dolphinzero Posted February 21, 2013 Share Posted February 21, 2013 After upgrading to CCleaner 3.24 when selecting "run cleaner" the mouse pointer no longer automatically positions its self in the "Verification Window". I personally miss this feature from my original version, which removes the additional step of physically moving the mouse and pointer to the "OK" in the verification window. I normally run the cleaner twice to clear the main window which still contains the cleaned data. Is there a registry setting that will restore this feature? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted February 22, 2013 Moderators Share Posted February 22, 2013 (edited) how is this different from your other post? Also I believe that's a windows setting not a program-by-program setting. also ccleaner .24 is 3 months old latest version is .27 please update and try again Edited February 22, 2013 by Nergal ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
dolphinzero Posted April 2, 2013 Author Share Posted April 2, 2013 Sorry about the double entry...I'm now at Version 4 using Win7 and the curser still remains on the "Run Cleaner Button" after clicking. I have a dual boot, (two hard drives), system; XP and Win7. I keep the older version ,(3.9.0.1493), on the Win XP system which seems to discover the same clean items as ver 4 and is much quicker. The only place in Windows where this could be is the registry or, during the rewrite and re-compile the prior bit to move the curser was not set. I can't complain since I'm using the "free" version, but have considered the upgrade if this small item is restored. Link to comment Share on other sites More sharing options...
Moderators mta Posted April 2, 2013 Moderators Share Posted April 2, 2013 There is something n Control Panel, Mouse, that says something like "snap cursor to default button" which I believe is what you are after. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
