trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.46.0 github-actions released this 22. Dec 2022 Fixes Add options stub to nofab scriptlet Rewrite logger's "exceptor" feature Be sure procedural filterer is present before use Use Blob URLs to reliably inject scriptlets -- as suggested by @evilpie Add :remove-attr() and :remove-class() pseudo selector operators Rework generic cosmetic filtering code Add pseudo-operator :matches-attr() Detect invalid usage of combinators in :not() pseudoclass Give more time for viewport to be ready (in popup panel) -- related feedback Handle potentially invalid CSS selector (in logger) Ensure state of more/less in panel reflect locked/disabled sections Isolate generic cosmetic filters from specific ones in generated stylesheet Do not cname-uncloak same-origin network requests Prevent the creation of non-cosmetic extended filters in element picker Fix visual of DOM inspector layer in dark theme mode Improve extraction of tokens from regexes Use placeholders to minimize vertical shifting at page load time Bundled filter lists in releases are not timestamped Ensure procedural filters are applied at least once Code maintenance: replace uDom.js with dom.js Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.12266 github-actions released this 26. Dec 2022 Release notes Remove "AdGuard CNAME-cloaked Trackers" list Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.47.0 released this 13. Feb 2023 Fixes / changes Prevent context menu entries on non-HTTP documents Ignore compilation hints when applying exception cosmetic filters Add support for regex-based values as target domain for static extended filters Add support for regex-based values for domain=/from=/to= options Rewrite static filtering parser uBO doesn't reject cosmetic filters with invalid pseudo-classes/pseudo-elements Make the logger entry dialog modeless Fix missing regex flags Import version 1.2.0 of RegexAnalyzer Set charset to utf-8 for Blob-based injected scriptlets Disallow -abp-... filters if not using #?# Work related to keyboard shortcuts for page reload New network filter option: to=[list of domain names] New network filter option: method=... Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.23.2176 github-actions released this 17. Feb 2023 Release notes Updated filter lists Translation work Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.47.2 github-actions released this 21. Feb 2023 Fixes / changes Support moving logger dialog around with touch events Raise minimum version of Firefox Fix improper invalidation of inline-(font|script) types Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.23.3038 github-actions released this 03. Mar 2023 Release notes Fix an issue which might have prevented some redirect filters from being properly triggered (cd21a0b) Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock 1.47.4 github-actions released this 03. Mar 2023 Fixes / changes Add list for Macedonia; add languages to Persian list Support update period below 1-day Restore behind-the-scene origin for docless secondary resources Refine AST template's regex for hosts file entries Flush cached result when adding to FilterDomainHitSet Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.23.3066 github-actions released this 06. Mar 2023 Release notes Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.48.0 github-actions released this 21. Mar 2023 New Readiness status at browser launch uBO's readiness at browser launch time is a particularly prickly issue on Chromium-based browsers,[1] especially more so since Chromium 110. This leads to numerous reports of "uBlock stopped working", which are simply caused by the fact that at launch time the browser started to load webpages before uBO was ready to filter properly (because the filter lists were not fully loaded in memory). To reduce the number of reports caused by this issue which is outside of uBO's control, uBO's toolbar icon will now reflect its readiness status at browser launch (i.e. make visible to users what has always been happening): A yellowish toolbar icon means that uBO is currently loading all filter lists into memory and as such is not ready to filter properly: If additionally there is a yellowish ! badge while uBO is working toward readiness, this means network requests were fired by the browser which could not be processed by uBO, potentially leading to ads/trackers/etc. not being filtered in some of the already opened webpages: Once uBO is ready to filter properly, a yellowish ! badge on a normally colored toolbar icon means that the current webpage was not filtered properly at browser launch, potentially causing the current webpage to be afflicted by ads/trackers/etc.: To remediate the browser launch filtering issue on a given webpage, you can simply force a reload of that webpage, which as a