trium Posted February 10, 2021 Share Posted February 10, 2021 ublock v1.33.2 github-actions released this Feb 1, 2021 Closed as fixed: After downgrading to 1.32.4, uBO is broken Whitelisting a site on Chromium Edge still blocks resources fetched by service worker Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted March 20, 2021 Share Posted March 20, 2021 ublock v1.34.0 github-actions released this Mar 10, 2021 Closed as fixed: Picker glitch with elements with special characters in their tag name Expose CNAME-uncloaking as a Privacy option in the Settings pane Impossible to add explicit exception for implicit strict blocking Invalid network filters suggested in element picker Use +/- in the popup to indicate whether 3-p frames were blocked Notable commits without en entry in the issue tracker Fix no-scripting switch not working for SVG-based documents Upgrade CodeMirror to 5.59.2 Fix 'adsbygoogle' neutered script Inject procedural cosmetic filterer's code only when needed Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted May 4, 2021 Share Posted May 4, 2021 ublock v1.35.0 github-actions released this Apr 21, 2021 New New filtering ability to remove specific response headers from document resources. Example: example.com##^responseheader(refresh) Only the following response headers are allowed to be removed, anything else will cause the filter to be invalid and discarded: location refresh report-to set-cookie Chromium-based browsers Google's FLoC is defused by default. Websites will be able to use the FLoC API (only if already present), but will be unable to get a result from it -- uBO causes the API to always fail as if there was no FLoC data available. If your Chromium-based browser supports the FLoC API, this is the result you should get with uBO when testing with EFF's "Am I FLoCed?" (assuming you did not disable uBO's "uBlock filters -- Privacy" list): Additionally, uBO causes all websites to opt-out of being part of FLoC calculation by injecting the appropriate response header. You can opt-in to FLoC by creating the appropriate exception filter, see commit message for details. Closed as fixed Block FLoC checks in Chrome/uBO json-prune doesn't remove all properties by full wildcard Notable commits without en entry in the issue tracker Remove advanced setting ignoreScriptInjectFilters Finalize 3rd-party scripts/frames mini-filtering widget Remove advanced setting ignoreRedirectFilters Fix regex used to extract attribute name in element picker Add support for removal of response headers Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted May 4, 2021 Share Posted May 4, 2021 ublock v1.35.2 github-actions released this Apr 30, 2021 Closed as fixed: Firefox 66.0 and earlier. Element picker, zapper and procedural filtering not working on facebook.com Notable commits without en entry in the issue tracker Better handle network error when fetching sublist Stop autoplay for unset media source with no-large-media-elements Use CDN URLs as fall back URLs Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted June 26, 2021 Share Posted June 26, 2021 ublock v1.36.0 github-actions released this 7 days ago Closed as fixed Chromium uBlock does not load adminSettings at first run Firefox Bizarre perf drain when ajaxing in 90,000 DOM nodes in a react component Core Google Tag Manager eventCallback in a populated dataLayer not called Countering a removeparam filter causes page-redirect problem Asset viewer shows no space between !#endif and a comment line in uBlock's list Text in Manage Extension Shortcuts includes escaped ­ In popup, the Reload button becomes immediately hidden if re-enabling the large power button too quickly Notable commits without en entry in the issue tracker Add ability to linger for remove-class scriptlet Add empty array, object to set-constant scriptlet Fix potential exception when casting to string Make googletagmanager_gtm.js an alias of google-analytics_analytics.js Ensure getter/setter are called with proper context Allow filter list subscription through context menu Keep reporting last time "out of date" lists were updated Fix improper hashing of rules in classic popup panel Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted June 26, 2021 Share Posted June 26, 2021 firefox legacy v1.16.4.29 JustOff released this 14 days ago Change Update scriptlets from the upstream Fix 'adsbygoogle' neutered script Add any-delay to timeout/interval boosters Add support for "remove all properties" in json-prune scriptlet Ensure getter/setter are called with proper context Fix potential exception when casting to string Add empty array, object to set-constant scriptlet Add ability to linger for remove-class scriptlet Add missing getResponseInformation() method to neutered JS API Use zero-based index for id Make googletagmanager_gtm.js an alias of google-analytics_analytics.js Update filter lists Update Fanboy's filter lists Update URL of HUN filter list Replace "EasyList China" with "AdGuard Chinese" Removing