LikeASomebodyy 0 Posted May 5, 2012 Share Posted May 5, 2012 This is on the latest version 1.16, I turn on Speccy and have my computer hang. I can move my mouse but cant click on anything. I checked my task manager and Speccy was using 3gb of my 4gb ram. The only way to turn it off was to use Task Manager. I'm using Windows 7 Ultimate. Link to post Share on other sites
Winapp2.ini 0 Posted May 5, 2012 Share Posted May 5, 2012 on my win7 pro x64, speccy consumes 18,752K with a 40,076K commit. So, I am unable to reproduce this. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
kroozer 0 Posted May 5, 2012 Share Posted May 5, 2012 Nor any snags for me either. Speccy1.16 now using 25.3 MB on my Win7Home64, 18.9 MB on VistaBasic32. Try uninstalling, then a fresh install from hippo. Link to post Share on other sites
Moderators Nergal 0 Posted May 5, 2012 Moderators Share Posted May 5, 2012 please, if kroozer's suggestion does not work, run speccy in debug mode and post the log here ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
LikeASomebodyy 0 Posted May 6, 2012 Author Share Posted May 6, 2012 It is now working correctly after I used the download file from filehippo. Link to post Share on other sites
LikeASomebodyy 0 Posted May 6, 2012 Author Share Posted May 6, 2012 EDIT: Speccy is still not working normally. I'll be posting on this one now since my problem is closely related to the OP here:http://forum.pirifor...showtopic=35681 Link to post Share on other sites
