CCleaner Community Forums
ublock users
hazelnut
 Share
  • 2 weeks later...
  • 1 month later...
ublock v1.14.24
gorhill released this
2 days ago
Emergency fix for "Cannot full support Domain restrictive Inverse type options".
I didn't look in all filter lists, but I searched in large high profile lists and I found:
  • Two filters in EasyList
  • One filter in EasyList China
Commits since 1.14.22:
Versions of CCleaner Cloud; Introduction Ccleaner Cloud;
Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free
Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard"
Link to comment
  • 3 weeks later...
ublock v1.15.0
a day ago
New
HTML filtering
Ability to remove DOM elements from a source document before it is parsed by the browser. The platform must support an extension API to modify the response body on the fly. Currently only Firefox 57+ allows this.
The filter syntax is similar to cosmetic filtering, except that the character ^ is used before a valid selector to denote that the filter is to be applied to the source data. Contrary to cosmetic filtering, with HTML filtering the elements matching a selector are removed from the source. Example:
twitter.com##^meta[http-equiv="refresh"]
www.google.ca##^#hplogo
boards.4chan.org##^script:has-text(7c9e3a5d51cdacfc)
Note that procedural operators are supported. Procedural operators which are senseless to use on source data will be ignored. For example, it makes no sense to use procedural operator such :matches-css(...) for HTML filtering.
Note that HTML filtering essentially brings back support for inline script tag filtering. I plan on deprecating the syntax ##script:contains(...) in favor of ##^script:has-text(...). For the time being, uBO will conveniently convert the old syntax to the new HTML filtering syntax.
Given that HTML filters are to be applied to the source data of a document, the best way to create such filters is to view-source: the document and from there analyze what should be removed. Thus the element picker won't be extended as a tool to create HTML filters.
In case it's still not clear at point: this is a big deal feature.
Sub-filter lists
Ability for filter list maintainers to force uBO to load extra filter lists from within a filter list, using an !#include directive. Example:
!#include adblock_ublock.txt
When uBO encounters the above directive inside a filter list, it tells uBO to load the extra filter list and append it to the current one. The main purpose of such directive is to allow filter list maintainers to be able to make use of uBO's extended filter syntax, without forfeiting the ABP-compatibility of their main filter list: ABP will ignore such directive since it will be seen as a mere comment.
All the details of the new directives syntax is being fleshed out at AdguardTeam/AdguardBrowserExtension#917. At this point only !#include is implemented by uBO, because it solves immediately a current issue by simplifying the work of filter list maintainers who want to make use of uBO's extended filter syntax.
Important: uBO forbids sublists which are outside the directory of the main list. Typically, filter list maintainers will just use a single file name, as seen in the example above, in which case same-origin and same directory is implicit.
Changes
Logger
The logger can now be opened in a sidebar on Firefox. Just open the side bar and "uBlock₀ -- Logger" will be available as a choice.
Given this new ability, I added the following enhancements:
  • A new entry in the tab selector: "Current tab":
    • This will cause the logger to automatically filter out rows which do not belong to the currently active tab.
  • The rows related to behind-the-scene scope are now always shown.
  • If you close a tab while "Current tab" is selected, the resulting void rows will be automatically deleted.
  • You can expand/collapse a single row by clicking on the time stamp cell.
Given that uBO's logger is unified, being able to open the logger in a sidebar means you could end up having multiple views opened for the logger: only one view will work at any given time.
Mind that there are minor visual issues which I have no control over:
  • The maximum horizontal space is limited by the browser.
  • Firefox: the font size is smaller than dictated in the DOM inspector view: I have no clue why, uBO's chosen font size is overridden by Firefox for some reasons.
    -Firefox: it's not possible to select text in the logger when it is embedded in a sidebar.
  • If you have the logger already opened in a tab or separate window, you will have to close these for the logger-in-a-sidebar to start working. However some internal message events are lost in Firefox and as a result the logger-in-a-sidebar may take over 30 seconds to start working after you close the logger-in-a-tab or window.
Closed as fixed:
Firefox
Core
Link to comment
now 2 updates :-)
ublock v1.15.2
8 hours ago
No change to the code, I just updated the filter lists packaged with the extension -- due to a bad EasyList filter being shipped with the previous package.
Link to comment
ublock v1.15.4
3 hours ago
Closed as fixed:
Firefox/webext
Link to comment
  • 2 weeks later...
nothing to thanks :-) my pleasure
ublock v1.15.6 --> especially for my species ;):D
7 hours ago
Link to comment
ublock v1.15.8
8 hours ago
Firefox/webext:
Fixed a minor memory leak occurring as a result of injecting scriptlets (through ##script:inject(...) filters) using webRequest.filterResponseData.
Commit: c5cbf5d.
Link to comment
ublock v1.15.10
4 hours ago
Firefox/webext
I rolled back part of the fix for #3069: scriptlets are back to being injected using the delayed path. Using stream filtering to inject the scriptlets raised two distinct issues lately:
HTML filtering is still available, i.e. filters using the ##^ syntax are unaffected.