Fanboy Enhanced Tracking Add fallback URLs for "IRN: Adblock-Iran" Update ABPVN List url to uBO specific support Update filter lists not included in the package Use getWindowlessBrowserFrame for all supported applications Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 7, 2021 Share Posted August 7, 2021 ublock v1.36.2 github-actions released this Jul 6, 2021 Closed as fixed DoS with strict-blocking filter Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 7, 2021 Share Posted August 7, 2021 ublock v1.37.0 github-actions released this Jul 23, 2021 Closed as fixed Core '$popup' not working Service worker "tabless" requests with correct context are still modified when page is whitelisted Back/Forward navigation does not work between Ublock Origin option pages csp_report filter created via logger is marked as invalid Extreme popup blocking - uBo dashboard is blocked when popups are ipv6 fe80::1%lo0 localhost from hosts file is marked as error line Whitespaces are now stripped from blocking-rule URLs, causing rules targeting whitespaces to fail and/or block extremely broadly uBO's dashboard does not refresh custom filters in real-time Element picker/zapper don't work if cosmetic filtering is disabled Logger always highlights first match Static filtering: Cannot prevent my filter from strict-blocking Notable commits without en entry in the issue tracker Provide visual cue in popup panel when base domain has subdomains Disclose where uBO's own filter lists are hosted Add abort-current-script scriptlet Fix spurious error messages when updating contextual menu Make getByName() return an dummy Tracker object Add asap behavior to remove-attr scriptlet Ensure pending callbacks are called only once Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 7, 2021 Share Posted August 7, 2021 ublock v1.37.2 github-actions released this Jul 28, 2021 Closed as fixed: uBO 1.37 breaks at least some sites that use googletagmanager if specific filters in use Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted August 7, 2021 Share Posted August 7, 2021 firefox legacy v1.16.4.30 JustOff released this Jul 20, 2021 Change Limit recursion when parsing URL in document-blocked page Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.38.0 New :matches-path(...) New cosmetic procedural operator, :matches-path(...). See "Add $path modifier of Adguard or any equivalents of this". Node.js A new Node.js package will now published with every release. The package allows to import and use uBO's static and dynamic filtering engines into Node.js. This is currently minimal and a first iteration, and issues regarding the Node.js package are accepted in order to improve usability of uBO's filtering engines in a Node.js package. The ability to run code from a Node.js package also opens the door to have test coverage in uBO. For now the package can be downloaded and unzipped locally. Once installed, you can execute node test in the root of the package to verify that the static network filtering engine works properly. For usage, refer to the test.js, or ublock.js used in Cliqz's benchmark. Since I have little experience with dealing with Node.js environment/packages, thanks to @mjethani for assistance. Removed The setting "Prevent WebRTC from leaking local IP addresses" has been removed since it is no longer necessary in modern browsers, except for Firefox for Android where the issue is still present. Closed as fixed: Remove WebRTC leak prevention $removeparam doesn't work well with UrlEncoded gb2312 Chinese word Scriptlets don't work randomly in Firefox Security: comments can be used to smuggle url() functions into css values Prevent uBO from hiding html or body when matched by a generic cosmetic filter On Android Popup Overlays [or Underlays] On-Screen Navigation Buttons Add $path modifier of Adguard or any equivalents of this The overview panel will not show everything if the uBO's icon is placed in the Firefox overflow menu [patch by @vtriolet] TypeError in noscript-spoof scriptlet with invalid meta refresh URL TypeError when trying to use element picker on plaintext resource Split out core functionality into separate module This is of course an ongoing work for the foreseeable future, but the concrete goal sought in the issue has been reached, i.e. the static network filtering engine can be used as a nodejs module with no external dependencies. Since uBO's codebase now uses JS modules, the minimum version of supported browsers has been increased to Chromium 61, Firefox 60, and Opera 48. Notable commits without an entry in the issue tracker Better lookup all elements under mouse cursor in element picker Add visual hint to grab area of element picker dialog Add no-xhr-if scriptlet Refactor hntrie to avoid the need for boundary cells Fix bad test in WASM version of HNTrieContainer Export the rule-based filtering engines to the nodejs package Rewrite logical expressions for ESLint [patch by @mjethani] Add Makefile [patch by @mjethani] Make uAssets a