trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.42.0 github-actions released this 30. Mar 2022 Fixes: Handle picture > source elements in element picker Use a better value to mark end of sequence of tokens Remove MVPS from stock lists due to inactivity A way to fix serious filter issues as soon as possible Add command to toggle cosmetic filtering Prevent unset minimal width for popup panel Notable commits without an entry in the issue tracker: Discard duplicate lines when merging imported directives Make browser use dark theme built-in widgets in dark theme Add letsblock.it as valid location for subscription links (by @xvello) Introduce experimental procedural cosmetic operator :others() Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.42.2 github-actions released this 02. Apr 2022 Fixes: Do not block root document at launch in Chromium-based browsers Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.42.4 github-actions released this 06. Apr 2022 Fixes: Need local URL to enabled-by-default quick-fixes list This fix prevents uBO from fetching quick-fixes list from remote server the first time it is launched after being installed. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.43.0 github-actions released this 09. Jun 2022 Fixes: Element-picker: Ensure frame background is transparent (by @emilio) Update popup url (by @u-RraaLL) Also dispatch loadend event in case of match Remove support for deprecated "classic" popup panel Prevent CSS transform on element picker layer Report specific filter before generic one Better highlight bad hostnames in static extended filters Avoid using Element.classList in DOM surveyor Improve logger accuracy re. reported injected scriptlets Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.44.0 github-actions released this 16. Aug 2022 New procedural cosmetic filter operator: :matches-media() Commit The argument must be a valid media query as documented on MDN, i.e. what appears between the @media at-rule and the first opening curly bracket (including the parentheses when required). Best practice: Use :matches-media() after plain CSS selectors, if any. Good: example.com###target-1 > .target-2:matches-media((min-width: 800px)) Bad (though this will still work): example.com##:matches-media((min-width: 800px)) #target-1 > .target-2 Fixes: Add 0.5s mp3 redirectable resource Add queue-related initialization code to AMZN shim script Fix dark theme issue in DOM inspector Better detect invalid cosmetic filters Properly "bleed" 3p rules onto 3p-script/3p-frame cells Skip testing context when none present in acis scriptlet Ignore auto-repeat events in ctrl keydown event handler Fix popup panel for Thunderbird Prevent picker from being larger than viewport use WebAssembly-1.0 compliant function names (by @rathann) Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.44.2 github-actions released this 05. Sep 2022 Fixes: Force prodecural cosmetic filtering when explicitly stated Using #?# instead of ## will prevent uBO from potentially using the declarative form of a filter where possible. Fallback to procedural :has() operator when argument is not a valid plain CSS selector Add missing method to shim script Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.44.4 github-actions released this 19. Sep 2022 Fixes: Fix broken :not() operator when forcing parsing as procedural Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.9205 github-actions released this 20. Sep 2022 Release notes Renamed "uBO Lite" from "uBO Minus" Added ability to enable/disable filter lists Added support for i18n Added support for optional permissions through new button in popup panel. Consequences: Support for specific plain CSS-based cosmetic filtering Support for scriptlet-based filtering: json-prune set-constant abort-current-script abort-on-property-read Fixed dark theme issue Improved reliability of cosmetic filtering uBO Lite (uBOL), a permission-less MV3 API-based content blocker. uBOL is entirely declarative, meaning there is no need for a permanent uBOL process for the filtering to occur, and CSS/JS injection-based content filtering is performed reliably by the browser itself rather than by the extension. This means that uBOL itself does not consume CPU/memory resources while content blocking is ongoing -- uBOL's service worker process is required only when you interact with the popup panel or the option pages. uBOL does not require broad "read/modify data" permission at install time, hence its limited capabilities out of the box compared to uBlock Origin or other content blockers requiring broad "read/modify data" permissions at install time. However, [...] uBOL allows you to explicitly grant extended permissions on specific sites of your choice so that it can better filter on those sites using declarative cosmetic and scriptlet injections. To grant extended permissions on a given site, open the popup panel and pick a higher filtering mode such as Optimal or Complete. The browser will then warn you about the effects of granting the additional permissions requested by the extension on the current site, and you will have to tell the browser whether you accept or decline the request: If you accept uBOL's request for additional permissions on the current site, it will be able to better filter content for the current site: You can set the default filtering mode from uBOL's options page. If you pick the Optimal or Complete mode as the default one, you will need to grant uBOL the permission to modify and read data on all websites: The default ruleset corresponds to at least uBlock Origin's default filterset: uBlock Origin's built-in filter lists EasyList EasyPrivacy Peter Lowe’s Ad and tracking server list You can add more rulesets by visiting the options page -- click the Cogs icon in the popup panel. Keep in mind this is still a work in progress, with these end goals: No broad host permissions at install time -- extended permissions are granted explicitly by the user on a per-site basis. Entirely declarative for reliability and CPU/memory efficiency. