cleanerjm 0 Posted April 17, 2017 Share Posted April 17, 2017 On 4/25/2018 at 07:21, Stephen Piriform said: Hey guys, I am starting this new thread and will merge all existing reports into this one so we can collate information about the issue and work on a fix. Windows 10 was tested prior to release, so this seems like something specific to the system setup. I will post updates in this post at the top of this thread. This thread is not for any of the following reported issues, please use another existing thread for: Issues with Chrome Profiles after cleaning Issues running CCleaner on Windows Server 2008 This thread is for reporting and discussing the issue detailed below: On Windows 10, when running a clean, CCleaner crashes/becomes unresponsive Hi. Been using CCleaner for many years without any problem until 3-4 days ago. If I run the cleaning scan, at about mid 95-96% progress, it stops working. A pop up window that reads "CCleaner has stopped working. A problem caused the program to stop working blah blah blah..." appears with a "Close Program" button. I believe this problem started happening after a windows update around that time. I uninstalled Ccleaner, rebooted laptop, and installed a new copy . Problem still remains. I'm using Windows 8.1 64-bit. Thanks for any help in advance. Link to post Share on other sites
cleanerjm 0 Posted April 17, 2017 Author Share Posted April 17, 2017 Ok, I found a quick fix below, which was for Windows 10. So the problem is happening at least on both Windows 8.1 and Windows 10. I unchecked "Mozilla -> compact databases" and the cleaner is working fine now. https://forum.piriform.com/index.php?showtopic=47979 Hope you can release a fix soon. Thanks again. Link to post Share on other sites
Moderators mta 0 Posted April 19, 2017 Moderators Share Posted April 19, 2017 (edited) @cleanerjm, v5.29 was just released which should fix the Compact Database issue. Edited April 26, 2018 by Stephen Piriform Removed advertising post and reference to it. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to post Share on other sites
rockon 0 Posted April 24, 2018 Share Posted April 24, 2018 Just installed latest update 5.42.6495 (64bit) to windows 10, and when trying to start just get the error message "ccleaner is not working". uninstalled and reinstalled still the same. Help!! Link to post Share on other sites
jletour 0 Posted April 24, 2018 Share Posted April 24, 2018 (edited) I am having the identical problem Is there a fix for this? Edited April 24, 2018 by jletour typo Link to post Share on other sites
Mark k 0 Posted April 24, 2018 Share Posted April 24, 2018 I'm having the same issue as well. I renewed my subscription. When I start Ccleaner, the screen shows up and shows what needs to be cleaned, but when I toggle the clean button, the screen disappears and does not clean anything. I'm using windows 7. Any suggestions? Link to post Share on other sites
Admin Stephen CCleaner 1 Posted April 25, 2018 Admin Share Posted April 25, 2018 Hey guys, I am starting this new thread and will merge all existing reports into this one so we can collate information about the issue and work on a fix. Windows 10 was tested prior to release, so this seems like something specific to the system setup. I will post updates in this post at the top of this thread. This thread is not for any of the following reported issues, please use another existing thread for: Issues with Chrome Profiles after cleaning Issues running CCleaner on Windows Server 2008 This thread is for reporting and discussing the issue detailed below: On Windows 10, when running a clean, CCleaner crashes/becomes unresponsive Link to post Share on other sites
sylt21 0 Posted April 25, 2018 Share Posted April 25, 2018 Identical problems, 1. PC Win10Pro, 64 bit: the cleaner runs perfectly well, no problems; 2. Laptop Win10Pro, 64 bit: the cleaner crashes, when you press the 'clean' buttom. If you 'analyze' first and than try to clean, the cleaner freezes; 3. Laptop Win10Pro, 32 bit: The 'analyze' works, the cleaner freezes. AV-system: Kaspersky Link to post Share on other sites
MirceaForce 0 Posted April 25, 2018 Share Posted April 25, 2018 do you have the same problem ? i did this video for better understanding https://drive.google.com/file/d/1_ayqOcGC8HvRTtvhhT4ku7TRZZG3PV3r/view if it's general problem when we have a fix ? also unsing kis 2018 Link to post Share on other sites
pk2 0 Posted April 25, 2018 Share Posted April 25, 2018 @sylt21: can you please create a process dump of CCleaner.exe on your 32-bit machine when ccleaner freezes? When it happen, please run Task Manager, find CCleaner.exe process, right click and create a dump. Can you please upload dump somewhere? Thanks. @others (64-bit users): please download procdump.zip (https://download.sysinternals.com/files/Procdump.zip), close running CCleaner UI and run procdump.exe -e 1 -f "" -x "C:\Program Files\CCleaner\CCleaner64.exe" - it should create a dump file when CCleaner crashes when you press "Clean" button. Thanks! Link to post Share on other sites
MirceaForce 0 Posted April 25, 2018 Share Posted April 25, 2018 19 minutes ago, pk2 said: @sylt21: can you please create a process dump of CCleaner.exe on your 32-bit machine when ccleaner freezes? When it happen, please run Task Manager, find CCleaner.exe process, right click and create a dump. Can you please upload dump somewhere? Thanks. @others (64-bit users): please download procdump.zip (https://download.sysinternals.com/files/Procdump.zip), close running CCleaner UI and run procdump.exe -e 1 -f "" -x "C:\Program Files\CCleaner\CCleaner64.exe" - it should create a dump file when CCleaner crashes when you press "Clean" button. Thanks! i don't have crashes Link to post Share on other sites
