TERRY HOSE Posted July 4, 2020 Share Posted July 4, 2020 Hi Is it normal for defraggler to take a long time on first use Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 5, 2020 Moderators Share Posted July 5, 2020 Yes, especially with todays large drives. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators nukecad Posted July 5, 2020 Moderators Share Posted July 5, 2020 As Nergal said. It also depends on what you you mean by '"a long time". (It could take hours on a highly fragmented multi-terabyte disc). Main factors: How big is the drive you are defragging. (Bigger drives take longer for a full defrag). How much free space is on the drive. (The less free space the longer a defrag will take). What percentage fragmentation did Defraggler report it had before starting. (The higher the fragmentation the longer it will take). Other factors that will have an effect: The amount of ram you have free. Your disc access speed. Your CPU speed. If you are doing anything else, or the computer is running something in the background, at the same time as defragging. PS. Once you have done the first full disc defrag then in future it's much faster to do a 'File Defrag'. Analyze>View Files>select all files found (by ticking the box in the top left corner)>Defrag Checked Whether to do full disc or file defrag depends on why you are defragging. The different methods do different things. You don't realy need a full disc defrag unless you are running short of disc space. A file defrag gets your files into one piece so that they load (slightly) faster. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 5, 2020 Moderators Share Posted July 5, 2020 It's well known enough by now for years that Defraggler is a bit slow, however something else to also consider is if the hard disk uses SMR technology (which has gotten hard disk manufacturers into legal trouble). I'd imagine an SMR hard disk could cause a full defrag/full optimization to take a long time. Link to comment Share on other sites More sharing options...
Willy2 Posted July 6, 2020 Share Posted July 6, 2020 - Switch off "System Restore". This will reduce the time needed for a full defrag of your HD. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
