update 0 Posted March 6, 2012 Share Posted March 6, 2012 I have some questions: Is there any way to delete every file on every Disk with a specific Typ, but without a path? e.g. Delete every .xy files And is there any way to make if clauses? That would be verry helpful.. Link to post Share on other sites
Winapp2.ini 0 Posted March 7, 2012 Author Share Posted March 7, 2012 You could with a broad RECURSE statement, but it'd take ages. No if clauses, though. Link to post Share on other sites
Winapp2.ini 0 Posted March 12, 2012 Author Share Posted March 12, 2012 [Registry Transaction Logs*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%SystemDrive%\Users\Default|*.regtrans-ms FileKey2=%LocalAppData%\Microsoft\Windows|*.regtrans-ms FileKey3=%UserProfile%\|*.regtrans-ms This one should be of interest to Alan_B Also this is a self reminder to remove the logs from the trilllian entry, and keep it in the trillian logs entry. Link to post Share on other sites
Alan_B 0 Posted March 12, 2012 Share Posted March 12, 2012 [Registry Transaction Logs*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%SystemDrive%\Users\Default|*.regtrans-ms FileKey2=%LocalAppData%\Microsoft\Windows|*.regtrans-ms FileKey3=%UserProfile%\|*.regtrans-ms This one should be of interest to Alan_B Also this is a self reminder to remove the logs from the trilllian entry, and keep it in the trillian logs entry. Thanks for grabbing my attention. I look forward to trying this, but for the next few days I will be focussed on what applications to add to a brand new Windows 7. At the weekend I gained an SSD and restored an image of both C:\ and the 100 MB System Reserved partitions of the previous HDD. Restoration operation was successful, but the system failed to live, so the Windows Installation Discs had to be used. Regards Alan Link to post Share on other sites
Alexei 0 Posted March 13, 2012 Share Posted March 13, 2012 Hi there, Can I make the Warning= line with an extra empty line between two lines? Thank you for your time. Alexei Link to post Share on other sites
Winapp2.ini 0 Posted March 13, 2012 Author Share Posted March 13, 2012 Not as far as I am aware. Link to post Share on other sites
Alexei 0 Posted March 13, 2012 Share Posted March 13, 2012 Not as far as I am aware. Thank you for quick response Link to post Share on other sites
Winapp2.ini 0 Posted March 13, 2012 Author Share Posted March 13, 2012 I'll experiment with it a bit, but I don't think it's possible. Link to post Share on other sites
Alan_B 0 Posted March 13, 2012 Share Posted March 13, 2012 Hi there, Can I make the Warning= line with an extra empty line between two lines? Thank you for your time. Alexei An empty line MAY work today, but it may fail tomorrow if it is not stipulated as a permissible peculiarity. Why not be legal and use an ALMOST empty line, e.g. one of the punctuuation marks such as . , : e.g. Warning=This will degrade internet speed Warning=: Warning=Give up now whilst you can Link to post Share on other sites
Alexei 0 Posted March 13, 2012 Share Posted March 13, 2012 An empty line MAY work today, but it may fail tomorrow if it is not stipulated as a permissible peculiarity. Why not be legal and use an ALMOST empty line, e.g. one of the punctuuation marks such as . , : e.g. Warning=This will degrade internet speed Warning=: Warning=Give up now whilst you can Thank you, I try it out Link to post Share on other sites
Winapp2.ini 0 Posted March 13, 2012 Author Share Posted March 13, 2012 I was able to do it [WarningTest*] Section=WarningTest Warning=THIS IS LINE ONE THIS IS LINE TWO (hopefully) I used several tabs. It's probably hit or miss depending on line length. I don't know if it varies depending on resolution or not. Developers: Is there a way to do this without tabbing? I tried using an ASCII newline character, but got ♀ Edit: The codebox looks like it changed it to spaces, but it was 13 tabs. My resolution is 1920x1080, and it retained the behavior on a 1440x900, so I assume the box comes in that size standard across resolutions unless they're (for some unknown reason) smaller than the box itself. Link to post Share on other sites
Alexei 0 Posted March 14, 2012 Share Posted March 14, 2012 Developers: Is there a way to do this without tabbing? Thanks for trying. Something I've already tried and it's going to. On a old laptop with XP and low resolution goes it not good. Possible know the developers a solution for this. Link to post Share on other sites
siliconman01 0 Posted March 16, 2012 Share Posted March 16, 2012 Please change Thumbsplus 8* to Thumbsplus 8/9* [ThumbsPlus 8/9*] LangSecRef=3023 Detect=HKCU\Software\Cerious Software Inc. Default=False FileKey1=%AppData%\Thumbsplus|*.log FileKey2=%AppData%\Thumbsplus|*.bak Link to post Share on other sites
Winapp2.ini 0 Posted March 16, 2012 Author Share Posted March 16, 2012 Will do, thanks! Link to post Share on other sites
