SMalik Posted March 22, 2012 Share Posted March 22, 2012 Great project! but, there's a problem with the "FastStone Capture*" entry: It somehow deletes your software registration, I had to register again. If there is no fix for the moment, maybe you should atleast add: Warning=This may deleted your software Registration! -joedf You're right. I have modified the entry. It should work fine now. [FastStone Capture*] LangSecRef=3024 DetectFile=%ProgramFiles%\FastStone Capture\FSCapture.exe Default=False FileKey1=%LocalAppData%\FastStone\FSC\EditWith|*.* FileKey2=%AppData%\FastStone\FSC|*.bak Removed the lines listed below. I have tried this program on 2 diff. systems and it doesn't create any reg paths. %LocalAppData%\FastStone\FSC|*.db %AppData%\FastStone\FSC|*.db HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId HKCU\Software\FastStone\APP.FSRecorder\Global|_LastClipPlayed HKCU\Software\FastStone\APP.FSRecorder\Global|_LastRecordingFileName Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 22, 2012 Author Share Posted March 22, 2012 Oh really? That sounds dangerous. I'll probably drop that file key if that's the case, don't want people having to constantly register for it :c winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted March 23, 2012 Share Posted March 23, 2012 Oh really? That sounds dangerous. I'll probably drop that file key if that's the case, don't want people having to constantly register for it :c Yes, it was deleting the registration. I have edited the entry again. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 23, 2012 Author Share Posted March 23, 2012 I think older versions created the registry path when you used the screen recorder winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted March 24, 2012 Share Posted March 24, 2012 MODIFIED ENTRY [Auslogics BoostSpeed*] LangSecRef=3024 DetectFile=%ProgramFiles%\Auslogics\Auslogics BoostSpeed\boostspeed.exe Default=False FileKey1=%AppData%\Auslogics|*.htm|RECURSE FileKey2=%AppData%\Auslogics|*.logl|RECURSE FileKey3=%AppData%\Auslogics|*.rsc|RECURSE FileKey4=%AppData%\Auslogics|*.xml|RECURSE Link to comment Share on other sites More sharing options...
Kojak Posted March 24, 2012 Share Posted March 24, 2012 Here is a couple of new ones, tested: Scan logs for Kaspersky's TDSSKiller from http://support.kaspersky.com/faq/?qid=208283363 [Kaspersky TDSSKiller Logs*] LangSecRef=3024 Default=False FileKey1=%SystemDrive%|TDSSKiller*.txt Latest version 3 of Far Manager from farmanager.com, stores the logs in a new location: [FAR Manager 3*] LangSecRef=3021 DetectFile=%LocalAppData%\Far Manager\Profile Warning=Also clears the plugin name cache Default=False FileKey1=%LocalAppData%\Far Manager\Profile|*.*|RECURSE Temporary files for the Gadugadu IM tool, http://en.wikipedia.org/wiki/Gadu-Gadu (the program doesn't clean its temp files after itself, but they can't be deleted until it is shut down) [Gadu-Gadu Temporary Files*] LangSecRef=3022 Detect=HKCU\Software\Gadu-Gadu\ Default=False FileKey1=%WinDir%\|TEMP*.htm* Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 24, 2012 Moderators Share Posted March 24, 2012 Here is a couple of new ones, tested: Scan logs for Kaspersky's TDSSKiller I'm a little weary about having a broad clean up like that for an antimalware program, which stores in the systemdrive, added to the public list. Especially weary of a first time poster, no offence, can a long time member test and sign off of this entry. also why is far manager deleting its own detect…or for that matter why does it delete the entire profile folder. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 24, 2012 Moderators Share Posted March 24, 2012 TDSSKiller is not a something that most folk would have on their system anyway as it's a specialist rootkit removal tool. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted March 25, 2012 Share Posted March 25, 2012 NEW ENTRY [OpenOffice.org 3*] LangSecRef=3021 Detect=HKCU\Software\OpenOffice.org\OpenOffice.org 3.3 Default=False FileKey1=%AppData%\OpenOffice.org\3\user\config\imagecache|*.* FileKey2=%AppData%\OpenOffice.org\3\user\registry\cache|*.* FileKey3=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Common.xcu FileKey4=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Views.xcu FileKey5=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Writer.xcu FileKey6=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Histories.xcu FileKey7=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\ucb|Hierarchy.xcu FileKey8=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\ucb|Store.xcu FileKey9=%AppData%\OpenOffice.org\3\user\store|.templdir.cache FileKey10=%AppData%\OpenOffice.org\3\user\template|*.* Link to comment Share on other sites More sharing options...
