PS3 Posted July 9, 2006 Share Posted July 9, 2006 gday everyone, i am not sure whether what i am about to tell you is a software problem or hardware but i believe its a software problem. if not then could someone move it to the hardware section? when i plug in my MP3, the computer recognises it and allows me to open the folders. but when i do, theres nothing on the MP3. sometimes it doesnt even allow me to gain access into the MP3. i have attached a photo to what it says. what should i do? is it a crap MP3 player or is there something wrong with all of my computers? (3) thank you. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted July 9, 2006 Moderators Share Posted July 9, 2006 Did you format the mp3 player first? I had to do that with one of mine although I don't know if it applies to all types. Apparently ( after using google) it means it's empty. Have you been able to play your music even once? Did you have any problems with your last mp3 player? Which model, the T19, or P310 perhaps? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
PS3 Posted July 9, 2006 Author Share Posted July 9, 2006 if i formatted the MP3 wouldnt that mean i loose all my information? i can still play the music but the computer just cant detect any folders on the MP3. this is my first MP3 player. i gave it to my cousin when i bought my ipod nano. got no clue what model it is. Link to comment Share on other sites More sharing options...
JohnDemolition Posted July 9, 2006 Share Posted July 9, 2006 i believe that if you format, you do lose all the data. however i'm not 100% sure. so just format, readd the files(if it deleted them), and you're good to go. Link to comment Share on other sites More sharing options...
PS3 Posted July 9, 2006 Author Share Posted July 9, 2006 ive got important data on there that will take me weeks to re-do. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 9, 2006 Moderators Share Posted July 9, 2006 I'd say visit the manufacturer website and look for an updated driver, and/or firmware version that may fix your problems. And formatting would most likely mean you'd lose everything that's already on the device, however if it isn't a driver or firmware issue that may be all you can do to get it to work properly again. Link to comment Share on other sites More sharing options...
PS3 Posted July 9, 2006 Author Share Posted July 9, 2006 firmware? Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted July 9, 2006 Moderators Share Posted July 9, 2006 PS3, You really need to know the name and model make if you are going to google for driver and firmware updates. First get that info. I have had a quick look around for Teclast, it's not easy as they are nearly all Chinese sites and don't translate well. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
zaphirer Posted July 9, 2006 Share Posted July 9, 2006 Format means EVERYTHING is deleted and isn't quite the best form of action. I think VOICE means that you have a folder, designed for recordings by the microphone. Does your MP3 player have a mic? If so try recording something (which means a file would be written there) and check again. Link to comment Share on other sites More sharing options...
PS3 Posted July 10, 2006 Author Share Posted July 10, 2006 PS3, You really need to know the name and model make if you are going to google for driver and firmware updates. First get that info. I have had a quick look around for Teclast, it's not easy as they are nearly all Chinese sites and don't translate well. chinese is it? i bought this in australia in a back way street. ok. when im home i will tell you the model number of it. Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted July 10, 2006 Share Posted July 10, 2006 if its a samsung, that could be the problem. it mysterily works when it wants to. i think its a windows update. i'd update windows and try it again or try it on a different computer. Link to comment Share on other sites More sharing options...
zaphirer Posted July 10, 2006 Share Posted July 10, 2006 if its a samsung, that could be the problem. it mysterily works when it wants to. i think its a windows update. i'd update windows and try it again or try it on a different computer. Samsung isn't Chinese. Link to comment Share on other sites More sharing options...
PS3 Posted July 10, 2006 Author Share Posted July 10, 2006 if its a samsung, that could be the problem. it mysterily works when it wants to. i think its a windows update. i'd update windows and try it again or try it on a different computer. samsung isnt chinese. its korean. didnt you read my first post? it said i tried it on all my computers (3) <- - - meaning i have tried on 3 different computers. and its a telfast by the way. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted July 10, 2006 Moderators Share Posted July 10, 2006 and its a telfast by the way. Help me out here ps3, it says teclast in your thumbnail Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
PS3 Posted July 10, 2006 Author Share Posted July 10, 2006 i was telling neighberaaron that its telfast. i will tell you tomorrow. the first thing. thank you for helping and understand. Link to comment Share on other sites More sharing options...
PS3 Posted July 14, 2006 Author Share Posted July 14, 2006 ok. i finally found the MP3 player. lost it for a few days. this is what it says on the player, Telcast MP3 Player Model: TL-P310 MP3 Player/Voice Recorder BATT:AAAX1 Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted July 14, 2006 Moderators Share Posted July 14, 2006 Here is the only page I could find, it translates from chinese so wait a moment for it to load. There is a download button as you can see for the latest driver just a bit down the page in the middle.... it's up to you! http://translate.google.com/translate?hl=e...6lr%3D%26sa%3DN P.S. It's Teclast !! Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
PS3 Posted July 14, 2006 Author Share Posted July 14, 2006 thanks for that and i know its telcast. so, what do i do? download the drivers and install it on the desired computer? Link to comment Share on other sites More sharing options...