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.9274 github-actions released this 27. Sep 2022 Release notes Added support for more scriptlet-based filters Added support for procedural cosmetic filtering This should help with removing inline ads on some high traffic sites (ex.: Twitter, Reddit, etc.) and also to prevent anti-content blockers on many sites. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.9285 github-actions released this 28. Sep 2022 Release notes New Added ability to enable broad permissions, i.e. to allow extended filtering for all websites by default. You can enable/disable broad permissions from the Filter lists pane in the dashboard. When broad permissions are enabled, it won't be possible to exclude a specific site to make it permission-less, as the browser does not support permissions exclusion. Consquently the permissions button (Sun icon) in the popup panel is disabled when broad permissions is enabled. At the moment, extended filtering comprises: Specific cosmetic filtering (including procedural cosmetic filtering) Scriptlet injections This will also open the door to properly enforce removeparam=, and redirect= filters in a future version, since these can only work properly when the extension is given broad permissions and wouldn't work with per-site permissions. Fixes Rules with excludedResourceTypes must not block main_frame Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.9305 github-actions released this 30. Sep 2022 Release notes New Added support for removeparam= filter option Consequently, AdGuard URL Tracking Protection (AUTP) has been added to the set of available filter lists. However, removeparam= equivalent DNR rules can only be enforced when granting uBOL broad permissions. If broad permissions are not granted, removeparam= equivalent DNR rules are ignored. Exception removeparam= filters are not supported, and these are present in AUTP and meant to unbreak some websites which are known to break as a result of removing query parameters. This is issue might be mitigated in the future by making the conversion from filters to DNR rules more complicated but this can never replace the accuracy of uBO's filtering engine being able to fully enforce arbitrary exception removeparam= filters. Also, it is not possible to translate regex-based removeparam= values to DNR rules, so these are dropped at conversion time. As with other filters to DNR rules conversion, the converter coallesce many distinct removeparam= filters into fewer DNR rules. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10106 github-actions released this 10. Oct 2022 Release notes New Replaced on/off toggle switch with a slider to select one of four filtering modes: no filtering, basic, optimal, complete. The basic mode is the default mode and does not require permission to read and change data. The optimal mode enables more advanced network filtering (support for removeparam=, and more in the future), specific cosmetic filtering, and scriptlet-based filtering. The complete mode adds generic cosmetic filtering, which support has been added in this release. Any of these filtering modes can be picked as the default one from the Settings pane (except for no filtering), and can also be picked on a per-website basis to override the default mode. A new setting to enable/disable auto-reload of webpages when the filtering mode is changed through the popup panel has been added. Enabled by default. The filter list AdGuard CNAME-Cloaked Trackers has been added. Enabled by default. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10135 github-actions released this 13. Oct 2022 Release notes New Added support for nosiif, nowoif, and aeld scriptlets. This should help fix more popup and anti-blocker issues on various sites. Added uBOL-specific list to fix filter issues arising specifically in uBOL. Fixed uBlock Origin Lite default filter breaks pushbullet extension Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10175 github-actions released this 17. Oct 2022 Release notes New Added support for redirect= filters. As with removeparam= filters, redirect= filters can only be enforced when the default filtering mode is set to Optimal or Complete in the Settings pane, since these filters require broad host permission to be enforced by the DNR engine. redirect-rule= filters are not supported since there is no corresponding DNR syntax. