ishan_rulz Posted June 3, 2011 Share Posted June 3, 2011 http://gyazo.com/f4379b90c4fcf57bf9bb307f46d32ec8.png The first tab is called "Cleaner" and the next one "Registry" It makes sense to Rename "Cleaner" to "System" for obvious reasons. Simplicity is hard. Link to comment Share on other sites More sharing options...
Alan_B Posted June 3, 2011 Share Posted June 3, 2011 In what way are Firefox caches part of the System ? Link to comment Share on other sites More sharing options...
ishan_rulz Posted June 3, 2011 Author Share Posted June 3, 2011 In what way are Firefox caches part of the System ? I didn't mean "system" specifically, I meant it in a more general sense. For example, "Registry" is "Registry Cleaner", so "Cleaner" should have a specific term as well. Simplicity is hard. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted June 3, 2011 Moderators Share Posted June 3, 2011 Cannot see the point really ishan. Folk know what 'cleaner' means and are used to it. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
ishan_rulz Posted June 3, 2011 Author Share Posted June 3, 2011 Cannot see the point really ishan. Folk know what 'cleaner' means and are used to it. True. Simplicity is hard. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 3, 2011 Share Posted June 3, 2011 I could see 'Disc' but not 'System' in terms of 'Disc Cleaner' and 'Registry Cleaner' winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 4, 2011 Moderators Share Posted June 4, 2011 I could see 'Disc' but not 'System' in terms of 'Disc Cleaner' and 'Registry Cleaner' CCleaner doesn't clean "Discs" though, it cleans "Disks". Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 4, 2011 Share Posted June 4, 2011 Potato/ Potassium winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 6, 2011 Moderators Share Posted June 6, 2011 Potato/ Potassium ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
