CCleaner Community Forums
CCleaner Firefox Cleaning Integrity Questioned
This topic has gone from bringing up an issue with CCleaner, to saying Mastertech doesn't advertise enough, to saying Mastertech lies about who he is. As much as I love reading this topic and laughing, this flaming needs to stop.
As for discussion on the actual issue at hand, Mastertech is right in saying if the same version of the OS, IE, and CCleaner are used, every computer will have the same problem. Although if some other program interferes, things may change.
I did a quick test and Mastertech is right, using XP SP2, IE 6.0.2900.2180, and Firefox 1.0.6, the issue is only reproducible in Firefox. An easier way to fix it instead of closing Firefox and re-running CCleaner is to just hold down SHIFT while reloading the page. This will force Firefox to download everything from the server rather than using the cache. It would be nice to have CCleaner tell the user to close Firefox before cleaning so it won't happen.
And although I probably shouldn't say it, your guide Mastertech does have some things that I'd recommend changing.
Do you have a hunger for tweaking? Have a sudden urge of the tweaking munchies and need to take care of it? Check out The Whistling Cricket Tweaking Restaurant.
Link to post
Can I assume you mean sites, oh master? I have seen the sights and they are something,see you later.............know the song? Let's live in peace. We all are prone to err.
If it isn't broke, tweak it.
Link to post
  • 4 weeks later...
Is this issue being addressed? A new version is released and still no resolution for this. Other "cleaning" programs will let you know your web browser is running. I see Firefox is still enabled by default and selecting it gives no warning.
Link to post
No but I can confirm it happens with v1.0.6.
1.0.6 is just a security and stability upgrade of 1.0, 1.5 (now being tested as Deerpark) is a major revision of the browser, including significant changes in how graphics are handled. I don't know if this will involve changing the caching system, though.
Since the release of 1.5 is scheduled to take place in a couple months, any revision to CCleaner intended to change the way it interacts with Firefox should be designed for that version.
Link to post
Register a new account
Sign in