result will bring back the badge to be rendered as expected: For Chromium-based browsers, it is possible to automate step 4 above by checking the setting Suspend network activity until all filter lists are loaded in Filter lists pane in the dashboard. Caveat: in the past some users have reported this negatively interfered with page loading at browser launch time in some cases (example, example), hence why it is optional and not enabled by default in Chromium-based browsers. With Firefox-based browsers, you should typically only see step 1 and 4 above, unless you disabled the setting Suspend network activity until all filter lists are loaded, which is enabled by default in Firefox. [1] See uBlock Origin works best on Firefox / Browser launch Code viewer Investigating filter issues can be a serious time sink, and to help with this, a code viewer has been added to uBO. The code viewer will automatically beautify HTML/CSS/JS code, which should be an improvement over the browser built-in view-source tool. You can view beautified source code of HTML/CSS/JS resources when clicking the link in a logger entry. Additionally, if the advanced setting filterAuthorMode is set to true, an entry labelled View source code... will be added to the context menu, so that you can view the source code of any page/resource without having to open the logger. Fixes / changes Fix broken http header filtering Prevent dashboard from loading at browser launch until ready Support removing whole lines of text with regex in m3u-prune scriptlet Fix broken filter parsing when prepended with spaces Context of about:blank is that of parent frame (popup option) Add experimental href-sanitizer scriptlet Prevent dialog box from overflowing logger's viewport Make parser take into account filterOnHeaders setting Show a distinct toolbar icon until filtering engines are fully initialized Add source code viewer Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.48.2 github-actions released this 28. Mar 2023 Fixes / changes Ensure astSelectorsFromSelectorList receive expected arguments Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.48.4 github-actions released this 01. Apr 2023 Fixes / changes Fix presumed network filter not being a valid network filter Avoid using ! toolbar icon badge when inconsequential Clear unprocessed requests status on webNavigation reload event Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.23.4076 github-actions released this 07. Apr 2023 Release notes Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.48.8 github-actions released this 12. Apr 2023 Notes This release mostly benefits Chromium-based browsers. I haven't decided yet if it's worth publishing this release on AMO since the main issue addressed here does not affect Firefox. Fixes / changes More aggressively clear the unprocessed-request status Provide explanation of yellowish toolbar icon badge in message section in popup panel Properly detect incorrect usage of CSS combinators Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.49.0 github-actions released this 18. Apr 2023 Fixes / changes Make the toolbar warning timeout configurable Better integrate suspend-network with unprocessed-request Properly detect incorrect usage of CSS combinators Wrap usage of setTimeout in helper for background + auxiliary pages Start using browser.alarms instead of setTimeout() where applicable Fix improper detection of quotes in quoted strings Add matched cosmetic filters in troubleshooting information Add infrastructure for static filter syntax linter Make object equivalent of frame for dynamic filtering purpose Enforce implicit media type for filters using mp4 option Better detect invalid network filter patterns Support view source of "other" type Add widget to filter firewall rows in popup panel Add support for negated hostnames in HTML filters Aggressively auto update assets when at least one is very obsolete Normalize non-ASCII characters in :matches-path() argument Refactor scriptlets injection code Add scriptlet dependencies to reduce code duplication Protect RegExp.prototype.test method in scriptlets.js Properly handle default list status changes in assets.json Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.49.2 github-actions released this 26. Apr 2023 Fixes Reverse usage of browser.alarms Mind rejected promises from vAPI.storage API Properly handle promise rejection from webext.storage.local API Add more checks against unexpected conditions re. assets.json Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.23.5226 github-actions released this 22. Mar 2023 Release notes Fix sticky blocking mode Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.23.6055 github-actions released this 05. Jun 2023 Release notes Fix issue with updateContentScripts API and other fixes Mitigation: Inject CSS user styles to enforce