SMalik Posted March 25, 2012 Share Posted March 25, 2012 MODIFIED ENTRIES [Corel PaintShop Pro X4 More*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel PaintShop Pro X4\Corel PaintShop Pro.exe Default=False FileKey1=%LocalAppData%\Corel PaintShop Pro\14.0\Database|*.db Removed the lines listed below: FileKey2=%AppData%\Corel\Messages|*.*|RECURSE ExcludeKey1=FILE|%AppData%\Corel\Messages|*.policy [Corel VideoStudio Pro X4 More*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel VideoStudio Pro X4\vstudio.exe Default=False FileKey1=%AppData%\Ulead Systems\Corel VideoStudio Pro\14.0\en-US|VS_Pro.log FileKey2=%Documents%\Corel VideoStudio Pro\14.0\AudioTmp|*.* FileKey3=%Documents%\Corel VideoStudio Pro\14.0\SmartProxy|*.* RegKey1=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\HerRFL RegKey2=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\Library Manager|Latest Export Folder RegKey3=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\Preference|Working Folder RegKey4=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\VIO\Recent Dir Removed the lines listed below: FileKey1=%AppData%\Corel\Messages|*.*|RECURSE ExcludeKey1=FILE|%AppData%\Corel\Messages|*.policy NEW ENTRY [Corel VideoStudio Pro X5*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel VideoStudio Pro X5\vstudio.exe Default=False FileKey1=%Documents%\Corel VideoStudio Pro\15.0\AudioTmp|*.* FileKey2=%Documents%\Corel VideoStudio Pro\15.0\SmartProxy|*.* RegKey1=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\15.0\HerRFL RegKey2=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\15.0\Library Manager|Latest Export Folder RegKey3=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\15.0\Preference|Working Folder RegKey4=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\15.0\VIO\Recent Dir Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 25, 2012 Author Share Posted March 25, 2012 Thanks for removing the entire page of spam posts! And thanks for the new entries and revised ones winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted March 25, 2012 Share Posted March 25, 2012 NEW ENTRY [OpenOffice.org 3*] LangSecRef=3021 Detect=HKCU\Software\OpenOffice.org\OpenOffice.org 3.3 Default=False FileKey1=%AppData%\OpenOffice.org\3\user\config\imagecache|*.* FileKey2=%AppData%\OpenOffice.org\3\user\registry\cache|*.* FileKey3=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Common.xcu FileKey4=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Views.xcu FileKey5=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Writer.xcu FileKey6=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\Office|Histories.xcu FileKey7=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\ucb|Hierarchy.xcu FileKey8=%AppData%\OpenOffice.org\3\user\registry\data\org\openoffice\ucb|Store.xcu FileKey9=%AppData%\OpenOffice.org\3\user\store|.templdir.cache FileKey10=%AppData%\OpenOffice.org\3\user\template|*.* How about changing the "3" with wildcard "*" and maybe the detect like this?: [OpenOffice.org 3*] LangSecRef=3021 Detect=HKCU\Software\OpenOffice.org Default=False FileKey1=%AppData%\OpenOffice.org\*\user\config\imagecache|*.* FileKey2=%AppData%\OpenOffice.org\*\user\registry\cache|*.* FileKey3=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Common.xcu FileKey4=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Views.xcu FileKey5=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Writer.xcu FileKey6=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Histories.xcu FileKey7=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu FileKey8=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Store.xcu FileKey9=%AppData%\OpenOffice.org\*\user\store|.templdir.cache FileKey10=%AppData%\OpenOffice.org\*\user\template|*.* Link to comment Share on other sites More sharing options...
