Tom AZ Posted September 9, 2009 Share Posted September 9, 2009 From time to time, I've noticed that my Volume Shadow Copy doesn't always activate when it should for a couple backup programs I use. After a reboot or two, it seems to "come alive" again, but that routine gets a little annoying. Any suggestions? Could there possibly be some settings that might need changing? Link to comment Share on other sites More sharing options...
aqua Posted September 9, 2009 Share Posted September 9, 2009 i think that's related to services...maybe yours is off..start-run-services.msc but look here first and read about http://www.overclockersclub.com/guides/win..._services/2.htm Link to comment Share on other sites More sharing options...
metalj Posted September 9, 2009 Share Posted September 9, 2009 Go to Start > run and type services.msc Make sure that the Remote Procedure Call (RPC) service is set to automatic and started. Now make sure that the Volume Shadow Copy service is set to manual and stoped (if it's running don't stop it, restart instead). Hope that helps. Piriform Software User Guides Link to comment Share on other sites More sharing options...
Tom AZ Posted September 10, 2009 Author Share Posted September 10, 2009 Go to Start > run and type services.msc Make sure that the Remote Procedure Call (RPC) service is set to automatic and started. Now make sure that the Volume Shadow Copy service is set to manual and stoped (if it's running don't stop it, restart instead). Exactly the way I have it set. For some reason, sometimes it just acts like it's not real stable. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 10, 2009 Moderators Share Posted September 10, 2009 Exactly the way I have it set. For some reason, sometimes it just acts like it's not real stable. Indeed, which is why I don't use any backup software that relies upon it to function since I don't know what mood VSC will be in. I use a batch file for backups and 7-Zip instead and haven't had any issues doing that for three years. Link to comment Share on other sites More sharing options...
Tom AZ Posted September 10, 2009 Author Share Posted September 10, 2009 Indeed, which is why I don't use any backup software that relies upon it to function since I don't know what mood VSC will be in. I use a batch file for backups and 7-Zip instead and haven't had any issues doing that for three years. So, Andaravi, can I interpret your statement as this is not particularly unusual behavior for VSC? Thought maybe it was just something on my end. It doesn't happen all the time -- it's sporadic. Your backup suggestion is a good one, but I use (and like a lot) Macrium Reflect, which uses VSC -- and also another program that backs up to an online server -- it also uses VSC. Seems like VSC is the "Service" of choice for these backup utilities. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted September 10, 2009 Moderators Share Posted September 10, 2009 Tom I use this service for my backups with FD-ISR (original one) and it has never caused me any bother in the last 3 years. It is set to automatic in services. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Tom AZ Posted September 10, 2009 Author Share Posted September 10, 2009 Tom I use this service for my backups with FD-ISR (original one) and it has never caused me any bother in the last 3 years. It is set to automatic in services. I currently have it set to Manual, which I believe is the default setting. However, I have also tried Automatic. Interestingly, it seems to respond about the same either way -- not much difference. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted September 10, 2009 Moderators Share Posted September 10, 2009 When it fails Tom, what error does it give in the event viewer? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Tom AZ Posted September 10, 2009 Author Share Posted September 10, 2009 I don't really know. I'll have to check that. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 10, 2009 Moderators Share Posted September 10, 2009 So, Andaravi, can I interpret your statement as this is not particularly unusual behavior for VSC? Thought maybe it was just something on my end. It doesn't happen all the time -- it's sporadic. It's sporadic, however that's enough for me not to trust it, and it's been like that from day one back when I had XP Pro SP1 all the way to SP3. If I wanted to backup the whole hard disk which I don't, I'd be very tempted to use a boot CD like BartPE, etc., for the whole copying process. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 11, 2009 Moderators Share Posted September 11, 2009 Funny how VSC was brought up in this topic. I looked through my event logs and noticed numerous VSC errors from a backup program I tried last month, that unfortunately never worked because VSC was producing some error. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted September 11, 2009 Moderators Share Posted September 11, 2009 The shortcomings of VSC detailed here, shows the importance of using "Verify" at every stage of making a backup with Macrium or any other Disk Imaging program. Verifying can be disabled as a time saver when making and restoring an Image, but doing that could be the worst shortcut you could ever take, and result in the disaster of a failed "Restore". Link to comment Share on other sites More sharing options...
