trium 0 Posted July 9, 2020 Share Posted July 9, 2020 ublock v1.28.0 gorhill released this Jun 30, 2020 Changes: ##script:inject(...), which has been deprecated in favor of ##+js(...) for more than two years, is no longer supported. It's no longer possible to point-and-click to create allow (green) rules from within the popup panel by default. This change is motivated by seeing way too many cases of improper usage of dynamic filtering in which users are creating allow (green) rules where noop (gray) rules should have been used. You can get back temporarily the ability to create allow rules from within the popup panel by tapping twice the Ctrl key. Improved syntax highlighting of static filters in "My filters" and asset viewer. Additionally, in "My filters": Ability to toggle commenting out of filter(s) by pressing the Tab key Auto-completion using Ctrl-Space, this works for: Static filter options Resource names for redirect= option Procedural operators for cosmetic/HTML filters Scriptlet names for ##+js filters Closed as fixed: Chromium 65 Broken popup panel in Chromium 65 Chromium Use default_public_interface_only in Chromium-based browsers Core Cookie-remover.js does not remove a cookie A possibility of using default system fonts for uBlock Origin? Some RegExp filters are not parsed properly Add support for entity-matching in domain= filter option Notable commits with no entry in issue tracker: Fix edge case involving filter with a single wildcard Add support for wildcard/array in json-prune Fix matching of filters with trailing ^| Make the creation of allow rules in panel an opt-in feature Add ability to lock firewall height to basic pane height Fix uselessly allocating one extra WASM page Replace FilterPlainHostname with composite filter Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted July 9, 2020 Share Posted July 9, 2020 firefox legacy v1.16.4.21 gorhill released this Jun 20, 2020 Change Prevent exceptions when several conflicting rules result in an empty filter Improve validation of CSS selector-based cosmetic filters Map upward to xpath using filter syntax converter Update scriptlets from the upstream repo Replace requestAnimationFrame-if.js with no-requestAnimationFrame-if.js Improve set-constant.js scriptlet Improve window.open-defuser scriptlet Add remove-class scriptlet (alias: rc) Add new scriptlet to allow blocking Amazon's apstag.js Bring fingerprint2.js scriptlet up to date Improve logging capabilities of json-prune scriptlet Add uBO: prefix to logged output in some scriptlets Remove obsolete filters from stock filter lists hpHosts Disconnect Malvertising Adblock Warning Removal Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted July 9, 2020 Share Posted July 9, 2020 firefox legacy v1.16.4.22 gorhill released this Jul 4, 2020 Change Strict-block only if match is anchored to end of hostname Improve procedural cosmetic filters processing (thanks to @hawkeye116477) Use +js name for logging Allow u flag in regexes Bump minimum browser versions due to ES6 semantics Add nowoif alias for window.open-defuser scriptlet Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted July 25, 2020 Share Posted July 25, 2020 ublock v1.28.2 gorhill released this Jul 11, 2020 Changes: Both stock malware domain lists, which are enabled by default in uBO, have been replaced by URLhaus Malicious URL blocklist, which is now enabled by default in uBO. For existing installations, both removed malware lists will be moved to the Custom section if you still have them enabled. It is recommended you remove these lists from your Custom lists -- only you can do this, uBO does not remove lists which are currently enabled. It may take a few days before you are updated with the new default stock lists. Closed as fixed: Remove Malware Domain List Remove Malware domains Remove Malware Domain List Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted July 25, 2020 Share Posted July 25, 2020 ublock v1.28.4 gorhill released this Jul 15, 2020 Closed as fixed: Add cdn.jsdelivr.net mirror for urlhaus blocklist Remove repo.or.cz from list of CDNs for urlhaus blocklist Fix spurious rejection of some AdGuard redirect filters Fix the reporting of invalid static extended filters in the logger Fix improper rejecting fitlers with $all,~document options Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted July 25, 2020 Share Posted July 25, 2020 firefox legacy v1.16.4.23 gorhill released this 14 days ago Change Further improve procedural cosmetic filters and operators (thanks to @hawkeye116477) Support CSS selectors mixed w/ operators in procedural cosmetic filters Fix and improve parsing rules from AdGuard's filter lists Natively implement :nth-ancestor(n) procedural operator Add :min-text-length(x) and :watch-attr procedural operators Replace exec with transpose in procedural filters Update filter syntax converter Use native implementation of :nth-ancestor(n) Re-map :upward(n) from :xpath to :nth-ancestor(n) Replace seemingly abandoned malware lists with URLhaus Malicious URL blocklist Restore support for Gecko 45-50 based browsers Note: The release notes are created/maintained by @JustOff. Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted July 25, 2020 Share Posted July 25, 2020 firefox legacy v1.28.4.24 gorhill released this yesterday Change Update procedural cosmetic filters and operators (thanks to @hawkeye116477) Fix using sibling-related CSS syntax at prefix position Fix processing !#include directive within conditions Add procedural cosmetic operators :remove() and :upward() Improve filter logger (thanks to @hawkeye116477) Update stock filter lists Use secure protocol for MVPS HOSTS Remove no longer maintained KOR list Update URL for EasyList Lithuania Note: The release notes are created/maintained by @JustOff. Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted August 22, 2020 Share Posted August 22, 2020 ublock v1.29.0 gorhill released this 13 days ago Closed as fixed: Chromium Performance regression in rendering of dashboard pane Firefox Open tabs can be closed when opening a webpage from about:newtab Core Use ISO8061 dates in user filter comments Support new Chromium based Edge in pre-parsing directives Do not triggers strict blocking for wildcard-only patterns Improve/refine syntax highlighter, specifically: Fix properly reporting invalid filter options Add syntax highlighting/auto-completion for preparsing directives Add CoreMirror's code-folding ability to list editor/viewer Reverse lookup fails for filter of type example.com##* New filter parser creates unexpected network filter from malformed cosmetic filter Avoid loading "!#include" filepaths that are wrapped into "!#if" tags that exclude the browser's environment Use "Trusted sites" instead of "Whitelist" Element picker suggests unhelpful network rule Logger shows names of scriptlet as different ones if short-hand is used A problem with cyrillic characters Adding csp to logger's filter expression picker Cosmetic filters in about:blank iframe Adguard French filter Can't use set-constant.js multiple times for same parent property Notable commits with no entry in issue tracker: Remove experimental click-to-load disqus scriptlets Improve annotations for search operations in CodeMirror editor Consolidate filter list reverse lookup code into a single file Allow :upward() operator to select html element Instantiate procedural filterer instance on demand only Deprecate pseudo user styles code Mind discarded status of tabs when internally handling them Do not let grow subframe dictionary grow unbound Consider an empty pattern with anchors to be dubious Add static filter parser checklist Fix highligthing of FQDN match in logger Add support to compare delay against literal Number.NaN in nossif/nostif Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted August 22, 2020 Share Posted August 22, 2020 ublock v1.29.2 gorhill released this 22 hours ago Fixes: Add argument to nowoif scriptlet Fix regression in set-constant scriptlet Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted August 22, 2020 Share Posted August 22, 2020 On 25/07/2020 at 21:46, trium said: firefox legacy v1.28.4.24 edit: its firefox legacy v1.16.4.24 Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted September 30, 2020 Share Posted September 30, 2020 ublock v1.30.0 gorhill released this 4 days ago Summary Important: The compile format of filter lists has changed, and this means upon update uBO will have to recompile all filter lists, so this may cause a longer delay at launch the first time uBO is launched after being updated. This is a one time event. The cloud storage feature has been improved in a number of ways: Better reporting of error conditions in the user interface; User interface widget to report storage used/total/max; Support for compressing cloud storage data. Improved "My rules" user interface: Ability to sort rules by type, source, or destination; Ability to show changes only. Added support to chain :style(...) operator to procedural operators. The element picker has been refactored to fix long standing issues (including some not reported in the issue tracker). The Ctrl key is no longer used to control the specificity of a candidate filter, and new widgets have been introduced for the purpose of more easily