abu aufa Posted June 13, 2009 Author Share Posted June 13, 2009 I found something that might tell you if you have a copy of your XP cd files on your pc. Go to this registry key: (regedit.exe) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup Take a look at the SourcePath data column. Chances are that the key might be pointing to the cdrom drive. But if it is still somewhere around we can work with it. yes ,there is sourcePath REG_SZ I:\ what should I do ? Link to comment Share on other sites More sharing options...
metalj Posted June 13, 2009 Share Posted June 13, 2009 Which drive is I:\ ? What's in it? If you got nothing there then there's nothing we can do. Anyways, have you tried chkdsk /F ? Fixes weird stuff sometimes. Piriform Software User Guides Link to comment Share on other sites More sharing options...
abu aufa Posted June 13, 2009 Author Share Posted June 13, 2009 Which drive is I:\ ?What's in it? If you got nothing there then there's nothing we can do. Anyways, have you tried chkdsk /F ? Fixes weird stuff sometimes. I: is USB flash drive cannot run chkdsk ! Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted June 13, 2009 Moderators Share Posted June 13, 2009 Have you tried one of these ? http://www.askvg.com/download-free-bootabl...ure-and-others/ Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 13, 2009 Moderators Share Posted June 13, 2009 cannot run chkdsk ! You can if you use that BartPE Boot disc I've mentioned. Using the BartPE Boot disc also allows the usage of programs already on your computer such as chkdsk, etc. Link to comment Share on other sites More sharing options...
metalj Posted June 13, 2009 Share Posted June 13, 2009 I got another idea: Does the msconfig command works? If it does, (in the general tab) try using the "Normal Startup" and the "Diagnostic Startup". I hope it works. Piriform Software User Guides Link to comment Share on other sites More sharing options...
abu aufa Posted June 15, 2009 Author Share Posted June 15, 2009 I gave up ,complicated procedure and decided to reinstall and roll back SP2 Thank for your all advices posted to this thread. Sorry if I made this thread too long. thanks again Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted June 15, 2009 Moderators Share Posted June 15, 2009 Sorry to hear that you had to give in, although I know you tried very, very hard. When you get all set up again it may be time for you to look at ways of having image backups etc. Let us know that everything goes ok. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
abu aufa Posted June 15, 2009 Author Share Posted June 15, 2009 Sorry to hear that you had to give in, although I know you tried very, very hard. When you get all set up again it may be time for you to look at ways of having image backups etc. Let us know that everything goes ok. So far all programs running fine. already backup with ERUNT Link to comment Share on other sites More sharing options...