siliconman01 Posted March 25, 2012 Share Posted March 25, 2012 Change name of Weather Watcher Live* to Weather Watcher Live (Temp files)* [Weather Watcher Live (Temp Files)*] LangSecRef=3021 Detect=HKCU\Software\VB and VBA Program Settings\Weather Watcher Live Default=False FileKey1=%AppData%\WeatherWatcherLive\Temp|*.* New entry [Weather Watcher Live (Data Log)*] LangSecRef=3021 Detect=HKCU\Software\VB and VBA Program Settings\Weather Watcher Live Default=False FileKey1=%AppData%\WeatherWatcherLive\|WeatherWatcherLive.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 25, 2012 Author Share Posted March 25, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted March 26, 2012 Share Posted March 26, 2012 How about changing the "3" with wildcard "*" and maybe the detect like this?: [OpenOffice.org 3*] LangSecRef=3021 Detect=HKCU\Software\OpenOffice.org Default=False FileKey1=%AppData%\OpenOffice.org\*\user\config\imagecache|*.* FileKey2=%AppData%\OpenOffice.org\*\user\registry\cache|*.* FileKey3=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Common.xcu FileKey4=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Views.xcu FileKey5=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Writer.xcu FileKey6=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Histories.xcu FileKey7=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu FileKey8=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Store.xcu FileKey9=%AppData%\OpenOffice.org\*\user\store|.templdir.cache FileKey10=%AppData%\OpenOffice.org\*\user\template|*.* I think Detect should be changed to HKCU\Software\OpenOffice.org. They have 3.4 beta and that has changed the reg path from HKCU\Software\OpenOffice.org\OpenOffice.org 3.3 to HKCU\Software\OpenOffice.org\OpenOffice.org 3.4 I don't know about changing the wildcards. Link to comment Share on other sites More sharing options...
nodles Posted March 26, 2012 Share Posted March 26, 2012 It'd probably detect & clean also other versions too, not just v3 / v3.3. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 26, 2012 Author Share Posted March 26, 2012 Update for CCleaner v3.17 on its way in a bit, as I am a bit busy at the moment. Fear not winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Tr3bg0D Posted March 26, 2012 Share Posted March 26, 2012 We are waiting........... Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 27, 2012 Author Share Posted March 27, 2012 Sorry for the delay. Updated. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted March 27, 2012 Share Posted March 27, 2012 Snagit 11 entry is not fixed in the latest version of Winapp2.ini http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=212221 Link to comment Share on other sites More sharing options...
SMalik Posted March 27, 2012 Share Posted March 27, 2012 The highlighted line should be removed from the entry listed below. These are locked and hidden files. When CCleaner tries to remove the regtrans-ms files from that location it only unhides the files, it does not remove the files. [Registry Transaction Logs*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%SystemDrive%\Users\Default|*.regtrans-ms FileKey2=%LocalAppData%\Microsoft\Windows|*.regtrans-ms FileKey3=%UserProfile%|*.regtrans-ms Link to comment Share on other sites More sharing options...
Tr3bg0D Posted March 27, 2012 Share Posted March 27, 2012 Sorry for the delay. Updated. Thanks....don't forget to update the version number in the 1st post Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 27, 2012 Author Share Posted March 27, 2012 I changed those two things, I updated the file hosted on the server. I always forget to modify the first post correctly! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted March 27, 2012 Share Posted March 27, 2012 SnagIt 11 was added in Winapp.ini of CCleaner V3.17. SnagIt 11* should be changed to: [snagit 11*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\11 Default=False Warning=This will delete the backups of the captures that you have performed with SnagIt 11. FileKey1=%LocalAppData%\TechSmith\Snagit|*.bin FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG FileKey4=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAGundo RegKey1=HKCU\Software\TechSmith\Snagit\11|CaptureCount Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 27, 2012 Author Share Posted March 27, 2012 Fixed that. Sorry. Bit out of it this week. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
