Alan_B Posted October 20, 2011 Share Posted October 20, 2011 Testing now @echo off SET SOURCE=E:\Images\v5\2FE769AFA97E71E8-09-09.inc_06.mrimg echo %TIME% # FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T1=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100 ) COPY %SOURCE% E:\Test\ echo %TIME% ## FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T2=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100-%T1% ) echo Copying %SOURCE% took %T2%0. mSec pause @echo off SET SOURCE=E:\Images\v5\2FE769AFA97E71E8-09-09.inc_06.mrimg echo %TIME% # FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T1=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100 ) COPY %SOURCE% E:\Test\ echo %TIME% ## FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T2=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100-%T1% ) echo Copying %SOURCE% took %T2%0. mSec pause Code box still broken Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted October 20, 2011 Moderators Share Posted October 20, 2011 Okay I will let MrH know. Thanks for testing. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted October 20, 2011 Moderators Share Posted October 20, 2011 Codebox has been broken like that for awhile if I'm remembering correctly, and I think it was even before all the forum upgrading. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 20, 2011 Moderators Share Posted October 20, 2011 @echo off SET SOURCE=E:\Images\v5\2FE769AFA97E71E8-09-09.inc_06.mrimg echo %TIME% # FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T1=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100 ) COPY %SOURCE% E:\Test\ echo %TIME% ## FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T2=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100-%T1% ) echo Copying %SOURCE% took %T2%0. mSec pause I'm confused what exactly is broken? OK I see it. If the code bbc button is pressed and the code is pasted extra endlines are being removed. If you type [code] [/code] and paste it in the middle (old school method of bbc before fancy "enter information here" boxes endlines remain entact. @echo off SET SOURCE=E:\Images\v5\2FE769AFA97E71E8-09-09.inc_06.mrimg echo %TIME% # FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T1=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100 ) COPY %SOURCE% E:\Test\ echo %TIME% ## FOR /F "tokens=1-4 delims=:." %%d in ("%TIME%") do ( SET /A T2=%%d*360000+1%%e*6000+1%%f*100+1%%g-610100-%T1% ) echo Copying %SOURCE% took %T2%0. mSec pause Interesting an extra endline at the end (so text > two blank lines > text) will only strip one causing the the code to be as the poster intends (text>blank line>text) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
kroozer Posted October 29, 2011 Share Posted October 29, 2011 Code box still broken Also, code box scroll bar is omitted. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted October 29, 2011 Share Posted October 29, 2011 I did notice that spellchecking in the quick reply box (on the bottom) has been restored winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted October 29, 2011 Author Share Posted October 29, 2011 Getting better every week. This does indeed feel like Progress. Which reminds me of the extreme relevance in today's Dilbert to the woes of this web-site http://dilbert.com/strips/2011-10-29/ Link to comment Share on other sites More sharing options...