SMalik 0 Posted March 16, 2012 Share Posted March 16, 2012 Please remove the highlighted detect paths as they have nothing to do with JDownloader. This reg path belongs to BookSmart (http://www.blurb.com/make/booksmart). [JDownloader .junique*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\.junique|*.* [JDownloader Capatchas*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\captchas|*.* FileKey2=%ProgramFiles%\JDownloader\tmp\linksave|*.* [JDownloader Config*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\config|*.* [JDownloader DLC*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\container|*.* [JDownloader Downloads*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\downloads|*.* [JDownloader Logs*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader|*.log FileKey2=%ProgramFiles%\JDownloader|*.lck Link to post Share on other sites
TKruzze 0 Posted March 16, 2012 Share Posted March 16, 2012 Using the latest version, I'm finding that the wildcard (*) does not seem to be working for RegKey entries on my Windows 7 64-bit system. When I run the addition below, no changes are made to the registry. However, if I modify the code and replace the * with actual numbers (second example below), it cleans just fine. Can anyone else reproduce this behavior or explain why it's happening to me? Thanks. [Media Player Classic More*] LangSecRef=3023 Detect=HKCU\Software\Gabest\Media Player Classic Default=False RegKey1=HKCU\Software\Gabest\Media Player Classic\Settings|File Name * RegKey2=HKCU\Software\Gabest\Media Player Classic\Settings|File Position * [Media Player Classic More*] LangSecRef=3023 Detect=HKCU\Software\Gabest\Media Player Classic Default=False RegKey1=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 1 RegKey2=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 2 RegKey3=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 3 RegKey4=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 1 RegKey5=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 2 RegKey6=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 3 Link to post Share on other sites
Winapp2.ini 0 Posted March 16, 2012 Author Share Posted March 16, 2012 Please remove the highlighted detect paths as they have nothing to do with JDownloader. This reg path belongs to BookSmart (http://www.blurb.com/make/booksmart). [JDownloader .junique*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\.junique|*.* [JDownloader Capatchas*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\captchas|*.* FileKey2=%ProgramFiles%\JDownloader\tmp\linksave|*.* [JDownloader Config*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\config|*.* [JDownloader DLC*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\container|*.* [JDownloader Downloads*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader\downloads|*.* [JDownloader Logs*] LangSecRef=3022 Detect1=HKLM\Software\JDownloader Detect2=HKLM\Software\ej-technologies Default=False FileKey1=%ProgramFiles%\JDownloader|*.log FileKey2=%ProgramFiles%\JDownloader|*.lck Are you sure it's Booksmart? I googled ej-technologies and couldn't find Booksmart on their page. Nor JDownloader, for that matter. Link to post Share on other sites
Winapp2.ini 0 Posted March 16, 2012 Author Share Posted March 16, 2012 Using the latest version, I'm finding that the wildcard (*) does not seem to be working for RegKey entries on my Windows 7 64-bit system. When I run the addition below, no changes are made to the registry. However, if I modify the code and replace the * with actual numbers (second example below), it cleans just fine. Can anyone else reproduce this behavior or explain why it's happening to me? Thanks. [Media Player Classic More*] LangSecRef=3023 Detect=HKCU\Software\Gabest\Media Player Classic Default=False RegKey1=HKCU\Software\Gabest\Media Player Classic\Settings|File Name * RegKey2=HKCU\Software\Gabest\Media Player Classic\Settings|File Position * [Media Player Classic More*] LangSecRef=3023 Detect=HKCU\Software\Gabest\Media Player Classic Default=False RegKey1=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 1 RegKey2=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 2 RegKey3=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 3 RegKey4=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 1 RegKey5=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 2 RegKey6=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 3 AFAIK: RegKey doesn't support Wildcard (yet) Link to post Share on other sites
SMalik 0 Posted March 17, 2012 Share Posted March 17, 2012 Are you sure it's Booksmart? I googled ej-technologies and couldn't find Booksmart on their page. Nor JDownloader, for that matter. Link to post Share on other sites
Winapp2.ini 0 Posted March 17, 2012 Author Share Posted March 17, 2012 http://www.ej-technologies.com/products/install4j/overview.html My guess is JDownloader was mistakenly identified as using Install4j. I'll remove it. Thanks! Link to post Share on other sites
