pasword required
Fatfrankie88
when cleaning in El Capitan  with the latest downloaded version 1.15.507 i am constantly asked for my admin password too allow changes to be made... twice to complete the clean.
This happens every time i use cleaner since it won't store the permission granted by my password to change system requirements, enabling Cleaner to do it´s cleaning
The previous version required this password only once during the first scan when newly installed and never again...it stored the permission granted by my password
How can i fix this ...it´s very annoying to have to enter my admin password twice every scan
Link to comment
  • Moderators
Since there are only a few Mac users in the forum,  it might take a bit for one of us to help you.  I've alerted the admin/dev team on this topic, that should get some eyes on it.
Link to comment
I just downloaded the new free version for my mac and I am being asked for my password every time, which is very annoying. I liked the older version much better. Can this issue be fixed?
Thanks for any and all help.
Link to comment
  • Moderators
See my reply right above yours
Link to comment
I have the same issue--every time I run the program I have to enter my password twice before it finishes.
Link to comment
I had the exact same issue as Fatfrankie88 and bflyfish this must be a bug with 1.15.507. I could not tolerate it so went back to version 1.14.451 on my MacBook.
Hopefully Piriform will fix this for the new Mac version of CCleaner.
Link to comment
CCleaner Mac 1.15.507 High Sierra
Problem 1: Password Nag .  CCleaner wants to make changes. Enter your password to allow this. Exact same reported above with debut of 1.15.507 issue constantly asking for Password. Then does it again. CCleaner wants to make changes. Enter your password to allow this. Happens every session & attempt.
Problem 2: Safari Nag. With Safari closed, and never opened this week.Safari needs to close down an internal process it will restart after. Do you wish to continue? Cleaning, reveals Safari -Session 0KB. Happens every session & attempt.
Problem 3: CCleaner running extremely slower.
Sure it may take awhile, because they don't check the Forum.  But this totally unacceptable, on new Owner Avast. How can somebody be so lazy to not test their work? And not want to monitor their Forums? This should never happen. Just ruins the Avast name & CCleaner reputation.
Nergal your a nice Volunteer who has been here before Avast, for years. They need to give you an better direct email contact, for embarrassing events, as this event has two easily verified documented problems.This version needs to be pulled ASAP, by Avast. I'd like to pull it, but then I get more nags saying my version 114 is out of date. I suggest Avast pull 115 immediately. Re upload 114 to save face. Don't let anybody get the 115 version.
CCleaner 114 came out September 2016, this much time to verify a new version, rather simple run it twice and you'll know. Nine months and we get this. Luckily I saved my 114 version. Because all the Windows CCleaner users on every Forum are warning everybody be careful its just a matter of time before Avast builds the app to their advantage, such as the Privacy opt out of sharing usage data with third parties for analytics purposes enabled by default on Windows version. People want the Pro version left alone, do your Avast analytics on the Free version, you'll make more money.
So sorry for a nasty reply, but come on, Avast people that write code, run the app twice please before you release it to the Public. Take care of Nergal and pay him.
Link to comment
  • Moderators
uuu we do bring posts like yours to the direct attention of Piriform.
However after that... it's up to them :(
We having been bring the Mac issues to their attention for some time now.
CCleaner documentation can be found here
https://www.ccleaner.com/docs/ccleaner
Support contact
support@ccleaner.com
Link to comment
have they more important things to do than take care of their customers??...hard to come by and harder to keep!!
Link to comment
Hey guys, i run High Sierra and am having the same issue. I have tried system preferences as well as running automator but have had no luck would be great if someone had an solution for this. I do understand it is a security issue which although annoying is better to type and retype password than have a security issue.
Link to comment
Noticed that in the latest version 1.15.507 (versus the previous version 1.14.451) they have added "Monitoring" under "Options". Unfortunately the "Enable system monitoring" check box is checked by default and the user is unable to uncheck this feature.
IMHO, so every time CCleaner is run it is asking for the "Admin password" to initiate the SYSTEM MONOTIRING feature.
Piriform needs to uncheck this feature to remove the hassle of having to enter the password twice to run CCleaner each time.
Please note that I am using the "Free version" of 1.15.507.
Until the problem is fixed I have gone back to the previous version and had to uncheck "Check for updates". Otherwise that is going to be a pop-up asking me to upgrade every time I run CCleaner.
Help to resolve this latest kink in an otherwise flawless piece of software will be greatly appreciated.
Thank you.
Link to comment
Come on Piriform we and many more like us are loyal Mac users of your product please get this corrected. We love your product and want to be able to keep using it as it once was..
Your help is greatly appreciated.
Link to comment
Hi, I am running MacOS High Sierra 10.13.4 on a 2015 MacBook Pro and have been using Cleaner Free for years, so I am very familiar with using it. After installing the latest version 1.15.507 I have 2 problems.
First, I have the issue mentioned by many above, where I have to enter my computer password TWICE during each and every scan.
Second, even though my banking cookies are still in the Cookies to Keep list in Options, after the update, CCleaner erases  the bank card numbers every time I do a clean. This has never happened before Version 1.15.507. I don't save passwords obviously, but having to enter all the numbers and renter all my info to the banking sites after each clean is totally unacceptable. I use Safari Version 11.1 as my browser.
These actions are both suspicious and annoying.
I am currently looking for another alternative cleaner, but I would rather stay with CCleaner, if they can QUICKLY fix these issues.
Thanks,
Phil
P.S. Just reloaded CCleaner Free Version 1.14.451 and both of these issues were immediately corrected!
Edited by PhilipRT
Updated information
Link to comment
Thanks,
Phil
Phil, I am having the same issue on my MacBook Pro. Will download previous version of CC until password issue is corrected.
Steve
Link to comment
Items I have noticed;
Requires password entry when cleaning certain system files.
Monitoring cannot be disabled, but not sure if it actually does anything anyway. I only have the free version.
Secure deletion is unavailable due to incompatibility with OS. I am on 10.13.4
I don't believe the application cleans any slower, I just don't think the UI responds in real time.
Link to comment
Here the answer email from piriform about this theme:
Quote
Hello,
Thank you for your email, sorry you are having problems with CCleaner Mac.
This occurs when you are Cleaning ‘Safari Cookies’ or ‘Directory Service Cache’, so if you have both of those rules checked when running a clean you will be asked twice to enter your password. We’re doing this so that we can clean things properly and thoroughly, as you’d expect from CCleaner
If you have any further questions just email me back.
Kind regards,
Andrei | CCleaner Support - London, UK
I wrote back and asked for giving further this issue to the developer department.
Link to comment
the 2nd answer from piriform:
Quote
Hello,
Rest assured that they will try to remove this issue from the software so you won't get annoyed by it anymore.
Is there anything else you would like us to help you with ?
Kind regards,
Link to comment
Register a new account
Sign in
Important Information