tuning the depth and specificity. The click-to-subscribe feature has been reworked and is now allowed only on a select number of domains, currently: https://easylist.to/, https://fanboy.co.nz/, https://filterlists.com/, https://forums.lanik.us/, https://github.com/, https://github.io/. The concept of "bad list" has been introduced, to prevent users from unwittingly end up using what are deemed "bad lists" by the uBO team. Some "bad lists" will be completely ignored and importing them will be forbidden by uBO. This restriction can be bypassed by users by simply appending a dummy query parameter to the URL of the list. Closed as fixed: Firefox for Android Fenix device name submit form Core Improper support of IPv6 addresses in static filter domain= option has() not work on <html> Cosmetic filters interfere with element picker visuals Picker gets deformed when a cosmetic filter is added Add Support for AdGuard special case pre-processor directives Sort dynamic filter list by destination / host components Better parsing of hosts file system addresses Can't control specificity in element picker with Firefox for Android Subscriber script needs to be improved Add ability to view changes only in My Rules Combining procedural selector :has() and :style() Add visual hint for last selected entry in element picker Prevent malicious pages from tampering with element picker Notable commits with no entry in issue tracker: Prevent spurious instantiation of procedural filterer Add abort-on-stack-trace scriptlet Related discussion: AdguardTeam/Scriptlets#82 Fix ability to overwrite overquota'ed cloud storage Add support for blocklist of filter lists Add concept of "really bad list" to badlists infrastructure Use modern popup panel in logger Add support for cloud storage compression Add widget to convey the amount of sync storage in use Fix cloud storage errors not reported in user interface Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted September 30, 2020 Share Posted September 30, 2020 firefox legacy v1.16.4.25 gorhill released this on 22 Aug Change Backport several improvements and fixes from the upstream (thanks to @hawkeye116477) Allow :upward() operator to select html element Fix broken :spath operators starting with > Better parsing of hosts file system addresses Add ability to control auto-commenting at filter creation time Use ISO8061 dates in filter comments Fix xmlhttprequest redirection Fix badfilter exception on CSP filters Use "Trusted sites" instead of "Whitelist" Change the way zapper and picker work on CSP protected sites (requires bug #1415352, see #254) Note: The release notes are created/maintained by @JustOff. Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted October 21, 2020 Share Posted October 21, 2020 ublock v1.30.2 gorhill released this Oct 7, 2020 Summary A regression in the element picker caused it to generate needlessly long cosmetic filter. The issue was reported at /r/uBlockOrigin Fixed: Fix picker generating overly long candidate cosmetic filters [regression] Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted October 21, 2020 Share Posted October 21, 2020 ublock v1.30.4 gorhill released this Oct 12, 2020 Closed as fixed: Prevent set-constant properties from being overtaken [regression] Update urlhaus-filter URL Update for twitch.tv (pull request by @pixeltris) Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted October 21, 2020 Share Posted October 21, 2020 ublock v1.30.6 gorhill released this Oct 20, 2020 Fixed: Prevent set-constant from trapping non-configurable properties [regression] Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted December 1, 2020 Share Posted December 1, 2020 ublock v1.30.10 gorhill released this Nov 16, 2020 Not for publication: this release exists strictly as reference point for future releases of uBO for development purpose. The built-in benchmark of the static network filtering engine has been fine tuned such that the benchmark results in the current iteration can be used as reference against future versions of uBO. Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted December 1, 2020 Share Posted December 1, 2020 ublock v1.31.0 gorhill released this Nov 17, 2020 Notes The format of compiled filter lists has changed, this means that when you will be updated to 1.31.0, uBO will have to parse and compile all your enabled filter lists, which may cause larger than usual delay at first launch following update to 1.31.0. This is a one time event. New: Click-to-load Support to replace embedded frames with a click-to-load widget. Examples of usage: ||youtube.com/embed/$3p,frame,redirect=click2load.html ||scribd.com/embeds/$3p,frame,redirect=click2load.html ||player.vimeo.com/video/$3p,frame,redirect=click2load.html Result: Users of medium mode can experiment with a redirect rule to reveal embedded frames in a page: *$3p,frame,redirect-rule=click2load.html Or if you want to have click-to-load only for embedded widgets from specific origins being blocked (reminder: redirect-rule does not create a block filter): ||youtube.com/embed/$3p,frame,redirect-rule=click2load.html Changes: Resources redirected to local, neutered versions will no longer be collapsed as would occur if those resources were only blocked. This change is to enable implementation of the new click-to-load feature. Cloud storage compression is now enabled by default. Interactivity for the no-large-media-elements switch has been improved. Notably, when the switch is enabled, uBO will try to stop playback of blob:-based media elements. Closed as fixed: Firefox for Android Unable to scroll down to the last line in My Filters pane on Firefox for Android Core "Home" button on Strict blocking page works incorrectly in some cases Implement a version of "{{origin}}" that uses the whole URL and not just the domain cosmetic filter ## selector is valid in element picker only Implement $queryprune parameter Calling callback if provided for google analytics mock Redirection syntax issue Use user styles to collapse the placeholder of blocked resources Make load-on-demand smarter for blocked large media elements Notable commits with no entry in issue tracker: Work around Firefox's data: favIconUrl leak Make json-prune scriptlet also trap Response.json() calls Incrementally improve static filtering parser Coallesce origin hit filters into their own bucket Allow domain= with entity values into pre-test buckets Enable origin-hit coalescing optimisation for modifier filters Re-classify redirect= option as a modifier option Improve token extraction from regex-based filters Improve specificity slider in element picker Use a CodeMirror editor instance in element picker Add support for click-to-load of embedded frames Minor improvements to syntax highlight of static filters Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted December 1, 2020 Share Posted December 1, 2020 firefox legacy v1.16.4.26 gorhill released this Oct 26, 2020 Change Make the button look consistent in Pale Moon on Windows Fix regression regarding filter used count per list Backport several improvements and fixes from the upstream (thanks to @hawkeye116477) Add no scripting feature Warn when navigating away from pane with unsaved changes Select existing "Advanced settings" page if any Update links for docs Fix problems with search input readability Visually emphasize directive syntax (!#if/!#endif) in list viewer/editor Allow to view list content from blocked-document page Fix filterlists and my filters wrapping Make use of CodeMirror in "Advanced settings" page Update urlhaus-filter URL Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted January 27 Share Posted January 27 ublock v1.31.2 gorhill released this Dec 3, 2020 This minor release benefits Chromium-based browsers. Chromium 87 added the long time missing tabs.removeCSS() API, which uBO uses: To enable the real-time toggling of cosmetic filters through the no-cosmetic-filtering switch; To enable visualization of hidden elements in DOM inspector. But the call to tabs.removeCSS() was still failing in uBO due to Chromium being more strict regarding the arguments passed to the API. Closed as fixed: tabs.removeCSS does not work as expected in Chromium 87 Commit with no entry in issue tracker: Fix handling of no-longer-existing port condition Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted January 27 Share Posted January 27 ublock v1.32.0 github-actions released this Dec 22, 2020 New: Ability to launch element picker into embedded frames, through a new "Block element in frame..." entry in the contextual menu. Support for match-case filter option, but only for regex-based static network filters. Ability to auto-complete (Ctrl-Spacebar) hostname values for origin-related options in static filter editor according to currently opened tabs. Changes: Dynamic filtering Noop-ing a blocked 3rd-party cell will cause uBO to immediately attempt to reload blocked stylesheets, if any. This will also occurs when the noop-ing is done through the "relax blocking mode" shortcut, in which case uBO will no longer force a reload the whole page. You can restore the previous behavior by modifying the advanced setting blockingProfiles. Closed as fixed: Core GitHub dark mode makes whole page invisible when element picker is active :watch-attr() stopped working (regression in 1.30.0) uBO should ignore redirect= directives with unrecognized redirect token Can't load the images Reverse lookup partially fails for a filter redirecting to empty media resource Add AdGuard's "$removeparam" as an alias for "$queryprune" Network error entries in the logger are no longer colored in red Support parsing "Homepage:" list header for custom lists Please change the dashboard icon to a gear Improve source & destination sorting in "My rules" settings pane uBO badge counter doesn't work when network requests originate from service-workers Convert "$rewrite=abp-resource" into "$redirect" Migrate icons to FontAwesome svg files (from the font file) Element picker works incorrectly on mail.com Notable commits without en entry in the issue tracker Fix case of scriptlet injection not working in about: frames Add new scriptlet: no-fetch-if Add support for match-case option; fine-tune behavior of redirect= Add support to auto-complete values of domain lists Improve representation of modifier filters in logger Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted January 27 Share Posted January 27 ublock v1.32.2 github-actions released this Dec 25, 2020 Closed as fixed: Core queryprune incorrectly handles (removes) "hash" part of the URL Notable commits without en entry in the issue tracker Allow default word selection when not using better selection Better handle Request argument in no-fetch-if Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted January 27 Share Posted January 27 ublock v1.32.4 github-actions released this Dec 29, 2020 Closed as fixed: Problems with asterisk in the destination of hostname-based rules Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted January 27 Share Posted January 27 firefox legacy v1.16.4.27 JustOff released this Dec 21, 2020 Change Backport several improvements and fixes from the upstream (thanks to @hawkeye116477) Update locales Redesign dashboard (wip) Improve logger Add a link to the remote asset in asset viewer Add a way to disable redirection Update and add new scriptlets from the upstream addEventListener-defuser.js / aeld addEventListener-logger.js / aell cookie-remover.js google-analytics.com/analytics.js json-prune.js no-setInterval-if.js / nowoif no-setTimeout-if.js / nostif set-constant.js / set twitch-videoad.js window.open-defuser.js / nowoif abort-on-stack-trace.js / aost (new) no-fetch-if.js (new) Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted January 27 Share Posted January 27 firefox legacy v1.16.4.28 JustOff released this Jan 25, 2021 Change Backport several improvements and fixes from the upstream (thanks to @hawkeye116477) Add fixes for search functionality from upstream Fix the handling of pseudoclass-based generic cosmetic filters Update and add new scriptlets and resources from the upstream Better handle Request argument in no-fetch-if Add resource for noop VMAP Add ability to linger for remove-attr scriplet Improve neutered adsbygoogle scriptlet Fix svg icons in redesigned dashboard on Gecko 45-51 Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
trium 0 Posted February 10 Share Posted February 10 ublock v1.33.0 github-actions released this Jan 29, 2021 New Many new managed storage properties to make it easier for administrators to configure uBO through policies -- see related documentation. Minimum browser version has been increased to: Chromium 55.0 Firefox 57.0 Closed as fixed: Firefox click2load.html fails to load CNAME-3p frames after click on tagesschau.de Core Only filtered part of rules is uploaded to cloud storage remove-attr does not always work Add AdGuard's noopvmap-1.0 equivalent as a redirect resource Using an alias for custom scriptlet in my Filters pane is seen as invalid Third party is not detected (or not exposed to the user) Notable commits without en entry in the issue tracker Add any-delay to timeout/interval boosters Improve neutered adsbygoogle scriptlet Expand managed storage for admins: Add userSettings entry to managed storage Add toOverwrite.filters entry as managed storage property Add toOverwrite.filterLists property to managed storage Adding to and further reviewing admin-managed settings Add support for admin-managed hidden settings Add ability to lookup effective context from store of frames Just extract token from queryprune -- don't create pattern Fix word-based selection in filter list editor/viewer Fix potentially missing context in logger for popup entries Improve extraction of tokens from regex-based filters Upgrade CodeMirror library to 5.59.0 (from 5.46.0) Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