Winapp2.ini 0 Posted March 17, 2012 Author Share Posted March 17, 2012 This is a tentative entry for Windows 8, the first (AFAIK) designed to clean up after Metro Apps Very limited testing has been done... so beware (I wont include this in any releases unless people would like me to) [Metro Apps*] LangSecRef=3021 Detect=%LocalAppData%\Packages Default=False FileKey1=%LocalAppData%\Packages\*\LocalState\Cache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\*\LocalState\*\Cache|*.*|RECURSE FileKey3=%LocalAppData%\Packages\*\AC\Temp|*.* FileKey4=%LocalAppData%\Packages\*\AC\Microsoft\*\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\*\AC\Microsoft\CryptUrlCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\*\TempState|*.*|RECURSE FileKey7=%LocalAppData%\Packages\*\AC\Microsoft\CLR_4.0\UsageLogs|*.*|RECURSE Link to post Share on other sites
TKruzze 0 Posted March 17, 2012 Share Posted March 17, 2012 AFAIK: RegKey doesn't support Wildcard (yet) You might want to go through the current .ini, then, as there are several instances of wildcards being used with RegKey. The example I quoted above was directly from the latest Winapp2.ini. Link to post Share on other sites
TKruzze 0 Posted March 17, 2012 Share Posted March 17, 2012 Alright, I lied (a little bit). There are 2 entries in the current ini that make use of wildcards in RegKey. The first one is below: [Macromedia Flashplayer*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer Default=True RegKey1=HKCU\Software\Macromedia\FlashPlayer|RecentMovie* It's basically useless as is. I would recommend removing it completely from the list unless someone can fix it with the proper entries. Also, I have fixed the entry I reported above and have listed it below. It now works compeltely as it should: [Media Player Classic More*] LangSecRef=3023 Detect=HKCU\Software\Gabest\Media Player Classic Default=False RegKey1=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 0 RegKey2=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 1 RegKey3=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 2 RegKey4=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 3 RegKey5=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 4 RegKey6=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 5 RegKey7=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 6 RegKey8=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 7 RegKey9=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 8 RegKey10=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 9 RegKey11=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 10 RegKey12=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 11 RegKey13=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 12 RegKey14=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 13 RegKey15=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 14 RegKey16=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 15 RegKey17=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 16 RegKey18=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 17 RegKey19=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 18 RegKey20=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 19 RegKey21=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 0 RegKey22=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 1 RegKey23=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 2 RegKey24=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 3 RegKey25=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 4 RegKey26=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 5 RegKey27=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 6 RegKey28=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 7 RegKey29=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 8 RegKey30=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 9 RegKey31=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 10 RegKey32=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 11 RegKey33=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 12 RegKey34=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 13 RegKey35=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 14 RegKey36=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 15 RegKey37=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 16 RegKey38=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 17 RegKey39=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 18 RegKey40=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 19 Thanks for your continued work on the very valuable project! Link to post Share on other sites
Winapp2.ini 0 Posted March 17, 2012 Author Share Posted March 17, 2012 Ah, I didn't know. If anyone has more information on that one, let me know. (The macromedia one) I'll comment it out for now so it's not forgotten. Link to post Share on other sites
siliconman01 0 Posted March 18, 2012 Share Posted March 18, 2012 [Macromedia Flashplayer*] LangSecRef=3023Detect=HKCU\Software\Macromedia\FlashPlayer Default=True RegKey1=HKCU\Software\Macromedia\FlashPlayer|RecentMovie* Technically speaking, this is Adobe Flash Player*, not Macromedia Flashplayer* Link to post Share on other sites