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10185 github-actions released this 18. Oct 2022 Release notes Various internal fixes: Salvage network filters which were previously wholly thrown out due to MV3 being incompatible with entity-based syntax. The salvaged network filters will be at least a partial translation of the original filters to DNR rules. There is currently no way in MV3 to translate entity-based syntax into DNR rules. Fixed uBOL not properly reflecting permission changes when permissions were revoked while the extension was not enabled. Refer to log.txt to see filters which could not be converted due to MV3 incompatibility. At the moment not all discarded filters are necessarily reported in there Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10187 github-actions released this 18. Oct 2022 Release notes Fixed: Fix overwriting valid DNR rules with invalid entries Refer to log.txt to see filters which could not be converted due to MV3 incompatibility. At the moment not all discarded filters are necessarily reported in there Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10207 github-actions released this 20. Oct 2022 New Added ability to handle entity-based CSS and scriptlet injection filters. Entity-based syntax is commonly used by filter list maintainers due to there convenience in real world scenarios. Since the scripting API is not compatible with entity patterns, the entity-related content scripts are injected in all documents and the entity-matching is done by the content script themselves. Given this, entity-based content scripts are enabled only when working in the Complete filtering mode, there won't be any entity-based filters injected in lesser modes. Also, since there is no way to reasonably have access to the Public Suffix List in the content scripts, the entity-matching algorithm is an approximation, though I expect false positives to be rare (time will tell). In the event of such false positive, simply falling back to Optimal mode on the affected site will fix the issue. Regarding network filtering, the DNR API is incompatible with entity-based approach (often used in domain= option), the only workaround is for filter list maintainers to painstakingly expand the wildcard to all required TLDs. Fixed: Fixed the no-filtering mode related rules having lower priority then redirect rules, i.e. redirect rules would still be applied despite disabling all filtering on a site. Fixed improper detection of changes to the generic-related CSS content script, potentially causing undue delays when for example trying to access the popup panel while working in Complete mode. The scripting MV3 can be quite slow when registering/updating large content scripts, so uBOL does its best to call the API only if really needed, but there had been a regression in the recent builds preventing uBOL from properly detecting unchanged content script parameters. Refer to log.txt to see filters which could not be converted due to MV3 incompatibility. At the moment not all discarded filters are necessarily reported in there Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10281 github-actions released this 28. Oct 2022 Mainly just a release with the latest changes to filter lists. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.10295 github-actions released this 29. Oct 2022 Fixed not injecting scriptlets et al. in embedded frames, which could prevent uBOL from properly defusing many cases of anti-blockers. Side note: In general, anti-blockers should be properly defused when using Optimal filtering mode, as the Complete mode may be more likely to cause detection by anti-blocker mechanisms. If you are using Complete mode and an anti-blocker is triggered, try lowering to Optimal mode, this can be done on a per-site basis from the popup panel. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.11056 github-actions released this 05. Nov 2022 Release notes Added support for csp= filters. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.11075 github-actions released this 07. Nov 2022 Release notes Do not merge rules with errors (doing so caused valid rules to be erroneously discarded). Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.45.0 github-actions released this 08. Nov 2022 Fixes: Try to inject scriptlets at onResponseStarted() time Harden scriptlet injections Might fix "ublock origin not blocking ads in the sidebar of Opera GX while using youtube music", to be confirmed Fix improperly detecting ruleset changes re. dynamic URL filtering Add new scriptlet: xml-prune New cosmetic filter parser using CSSTree library Breaking change: filter list authors, please read the commit message Add support to report/filter SVG image elements in element picker Add original Firefox-authored google-ima shim script element-picker: Declare we support both light and dark color-schemes by @emilio Redesign document-blocked page Make popup panel reflect state of the actual blocked page Unescaped escaped commas in regex-based removeparam values Fix redundant calls to extract image data Extend matches-css() to support any pseudo-element Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.45.2 github-actions released this 11. Nov 2022 Fixes Test for unsupported pseudo operators after normalization Mind implicit prelude * element in pseudo operators Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.11165 github-actions released this 16. Nov 2022 Release notes Fixed undue delay in 1st application of cosmetic procedural filters Use Set instead of array to avoid spurious declarative script updates Add support for no-xhr-if/no-fetch-if scriptlets Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 uBOLite_0.1.22.11296 github-actions released this 29. Nov 2022 Release notes Handle multiple windows Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
