19, 2020 Admin Share Posted December 19, 2020 13 hours ago, jopa66 said: Sheesh! I didn't have this problem till last Tuesday. Just lucky I guess. @jopa66: you too have posted on an old thread about an old version of CCleaner . If you're having some problems with the latest version (~30 releases later) then it's probably best to start a new thread (or join a more recent one) with specifics to see if someone can help you out. Piriform Homepage - [CCleaner - CCleaner Mac - CCleaner Android - CCleaner Browser - Recuva - Speccy - Kamo] - Product Support Looking for your licence key, expiry date or download link? Check here first: https://www.ccleaner.com/support/license-lookup To find out how we protect your privacy - read CCleaner's Data Factsheet. What's new? Check the latest CCleaner for Windows release notes. Link to comment Share on other sites More sharing options...
jopa66 Posted December 19, 2020 Share Posted December 19, 2020 Yeah, sorry Dave. Have already dealt with this issue with nukecad's help on another thread. Was just surprised that I've not had this issue before. Link to comment Share on other sites More sharing options...
okjohn Posted July 21, 2021 Share Posted July 21, 2021 Same here. My present version won't run - and when I tried to download the latest version the installer stalls 2 minutes in and doesn't complete the install. Something is blocking CCleaner from either running OR installing. I use MalwareBites on Windows 10. Link to comment Share on other sites More sharing options...
Admin Dave CCleaner Posted July 22, 2021 Admin Share Posted July 22, 2021 8 hours ago, okjohn said: when I tried to download the latest version This is a thread about CCleaner 5.48 and FileHippo - so we might need a little more information from you: What is your present version number? Is it a free, paid or trial copy? When did it stop working for you? Will your existing installation of CCleaner run if you go to C:\Program Files\CCleaner, right-click on CCleaner64.exe and select "Run as Administrator"? Where are you trying to download the latest version (5.83 at the time of writing) from? Can you screenshot where the installer fails or any messages that are received when it does? Piriform Homepage - [CCleaner - CCleaner Mac - CCleaner Android - CCleaner Browser - Recuva - Speccy - Kamo] - Product Support Looking for your licence key, expiry date or download link? Check here first: https://www.ccleaner.com/support/license-lookup To find out how we protect your privacy - read CCleaner's Data Factsheet. What's new? Check the latest CCleaner for Windows release notes. Link to comment Share on other sites More sharing options...