pk2 0 Posted April 25, 2018 Share Posted April 25, 2018 38 minutes ago, MirceaForce said: i don't have crashes you actually have -- I looked at your video (thanks for it!) and CCleaner just disappears (= crashed); you can verify it from "Task Manager" if CCleaner is removed from the list, or not Link to post Share on other sites
MirceaForce 0 Posted April 25, 2018 Share Posted April 25, 2018 if what you say is true...i did not see anything even maintenance of windows 10 ..yes when i click clean is just like exit the program..yes is disappear from task manager...where did you see the crash ? p.s i did install ccleaner 5.41 works perfect .. but is strange that without kaspersky internet security 2018 in the process it works .... this new version worked with kis 2018 but after the av update today ccleaner did no longer worked but only when you click continue cleaner close no crash dump or something like that...i did submit to kaspersky support what could it be ? https://forum.kaspersky.com/index.php?/topic/393838-kis-2018-update-today-25042018-close-ccleaner-when-execute-comand-clean/ Link to post Share on other sites
Moderators Nergal 0 Posted April 25, 2018 Moderators Share Posted April 25, 2018 Can you white list ccleaner in Kaspersky, idk I don't run it, but just spit-balling. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
MirceaForce 0 Posted April 25, 2018 Share Posted April 25, 2018 7 hours ago, sylt21 said: Identical problems, 1. PC Win10Pro, 64 bit: the cleaner runs perfectly well, no problems; 2. Laptop Win10Pro, 64 bit: the cleaner crashes, when you press the 'clean' buttom. If you 'analyze' first and than try to clean, the cleaner freezes; 3. Laptop Win10Pro, 32 bit: The 'analyze' works, the cleaner freezes. AV-system: Kaspersky do you have kaspersky on all systems ? or only on one with the problem ? Link to post Share on other sites
MirceaForce 0 Posted April 25, 2018 Share Posted April 25, 2018 13 minutes ago, Nergal said: Can you white list ccleaner in Kaspersky, idk I don't run it, but just spit-balling. sorry i did not understand you white list you mean to exclude in kaspersky interface if this your point i did this ... can you be more specific to this problem ? Link to post Share on other sites
wisua 0 Posted April 26, 2018 Share Posted April 26, 2018 just purchased ccleaner 5.42.6495 (64 bit). I'm a computer novice. get "ccleaner has stopped working". Any workarounds? Link to post Share on other sites
Moderators Nergal 0 Posted April 26, 2018 Moderators Share Posted April 26, 2018 2 hours ago, MirceaForce said: sorry i did not understand you white list you mean to exclude in kaspersky interface if this your point i did this ... can you be more specific to this problem ? Yes that's what I meant ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
MirceaForce 0 Posted April 26, 2018 Share Posted April 26, 2018 6 hours ago, Nergal said: Yes that's what I meant no fix i did try this already before you posted only exit the app will fix... so what is the cause ? ? Link to post Share on other sites
jletour 0 Posted April 26, 2018 Share Posted April 26, 2018 I uninstalled the latest version because it would not run properly. Reloaded version 3.41, it works just fine. Link to post Share on other sites
MirceaForce 0 Posted April 27, 2018 Share Posted April 27, 2018 18 hours ago, jletour said: I uninstalled the latest version because it would not run properly. Reloaded version 3.41, it works just fine. with 5.41 it's all ok 3.41 too old Link to post Share on other sites
d4k0 0 Posted April 28, 2018 Share Posted April 28, 2018 On 25.4.2018 at 20:38, pk2 said: @others (64-bit users): please download procdump.zip (https://download.sysinternals.com/files/Procdump.zip), close running CCleaner UI and run procdump.exe -e 1 -f "" -x "C:\Program Files\CCleaner\CCleaner64.exe" - it should create a dump file when CCleaner crashes when you press "Clean" button. Thanks! I created a dump file using procdump: https://app.box.com/s/scqvm6x0kpgj40lie7s1g9f6r0t6inf0 The error code is 0xC0000374. My OS is Windows 10 1709 Build 16299.402 x64 and I use Kaspersky Anti-Virus 18.0.0.405(g). If I close Kaspersky completely, CCleaner works; whitelisting CCleaner in Kaspersky has no effect. In a virtual machine with Windows 10 x86 and Avast I don't have this problem. Link to post Share on other sites
MirceaForce 0 Posted April 28, 2018 Share Posted April 28, 2018 did you report to kaspersky support ? Link to post Share on other sites
sylt21 0 Posted April 29, 2018 Share Posted April 29, 2018 It´s strange. May be it´s a KIS-problem ... may be in connection with Win10. 1. PC Win10 x64 + KIS + ccleaner-update = so long - no problems at all. 2. Laptop Win10 x84 + KIS + ccleaner-update = the cleaner froze - when the cleaning process was started. But now = today everything works pretty fine. Nothing was changed! - There was an invisible touch! 3. Laptop Win10 x64 + KIS + ccleaner-update = the cleaner still shuts down - when the cleaning process is started. If KIS is closed the cleaner works. If KIS is reactivated during the cleaning process, the cleaner carries on and finishes its work. Restarting the cleaning process again with KIS the cleaner crashes ... or a window appears with the message that there is a problem with Win10 and therefore the cleaner has to be shut down. - Still waiting for the invisible touch for that Laptop. Link to post Share on other sites
d4k0 0 Posted April 30, 2018 Share Posted April 30, 2018 On 28.4.2018 at 23:56, MirceaForce said: did you report to kaspersky support ? No, not yet, but someone on the Kaspersky forums did. I saw that you also replied there. Link to post Share on other sites