submodule Ensure compiled sections are ordered in ascending id Fix handling of some procedural cosmetic filters with explicit :scope Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.38.2 Closed as fixed: Regression with important filter option Weird issues with removeparam and negated types Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.38.4 Notable commits without an entry in the issue tracker Update twitch-videoad scriptlet (solution contibuted by @pixeltris) Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.38.6 Closed as fixed [patch by @pixeltris] Fix broken twitch.tv functionality Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.39.0 Important Fixed security issues reported by @hackvertor, see "uBlock, I exfiltrate: exploiting ad blockers with CSS". New A new "Report an issue on this website" icon has been added to the popup panel, to make it easier to report filter issue to volunteers maintaining filter lists. Reporting filter issues through this new feature requires a GitHub account. A new Support pane has been added to the dashboard, to make it easy for users to share technical information about their current uBO's configuration, and consequently make it easier for volunteers to diagnose reported issues. Closed as fixed Chromium Text editing boxes have mouse location issues in higher DPIs Cosmetic filters not working on many websites with "Experimental Web Platform features" in chrome://flags This also fixed "Security: Comments can still be used to smuggle arbitrary CSS", which was reported afterward. Core [discovered by @hackvertor] Security: Cosmetic filters can make background requests using image-set() on Firefox uBlock GA overwrites breaking _link implementation when using a named property [discovered by @hackvertor] Security: Smuggle arbitrary CSS inside cosmetic uBlock filters [discovered by @hackvertor] Security: JavaScript URL injection allowed in query string parameter and redirection to uBlock origin urls Fix not highlighting cases of invalid syntax [patch by @pixeltris] Twitch bypass is circumvented Extension report website adblocking option [patch by @eligrey] Don't assume document.documentElement is non-null Add support for pseudo classes Notable commits without an entry in the issue tracker Do not decode query parameter name when used as token Suggest network filter as best candidate by default Auto-escape commas in removeparam's regexes Simplify handling of valid HTML tags in i18n files Give precedence to negated types in case of ambiguity Fix regression in isBlockImportant() Add refresh-defuser scriptlet Add advanced setting to modify default webext flavor Convert fingerprint2.js scriptlet into a redirectable resource Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.39.2 30. Nov 2021 Closed as fixed 'Address of webpage' textbox needs to be readonly or changes to it need to be monitored Notable commits without an entry in the issue tracker Fine tune new reporting feature Link to filter descriptions (patch by @breyed) Reject generic HTML block filters Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.40.0 22. Dec 2021 Notes: Given that the format of compiled lists and selfie changed, this may cause a noticeable delay for the first launch after updating to 1.40.0 on less powerful devices. For a concrete example, in Firefox for Android I got ~7 seconds launch time after update to 1.40.0. Subsequent launches will be back to normal, for example on mobile I get ~790ms with selfie (and "uBlock filters -- Annoyances" enabled). On more powerful devices, this should be less noticeable if at all. Closed as fixed: Inconsistent line-break in the support pane for Japanese environment Wrong description in Trusted site pane Update nobab Specific-generic cosmetic filter is not disabled by generichide "Your request URL is too long": problem with too many filters and the new "problem with filter lists" button Exceptions do not work when processing requests with long paths Notable commits without an entry in the issue tracker Improve auto-completion in "My filters" editor Store domain= option into trie container's character buffer Partially bring suspendTabsUntilReady out of experimental status Fix potentially reporting wrong context in logger for ghide filters Fine-tune static network filtering engine code Wait for placeholders to be present (in googlesyndication_adsbygoogle.js) Create synthetic event for new windows created from external application Add window.close scriptlet Store regex filter pattern into bidi-trie buffer Ignore pointless trailing *^ in network filters Change compiled list format to a saner block id management Store generic pattern string into bidi-trie buffer Remove classes specialized in handling single-wildcarded patterns Refactoring work in static network filtering engine Have getAll() returns at least one neutered Tracker object Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.40.2 26. Dec 2021 Closed as fixed: localhost: breakage Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.40.4 02. Jan 2022 Notes This release is intended for Chromium-based browsers only. Closed as fixed: Chromium Better test for presence of browser extensions API Notable commits without an entry in the issue tracker: Offer a way to disable tab-reloading at launch on Chromium-based browsers Fix broken suspendTabsUntilReady for Chromium-based browsers Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.40.8 11. Jan 2022 Fix selfie with invalid data in some circumstances (reported internally by @gwarser) Fix bad release 1.40.6: the previous release should have forced an invalidation of existing selfie, I overlooked this. Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.41.0 08. Feb 2022 Firefox: Rejected by Mozilla Add-ons Team. The reason is that I did not provide an exact link to the origin of the hsluv-0.1.0.min.js library used by uBO to implement dark theme (uBO's About page does credit the author of the library). A README has been added to 1.41.2 to disclose the exact origin of the library. Notes Minimum supported browser versions has been bumped up: Firefox 68 Chromium 66 Consequently, Opera 53 New Dark mode Support for dark mode added to the Settings pane, under the (new) Appearance section: The new setting can be either Auto, Light, or Dark. In addition, there is a new setting to control the accent color used by uBO throughout its user interface: For example, changing the accent color changes the look of the popup panel: Behavior at browser launch A new setting in "Filter lists" pane to control whether uBO should wait for all filter lists to be loaded before unsuspending network activity. By default, at browser launch uBO waits for all filter lists to be loaded before unsuspending network activity so as to ensure web pages are properly filtered at launch. The new setting allows to opt out of network activity suspension at launch, i.e. allowing web pages to load without waiting for filter lists to be fully loaded, of course at the cost of potentially not filtering properly those web pages. Closed as fixed: Chromium-based browsers Conflicted with another extension called WebRTC Protect Core Logger incorrectly reporting header= filters Picker is broken by quotation mark in attribute Use "…" instead of "..." Fix bad detection of unnecessary trailing | Unexplained popup block on streamlare Scrollbars appear in click2load.html Element Zapper denies on a specific website Prevent uBO from hiding html or body when matched by a generic cosmetic filter (final fix) Dark Mode support Notable commits without an entry in the issue tracker: Add a redirectable script that sets canRunAds true Related commit (contributed by @Yuki2718) Raise minimum versions of browsers Improve dealing with ambiguity in regex-based-looking network filters Improve google-analytics shim Fix regression causing regex-based filters to be case sensitive Add shim for FingerprintJS (aka Fingerprint v3) Disable the suspending of network requests when installing the extension Do not select background images as best candidate in picker Add "blockedDetails" section to troubleshooting information Remove "ABP X Files" from stock filter lists Add setting to control suspension on network activity at launch Make FilterJustOrigin derive from FilterOriginHitSet Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted February 11, 2022 Share Posted February 11, 2022 ublock v1.41.2 10. Feb 2022 Notes Mozilla Add-ons Team rejected 1.41.0 and disabled the submission, and this breaks the history of uBO's versions for Firefox. See Release 1.41.0 for complete release notes for 1.41.2. Closed as fixed: Textarea focus border is slightly cut off from the sides in the static filter pane in the logger Notable commits without an entry in the issue tracker: Use theme-related shade of red for DOM inspector Fix bad font size in DOM inspector Fix visually glitchy Create button in element picker Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.41.4 github-actions released this 16. Feb 2022 Notes As per various feedback, the new setting "Suspend network activity until all filter lists are loaded" is now unchecked by default in Chromium-based browsers. You will have to explicitly enable it to restore the attempt at mitigating Chromium-based browsers inability to reliably block network requests at launch. Closed as fixed: Fix improper handling of match-all removeparam [Chromium] Rework behavior of "Suspend network activity until ..." Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.41.6 github-actions released this 18. Feb 2022 Fixes: Use unspoofable MessageSender.origin to determine privilege level of ports Revert "Prevent highly generic cosmetic filters from affecting html/body elements" Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted July 1, 2023 Share Posted July 1, 2023 ublock v1.41.8 github-actions released this 23. Feb 2022 Fixes: Fix testing a 8-bit integer instead of a 32-bit integer in PSL library Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