Link to comment
  • 4 weeks later...
ublock 1.15.12
a day ago
New
Added a new advanced setting: streamScriptInjectFilters. The purpose is to tell uBO to use stream filtering to inject scriptlets where possible. Default to false. Set to true to bring back scriptlet injection through stream filtering as was the default before 1.15.10. A fix has also been added to resolve uBlockOrigin/uAssets#1492, which was the main reason to disable stream filtering-based scriptlets injection in 1.15.10.
Integration of CodeMirror in uBO's dashboard. Please do not open feature requests related to this.
Changes:
Firefox/webext
From now on, the beta version will be signed and self-hosted here. The stable version and the beta version auto-update independently of each other.
Closed as fixed:
Firefox
Nightly
Core
Link to comment
ublock 1.15.14
a day ago
There is no change in this version relative to 1.15.12. I was forced to bump revision number to upload again to AMO -- the proper way this time.
Link to comment
ublock 1.15.16
20 hours ago
Link to comment
ublock v1.15.18
a day ago
Link to comment
  • 3 weeks later...
3 fly´s with one stroke
ublock v1.15.20
2 days ago
Changes:
From now on, behind-the-scene network requests will be treated and filtered just like any other network requests. The behind-the-scene scope will be un-whitelisted when migrating to 1.15.20+ from an older version.
This will not apply to current installations of the Firefox/legacy version of uBO, as this would cause serious breakage of the browser given that uBO can see all network requests in Firefox/legacy. However for a fresh install of the Firefox/legacy version, you will have to manually add the behind-the-scene scope as a whitelist directive in the Whitelist pane.
Keep in mind I plan to drop support for Firefox/legacy once Firefox 60 ESR is released on May 7. This will remove a roadblock for simplifying uBO's code base in many areas.
Miscellaneous:
  • Ability to visually filter out rules in the "My rules" pane in the dashboard.
  • Firefox for Android: improved compatibility with the CodeMirror editor.
  • Responsive design of the dashboard user interface has been improved a bit.
Closed as fixed:
Firefox
Core
Link to comment
ublock v1.15.22
a day ago
Changes:
Regression introduced in version 1.15.12 with the fix to issue #3546: whitelist directives were not taken into account for filterable behind-the-scene network requests. This is now fixed.
Link to comment
ublock v1.15.24
a day ago
Changes:
Firefox only: release version of uBO on AMO is not allowed to update its resources.txt asset. This means the version shipped with the extension must be used. However, uBO compile and cache the data in resources.txt, and unless the cache is invalidated, uBO will keep using a potentially out of date version of resources.txt. This has been fixed by unconditionally invalidating the cache when a new version of uBO is detected.
Notes:
I will wait a bit before releasing in Chrome and Opera stores, to see if any regression surfaces in the Firefox version. It is easier for me to have a speedy update in AMO than it is in the Chrome store.
Link to comment
  • 3 weeks later...
ublock v1.16.0
8 hours ago
New:
Added support for pre-parsing directives to filter list compiler. This allows filter list maintainers to create areas in a filter list which will be compiled only if certain conditions are met (or not met). See detailed documentation.
Changes:
The "3rd-party filters" pane in the dashboard has been renamed "Filter lists", and its look and behavior has been fine tuned.
Work has been done in the dashboard to further improve rendering on small screens.
Closed as fixed:
Chromium
Firefox
Core
Link to comment
ublock v1.16.2
11 hours ago
Notes:
Publishing the dev build in the Chrome store has become very slow, new versions are languishing for days in "pending review" status, even when changes are trivial (meanwhile...). I consider this a hurdle to uBO development and the quick addressing of new issues/regressions. New versions of uBO on AMO become available literally minutes following submission.
uBO 1.15.24 in Opera store has been stuck in "pending approval" status since April 9th. If this situation does not resolve, I will seriously consider removing uBO from the Opera store. For Opera users, there is an Opera extension which allows installing extensions from the Chrome store if ever I end up removing uBO from the Opera store.
Closed as fixed:
Chromium builds without WebRTC
Chromium-based browsers
Firefox legacy
Firefox 52 ESR + uBO/webext
Firefox for Android
Firefox webext
Core
Link to comment
  • 2 weeks later...
ublock v1.16.4
2 days ago
Closed as fixed:
Firefox for Android
Core
Link to comment
ublock firefox legacy v1.16.4
7 days ago
No changes from 1.16.2, it's just to test that all work fine for releasing new Firefox-legacy packages of uBO.
Link to comment
  • 2 weeks later...
ublock v1.16.6
a day ago
Closed as fixed:
Firefox:
Core:
Link to comment
  • 2 weeks later...
ublock v1.16.8
a day ago
No change to uBO itself.
The only change is in uBO's assets and publishing a new version of uBO package is to ensure all users get a new version of the neutered script from googletagservices.com/gpt.js -- see uBlockOrigin/uAssets@2bc9754.
Link to comment
  • Moderators
Since uBlock v1.16.6 Chromium build I've noticed YouTube takes forever to load images or doesn't load them at all. I don't have that issue in the very old legacy v1.13.8 for Firefox.
Link to comment
Register a new account
Sign in
 Share
