dolphinzero Posted February 21, 2013 Share Posted February 21, 2013 The auto positioning of the curser in the "Verification Window", (OK/Cancel) after clicking "Run Cleaner" was removed in later version of CCleaner. Please put it back or at least make it an option. Link to comment Share on other sites More sharing options...
dolphinzero Posted April 2, 2013 Author Share Posted April 2, 2013 The "Auto positioning" stopped working after version 3.9.0.1493 Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted April 3, 2013 Moderators Share Posted April 3, 2013 http://forum.piriform.com/index.php?showtopic=38047entry232576 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 4, 2013 Moderators Share Posted April 4, 2013 I think hazel meant to do this but thread closed as member already has a thread on this. Auto cursor is not a feature of softwares it is a feature of windows. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
