trium Posted August 19 Share Posted August 19 uBOLite v1.0.23.8128 github-actions released this 12. aug 2023 Release notes This is the first version which functions as expected in Firefox and which is published to AMO. Various approaches to minimize DNR ruleset files Use workaround to inject scriptlets in Firefox Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 19 Share Posted August 19 uBOLite v1.0.23.8155 github-actions released this 15. aug 2023 Release notes Properly serialize CSS combinators according to position in selector Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted September 20 Share Posted September 20 ublock v1.52.0 github-actions released this 08. sept 2023 Fixes / changes Add json-prune-xhr-response and trusted-replace-xhr-response scriptlets Use globalThis instead of self in scriptlet helper Add json-prune-fetch-response scriptlet Position reload icon in logger as per feedback Re-factor extra args for set-constant scriptlet Use Unicode version of hostnames in element picker Disallow trailing CSS universal selector unless properly separated Fix/improve xml-prune scriptlet Improve xml-prune scriptlet Put uBO's icon in nav bar by default Properly serialize CSS combinators according to position in selector Improve no-xhr-if scriptlet Improve no-xhr-if scriptlet Use non-normalized URL for reload/report operations Add commented keywords to googlesyndication_adsbygoogle.js scriptlet Improve fingerprint2.js scriptlet Nothing can come after action operator in procedural cosmetic filters Add trusted-replace-fetch-response scriptlet Harden spoof-css scriptlet Support negated pattern for stack test in scriptlets Fix looking up clickable URLs in code viewer Fine tune logging capabilities of json-prune scriptlet Add stackNeedle argument to json-prune scriptlet Improve remove-class behavior Add visual hint for filtered out rows in firewall pane Add $currentISODate$ to trusted-set-local-storage-item scriptlet Eliminate case-sensitivity from values in set-cookie scriptlet Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
