Moderators hazelnut Posted January 8, 2012 Author Moderators Share Posted January 8, 2012 Now officially supported by Firefox http://waterfoxproj.sourceforge.net/news/26/15/Powered-by-Mozilla-Waterfox-9-0-1/ Support contact https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 support@ccleaner.com Link to comment Share on other sites More sharing options...
David_L Posted January 9, 2012 Share Posted January 9, 2012 I gave Waterfox a try and set it as the default browser, but now every time I open Waterfox or Firefox I get the pop-up that it's checking add ons for compatibility before the program will open. Anyone know what I need to do to make it not do that? I wonder if it's because I'm using Waterfox 9.0 and Firefox 9.0.1? Do the two versions need to be the same? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 9, 2012 Share Posted January 9, 2012 Yes they do, but you should be able to get Waterfox 9.0.1 from the internal updater. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 9, 2012 Moderators Share Posted January 9, 2012 I hope the Devs see this and try to shoehorn waterfox into the firefox/mozilla ccleaner ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 10, 2012 Share Posted January 10, 2012 Why? It has been cleaning fine for me, as it uses the firefox profile. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Corona Posted January 10, 2012 Share Posted January 10, 2012 I'm almost tempted to use Waterfox. But how is it with add-ons/extentions? Link to comment Share on other sites More sharing options...
nodles Posted January 10, 2012 Share Posted January 10, 2012 I'm almost tempted to use Waterfox. But how is it with add-ons/extentions? http://waterfoxproj.sourceforge.net/faq Do all my Add-Ons work? Yes! Add-Ons work on any version of Firefox, on any platform. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 10, 2012 Share Posted January 10, 2012 *so long as they're 64bit. 32bit flash/java, for example, wont work in waterfox. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted January 10, 2012 Share Posted January 10, 2012 Ah ok. Though both are available also as 64bit (Java/Flash). Link to comment Share on other sites More sharing options...
Alan_B Posted January 11, 2012 Share Posted January 11, 2012 Neither I nor Mozilla are confident that any Mozilla based browser will be compatible with any add-ons/extensions. Every time they push through an update they may disable extensions that they have outgrown and you may have to wait for the extension developer to catch up. I like Pale Moon because it is taking more care and time to accept Mozilla "improvements". Perhaps Waterfox has the same merits. In my view any extension has a better chance of compatibility with both Pale Moon and Waterfox than it has of keeping up with Firefox's mad rush to infinity Link to comment Share on other sites More sharing options...
nodles Posted January 11, 2012 Share Posted January 11, 2012 Well, never had problems with Mozilla/Firefox + addons, though mainly using just Adblock+ & NoScript at the moment. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 11, 2012 Share Posted January 11, 2012 I have addon compatibility checking shut off :3 I never run into issues running "outdated" addons winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
