Winapp2.ini additions
Winapp2.ini
New Entry
[Auslogics Registry Cleaner 5*]
LangSecRef=3024
Detect1=HKLM\Software\Auslogics\Registry Cleaner\5.X
Detect2=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X
Default=False
Warning=This will remove your backups, and you will be unable to undo any changes you made with Auslogics Registry Cleaner.
FileKey1=%CommonAppData%\Auslogics\Registry Cleaner\5.X\Rescue\Auslogics Registry Cleaner|*.*|RECURSE
FileKey2=%LocalAppData%\VirtualStore\ProgramData\Auslogics\Registry Cleaner\5.X\Rescue\Auslogics Registry Cleaner|*.*|RECURSE
RegKey1=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey2=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey3=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey4=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey5=HKLM\Software\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.LastScan
RegKey6=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey7=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey8=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey9=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey10=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\5.X\Settings|RegCleaner.AppLogic.LastScan
Link to comment
Hence will not be added, we don't remove reg cleaner backups, for obvious reasons
Link to comment
Revised Entry
Removed the following. These logs are needed to update/uninstall the program.
%CommonAppData%\Hauppauge|*.log
%Public%\WinTV\Installation Log|*.txt
Changed the name and the Detect path to make it universal for all WinTV versions (6, 7 & 8).
[Hauppauge WinTV*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Hauppauge
Default=False
FileKey1=%SystemDrive%\|hcwDriverInstall.txt
FileKey2=%Public%\Videos\Pause Buffer|*.*|RECURSE
FileKey3=%Public%\WinTV\Logs\minidump|*.*|RECURSE
Link to comment
  • Moderators
I agree, but how about the many similar entries that are already there?
Unknown, but as community members mention/notice them they should be excised from the template.
:lol:
winapp2.com needs a page of functional but ultimately rejected/removed entries for those "bad boys" who don't wanna foller the rulez
Link to comment
:lol:
I used to maintain something similiar (mostly language files, but a few "not suitable for common usage"/"power user" entries like Software Distribution) but ultimately it was accessed very infrequently so I stopped :lol:
Link to comment
  • Moderators
And that kids is why the "rules" are there (hint hint to those who publicly and/or privately told me that they thought I was being strict whilst I opined publicly to advise caution on some proposals ;P <----means I'm joking no need for public nor private rejoinder)
Link to comment
Here are some entries that remove registry cleaner/uninstall backups. In fact, all of the entries that remove backups should be removed. The entries that have a warning should also be removed.
Acebytes
Ace Utilities
AMUST Registry Cleaner Undo Data
Auslogics (All programs)
AVG PC TuneUp & TuneUp Utilities (Backups)
CleanMyPC Registry Cleaner
Eusing Free Registry Cleaner Backups
Glary Utilities (Backups)
IObit Advanced SystemCare (All)
jv16 PowerTools (All)
jv16 PowerTools Reg Compact Backups
NirSoft RegScanner Backups
Perfect Registry
RegClean Pro
RegCleaner 4.3
Registry Clean Expert
Registry First Aid (Backups)
Registry Mechanic
Reg Organizer (Backups)
Revo Uninstaller Backups
System Mechanic
SystemTuneUp
Total Uninstall Backups
Total Uninstall Free Backups
TweakNow PowerPack 2005
Uniblue Registry Booster 2(Backups)
Uniblue Registry Booster(Backups)
WinASO Registry Optimizer (Backups)
Link to comment
Revised Entries since you're removing the Registry First Aid (Backups) entry.
[Registry First Aid 10*]
LangSecRef=3024
Detect=HKCU\Software\KsL Software\RFA\10.0
Detect1=HKCU\Software\KsL Software\RFA\10.1
Default=False
FileKey1=%ProgramFiles%\RFA 10|*.diz;*.url
FileKey2=%LocalAppData%\VirtualStore\Program Files*\RFA 10|*.diz;*.url
FileKey3=%UserProfile%\|NTUSER.tmp;UsrClass.tmp
FileKey4=%LocalAppData%\Microsoft\Windows|NTUSER.tmp;UsrClass.tmp
FileKey5=%WinDir%\ServiceProfiles\LocalService|*.tmp;*.tmp.LOG1;*.tmp.LOG2
FileKey6=%WinDir%\ServiceProfiles\NetworkService|*.tmp;*.tmp.LOG1;*.tmp.LOG2
FileKey7=%WinDir%\System32\config|*.tmp;*.tmp.LOG1;*.tmp.LOG2
FileKey8=%WinDir%\System32\config\systemprofile|*.tmp;*.tmp.LOG1;*.tmp.LOG2
FileKey9=%WinDir%\SysWOW64\config\systemprofile|*.tmp;*.tmp.LOG1;*.tmp.LOG2
[Registry First Aid 9*]
LangSecRef=3024
Detect=HKCU\Software\KsL Software\RFA\9.0
Default=False
FileKey1=%ProgramFiles%\RFA 9|*.diz;*.url
FileKey2=%LocalAppData%\VirtualStore\Program Files*\RFA 9|*.diz;*.url
Link to comment
Please add the following for Devolutions Remote Desktop Manager:
[Devolutions Remote Desktop Manager*]
LangSecRef=3021
DetectFile=%AppData%\Devolutions\RemoteDesktopManager
Default=True
FileKey1=%AppData%\Devolutions\RemoteDesktopManager|*.log
FileKey2=%AppData%\Devolutions\RemoteDesktopManager|*.log.db
FileKey3=%LocalAppData%\Devolutions\RemoteDesktopManager|*.log
FileKey4=%LocalAppData%\Devolutions\RemoteDesktopManager|*.log.db
Thanks!