cosmetic filtering Virtuous side effect is to fix cosmetic filtering in Firefox. Refactor content scripts related to specific cosmetic filtering As a result, two annoyances-related lists have been added: EasyList -- Cookies EasyList -- Annoyances Extend scriplet filtering support to all scriptlets Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.50.0 github-actions released this 07. Jun 2023 Fixes / changes Add support to remove attributes in xml-prune scriptlet Fix/improve href-sanitizer scriptlet Add evaldata-prune scriptlet Add support for xhr in xml-prune Add remove-node-text.js scriptlet Add trusted-set-constant scriptlet Support injecting scriptlet in MAIN or ISOLATED world Add trusted-source support for privileged scriptlets (and add replace-node-text scriptlet) Add spoof-css scriptlet Add back AdGuard Tracking Protection Expand/harden some scriptlets Return string when storage.sync.get() promise fails Do not bail out when content-disposition is inline Fix improperly unselecting imported lists Report injected scriptlets in troubleshooting information Fix rendering issue of row-filter icon in popup panel Add "scriptlet" filter expression to logger Fix hostname-detecting regex Add support for sublists in "Filter lists" pane Properly handle converted procedural filters in logger Mind small screen size in asset viewer Add thunderbird as target for installation Add ability to execute aeld scriptlet at a later time Move hostname label to top of popup panel Offer opportunity to update filter lists before reporting issue Fix compiling of negated regex-based to= domain Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_1.0.23.6136 github-actions released this 13. Jun 2023 Release notes No longer experimental Add support for admin configurations Add more specific purposed annoyances-related lists Move hostname label to top of popup panel Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_1.0.23.6195 github-actions released this 19. Jun 2023 Release notes Fix various minor quirks Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 19, 2023 Share Posted August 19, 2023 uBOLite v1.0.23.6195 github-actions released this 19. jun 2023 Release notes Fix various minor quirks Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 19, 2023 Share Posted August 19, 2023 uBOLite v1.0.23.7095 github-action released this 09. jul 2023 Release notes Prevent enabling more filter lists than allowed Add support for highly generic cosmetic filters Properly distinguish trust level when compiling scriptlets Revert back to EasyList Cookie Notices Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 19, 2023 Share Posted August 19, 2023 uBOLite v1.0.23.7135 github-actions released this 13. jul 2023 Release notes Properly enforce generic cosmetic exception filters Add support for permissions= filter option Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 19, 2023 Share Posted August 19, 2023 ublock v1.51.0 github-actions released this 19. jul 2023 Fixes / changes Remove obsolete web_accessible_resources Add missing (deprecated) method to google ima Fix regression in handling of experimental header= filter option Only already normalized CSS selectors can be fast path-compiled Improve compatibility with AdGuard's scriptlets Add static network filter option: permissions Add set-attr scriptlet Do not bail too early when trapping properties in acs scriptlet Fix regression in cloud storage import of "Filter lists" pane Add set-session-storage-item scriptlet Prevent negative position when widget size is greater than viewport size Ensure no negative value for top property of floating widget in logger Add visual hint when not all sublists are enabled Add support for AdGuard's noop (_) network filter option Add "tabless" filter expression for logger output Add support for logical expressions to !#if directive Also added support for !#else Add resource aliases for increased compatibility with AdGuard lists Add compatibility with AdGuard's #%#//scriptlet(...) syntax Also added support for quoted parameters in ##+js(...) syntax Fix syntax highlighter throwing with invalid patterns Prevent creating report until filter lists are updated Add support for sublist at any tree depth in "Filter lists" pane Add set-local-storage-item/trusted-set-local-storage-item scriptlets Add support to remove values in set-local-storage-item scriptlet Fix m3u-prune scriptlet Rework nowoif scriptlet Add trusted-set-cookie scriptlet (requires trusted source) Add set-cookie scriptlet Can't have whitespace in network filter pattern Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 19, 2023 Share Posted August 19, 2023 uBOLite v1.0.23.8106 github-actions released this 10. aug 2023 Release notes Add managed setting to disable first-run page Updated filter lists Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