Link to comment
  • Moderators
Default needs to be changed to false on the above entry
Link to comment
Acebytes
Ace Utilities
Perfect Registry
RegClean Pro
RegCleaner 4.3
Registry Mechanic
System Mechanic
SystemTuneUp
I really don't see any need to remove all of these cleaning modules just because they clean specific backup files.  Most of these modules have been in Winapp2.ini for years and users are use to having them do their work.  If a user specifically complains about module, then the complaint can be addressed.  JMO :unsure:
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC and Dell XPS 16 9640 Laptop.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more.
Link to comment
Revised Entries
Changed the Detect
HKLM\Software\Microsoft\Windows\CurrentVersion\App Paths\FSCapture.exe
HKLM\Software\Microsoft\Windows\CurrentVersion\App Paths\FSViewer.exe
[FastStone Capture More*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\FastStone Capture
Default=False
FileKey1=%AppData%\FastStone\FSC|*.bak
RegKey1=HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId
RegKey2=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastClipPlayed
RegKey3=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastRecordingFileName
[FastStone Image Viewer More*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\FastStone Image Viewer
Default=False
FileKey1=%AppData%\FastStone\FSIV|FSViewer.db
Link to comment
http://forum.piriform.com/index.php?showtopic=32310&p=264484
I agree with JDPower.
Link to comment
Revised Entry
Added Detect1 because there is a newer version 10.1 and current Detect was not working.
LangSecRef=3024
Default=False
Please check the post listed below. I have added Detect1 into the [Registry First Aid 10*] entry.
http://forum.piriform.com/index.php?showtopic=32310&p=264573
Link to comment
Revised Entry
LangSecRef=3024
Default=False
Should be Detect1 and Detect2 ;)
Link to comment
Avafind - delete search cache
deleting the marked files can also repair the cache :)
Avafind is mainly used for searching MP3 Tracks on the Device
[AvaFind - Search Cache*]
LangSecRef=3023
Detect=HKLM\Software\Think Less Do More Services\AVA Find
Default=False
FileKey1=%AppData%\AvaFind Data|*00.db
Link to comment
You might think of this as a coincidence, but this happened to me recently. I installed Windows 10 and I ran one of the most known registry cleaners out there. It deleted some of the essential files that belong to the Windows Store. Unintentionally, I ran CCleaner and the backup was gone. It was not possible to fix the Store so I had to reinstall the OS all over again. Now, I strongly believe that we should not have any registry cleaner entries in Winapp2.ini.
Link to comment
[service Control Manager Logs*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\system32\LogFiles\Scm\|SCM.EVM*|RECURSE
The entry listed above is useless. It should be removed or replaced with the one listed below. Previously, one user here, siliconman01, had some issues with the one listed below. Almost all of the known privacy eraser programs include it the way that is listed below. I never had any issue with this entry on Windows 7, Windows 8.1 and now on Windows 10.
LangSecRef=3025
Default=False
FileKey1=%WinDir%\System32\LogFiles\Scm|*.*|RECURSE
Link to comment
Here is a universal entry that I use for Windows 10 Metro Apps and it works fine.
[Metro Apps *]
DetectOS=10.0
Section=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData
Default=False
FileKey1=%LocalAppData%\Packages\*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\*\AC\INetCache|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\*\AC\Microsoft\CLR_v4.0|*.log
FileKey5=%LocalAppData%\Packages\*\AC\Microsoft\CLR_v4.0\NativeImages\Temp|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\*\AC\Microsoft\CLR_v4.0_32|*.log
FileKey8=%LocalAppData%\Packages\*\AC\Microsoft\CLR_v4.0_32\NativeImages\Temp|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\*\AC\Microsoft\CLR_v4.0_32\UsageLogs|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey11=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey12=%LocalAppData%\Packages\*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey13=%LocalAppData%\Packages\*\AC\PRICache|*.*|RECURSE
FileKey14=%LocalAppData%\Packages\*\AC\Temp|*.*|RECURSE
FileKey15=%LocalAppData%\Packages\*\LocalCache|*.*|RECURSE
Link to comment
Warning: If you have a lot of accounts in the new Mail app on Win10. [internet Explorer 10/11*] removes the saved password of the accounts. You will get a Fix Account notification.
Not sure exactly which Key is causing it at the moment
[Internet Explorer 10/11*]
LangSecRef=3022
DetectFile=%LocalAppData%\Microsoft\Windows\WebCache
Default=False
FileKey1=%LocalAppData%\Microsoft\SmartScreen|*.tmp
FileKey2=%LocalAppData%\Microsoft\Vault\*|*.vcrd
FileKey3=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE
FileKey4=%LocalAppData%\Microsoft\Windows\IECompatCache|*.*|RECURSE
FileKey5=%LocalAppData%\Microsoft\Windows\IECompatUACache|*.*|RECURSE
FileKey6=%LocalAppData%\Microsoft\Windows\INetCache|*.*|RECURSE
FileKey7=%LocalAppData%\Microsoft\Windows\WebCache|*.*|RECURSE
FileKey8=%LocalAppData%\Microsoft\Windows\WebCache.old|*.*|REMOVESELF
FileKey9=%LocalLowAppData%\Microsoft\Windows\AppCache|*.*|RECURSE
FileKey10=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache|*.*|RECURSE
RegKey1=HKCU\Software\Microsoft\Internet Explorer\TypedURLSTime
Link to comment
LangSecRef=3025
Default=False
LangSecRef=3025
Default=False
Doesn't mean others haven't also had an issue with it and haven't reported it, or haven't realised the cause. Unless siliconman can clarify the issue I'm not sure it should be changed (yet)
Link to comment
LangSecRef=3022
Default=False
I think it's FileKey2=%LocalAppData%\Microsoft\Vault\*|*.vcrd
Link to comment
Register a new account
Sign in
Important Information
